03-15-2016, 16:03 | #13038 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | kyocera c6530n unlock done Software engine version: 1.0.0.9836 Searching phone ... MODEL : QCOM SERIES 42 COMPILED DATE : Nov 26 2014 03:53:00 RELEASE DATE : Mar 21 2014 18:00:00 FIRMWARE INFO : MPSS.TR.2.0-00715-M8610BAAAANAZM-1 IMEI : 01401600716 BLUETOOTH ADDR : 8A F3 2A 60 76 6C DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Log file saved to: LOG_15_03_2016_16_01_26.txt Time needed - 00:00:40 |
03-16-2016, 16:06 | #13040 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | vodafone v575 unlocked done Code: Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6255, E03 Sw version: MAUI.11B.W12.24.MP.V2.F11 Hw Version: JRDHZ55_W1224_11B_COSMOS_HW Reading phone info; IMEI: 869115-01-0xxxxx-x Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:23 |
03-16-2016, 18:35 | #13041 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | zte s519 unlock done fast and easy Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem105.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM587]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6530 FdlStat: C000 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 866409-02-214703-3 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303B0000 Reading NV; NV saved to : NV_000000-00-000000-0_866409-02-214703-3_6530C000_16_03_2016_18_33_25.spd IMEI: 866409-02-214703-3 UNLOCK CODE: NONE Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_16_03_2016_18_33_53.txt Time needed - 00:00:39 |
03-16-2016, 21:29 | #13042 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | zte z730 unlock done Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: ZTE MODEL: Z730 ANDROID: v4.3 CPU: QCOM IMEI: 866061020428228 KERNEL: Linux version 3.4.0+ (xueyibing@zte2) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Fri Mar 28 14:59:01 CST 2014 Cleaning; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM745)] Backing up sensitive data; Done; Backup saved to: 866061020428228.NV Done; Done; Restarting the phone; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM745)] Restoring sensitive data; Done; SIM_LOCK REMOVED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE THE UNLOCK ! Log file saved to: LOG_16_03_2016_21_25_10.txt Time needed - 00:05:49 |
03-17-2016, 12:54 | #13043 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OT-5042T Direct Unlock done.. Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (USB Modem Driver (COM97)) Preparing to start flash mode; Preparing to open COM97 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: b431b61c4b53ced688132d90b56afc58 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port (COM98)) TRYING TO OPEN COM98; DEVICE INFO: BB CHIP: MT6752_S01 [CA01, 01, 6752, 05] HW_STORAGE_EMMC: 0x51000115 0x41535837 0x1A3E0142 0xBB32C1C0 [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 014247-00-112021-2 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5042T-2BTBUS1-R USRDATA INFO: 0x6C000000 SIZE: 0x66880000 Searching data; Done; Phone unlocked; Wait until the phone starts and shows charging screen; Time needed - 00:00:17 Log file saved to: LOG_17_03_2016_11_48_17.txt |
03-17-2016, 22:51 | #13044 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | zte z740g unlock done Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: ZTE MODEL: Z740G ANDROID: v4.1.2 CPU: QCOM IMEI: 864997021134392 KERNEL: Linux version 3.4.0-svn12591 (panyuanqing@zte) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Oct 23 12:46:57 CST 2015 Cleaning; Loading files; Done; Reconnecting; Setting access; Initing kernel config; Done; Remapping; Done; Checking tz cfg; Checking modem; Done; Enabling i/o; Done; Exploiting; Done; Patching; Done; Enabling access; Done; Reading; Done; Reading simlock; Done; Backup saved to: 864997021134392_3C59B085872FA3EFB475F7E8A0198D10 Checking simlock; Unlocking; Writing simlock; Done; Checking simlock status; Done; SIM_LOCK REMOVED ! RESTARTING ! DONE ! Log file saved to: LOG_17_03_2016_22_46_36.txt Time needed - 00:01:52 |
03-18-2016, 22:14 | #13045 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 6032 Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM (Android) (COM167)) Preparing to start flash mode; Preparing to open COM167 Connecting; Downloading DA; Initializing; Rid: 66c0da4d1b94014cc4c6cc1e23f6b85b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem160.inf,%vcom_preloader%;PreLoader USB VCOM (Android)) TRYING TO OPEN COM255; DEVICE INFO: BB CHIP: MT6589_S00 [CA00, 00, 6583, FF] HW_STORAGE_EMMC: 0x4B000115 0x30305533 0x403B124D 0x61B00380 [SIZE=0x3A4220000] IMEI1 [OTP 0001]: 862329-02-079083-8 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 6032X-2BRGDO1 USRDATA INFO: 0x67880000 SIZE: 0x3C9A0000 Searching data; Locked to [SIM1]: 370-01 code_cat_n: 21847591 enabled: yes tries: 10 code_cat_ns: 42491963 enabled: no tries: 10 code_cat_sp: 42231649 enabled: no tries: 10 code_cat_c: 41629052 enabled: no tries: 10 code_cat_sim: 22926955 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:00:40 Log file saved to: LOG_18_03_2016_22_07_18.txt |
03-22-2016, 17:26 | #13047 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Amazon Fire Direct Unlock done.. Software engine version: 1.0.0.9842 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jan 27 2015 10:11:00 RELEASE DATE : Jan 8 2015 00:00:00 FIRMWARE INFO : PB_02_06_12 IMEI : 01418600038650-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Log file saved to: LOG_22_03_2016_14_51_53.txt Time needed - 00:01:00 |
03-23-2016, 11:52 | #13048 (permalink) |
Freak Poster Join Date: May 2008 Location: Bangladesh (Sezan point) Age: 43
Member: 772645 Status: Offline Sonork: 100.1591509 Thanks Meter: 176 | Digicel DL800 successfully Unlocked Digicel DL800 successfully Unlocked with furious gold. Use OTSmart tools v 1.0.0.933 Use Model: ZTE KIS III MAX Here is log, Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (PreLoader USB VCOM Port (COM33)) Preparing to start flash mode; Preparing to open COM33 Connecting; Downloading DA; Initializing; Rid: fc1876f908ca48102faa70f0ac95cab5 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port (COM34)) TRYING TO OPEN COM34; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x484A0190 0x64314734 0xA1020504 0xB781268C [SIZE=0xE9C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x4A940000 SIZE: 0x9F2C0000 Searching data; Locked to [SIM1]: 338-05 code_cat_n: 12345678 enabled: yes tries: 0 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:27 BR, Dreams_bd |
03-23-2016, 11:55 | #13049 (permalink) |
Member: 772645 Status: Offline Sonork: 100.1591509 Thanks Meter: 176 | Digicel DL800 Unlock with furious gold Digicel DL800 successfully Unlocked with furious gold. Use OTSmart tools v 1.0.0.933 Use Model: ZTE KIS III MAX Here is log, Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (PreLoader USB VCOM Port (COM33)) Preparing to start flash mode; Preparing to open COM33 Connecting; Downloading DA; Initializing; Rid: fc1876f908ca48102faa70f0ac95cab5 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port (COM34)) TRYING TO OPEN COM34; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x484A0190 0x64314734 0xA1020504 0xB781268C [SIZE=0xE9C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x4A940000 SIZE: 0x9F2C0000 Searching data; Locked to [SIM1]: 338-05 code_cat_n: 12345678 enabled: yes tries: 0 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:27 BR, Dreams_bd |
03-23-2016, 19:08 | #13050 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Samsung g900a 5.1.1 unlok done If phone ask to allow usb debuging please accept! Searching for phone; ok Reading info; ok Initialising data; ok Detecting port; ok Reading info; ok BRAND: SAMSUNG MODEL: SAMSUNG-SM-G900A KLTEATT KLTEUC IMEI: 3546910******** PLATFORM: AAAAANRZ: Sep 22 2015 20:51:56 Aug 27 2015 00:00:00 BUILD: MPSS.DI.2.0.1.c2-00185-M8974AAAAANRZM-1 HWID: QCOM-14 BOOT LOADER: G900AUCU4COI5 COUNTRY CODE: USA US SALES CODE: ATT VERSION: ANDROID 5.1.1 BUILD LMY47X G900AUCU4COI5 G900AUCU4COI5 G900AATT4COI5 (PDA/CSC) FIRMWARE: KLTEUC-USER G900AUCU4COI5 KERNEL: 3.4.0-5869384 (dpi@SWHD4323) (gcc 4.8 ) #1 SMP PREEMPT Tue Sep 22 21:22:27 KST 2015 FINGERPRINT: SAMSUNG_KLTEUC_KLTEATT_5.1.1_LMY47X_G900AUCU4COI5_ USER_RELEASE-KEYS PHONE SN: 921A2876_R38FA0QDJKJ CPU TYPE: MSM8974 ARMv7 RIL MODEM: MSM8974PRO RIL VERSION: SAMSUNG RIL V3.0 SIM STATUS: NETWORK_LOCKED Reading data; error - NEW SECURITY! Bypassing new security; error - NEWEST SECURITY! Bypassing newest security; ok Writing data; ok Restarting phone; ok IF PHONE NOT RESTART DO NOT REMOVE BATTERY, PLEASE RESTART PHONE MANUALLY FROM MENU! End at 13:02:43 |
The Following User Says Thank You to Dwight07 For This Useful Post: |
