Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 09-08-2015, 15:09   #12631 (permalink)
Master-Key's Avatar
Member: 2390703
Thanks Meter: 185
Direct Unlock Vtelca V791
unlock Vtelca V791 (Caribe 3)
Old 09-09-2015, 15:12   #12632 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
Alcatel 2050G SPD phone direct Unlock done... other box failed...
Searching phone;
For an successful connection do the following:
1. Remove battery and usb cable
2. Insert the usb cable in the phone
3. Keep pressed the boot key and insert the battery
Phone detected (SCI USB2Serial)
Preparing to sync;
Port opened [COM10];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT
Chip type: 6531 FdlStat: 0000
Starting auth;
HW IMEI : 862644-02-005756-0
Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000
Reading phone info;
PHONE INFO: 2050G-3DSFFR1
BT ADDR: 0C:82:C4:02:2D:E4
SW IMEI[0]: 352273-01-738634-0
SW IMEI[1]: 352751-01-952326-7
SW IMEI[2]: 358570-01-010389-3
SW IMEI[3]: 910575-60-140046-8
SIMLOCK FLAG: ON
FIXED NV BASE: 303A8000
Reading NV;
NV saved to : NV_862644-02-005756-0_352273-01-738634-0_65310000_8_09_2015_16_51_34.spd
IMEI: 862644-02-005756-0 UNLOCK CODE: 61232114
Re-programming;
NV programmed;
Done;
Phone unlocked;
Remove battery and cable;
Log file saved to: LOG_8_09_2015_16_52_02.txt
Time needed - 00:00:42
Old 09-09-2015, 19:00   #12633 (permalink)
Member: 1196714
Thanks Meter: 238
Thumbs up SM-N900A Android Version: 5.0 Finished successfully.
Chimera Mobile Phone Utility version: 7.61.1649 @ 2015-09-08
[Unlock phone started]
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-N900A
Sales Code: ATT
PDA Version: N900AUCUEOC1 [march 2015, rev1]
Phone Version: N900AUCUEOC1 [march 2015, rev1]
CSC Version: N900AATTEOC1 [march 2015, rev1]
Product Code: SM-N900AXXXATT
HIDSw Version: N900AUCUEOC1/N900AATTEOC1/N900AUCUEOC1/N900AUCUEOC1
Board Platform: MSM8974
Serial Number: R31D90QKAQH
Imei: 357572050XXXXXX
Unique Number: CMB002B89B47990
Connections: AT,MTP
Battery Status: 4.24V (90%)
SIM Status: ABSENT
Knox Version: v30
Warranty Bit: 0
Checking root state...
Not rooted.
There is no backup, because there is no root access.
Unlocking...
Trying on SAMSUNG Mobile USB Serial Port (COM9)
Unlocked.
Finished at local time: [09.08.15 18:22:23]
WorkID: XXXXXXX
Old 09-09-2015, 19:01   #12634 (permalink)
Member: 1196714
Thanks Meter: 238
Thumbs up Blackberry Q10 SQN 100-1 Successfully unlocked.
Chimera Mobile Phone Utility version: 7.69.1527 @ 2015-09-09
[Direct unlock started.]
Phone is in loader mode
Updating software.
Retrieving necessary files
Files have been already downloaded!
Extracting: qcfm.image.com.qnx.qcfm.radio.qc8960.wtr.BB10_3_0. 1419.783508.signed
Initializing phone mode
Device recognized
Flashing file
Parsing file
Start flashing
Flashing has been finished
Reconnected
Flashing file
Parsing file
Start flashing
Waiting for the phone connection.
Please un-plug the cable, put in the battery, turn it on, re-plug the cable, wait for Chimera logo on your phone
Phone found.
Initializing usb connection.
Testing usb connection.
Usb successfully initialized.
Waiting for the usb answer.
Starting unlock ...
Could not automatically restart the phone.
Please, restart the phone or put out the battery and re-plug the cable.
Device recognized
Flashing file
Parsing file
Start flashing
Reconnected
Flashing file
Parsing file
Start flashing
Finished at local time: [09.09.15 09:56:27]
WorkID: XXXXXXX
Old 09-09-2015, 19:08   #12635 (permalink)
Member: 1196714
Thanks Meter: 238
Thumbs up SGH-I896 Android Version: 2.3.3 Finished successfully.
Model: SGH-I896
Sales Code: ATT
PDA Version: I896UXKH2 [august 2011, rev2]
Phone Version: I896UXKH2 [august 2011, rev2]
Product Code: SGH-I896ZKARWC
HIDSw Version: I896UXKH2//I896UXKH2/I896UXKH2
Board Platform: S5PC110
Serial Number: 00000000000
Imei: 354182040XXXXXX
Connections: DEBUG
Battery Status: 4.10V (81%)
Network Type: GSM
SIM Status: ABSENT
Rooting by generic root method 2...
Rooting in progress. Be patient! Do NOT disconnect the phone!
Root method failed.
Rooting by generic root method...
Rooted.
Unlocking...
Checking secure image.
Storing secure image.
Preparing secure block.
Preparing image: #0.
Preparing image: #1.
Preparing image: #2.
Success.
Finished at local time: [09.09.15 11:07:06]
WorkID: XXXXXXX
Old 09-09-2015, 20:26   #12636 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 266
meo a68 unlock done:
cheers
Old 09-10-2015, 00:27   #12637 (permalink)
Member: 642071
Thanks Meter: 54
Huawei model: Y220-u05
Using library Brom_DLL_v7.1413.5
Connecting; Be sure you unlock the phone screen;
BRAND: HUAWEI MODEL: Y220-U05
ANDROID: v2.3.6
CPU: MT6572
IMEI: 86*************
Trying to get root access;
Done;
Reading simlock data;
Done;
Locked to [SIM1]: 714-04
code_cat_n: 82390605 enabled: yes tries: 0
code_cat_ns: 56781234 enabled: no tries: 5
code_cat_sp: 11112222 enabled: no tries: 5
code_cat_c: 33334444 enabled: no tries: 5
code_cat_sim: 55556666 enabled: no tries: 5
code_cat_ns_sp: 77778888 enabled: no tries: 5
code_cat_sim_c: 99990000 enabled: no tries: 5
Cleaning;
Calculating;
Reconnecting;
Done;
Unlocking;
Done;
Phone unlocked; Remove battery and cable;
Time needed - 00:03:37
Old 09-10-2015, 12:33   #12638 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
Alcatel OT-918 Direct Unlock done...
Searching phone;
Phone detected (PreLoader USB VCOM Port)
Preparing to start meta mode;
Searching for debug port; (be sure drivers from support were installed)
Debug Port found on FTEAM USB Serial Port (COM65);
Preparing to connect meta mode;
Meta mode entered;
Baseband Chip: MT6573, E00
Sw version: MAUI.11AMD.W11.37.SP.V27.P35
Hw Version: JRD73_GIN_MODEM_GEMINI2_HW
Reading phone info;
IMEI: 860767-00-282453-3
Reading simlock info;
Locked to: 613-02
code_cat_n: 36847893 enabled: yes tries: 3
code_cat_ns: 27658968 enabled: no tries: 10
code_cat_sp: 27201234 enabled: no tries: 10
code_cat_c: 27132762 enabled: no tries: 10
code_cat_sim: 35105285 enabled: no tries: 10
code_cat_ns_sp: 53297761 enabled: no tries: 5
code_cat_sim_c: 86817778 enabled: no tries: 5
Time needed - 00:01:12
Log file saved to: LOG_10_09_2015_11_17_15.txt
Old 09-10-2015, 15:05   #12639 (permalink)
ibrajinja's Avatar
Member: 562975
Sonork: better tomorow
Thanks Meter: 247
ZTE Z740 unlocked
Connecting;
Check your phone and "Always allow from this computer" and select "OK".
Connected;
BRAND: ZTE
MODEL: Z740
ANDROID: v4.1.2
CPU: QCOM
IMEI: 861897010126396
KERNEL: Linux version 3.4.0-svn9819 (xueyibing@zte) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Sep 10 14:43:48 CST 2013
Cleaning;
Loading files;
Done;
Reconnecting;
Setting access;
Initing kernel config;
Done;
Remapping;
Done;
Checking tz cfg;
Checking modem;
Done;
Enabling i/o;
Done;
Exploiting;
Done;
Patching;
Done;
Enabling access;
Done;
Reading;
Done;
Reading simlock;
Done;
Backup saved to: 861897010126396_34B131B30769F8D03CC5248B7987F3C4
Checking simlock;
Unlocking;
Writing simlock;
Done;
Checking simlock status;
Done;
SIM_LOCK REMOVED !
RESTARTING !
The Following User Says Thank You to ibrajinja For This Useful Post:
Old 09-12-2015, 10:05   #12640 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 523
etisalat 211fm unlock done
Keep pressing the power button if serial used !
(for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable)
Connecting;
Meta mode entered;
Baseband Chip: MT6223, E05
Sw version: AE-UAE-ET-P109A2FMV1.0.0B04
Hw Version: 07A ZTENJ23_07A_PMJ
Reading phone info;
IMEI: 358614-02-014391-9
Unlock codes:
Locked to: 424-02
code_cat_n: 860378060288 enabled: yes tries: 5
code_cat_sp: 1122FFFF enabled: no tries: 5
code_cat_c: 3344FFFF enabled: no tries: 5
code_cat_sim: 5566FFFF enabled: no tries: 5
code_cat_ns_sp: 7788FFFF enabled: no tries: 5
code_cat_sim_c: 9900FFFF enabled: no tries: 5
Time needed - 00:00:26
Log file saved to: LOG_12_09_2015_14_02_23.txt
Old 09-12-2015, 18:05   #12641 (permalink)
Member: 1196714
Thanks Meter: 238
Thumbs up GT-I9305 Android Version: 4.3 Finished successfully.
Chimera Mobile Phone Utility version: 7.70.1439 @ 2015-09-12
Model: GT-I9305
Sales Code: EVR
PDA Version: I9305XXUENH1 [august 2014, rev1]
Phone Version: I9305XXUENG1 [july 2014, rev1]
CSC Version: I9305EVRENH1 [august 2014, rev1]
Product Code: GT-I9305TADEVR
HIDSw Version: I9305XXUENH1/I9305EVRENH1/I9305XXUENG1/I9305XXUENH1
Board Platform: EXYNOS4
Serial Number: R31CA1H43DB
Imei: 353575054XXXXXX
Unique Number: CMAF14B0E48C47F
Connections: AT,MTP
Battery Status: 4.16V (91%)
Network Type: GSM
SIM Status: READY
Warranty Bit: 0
Not rooted.
Unlocking...
Trying on SAMSUNG Mobile USB Serial Port (COM15)
Unlocked.
Finished at local time: [09.12.15 11:23:11]
WorkID: XXXXXXX
Old 09-12-2015, 20:14   #12642 (permalink)
Member: 1196714
Thanks Meter: 238
Thumbs up SM-G900T Android Version: 4.4.2 Finished successfully.
Model: SM-G900T
Sales Code: TMB
PDA Version: G900TUVU1BNH5 [august 2014, rev5]
Phone Version: G900TUVU1BNH5 [august 2014, rev5]
CSC Version: G900TTMB1BNH5 [august 2014, rev5]
Product Code: XXXXXXXXXXXTMB
HIDSw Version: G900TUVU1BNH5/G900TTMB1BNH5/G900TUVU1BNH5/G900TUVU1BNH5
Serial Number: RV8F40X0TTR
Imei: 351881062XXXXXX
Unique Number: CMA00D522D26731
Connections: AT,MTP
Battery Status: 3.99V (62%)
Network Type: GSM
SIM Status: ABSENT
Knox Version: v30
Warranty Bit: 1
Not rooted.
Unlocking...
Trying on SAMSUNG Mobile USB Serial Port (COM29)
Unlocked.
Finished at local time: [09.12.15 14:11:49]
WorkID: XXXXXXX
Old 09-13-2015, 02:41   #12643 (permalink)
Member: 1196714
Thanks Meter: 238
Thumbs up SM-J100H Android Version: 4.4.4 Finished successfully.
Model: SM-J100H
Sales Code: XME
PDA Version: J100HXXU0AOH1 [august 2015, rev1]
Phone Version: J100HDXU0AOH1 [august 2015, rev1]
CSC Version: J100HOLB0AOH1 [august 2015, rev1]
Product Code: SM-J100HZKDINS
HIDSw Version: J100HXXU0AOH1/J100HOLB0AOH1/J100HDXU0AOH1/J100HXXU0AOH1
Board Platform: SC8830
Serial Number: RZ1G71V72TY
Imei: 352313071XXXXXX
Unique Number: C0145B350DB62
Connections: AT,MTP
Battery Status: 4.29V (90%)
Network Type: GSM
SIM Status: NETWORK_LOCKED
SIM2 Status: ABSENT
Knox Version: v00
Processing...
Reading image #1
Storing image #1
Preparing image: #1
Writing image #1
Reading image #2
Storing image #2
Preparing image: #2
Writing image #2
Reading image #3
Storing image #3
Preparing image: #3
Writing image #3
Reading image #4
Storing image #4
Preparing image: #4
Writing image #4
Unlocked.
Finished at local time: [09.12.15 20:36:12]
WorkID: XXXXXXX
Old 09-13-2015, 18:03   #12644 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,265
Zte s501 (warid) unlock
ZTE S501 (WARID) UNLOCKED SUCCESSFULLY.
Old 09-14-2015, 06:55   #12645 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Huawei Y530 successfully unlocked
Connecting;
Connected;
BRAND: HUAWEI
MODEL: HUAWEI Y530-U00
ANDROID: v4.3
CPU: QCOM
IMEI: 8649210277xxxxx
KERNEL: Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Aug 11 18:52:35 IST 2014
Cleaning;
Loading files;
Done;
Reconnecting;
Setting access;
Done;
Exploiting;
Android v4.3 TRUE
Backing up sec area;
Done;
Getting sec size;
00165832 bytes
Decompressing;
Backup saved to: 8649210277xxxxx
Finished;
BT ADDR: 3C:47:11:C8:C9:63
MAC ADDR: 3C:47:11:C8:C1:6A
BOOTLOADER PASS: 1619622710421212
MCC-MNC: 226-10 [orange/ro]
LOCK [0] HASH: DEDA95CF6F990865A461A6A28AC4E982
LOCK [1] HASH: 05BC7148669669B5B792B12B28CFF4A2
LOCK [2] HASH: 9C1BEBC16FCCA72380EC926052C00015
LOCK [3] HASH: E9DA11DABD5014809922DF78C7B70FB9
LOCK [4] HASH: E9DA11DABD5014809922DF78C7B70FB9
LOCK [5] HASH: D7E7805904E4C16AF25116D94238B70A
LOCK [6] HASH: D97E541A5DC214E3559C0BB61CB22B40
LOCK [7] HASH: E9DA11DABD5014809922DF78C7B70FB9
LOCK [8] HASH: E9DA11DABD5014809922DF78C7B70FB9
LOCK [9] HASH: E9DA11DABD5014809922DF78C7B70FB9
Starting;
Done;
Unlocking in progress;
Calc 0000 ;
Calc 0001 ;
SIM_LOCK REMOVED !
Rebooting;
Log file saved to: LOG_14_09_2015_08_50_24.txt
Time needed - 00:00:55
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.39748 seconds with 10 queries
