03-07-2010, 03:53 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: places I repair phones
Member: 621698 Status: Offline Thanks Meter: 405 | Furious Gold Team, need help on b8100 wrong code Searching for usb device ... Reading info ... IMEI: 354580016926324 Calculating ... MEP: MEP-04104-007 MEP2 CODE: 6189392224867069 <<<< I use this! MEP3 CODE: 9502480388038747 MEP4 CODE: 8321708770355876 MEP5 CODE: 3140921865352879 MEP6 CODE: 3580218756901200 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:42vq Last edited by mymiela0419; 03-07-2010 at 03:59. |
03-07-2010, 07:11 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | Code: MEP3 CODE: 9502480388038747 MEP4 CODE: 8321708770355876 MEP5 CODE: 3140921865352879 |
The Following 2 Users Say Thank You to nadirghazi For This Useful Post: |
03-07-2010, 08:25 | #4 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: INDIA Age: 43
Member: 75612 Status: Offline Thanks Meter: 1,427 | Quote:
MEP: MEP-04104-007 MEP2(Network): 6189392224867069 MEP3(Network Subset): 9502480388038747 MEP4(Service Provider): 8321708770355876 MEP5(Corporate): 3140921865352879 CODES ARE 100% OK CHECK YOUR IMEI | |
The Following User Says Thank You to rajan nishchal For This Useful Post: |
03-07-2010, 10:05 | #6 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Well after seeing bad advice about slow method. You have to disable fast code read and select unlock. Then download the SFI file for your blackberry. Check the ABOUT menu on your BB to check firmware and application inside blackberry. It's very important to have the same versions. Can't mismatch or phone will go to "sleep" Then select unlock function and press do jobs. You will need to select the SFI file in a middle step... |
The Following User Says Thank You to FTEAM_MODERATOR For This Useful Post: |
Furious-Gold team pleas help me "problem in QCOM SMART TOOL Module v1.0.0.1206 | firstmaas | FuriousGold | 4 | 02-23-2009 19:25 |
team need help on ks360 | rirou | FuriousGold | 0 | 01-26-2009 23:34 |
Furious Gold Erros Need Help Urgent | master10 | FuriousGold | 1 | 10-25-2007 17:49 |
To UFO team need help on repair X60 | bcnboy | UfoTools | 4 | 12-09-2004 20:50 |
