07-03-2017, 18:28 | #13801 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem84.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM63 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01460800369601-4 PTH: 13 PTS: A4U PROV_ID: 5056A-2GRGDO1-1 SBTADDR: 4C:4E:03:8B:53:33 SWIFIADDR: 4C:4E:03:CA:8A:69 HS_PN: SAA1F51WA10C SSN: L3KC09CO1HA001K Work id: 08A0ABED Done; Stype: 00000001 SECURITY: XHA0NJ04BR10 Size: 000002B1 Backup saved to: 01460800369601-4 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_3_07_2017_13_26_08.txt Time needed - 00:00:46 |
07-03-2017, 21:49 | #13802 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ZTE Z221 UNLOCK DONE Software engine version: 1.0.0.10517 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Aug 8 2011 19:45:00 RELEASE DATE : Apr 19 2011 08:00:00 FIRMWARE INFO : ATT_AM_P671B40V1.0.0B09-S IMEI : 86380601866880-2 BLUETOOTH ADDR : 47 A5 DA 81 E0 8C INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 0D0A2225DBA14CB738A8889040C1E0E9.bin ERASING; WRITING; READING; AFTER BACKUP: F463B9ABAEE7EA22D755811B2614650B.bin UNLOCKED; RESET ! Log file saved to: LOG_3_07_2017_16_47_46.txt Time needed - 00:00:07 |
07-04-2017, 08:25 | #13803 (permalink) |
No Life Poster Join Date: Oct 2004 Location: gsmworld Age: 43
Member: 85537 Status: Offline Thanks Meter: 66 | lenovo beeline pro 6 frp done i removed frp beeline pro 6 ,in software i choice lenovo vibe . Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM9)) Preparing to start flash mode; Preparing to open COM9 Connecting; Downloading DA; Initializing; Rid: 005de7b37eaefbe4a2d7b9fad8e2711b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem297.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM11; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x46000115 0x4D32584E 0xC0640142 0x71141ED4 [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x99000000 SIZE: 0x39880000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 thanks furious team. |
The Following 2 Users Say Thank You to mishiko_gsm For This Useful Post: |
07-04-2017, 15:04 | #13804 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL TRU 5065N FRP DONE Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem408.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM122 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01470500018345-7 PTH: 02 PTS: N5Q PROV_ID: 5065N-2CE4US1 SBTADDR: 20:A9:0EB:63:C0 SWIFIADDR: 20:A9:0E7:E1:3D HS_PN: SAA34NBAA10C SSN: 98KJ09CQ7KZ04L9 Work id: 02379981 Done; Stype: 00000001 SECURITY: X8C0LS01BR20 Size: 000002A5 Backup saved to: 01470500018345-7 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; FRPEx Done; Log file saved to: LOG_4_07_2017_10_01_05.txt Time needed - 00:01:08 |
07-04-2017, 15:55 | #13805 (permalink) | |
Freak Poster Join Date: Dec 2008 Location: cali-colombia Age: 29
Member: 914317 Status: Offline Sonork: 100.1601159 Thanks Meter: 66 | 5056n unlocked done!! Quote:
07-05-2017, 19:03 | #13806 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 2001A UNLOCK DONE Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM936)) Preparing to start meta mode; Requesting authorization; Done; Meta mode entered; Baseband Chip: MT6250 Sw version: MAUI.11B.W12.24.MP.V2.F42 Hw Version: JRDHZ50_12864_11B_24MP_HW Reading phone info; IMEI: 013765-00-160355-7 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:27 Log file saved to: LOG_5_07_2017_13_56_02.txt |
07-05-2017, 21:18 | #13807 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 4060O FRP UNLOCK DONE Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem84.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM63 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01467100105588-0 PTH: 06 PTS: A45 PROV_ID: 4060O-2ARKUS3 SBTADDR: 28:BE:03:293:F8 SWIFIADDR: 28:BE:03:2D:F5:B3 HS_PN: SAA1GN0WA10C SSN: 96KB06CIQKZ04VL Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 06D4C3BD Done; Stype: 00000001 SECURITY: X8C0LS01BR20 Size: 000002A5 Backup saved to: 01467100105588-0 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_5_07_2017_16_10_07.txt Time needed - 00:25:18 |
07-05-2017, 22:05 | #13808 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 6045O UNLOCK DONE Software engine version: 1.0.0.10516 Searching phone ... MODEL : QCOM SERIES 46 COMPILED DATE : Oct 28 2015 16:23:00 RELEASE DATE : Aug 31 2015 03:00:00 FIRMWARE INFO : MPSS.DPM.2.0.2.c1.6-00022-M8936FAAAANUZM-1.26298.1.28320.1 IMEI : 01449700227612-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 69D9571DD0145322E30500E3219E7287.bin UNLOCK CODE: N/A DONE; DOING EXTRA CALCULATION; AFTER UNLOCK YOU MUST RESTART THE PHONE MANUALLY; RESET ! Log file saved to: LOG_5_07_2017_17_04_12.txt Time needed - 00:00:50 |
07-06-2017, 00:44 | #13809 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Y625 unlock done Software engine version: 1.0.0.10485 Searching phone ... MODEL : QCOM SERIES 42 COMPILED DATE : May 14 2015 09:22:00 RELEASE DATE : Mar 4 2015 22:00:00 FIRMWARE INFO : 8x10_PL190335_20141120 IMEI : 86634?********* BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; FIRMWARE: Y625-U13V100R001C54B100 SN: T6ZBBBB562502059 IMEI: 86634002300501-3 REQUESTING AUTH; CALCULATING; AUTH DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Log file saved to: LOG_5_07_2017_18_27_40.txt Time needed - 00:00:27 |
07-06-2017, 14:25 | #13810 (permalink) |
Freak Poster Join Date: Feb 2015 Location: guyane francaise
Member: 2351647 Status: Offline Thanks Meter: 37 | Unlock Alcatel 9001D frp with furiousgold Unlock Alcatel 9001D frp with furiousgold .:hack3r2k:. thanks bro Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;Périphérique USB composite) Preparing to enter download mode; Preparing to open COM53 Connecting; Init; Port opened; Phone detected (@oem146.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM15 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 358344071264***** PTH: 09 PTS: D25 PROV_ID: 9001D-2AALWE1 SBTADDR: CC:FD:172:92:85 SWIFIADDR: CC:FD:17:E4:E2:14 HS_PN: SAA1FA2AA10C SSN: A4KE15COLEA00B7 Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 060B978C Done; Stype: 00000001 SECURITY: XMD0L502BR00 Size: 000002A5 Backup saved to: 358344071264**** Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; Erase Done; Erase Done; FRPEx Done; Log file saved to: LOG_6_07_2017_09_57_05.txt Time needed - 00:27:31 |
07-08-2017, 15:09 | #13813 (permalink) |
Freak Poster Join Date: Oct 2016 Location: United Republic of Tanzania
Member: 2639338 Status: Offline Thanks Meter: 133 | Samsung gt e1205y sim lock removed Here is a full Log of operation Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem18.inf,%dc_diag%;SPRD U2S Diag) Preparing to sync; Port opened [COM48]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6530 FdlStat: C000 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0017 - SIZE : 00800000 Reading phone info; PHONE INFO: GT-E1205ZKYKEN PHONE SN: R21F61Y8N9 MSL PASS: 4839063F3D435D2E54184C512E295332 BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: FURIOUSTHEBESTTEAM SW IMEI[1]: FURIOUSTHEBESTTEAM SW IMEI[2]: FURIOUSTHEBESTTEAM SW IMEI[3]: FURIOUSTHEBESTTEAM SIMLOCK FLAG: ON FIXED NV BASE: 30750000 Reading NV; NV saved to : NV_000000-00-000000-0_FURIOUSTHEBESTTEAM_6530C000_1_01_2002_00_29_09.s pd Calculating ... Freeze code: 37920317 NET lock: 68695851 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; |
07-08-2017, 16:37 | #13814 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 5065N UNLOCK DONE Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem84.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM63 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01470500032342-6 PTH: 03 PTS: N5Q PROV_ID: 5065N-2CE4US1 SBTADDR: 20:A9:0E:E1:64:90 SWIFIADDR: 20:A9:0E:E3:12:40 HS_PN: SAA34NBAA10C SSN: 98KJ09CQCKZ00S3 Work id: 0237AED8 Done; Stype: 00000001 SECURITY: X2N0UP00CL10 Size: 000002C3 Backup saved to: 01470500032342-6 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_7_07_2017_23_32_50.txt Time needed - 00:00:54 |
07-09-2017, 12:27 | #13815 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Sri Lanka@cellularsolutions
Member: 230004 Status: Offline Thanks Meter: 174 | Searching phone... (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM Port) Preparing to start MTK debug mode; Searching for debug port... (be sure drivers from support were installed!) MTK debug mode entered Baseband Chip: MT6735M,S01 Sw version: Hw Version: ALPS.L1.MP3.V2.95_OT6735M.35GU.L1_P91 Baseband Chip: MT6735, E00 Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V48.P8 Hw Version: OT6735_65C_LU_L1_HW Reading info... IMEI 1: 869821021307268 IMEI 2: N/A Open port success! 2017-07-09 16:44:55.622 Reading data from server... 2017-07-09 16:44:56.325 Reading data from server success! Reading simlock info; Gathering info; SIM UNLOCK CODE: 07156117 Simlock read end; yes good job FG |
