11-21-2017, 14:39 | #14071 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | Zte f320 network unlock done by furious gold For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem88.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM17]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Chip type: 7702 FdlStat: 0000 Starting auth; Memory NAND [CS0]: 00C8:00B1 - SIZE : 08000000 EFUSE HASH: 0000000000000000000000000000000000000000 HW IMEI : 000000-00-000000-0 Reading phone info; PHONE INFO: VDF_UK_QB18S_P701A24 BT ADDR: 4D:37:7B:F1:16:4C SW IMEI[0]: 867063-02-075062-6 SW IMEI[1]: 000000-00-000000-0 SW IMEI[2]: 000000-00-000000-0 SW IMEI[3]: 000000-00-000000-0 SIMLOCK FLAG: ON FIXED NV BASE: 40040000 Reading NV; NV saved to : NV_000000-00-000000-0_867063-02-075062-6_77020000_21_11_2017_15_30_56.spd IMEI: 867063-02-075062-6 UNLOCK CODE: 65160330 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_21_11_2017_15_31_32.txt Time needed - 00:00:45 |
The Following User Says Thank You to bright hlatini For This Useful Post: |
11-21-2017, 15:49 | #14072 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | kyocera c6530n unlock done Software engine version: 1.0.0.10603 Searching phone ... MODEL : QCOM SERIES 42 COMPILED DATE : Nov 26 2014 03:53:00 RELEASE DATE : Mar 21 2014 18:00:00 FIRMWARE INFO : MPSS.TR.2.0-00715-M8610BAAAANAZM-1 IMEI : 01401600721236-8 BLUETOOTH ADDR : BB 04 2B 60 76 6C DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Log file saved to: LOG_21_11_2017_10_45_54.txt Time needed - 00:00:50 |
11-21-2017, 19:43 | #14073 (permalink) |
Freak Poster Join Date: Aug 2017
Member: 2751525 Status: Offline Thanks Meter: 28 | y6 2 2017 Using library Brom_DLL_v7.1712.1 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM10)) Preparing to start flash mode; Preparing to open COM10 Connecting; Downloading DA; Initializing; Rid: c5936a33bb46127901e9591a3b5e17d4 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6737T [CA00, 00, 321, FF] HW_STORAGE_EMMC: 0x484A0190 0x61344741 0x854ED432 0x87748869 [SIZE=0x3AC000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 554250-59-56875=-1 PROVIDER: N/A USRDATA INFO: 0x102000000 SIZE: 0x2A8380000 Searching data; Locked to [SIM1]: FFF-FF code_cat_n: 12345678 enabled: no tries: 255 code_cat_ns: 56781234 enabled: no tries: 255 code_cat_sp: 1122FFFF enabled: no tries: 255 code_cat_c: 3344FFFF enabled: no tries: 255 code_cat_sim: 5566FFFF enabled: no tries: 255 code_cat_ns_sp: 7788FFFF enabled: no tries: 255 code_cat_sim_c: 9900FFFF enabled: no tries: 255 Phone unlocked; Remove battery and cable; Time needed - 00:00:04 Log file saved to: LOG_21_11_2017_10_42_24.txt |
11-21-2017, 19:45 | #14074 (permalink) |
Member: 2751525 Status: Offline Thanks Meter: 28 | y6 2 2017 Using library Brom_DLL_v7.1712.1 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM10)) Preparing to start flash mode; Preparing to open COM10 Connecting; Downloading DA; Initializing; Rid: cfd3b1ab70f83e9398904c80c12a8453 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6737T [CA00, 00, 321, FF] HW_STORAGE_EMMC: 0x484A0190 0x61344741 0xDA20D432 0x7574216C [SIZE=0x3AC000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x102000000 SIZE: 0x2A8380000 Searching data; Locked to [SIM1]: FFF-FF code_cat_n: 12345678 enabled: no tries: 255 code_cat_ns: 56781234 enabled: no tries: 255 code_cat_sp: 1122FFFF enabled: no tries: 255 code_cat_c: 3344FFFF enabled: no tries: 255 code_cat_sim: 5566FFFF enabled: no tries: 255 code_cat_ns_sp: 7788FFFF enabled: no tries: 255 code_cat_sim_c: 9900FFFF enabled: no tries: 255 Phone unlocked; Remove battery and cable; Time needed - 00:00:04 Log file saved to: LOG_21_11_2017_10_45_05.txt |
11-22-2017, 16:43 | #14075 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | LG E610l unlock done Software engine version: 1.0.0.10600 Searching phone ... MODEL : E610 COMPILED DATE : Feb 11 2013 09:37:00 RELEASE DATE : Apr 19 2012 06:00:00 FIRMWARE INFO : LGE610vAT-00-V10g-VDF-XXX-FEB-11-2013+0 IMEI : 35358405306866-0 BLUETOOTH ADDR : DC 1A 11 8F 43 C4 ENTERING DOWNLOAD MODE; ENTERED; LOADING DATA; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT EMMC ROUTINES; EMMC INIT MADE; EMMC manufacturer id: 00000015, oem id: 00000000 EMMC name SJS00M, S/N: 1044599304, rev: 00000000 EMMC size: E9000000 Getting partition tables info Security found at 00022000 size 00002000 Reading; Initializing security; Checking security; MCC-MNC: 214-01 IMEI: 353584-05-306866-0 PID: HD54S130502004855 Calculating security; Writing; SIM_LOCK REMOVED ! RESET ! Sign DB updated ! Log file saved to: LOG_22_11_2017_20_24_59.txt Time needed - 00:02:12 |
The Following User Says Thank You to iftikhar_246 For This Useful Post: |
11-22-2017, 18:52 | #14076 (permalink) |
Freak Poster Join Date: Oct 2007 Location: valencia Age: 44
Member: 621737 Status: Offline Thanks Meter: 87 | neo3600 unlock Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Nov 21 2014 16:32:00 RELEASE DATE : Oct 25 2010 09:00:00 FIRMWARE INFO : LQBKI04.1.2_M034 IMEI : 3575 BLUETOOTH ADDR : A0 51 82 73 04 9C DONE; PHONE CODE: 0000 READING DATA; CALCULATING; UNLOCK CODE: 2893602275 TO COMPLETE THE UNLOCK ENTER *#8611# AND ENTER THE UNLOCK CODE ABOVE. |
11-22-2017, 19:37 | #14077 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Rep Dom Age: 38
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | Zte blade L110 unlock done Root the phone with kingo root Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: ZTE MODEL: ZTE BLADE L110 ANDROID: v5.1 CPU: SC8830 IMEI: NA KERNEL: Linux version 3.10.65-svn3409 (root@zte-128) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Mon May 1 10:52:55 CST 2017 Cleaning; Loading files; Done; Reconnecting; Getting memory info; Done; Gathering info; Done; Cleaning done; Setting permissions; Reading data; Getting data size; 00016567 bytes Decompressing; BT ADDR: 07:97:FE:6A:68:18 SW IMEI[0]: 862945-03-859069-4 SW IMEI[1]: 004401-78-377925-5 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON SIM network unlock PIN: 16919986 Unlock Procedure: 1. Enter an restricted SIM 2. Power on the phone and you will be requested to enter the unlock pin 3. Enter the code and the phone will be unlocked Code reading finished ! Log file saved to: LOG_22_11_2017_14_27_22.txt Time needed - 00:00:57 Last edited by boliargsm; 11-22-2017 at 19:46. |
11-24-2017, 11:57 | #14078 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Spain Age: 40
Member: 180702 Status: Offline Sonork: 1586150 Thanks Meter: 48 | ZTE Axon 7 Mini Remove and Unlock Done thanks to the big work of this team it is possible to unlock and remove frp from zte axon 7 mini log unlock Code: Software engine version: 1.0.0.10607 Searching phone ... MODEL : QCOM SERIES 50 COMPILED DATE : Mar 15 2017 13:18:00 RELEASE DATE : Nov 15 2016 22:00:00 FIRMWARE INFO : TA.2.1.c1-00101-8976_GEN_PACK IMEI : 86093503411523-4 BLUETOOTH ADDR : B3 B7 24 BC 73 60 FIRMWARE: P852A11V1.0.0B23 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: D:\Telefonia\Furious Gold\PACK5\86093503411523_24_11_2017_11_20_56.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM207 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22F8 Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM231)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Code: Software engine version: 1.0.0.10607 Searching phone ... MODEL : QCOM SERIES 50 COMPILED DATE : Mar 15 2017 13:18:00 RELEASE DATE : Nov 15 2016 22:00:00 FIRMWARE INFO : TA.2.1.c1-00101-8976_GEN_PACK IMEI : 86093503411523-4 BLUETOOTH ADDR : B3 B7 24 BC 73 60 FIRMWARE: P852A11V1.0.0B23 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: D:\Telefonia\Furious Gold\PACK5\86093503411523_24_11_2017_11_25_49.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM207 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22F8 start_frp_reset: OK; big team big work |
11-24-2017, 14:30 | #14079 (permalink) |
No Life Poster Join Date: Jan 2010 Location: iraq
Member: 1215266 Status: Offline Thanks Meter: 129 | Huawei p10 unlock done 2017-11-24 16:28:56.955 Autodetect started! 2017-11-24 16:28:59.537 Found COM port: COM170 2017-11-24 16:28:59.547 Open port COM170 (Android Adapter PCUI (COM170))... 2017-11-24 16:28:59.676 Connecting to server... 2017-11-24 16:29:00.526 Connected! 2017-11-24 16:29:00.536 Read data from server... 2017-11-24 16:29:02.065 Read data from server success! 2017-11-24 16:29:02.286 Phone authorize start 2017-11-24 16:29:05.882 Phone authorize success! 2017-11-24 16:29:05.892 Read secure info... 2017-11-24 16:29:14.753 Read secure info success! 2017-11-24 16:29:14.753 Read basic info... 2017-11-24 16:29:18.776 Read basic info success! 2017-11-24 16:29:18.786 Unlocking start 2017-11-24 16:29:18.796 Phone secure identify start 2017-11-24 16:29:22.869 Phone secure identify success! 2017-11-24 16:29:24.274 Unlock done! 2017-11-24 16:29:24.284 Job finished! |
11-24-2017, 14:34 | #14080 (permalink) |
Member: 1215266 Status: Offline Thanks Meter: 129 | Huawei p9 unlock done 2017-11-24 16:32:28.782 Autodetect started! 2017-11-24 16:32:31.364 Found COM port: COM176 2017-11-24 16:32:31.373 Open port COM176 (Android Adapter PCUI (COM176))... 2017-11-24 16:32:31.492 Connecting to server... 2017-11-24 16:32:32.175 Connected! 2017-11-24 16:32:32.175 Read data from server... 2017-11-24 16:32:33.704 Read data from server success! 2017-11-24 16:32:33.931 Phone authorize start 2017-11-24 16:32:36.332 Phone authorize success! 2017-11-24 16:32:36.332 Read secure info... 2017-11-24 16:32:45.278 Read secure info success! 2017-11-24 16:32:45.278 Read basic info... 2017-11-24 16:32:49.251 Read basic info success! 2017-11-24 16:32:49.251 Unlocking start 2017-11-24 16:32:49.251 Phone secure identify start 2017-11-24 16:32:51.708 Phone secure identify success! 2017-11-24 16:32:51.710 Reading data from server... 2017-11-24 16:32:52.103 Reading data from server success! 2017-11-24 16:32:52.886 Unlock done! 2017-11-24 16:32:52.891 Job finished! |
The Following 2 Users Say Thank You to tornado779 For This Useful Post: |
11-24-2017, 17:15 | #14081 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Coolpad 3622A unlock without T-mobiles permission Go away T-Mobile with those 100 USD unlock prices Black Friday unlocks are better Code: Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: COOLPAD MODEL: COOLPAD 3622A ANDROID: v5.1.1 CPU: QCOM IMEI: NA KERNEL: Linux version 3.10.49-g3523c12-00131-gfd2b782 (mine@ubuntu) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Mon Apr 11 12:44:54 CST 2016 Cleaning; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [Coolpad Android Diagnostics USB VCOM (COM149)] Backing up sensitive data; connect_server: OK; backup in progress: OK; Backup saved to: F:\FURIOUS\NOT ON DVD\PACK5\ADB\ Done; Done; Done; Restarting the phone; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [Coolpad Android Diagnostics USB VCOM (COM149)] Restoring sensitive data; connect_server: OK; restore in progress: OK; Done; SIM_LOCK REMOVED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE THE UNLOCK ! Log file saved to: LOG_24_11_2017_17_08_54.txt Time needed - 00:03:35 |
The Following 2 Users Say Thank You to byteforce2016 For This Useful Post: |
11-26-2017, 12:19 | #14082 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan
Member: 2138570 Status: Offline Sonork: 100.1611495 Thanks Meter: 301 | ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2017-11-26 16:14:17.781 Start read phone info! 2017-11-26 16:14:18.246 Detect phone done! Model: HUAWEI LUA-U22 Firmware ver.: LUA-U22C328B013 SN: G8M9XA1762423329 2017-11-26 16:14:22.199 Erase FRP start 2017-11-26 16:14:27.616 Reading phone info... 2017-11-26 16:14:28.082 Read phone info success! Model: HUAWEI LUA-U22 Firmware ver.: LUA-U22C328B013 SN: G8M9XA1762423329 2017-11-26 16:14:28.246 Reading Certify data... 2017-11-26 16:14:28.403 Signing certify data... 2017-11-26 16:14:28.970 Signing certify data success! 2017-11-26 16:14:28.972 Erasing FRP... 2017-11-26 16:14:32.811 Erase FRP done! |
11-27-2017, 11:59 | #14083 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Gsm World Age: 37
Member: 2070850 Status: Offline Thanks Meter: 9 | Wiko Jerry 2 Unlock Done MTK Reader Searching phone; Phone detected (@oem22.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Gadget CDC VCOM Driver (COM12); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6580, E01 Sw version: MOLY.WR8.W1449.MD.WG.MP.V91.5.P15 Hw Version: TINNO6580_WE_N_HSPA_HW Reading phone info; IMEI: 354040-09-0xxxxxx Reading simlock info; Locked to: 228-02 code_cat_n: 87654321 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Unlocking SIM2 too. Time needed - 00:00:59 Log file saved to: LOG_27_11_2017_11_31_10.txt |
11-27-2017, 20:25 | #14084 (permalink) |
Freak Poster Join Date: Dec 2015 Location: New Zeland
Member: 2506735 Status: Offline Sonork: IT ZONE Thanks Meter: 20 | ALCATEL 9008A (A3 XL) FRP done Using library Brom_DLL_v7.1712.1 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM19)) Preparing to start flash mode; Preparing to open COM19 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: b1fca0d1cd27dcca7c6be64f903a9789 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem129.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM20; DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x30000111 0x33473631 0x4E8E0030 0xBD242BAD [SIZE=0x3AC000000] IMEI1 [OTP 0001]: 357245-08-007006-3 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 9008T-2AVDAU1 USRDATA INFO: 0xC3000000 SIZE: 0x2E4880000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_28_11_2017_09_24_07.txt |
11-27-2017, 20:27 | #14085 (permalink) |
Member: 2506735 Status: Offline Sonork: IT ZONE Thanks Meter: 20 | ALCATEL 9008A (A3 XL) unlock DONE Using library Brom_DLL_v7.1712.1 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM19)) Preparing to start flash mode; Preparing to open COM19 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: b1fca0d1cd27dcca7c6be64f903a9789 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem129.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM20; DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x30000111 0x33473631 0x4E8E0030 0xBD242BAD [SIZE=0x3AC000000] IMEI1 [OTP 0001]: 357245-08-007006-3 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 9008T-2AVDAU1 USRDATA INFO: 0xC3000000 SIZE: 0x2E4880000 Searching data; Locked to [SIM1]: 505-03 code_cat_n: 98936188 enabled: yes tries: 99 code_cat_ns: 93915050 enabled: no tries: 10 code_cat_sp: 09576420 enabled: no tries: 10 code_cat_c: 90742099 enabled: no tries: 10 code_cat_sim: 56345416 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:18 Log file saved to: LOG_28_11_2017_09_27_38.txt |
