04-08-2016, 21:27 | #13081 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Software engine version: 1.0.0.9858 Searching phone ... MODEL : QCOM SERIES 42 COMPILED DATE : Jun 23 2014 02:25:00 RELEASE DATE : Mar 21 2014 18:00:00 FIRMWARE INFO : MPSS.TR.2.0-00715-M8610BAAAANAZM-1 IMEI : 01401600400692-0 BLUETOOTH ADDR : AD E7 5C C8 21 C4 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Log file saved to: LOG_8_04_2016_16_26_04.txt Time needed - 00:00:30 |
The Following User Says Thank You to maxpatri9 For This Useful Post: |
04-13-2016, 17:09 | #13082 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Vodafone Smart Prime 6 V895N Direct Unlock done... Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM235 Connecting; Init; Port opened; Phone detected (@oem145.inf,%qcomdevice90080%;ALCATEL HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM157 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 35690706588XXX-6 PTH: 13 PTS: W7E PROV_ID: V895N-2HVDGB2 SBTADDR: 8C:99:E6:E2:31:91 SWIFIADDR: 8C:99:E6:E2:31:92 HS_PN: SAA6197AAC0C SSN: 3PKC34CB7NY016B Work id: 110E3C94 Setup 1; Done; Setup 2; Done; Setup 3; Done; Uploading; Done; SECURITY: X9W7FCE0BG00 Size: 00000430 Backup saved to: 35690706588XXX-6 Backup file(s) removed; Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_13_04_2016_15_59_29.txt Time needed - 00:01:13 |
The Following 3 Users Say Thank You to razib143 For This Useful Post: |
04-15-2016, 17:36 | #13084 (permalink) |
No Life Poster Join Date: Oct 2007 Location: places I repair phones
Member: 621698 Status: Offline Thanks Meter: 405 | hack, thank you for your help! I really appreciated waiting for me. All 3pcs. Alcatel 5042T unlocked successfully by FGbox! Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM89)) Preparing to start flash mode; Preparing to open COM89 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 2ce79463be26e09a8ddb53b92a073551 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem141.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM90; DEVICE INFO: BB CHIP: MT6752_S01 [CA01, 01, 6752, 05] HW_STORAGE_EMMC: 0x51000115 0x41535837 0xC8380142 0xDF2293F2 [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 014247-00-14XXXX-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5042T-2BTBUS1 USRDATA INFO: 0x6C000000 SIZE: 0x66880000 Searching data; Done; Phone unlocked; Wait until the phone starts and shows charging screen; Time needed - 00:00:13 Log file saved to: LOG_15_04_2016_09_33_55.txt |
The Following User Says Thank You to mymiela0419 For This Useful Post: |
04-15-2016, 23:11 | #13085 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 3022g unlock done Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem105.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM587]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0017 - SIZE : 00800000 Reading phone info; PHONE INFO: 3022G-3ARGDO1 BT ADDR: 94:AF:4A:598:94 SW IMEI[0]: 014227-00-215622-5 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 30640000 Reading NV; NV saved to : NV_000000-00-000000-0_014227-00-215622-5_65310001_15_04_2016_17_47_50.spd Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_15_04_2016_18_04_30.txt Time needed - 00:16:55 |
04-16-2016, 13:02 | #13086 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OT-5042T Direct unlock done.. Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM241)) Preparing to start flash mode; Preparing to open COM241 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 21ab9af6c744b218dc749dff682dff67 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem175.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM243; DEVICE INFO: BB CHIP: MT6752_S01 [CA01, 01, 6752, 05] HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0xF747124B 0xA172D017 [SIZE=0xE9B00000] IMEI1 [OTP 0001]: 014247-00-38XXXX-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5042T-2BTBUS1-R USRDATA INFO: 0x6C000000 SIZE: 0x66880000 Searching data; Done; Phone unlocked; Wait until the phone starts and shows charging screen; Time needed - 00:00:18 Log file saved to: LOG_16_04_2016_11_51_19.txt |
04-18-2016, 12:53 | #13087 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Orange tado unlocked done Code: Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM211); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V36.P18 Hw Version: ZTENJ72_WE_72_KK_HSPA_HW Reading phone info; IMEI: 865846-02-52xxxx-x Reading simlock info; Locked to: 226-10 code_cat_n: 12345678 enabled: yes tries: 0 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:01:11 |
04-18-2016, 14:36 | #13088 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | SFR 112 Direct Unlock done.. Software engine version: 1.0.0.6551 Connect phone powered on ! Start auth ! SW Ver: EFSPI-FR-SFR-P108E10FM(S)V1.0.0B08 Imei: 353894032520503 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0103 Reading ... Saved: ZTE_353894032520503_EFSPI-FR-SFR-P108E10FM(S)V1.0.0B08_13.34.02_18.04.2016_PARTIAL. bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:38 |
04-21-2016, 05:24 | #13089 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Jamaica
Member: 1714782 Status: Offline Thanks Meter: 5 | Alcatel 4037n unlock Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM12)) Preparing to start flash mode; Preparing to open COM12 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: a857effff221e8ee7c5ddb616010387f Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem83.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM14; DEVICE INFO: BB CHIP: MT6582_S01 [CA01, 01, 6582, 05] HW_STORAGE_EMMC: 0x4E000115 0x4D5A5835 0xB4720142 0xBD81CCDC [SIZE=0xE9880000] IMEI1 [OTP 0001]: 014067-00-264441-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4037N-2BE4US1 USRDATA INFO: 0x6D080000 SIZE: 0x7C800000 Searching data; Locked to [SIM1]: 310-26 code_cat_n: 2355702534 enabled: no tries: 3 code_cat_ns: 2509144440 enabled: no tries: 10 code_cat_sp: 1662883340 enabled: yes tries: 2 code_cat_c: 2433946464 enabled: no tries: 10 code_cat_sim: 0101815235 enabled: no tries: 10 code_cat_ns_sp: 2245874600 enabled: no tries: 5 code_cat_sim_c: 1720421921 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:10 Log file saved to: LOG_20_04_2016_23_11_01.txt |
04-21-2016, 11:40 | #13090 (permalink) |
Registered User Join Date: May 2006 Location: ROMANIA - BISTRITA Age: 44
Member: 279656 Status: Offline Sonork: 1684319 Thanks Meter: 7 | Lg x150 flash/repair done . Lg x150 flash/repair done : Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM23)) Preparing to start flash mode; Preparing to open COM23 Connecting; Downloading DA; Initializing; Rid: bd277ae5c7759f681e2643566d7ac553 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem10.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM24; DEVICE INFO: BB CHIP: MT6582_S01 [CA01, 01, 6582, 05] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x82560042 0x35925DD2 [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 9=8?87-00-9>9004-4 PROVIDER: N/A USRDATA INFO: 0xC1F00000 SIZE: 0x10980000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:08:06 Phone is alive now ! Many thanks to .:hack3r2k:. for this super happy ending story ! |
04-21-2016, 13:50 | #13091 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Algeria
Member: 158242 Status: Offline Sonork: 100.1591384 Thanks Meter: 194 | lg x150 revived lg x150 alive with new version and new flash file thanks furious team Code: Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM113)) Preparing to start flash mode; Preparing to open COM113 Connecting; Downloading DA; Initializing; Rid: d748802b847dd22082b04da42b7671db Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem136.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM49; DEVICE INFO: BB CHIP: MT6582_S01 [CA01, 01, 6582, 05] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x01550042 0xA79270D2 [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 9=8?87-00-9>9004-4 PROVIDER: N/A USRDATA INFO: 0xC1F00000 SIZE: 0x10980000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:05:58 |
The Following User Says Thank You to djlicks For This Useful Post: |
04-21-2016, 16:03 | #13092 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | Code: Model: HUAWEIKIW-L21 IMEI: xxxxxxxx Firmware ver.: MSM8939C900B130_AMSS Jan 14 201621:18:37 SN: EJBDU16126016936 Custom SN: DU3LWT161H038095 WiFi MAC: 1C:67:58:20:41:6A BlueTooth MAC: 1C:67:58:20:51:0B Vendor: channel Country: tr KII-L21C464B130_BOOT MSM8939C900B130_AMSS Jan 14 201621:18:37 KIW-L21_C00B007_EFS_RFNV_B04 HL3KIWMAD KII-L21C464B130_APPSBOOT KII-L21C464B130_KERNEL KII-L21C464B130_SYSTEM KII-L21C464B130_RECOVERY MSM8939 HUAWEI KIW-L21 C464 D002 IMEI 1 Sim Lock status: NET: unlocked NETSUB: unlocked SP: unlocked 2016-04-21 17:37:18.645 Autodetect started! 2016-04-21 17:37:20.287 Found COM port: COM109 2016-04-21 17:37:20.295 Open port COM109 (DBAdapter Reserved Interface (COM109))... 2016-04-21 17:37:20.406 Connecting to server... 2016-04-21 17:37:21.375 Connected! 2016-04-21 17:37:21.377 Read data from server... 2016-04-21 17:37:22.850 Read data from server success! 2016-04-21 17:37:23.995 Repairing start New IMEI 1 : xxxxxxx 2016-04-21 17:37:23.998 Phone authorize start 2016-04-21 17:37:24.003 Phone authorize success! 2016-04-21 17:37:24.008 Read secure info... 2016-04-21 17:37:24.041 Read basic info... 2016-04-21 17:37:24.057 Repair security data start! 2016-04-21 17:37:24.058 Phone identify start 2016-04-21 17:37:24.620 Phone identify success! 2016-04-21 17:37:24.627 Calculating secure data... 2016-04-21 17:37:27.230 Calculate success! 2016-04-21 17:37:27.235 Writing secure data... 2016-04-21 17:37:27.445 Writing secure data success! 2016-04-21 17:37:27.640 Repair security data success! 2016-04-21 17:37:27.678 Finished! |
04-21-2016, 17:08 | #13093 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | zte z222 unlock done x 2 Software engine version: 1.0.0.9858 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Mar 28 2014 08:52:00 RELEASE DATE : Dec 30 2011 06:00:00 FIRMWARE INFO : ATT_AM_P671B41V1.0.0B13-S IMEI : 86609902676392-5 BLUETOOTH ADDR : CB 48 3F D7 37 D4 FON; INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 7ECC4C173C288BBEB584F2FD1D0D1B21.bin ERASING; WRITING; READING; AFTER BACKUP: 17E1F6C2C2933818FC0D400C8E8123DA.bin UNLOCKED; FOFF; RESET ! Log file saved to: LOG_21_04_2016_12_02_03.txt Time needed - 00:00:28 Software engine version: 1.0.0.9858 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Mar 28 2014 08:52:00 RELEASE DATE : Dec 30 2011 06:00:00 FIRMWARE INFO : ATT_AM_P671B41V1.0.0B13-S IMEI : 86794002422828-9 BLUETOOTH ADDR : 42 2E B7 D7 37 D4 FON; INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 7ECC4C173C288BBEB584F2FD1D0D1B21.bin ERASING; WRITING; READING; AFTER BACKUP: 17E1F6C2C2933818FC0D400C8E8123DA.bin UNLOCKED; FOFF; RESET ! Log file saved to: LOG_21_04_2016_12_07_58.txt Time needed - 00:00:28 |
04-21-2016, 21:30 | #13094 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Samsung sm-g386w direct unlock FG Samsung Module v1.0.4.3 ~ SAMSUNG SM-G386W ~ ~ DIRECT UNLOCK ~ Start at 15:20:14 If phone ask to allow usb debuging please accept! Searching for phone; ok Reading info; ok Initialising data; ok Detecting port; ok Reading info; ok BRAND: SAMSUNG MODEL: SM-G386W AFYONLTECAN AFYONLTEVL IMEI: 3546960******** PLATFORM: DAAAANAZ: Oct 13 2014 14:19:38 Sep 22 2014 04:00:00 BUILD: MPSS.DI.2.0.c8-00083-M8926DAAAANAZM-1 HWID: QCOM-6 BOOT LOADER: G386WVLU1ANJ1 COUNTRY CODE: CANADA CA SALES CODE: VMC VERSION: ANDROID 4.4.2 BUILD KOT49H G386WVLU1ANJ1 G386WVLU1ANJ1 G386WOYA1ANJ1 (PDA/CSC) FIRMWARE: AFYONLTEVL-USER G386WVLU1ANJ1 KERNEL: 3.4.0-2988301 (dpi@SWDD3018) (gcc 4.7 ) #1 SMP PREEMPT Mon Oct 13 20:47:47 KST 2014 FINGERPRINT: SAMSUNG_AFYONLTEVL_AFYONLTECAN_4.4.2_KOT49H_G386WV LU1ANJ1_USER_RELEASE-KEYS PHONE SN: E271033A_R28F904C7ZK CPU TYPE: MSM8226 ARMv7 RIL MODEM: MSM8926 RIL VERSION: SAMSUNG RIL V3.0 SIM STATUS: ABSENT Reading data; error - NEW SECURITY! Bypassing new security; ok Writing data; ok Restarting phone; ok IF PHONE NOT RESTART DO NOT REMOVE BATTERY, PLEASE RESTART PHONE MANUALLY FROM MENU! End at 15:23:05 |
04-22-2016, 09:02 | #13095 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania/Piatra Neamt
Member: 880649 Status: Offline Thanks Meter: 73 | Vodafone 890N done Connecting; Check your phone and “Always allow from this computer” and select ‘OK’. BRAND: VODAFONE MODEL: VODAFONE 890N ANDROID: v4.4.4 CPU: QCOM IMEI: NA Trying to get root access; Done; Setting usb config; Config done; Install the drivers if needed; Software engine version: 1.0.0.9842 Searching phone ... MODEL : QCOM SERIES 43 COMPILED DATE : Sep 24 2014 10:53:00 RELEASE DATE : Sep 16 2014 04:00:00 FIRMWARE INFO : GWL_T3_01_10350101_02 IMEI : 35660206542XXX-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 3FDCE55080B7DF0B37BD0C7A381D639F.bin UNLOCK CODE: N/A DONE; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_22_04_2016_10_34_55.txt Time needed - 00:00:21 |
