05-07-2018, 14:20 | #14581 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Online Sonork: celular center Thanks Meter: 573 | Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Oct 8 2016 13:02:00 RELEASE DATE : Aug 31 2016 03:00:00 FIRMWARE INFO : MPSS.JO.1.1.c1-00050-8909_GEN_PACK-1.68943.2 IMEI : 8610xxxxxxxxxx-1 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: DO_CLA_S_P809A50V1.0.0B06 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\cell center\Desktop\01-FURIUOS GOLD DONGLE\QCOM_SMART_TOOL_v1.0.0.10670\86103903157892 _7_05_2018_09_13_37.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM36 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD Looking for the interface; Port found [ZTE HS-USB Diagnostics Interface Driver (COM31)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_7_05_2018_09_16_34.txt Time needed - 00:03:00 |
05-07-2018, 16:46 | #14582 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | huawei cam-l03 frp done Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2018-05-07 11:39:40.503 Erase FRP start 2018-05-07 11:39:44.715 Reading phone info... 2018-05-07 11:39:45.589 Read phone info success! Model: CAM-L03 IMEI: 864823032379331 Firmware ver.: CAM-L03DOMC109B124 SN: NSXDU17317005481 2018-05-07 11:39:45.604 Reading Certify data... 2018-05-07 11:39:45.791 Reading Certify data success! 2018-05-07 11:39:45.791 Signing Certify data... 2018-05-07 11:39:50.489 Erase FRP done! |
05-08-2018, 16:10 | #14583 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 5099A UNLOCK DONE Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM44)) Preparing to start flash mode; Preparing to open COM44 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: b15919dc7dc827b6e529d59814aa8f13 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem107.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM42; DEVICE INFO: BB CHIP: MT6737T [CA00, 00, 321, 05] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0xD7550342 0x35941ACC [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 015106-00-003312-4 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5099A-2CRGDO1 USRDATA INFO: 0xEE000000 SIZE: 0x2B2280000 Searching data; Locked to [SIM1]: 370-01 code_cat_n: 4390147867519009 enabled: yes tries: 10 code_cat_ns: 4390147867519009 enabled: no tries: 0 code_cat_sp: 4390147867519009 enabled: no tries: 0 code_cat_c: 4390147867519009 enabled: no tries: 0 code_cat_sim: 4390147867519009 enabled: no tries: 0 Phone unlocked; Remove battery and cable; Time needed - 00:00:07 Log file saved to: LOG_8_05_2018_10_54_08.txt |
05-08-2018, 23:31 | #14584 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 4047g unlock done Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM40)) Preparing to start flash mode; Preparing to open COM40 Connecting; Downloading DA; Initializing; Rid: b6789f8715ce829c3c5f33cfde833c46 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x46000115 0x4D32364E 0x962B0342 0xBDC42EDE [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 014910-00-556547-2 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 4047G-2ARGDO1 USRDATA INFO: 0xCE800000 SIZE: 0xFFC80000 Searching data; Locked to [SIM1]: 370-01 code_cat_n: 35574126 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 35574126 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:05 Log file saved to: LOG_8_05_2018_18_29_06.txt |
05-09-2018, 12:56 | #14585 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Alcatel 5056N app lock based 50+ units DONE! Code: Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem94.inf,%qcomdevice90080%;ALCATEL HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM11 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 14.7 GB IMEI: 01465000703387-7 PTH: 08 PTS: B71 PROV_ID: 5056N-2ATBUS7 SBTADDR: 4C:4E:03:C3:C6:A6 SWIFIADDR: 4C:4E:03:B3:4C:07 HS_PN: SAA1F5BWA10C SSN: N6KB12BBKHA00G6 Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 0650A5BF Done; Stype: 00000001 SECURITY: XUB0UP01BR10 Size: 000002C3 Backup saved to: 01465000703387-7 Unlocking; SIM_LOCK REMOVED ! |
05-09-2018, 14:55 | #14586 (permalink) |
Member: 1537078 Status: Online Sonork: celular center Thanks Meter: 573 | Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM14)) Preparing to start flash mode; Preparing to open COM14 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 5bab6019ea2585b7b14ca3322f1c0ea0 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem64.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM37; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x88620742 0x958401F2 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-xxxxxx-2 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_9_05_2018_09_54_04.txt |
05-09-2018, 18:57 | #14587 (permalink) |
Freak Poster Join Date: Jan 2012 Location: amman jordan Age: 45
Member: 1713974 Status: Offline Thanks Meter: 34 | 5049w Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM42)) Preparing to start flash mode; Preparing to open COM42 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: d2914ab31a27205f83c1da74d9811bef Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem304.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM11; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xFB190742 0x8BA4EDAA [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-449822-1 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:05:23 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:05:26 Log file saved to: LOG_9_05_2018_19_40_00.txt |
05-10-2018, 12:18 | #14588 (permalink) | |
Freak Poster Join Date: May 2014 Location: baia mare romania Age: 40
Member: 2195859 Status: Offline Thanks Meter: 19 | zte blade A520 ...dead after flashing with other tools. spflashtool always memory error while flashing flashed with furious pack 6 and dump from support area. Phone alive and working Quote:
05-10-2018, 14:52 | #14589 (permalink) |
Member: 1537078 Status: Online Sonork: celular center Thanks Meter: 573 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;Dispositivo compuesto USB) Preparing to enter download mode; Preparing to open COM321 Connecting; Init; Port opened; Phone detected (@oem13.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM36 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 7,3 GB IMEI: 01480200305318-1 PTH: 08 PTS: M5R PROV_ID: 4060A-2AAQUS3-R1 SBTADDR: CC:FD:17:22:93D SWIFIADDR: CC:FD:17:07:C2:B7 HS_PN: SAA1GY0WA10C SSN: 48KB10BMBOZ0270 Work id: 09715B7F Done; Stype: 00000001 SECURITY: X1M0UA04CL10 Size: 000002E2 Backup saved to: 0148xxxxxxxxx-1 Backup file(s) removed; Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; FRPEx Done; Log file saved to: LOG_10_05_2018_09_50_44.txt Time needed - 00:00:35 |
05-10-2018, 15:12 | #14590 (permalink) |
Member: 1537078 Status: Online Sonork: celular center Thanks Meter: 573 | Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM18)) Preparing to start flash mode; Preparing to open COM18 Connecting; Downloading DA; Initializing; Rid: d3cf50d0234b003a246964061ec56db6 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem64.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM37; DEVICE INFO: BB CHIP: MT6572_S00 [CA00, 00, 6572, FF] HW_STORAGE_EMMC: 0x484A0190 0x61324734 0xB51E0111 0x49225BC8 [SIZE=0xE9C00000] IMEI1 [OTP 0001]: 014325-00-040855-4 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4027A-2AWCDO1 USRDATA INFO: 0x6E380000 SIZE: 0x77880000 Loading the file ... Cfg done ... Formatting file system now... Done; Formatting SECCFG partition now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:04:20 |
05-11-2018, 17:51 | #14591 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | zte z833 frp done Software engine version: 1.0.0.10670 Searching phone ... MODEL : QCOM SERIES 53 COMPILED DATE : Jun 15 2017 16:08:00 RELEASE DATE : Apr 5 2017 04:00:00 FIRMWARE INFO : MPSS.JO.1.2.c2-00114-8937_GENNS_PACK-1.92596.3 IMEI : 86214703829511-5 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: P817T06_MPCSV1.0.0B16 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Program Files (x86)\FURIOUS-GOLD\PACK5\86214703829511_11_05_2018_12_36_22.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM4 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D5 start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_11_05_2018_12_38_49.txt Time needed - 00:02:31 |
05-11-2018, 18:58 | #14592 (permalink) |
No Life Poster Join Date: Sep 2004 Location: South Mrorocco Age: 49
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | Hi to all. unlock CAM- L03 succefull Here is log 2018-05-11 22:06:05.218 Autodetect started! 2018-05-11 22:06:06.531 Found COM port: COM128 2018-05-11 22:06:06.531 Open port COM128 (Android Adapter PCUI (COM128))... 2018-05-11 22:06:06.656 Start read phone info! 2018-05-11 22:06:07.687 Connecting to server... 2018-05-11 22:06:09.656 Connected! 2018-05-11 22:06:09.671 Read data from server... 2018-05-11 22:06:12.781 Read data from server success! 2018-05-11 22:06:24.843 CP State: ready 2018-05-11 22:06:24.843 Read phone basic info... 2018-05-11 22:06:26.265 Read phone secure info... 2018-05-11 22:06:34.437 Autodetect started! 2018-05-11 22:06:35.140 Found COM port: COM129 2018-05-11 22:06:35.593 Connecting to server... 2018-05-11 22:06:37.734 Connected! 2018-05-11 22:06:37.734 Read data from server... 2018-05-11 22:06:41.062 Read data from server success! 2018-05-11 22:06:41.062 Open COM port COM129 (DBAdapter Reserved Interface (COM129))... 2018-05-11 22:06:44.078 ERROR! Phone in wrong mode, please connect phone in Manufacture mode 2018-05-11 22:06:47.187 Detect phone done! Model: CAM-L03 IMEI: 864823035550060 SUB_IMEI: 864823035550060 IMEISV: 05 Firmware ver.: CAM-B062 SN: NSXDU17627003368 Custom SN: DU3UGD176U106121 WiFi MAC: D8:C7:71:33:BE:CC BlueTooth MAC: D8:C7:71:33:CA:C1 Vendor: claro Country: la FASTBOOTailyBuild_201606031900_FASTBOOT BOOTailyBuild_201606031900_BOOT RECOVERYunknow) SYSTEM:CAM-L03C900B105_SYSTEM MAINVER:CAM-B062 DATAVER:CAM-B062_DATA_claro_la APTIME:Fri Jun 3 19:03:23 CST 2016 RAM: 2G eMMC: 16G IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 10 NETSUB: unlocked SP: unlocked 2018-05-11 22:10:44.718 Autodetect started! 2018-05-11 22:10:45.875 Found COM port: COM128 2018-05-11 22:10:47.562 Connecting to server... 2018-05-11 22:10:50.406 Connected! 2018-05-11 22:10:50.421 Read data from server... 2018-05-11 22:10:53.515 Read data from server success! 2018-05-11 22:10:53.515 Open COM port COM128 (Android Adapter PCUI (COM128))... 2018-05-11 22:11:13.843 CP State: ready 2018-05-11 22:11:13.843 Read phone basic info... 2018-05-11 22:11:15.218 Read phone secure info... 2018-05-11 22:11:24.078 Unlocking start 2018-05-11 22:11:24.093 Phone secure identify start 2018-05-11 22:11:27.750 Phone secure identify success! 2018-05-11 22:11:27.765 Read from server... 2018-05-11 22:11:28.453 Read from server success! 2018-05-11 22:11:30.375 Unlock done! 2018-05-11 22:11:30.390 Job finished! |
The Following User Says Thank You to ramoon20 For This Useful Post: |
05-11-2018, 19:01 | #14593 (permalink) |
Freak Poster Join Date: Aug 2012 Location: ireland
Member: 1801470 Status: Offline Thanks Meter: 41 | 5080 [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM69)) Preparing to start flash mode; Preparing to open COM69 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 898f151a37714eacd930b0543005cee9 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem41.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM185; DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x51000115 0x4D333145 0x3C810D42 0x33C35BEE [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 352095-08-168939-4 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5080X-2GTWIE7 USRDATA INFO: 0xE7000000 SIZE: 0x2B9200000 Searching data; Locked to [SIM1]: 206-01 code_cat_n: 2983035405472662 enabled: yes tries: 10 code_cat_ns: 2523462658753193 enabled: no tries: 10 code_cat_sp: 2532112611728748 enabled: yes tries: 10 code_cat_c: 1521227231714012 enabled: no tries: 10 code_cat_sim: 8528306832950298 enabled: no tries: 10 code_cat_ns_sp: 8968734354399096 enabled: no tries: 5 code_cat_sim_c: 4367810187941973 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:03 Log file saved to: LOG_11_05_2018_10_50_30.txt |
The Following User Says Thank You to PhoneWIZZ For This Useful Post: |
05-12-2018, 11:36 | #14594 (permalink) |
Insane Poster Join Date: May 2013 Location: Earth
Member: 1948180 Status: Offline Thanks Meter: 36 | Vodafone Smart Turbo 7 Unlock success ! Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM26)) Preparing to start flash mode; Preparing to open COM26 Connecting; Downloading DA; Initializing; Rid: 7a857bb57222397bfbf5248a7ee8b3f7 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem138.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM44; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x46000115 0x4D32584E 0xA5760142 0x9714DFEE [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 357xxx-07-xxxxxx-x IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V500-2AVDGB2 USRDATA INFO: 0xBD000000 SIZE: 0x111480000 Searching data; Locked to [SIM1]: 234-15 code_cat_n: 3141802509924746 enabled: yes tries: 10 code_cat_ns: 2486339547742518 enabled: no tries: 10 code_cat_sp: 3893196689567627 enabled: no tries: 10 code_cat_c: 5293419367072823 enabled: no tries: 10 code_cat_sim: 4294561395653173 enabled: no tries: 10 code_cat_ns_sp: 9965892995449184 enabled: no tries: 5 code_cat_sim_c: 4471186845225582 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:05 !!! |
05-12-2018, 14:48 | #14595 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | tecno k8 frp removed by furious new Boot sing library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM10)) Preparing to start flash mode; Preparing to open COM10 Connecting; Downloading DA; Initializing; Rid: 38e9653ff5a256039ac41cbc8d58f651 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x46000115 0x4D323645 0x3C050342 0xB7A49EE4 [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x124000000 SIZE: 0x27ED80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_12_05_2018_16_07_35.tx |
The Following User Says Thank You to MGT SOFTWARE For This Useful Post: |
