06-26-2019, 16:20 | #15196 (permalink) |
No Life Poster Join Date: May 2003 Location: Romania Age: 48
Member: 29006 Status: Offline Thanks Meter: 28 | OTZ Flasher Pack 6 Select Huawei G5520 Code: Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM54)) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6260 Sw version: 1370_UL231_N_S04A_V02_M181207_MP Hw Version: SAGETEL60A_12864_11B_HW Reading phone info; IMEI: 356877-09-090644-8 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:08 Log file saved to: LOG_26_06_2019_18_11_48.txt Code: Using library Brom_DLL_v5.1316.1 EMI Settings Loaded; Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM54)) Preparing to start flash mode; Connecting; Downloading DA; Initializing; Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6260_S0000 [CB00, 00, 6260, 05] MEMORY: [GigaDevice] GD25LQ128 [C8:60:18] [SIZE=0x01000000] FAT INFO: 0x00D30000 SIZE: 0x002D0000 Reading data; Done; Contents saved to :D:\GSM\Furious\Pack6\SAGETEL60A_12864_11B_HW.otz Time needed - 00:01:07 Log file saved to: LOG_26_06_2019_18_17_48.txt |
The Following User Says Thank You to gabiz_ro For This Useful Post: |
06-27-2019, 14:10 | #15197 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 227 | NEW_TEST.spd Perfect work! Flash other patched firmware no network, after flash BLAUPUNKT_FL01_SC6531E_EN_HU-2PATCHED_NEW_TEST.spd full network:-) Preparing to sync; Port opened [COM21]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 [000071C4309BCA8A:0000] Reading phone info; PHONE INFO: NONE BT ADDR: 49:CE:08:45:2E:1E SW IMEI[0]: 355478-09-xxxxxx-9 SW IMEI[1]: 352751-01-xxxxxx-7 SW IMEI[2]: 358570-01-xxxxxx-3 SW IMEI[3]: 910575-60-xxxxxx-8 SIMLOCK FLAG: ON FIXED NV BASE: 10390000 Uncompressing; Done; Re-programming; FLS programmed; Done; Remove battery and cable; |
The Following User Says Thank You to Pufi164 For This Useful Post: |
06-30-2019, 10:53 | #15198 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | P smart 2019 flashing done here log [CODE] Code: Looking for a device in upgrade mode COM489: Android Adapter PCUI (COM489) COM494: DBAdapter Reserved Interface (COM494) 30-Jun-19 11:18:08 AM Starting to write device in UPGRADE mode... File to update: UPDATE.APP Validating file... Detecting port... Preparing to write... Writing file 1 of 41: SHA256RSA...OK Writing file 2 of 41: CRC...OK Writing file 3 of 41: BASE_VERLIST...OK Writing file 4 of 41: BASE_VER...OK Writing file 5 of 41: PACKAGE_TYPE...OK Writing file 6 of 41: HISIUFS_GPT...OK Writing file 7 of 41: XLOADER...OK Writing file 8 of 41: FASTBOOT...OK Writing file 9 of 41: HHEE...OK Writing file 10 of 41: DTS...OK Writing file 11 of 41: TRUSTFIRMWARE...OK Writing file 12 of 41: FW_LPM3...OK Writing file 13 of 41: DTO...OK Writing file 14 of 41: KERNEL...OK Writing file 15 of 41: TEEOS...OK Writing file 16 of 41: ISP_FIRMWARE...OK Writing file 17 of 41: VECTOR...OK Writing file 18 of 41: SENSORHUB...OK Writing file 19 of 41: FW_HIFI...OK Writing file 20 of 41: VBMETA...OK Writing file 21 of 41: MODEMNVM_UPDATE...OK Writing file 22 of 41: MODEMNVM_CUST...OK Writing file 23 of 41: RECOVERY_RAMDISK...OK Writing file 24 of 41: RECOVERY_VENDOR...OK Writing file 25 of 41: RECOVERY_VBMETA...OK Writing file 26 of 41: ERECOVERY_KERNEL...OK Writing file 27 of 41: ERECOVERY_RAMDISK...OK Writing file 28 of 41: ERECOVERY_VENDOR...OK Writing file 29 of 41: ERECOVERY_VBMETA...OK Writing file 30 of 41: ENG_VENDOR...OK Writing file 31 of 41: ENG_SYSTEM...OK Writing file 32 of 41: CACHE...OK Writing file 33 of 41: SYSTEM...OK Writing file 34 of 41: CUST...OK Writing file 35 of 41: MODEM_FW...OK Writing file 36 of 41: HISEE_IMG...OK Writing file 37 of 41: HISEE_FS...OK Writing file 38 of 41: VENDOR...OK Writing file 39 of 41: ODM...OK Writing file 40 of 41: PRODUCT...OK Writing file 41 of 41: USERDATA...OK Software written 30-Jun-19 11:50:00 AM Starting to write device in UPGRADE mode... File to update: UPDATE.APP Validating file... Detecting port... Preparing to write... Writing file 1 of 7: SHA256RSA...OK Writing file 2 of 7: CRC...OK Writing file 3 of 7: CUST_VERLIST...OK Writing file 4 of 7: CUST_VER...OK Writing file 5 of 7: PACKAGE_TYPE...OK Writing file 6 of 7: PTABLE_CUST...OK Writing file 7 of 7: VERSION...OK Software written 30-Jun-19 11:50:36 AM Writing device finished OK |
07-01-2019, 11:22 | #15199 (permalink) |
Freak Poster Join Date: Aug 2017
Member: 2751525 Status: Offline Thanks Meter: 28 | 5053y Preparing to start flash mode; Preparing to open COM19 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22E9 size 29.1 GB IMEI: 353299xxxxxx961-5 PTH: 08 PTS: F29 PROV_ID: 5053Y-2BMWIE1 SBTADDR: 94:27:90D06 SWIFIADDR: 94:27:90:AF:4C:96 HS_PN: SAA2DS10G10C SSN: 47LC04BPIIC005Y Work id: 22021984 Done; Stype: 00000001 SECURITY: X3F0CW02CX00 Size: 00000400 Backup saved to: 353299xxxxx961-5 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_1_07_2019_11_21_36.txt Time needed - 00:00:40 |
07-03-2019, 12:42 | #15200 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1507732 Status: Offline Thanks Meter: 36 | DUA-L22 IMEI Repair Done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MediaTek USB Port (COM233)) Preparing to start flash mode; Preparing to open COM233 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 4391957065e64c085da6822ddb0a743c Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CA00, 00, 6739, 00] HW_STORAGE_EMMC: 0x484A0190 0x61344741 0xE4C2D432 0x6345231A [SIZE=0x3AC000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEC000000 SIZE: 0x2BE3FBE00 Searching data; Checking data; IMEI repaired; Remove battery and cable; Time needed - 00:00:05 |
The Following User Says Thank You to /\/\@ster For This Useful Post: |
07-03-2019, 13:27 | #15201 (permalink) |
Freak Poster Join Date: May 2005 Location: Novi Sad, Serbia Age: 43
Member: 145248 Status: Offline Thanks Meter: 27 | Code: Software engine version: 1.0.0.10786 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Jul 2 2017 03:07:00 RELEASE DATE : Jun 27 2017 02:00:00 FIRMWARE INFO : MPSS.JO.3.0-00306-8909_GEN_PACK-1.102677.1.105159.1 IMEI : 86423703876466-1 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: P890A06V1.0.0B13 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: E:\FURIOUS-GOLD\PACK5\86423703876466_3_07_2019_14_21_04.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM120 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM132)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_3_07_2019_14_24_17.txt Time needed - 00:03:15 but phone asking sim unlock pin... |
07-04-2019, 10:18 | #15202 (permalink) |
Freak Poster Join Date: May 2014 Location: Africa
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | Orange Rise 53 Unlock Done BootKey use : VolUp 1. Operation : choose relock and open sloc to ON Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem84.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM144]; Entering diagnostic mode; Done; Chip type: 6B4C:5300 Platform Version: MOCORTM_15C_W17.39.2_P1.03_Debug Project Version: sc983x_cp1 BASE Version: FM_BASE_15C_W17.39.2_P1.03 HW Version: sc983x_modem 12-22-2017 21:57:31 Build number: sp9832a_2h11_orange-user 7.0 NRD90M 47416 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 867302-03-220736-9 SW IMEI[1]: 867302-03-230736-7 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: OFF Done; SLOCK repaired; Remove battery and cable; Log file saved to: LOG_4_07_2019_09_10_43.txt Time needed - 00:00:01 -------------------------------------------------- 2. Operations: Remove Sim_lock Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem84.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM144]; Entering diagnostic mode; Done; Chip type: 6B4C:5300 Platform Version: MOCORTM_15C_W17.39.2_P1.03_Debug Project Version: sc983x_cp1 BASE Version: FM_BASE_15C_W17.39.2_P1.03 HW Version: sc983x_modem 12-22-2017 21:57:31 Build number: sp9832a_2h11_orange-user 7.0 NRD90M 47416 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 867302-03-220736-9 SW IMEI[1]: 867302-03-230736-7 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON SIM_LOCK TYPE: 2 IMEI: 867302-03-220736-9 UNLOCK CODE: 49462176 Code reading finished; Remove battery and cable; Log file saved to: LOG_4_07_2019_09_13_59.txt Time needed - 00:00:14 Last edited by elykia; 07-04-2019 at 10:26. |
The Following User Says Thank You to elykia For This Useful Post: |
07-04-2019, 20:41 | #15203 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | zte z835 frp done Software engine version: 1.0.0.10659 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Jul 2 2017 03:07:00 RELEASE DATE : Jun 27 2017 02:00:00 FIRMWARE INFO : MPSS.JO.3.0-00306-8909_GEN_PACK-1.102677.1.105159.1 IMEI : 8642********** BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: P890A06V1.0.0B13 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\Dwight\Documents\PHONE\Furious Gold\Furious Gold Latest Software\QCOM_SMART_TOOL_v1.0.0.10659\864237039678 20_4_07_2019_14_31_27.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM76 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_4_07_2019_14_33_47.txt Time needed - 00:02:23 |
07-05-2019, 19:18 | #15204 (permalink) |
Freak Poster Join Date: Feb 2016 Location: First In The GSM World
Member: 2526196 Status: Offline Thanks Meter: 60 | Repair IMEI Huawei ATU-LX3 success! 2019-07-05 13:38:03.632 Autodetect started! 2019-07-05 13:38:04.515 Found COM port: COM131 2019-07-05 13:38:07.492 Repairing start New IMEI 1 : 86XXXXXXXXXXXXX 2019-07-05 13:38:07.505 Connecting to server... 2019-07-05 13:38:09.064 Connected! 2019-07-05 13:38:09.070 Read data from server... 2019-07-05 13:38:14.556 Read data from server success! 2019-07-05 13:38:14.564 Open COM port COM131 (DBAdapter Reserved Interface (COM131))... 2019-07-05 13:38:30.277 Read secure info... 2019-07-05 13:38:30.509 Read basic info... 2019-07-05 13:38:30.556 Repair phone security data start! 2019-07-05 13:38:30.564 Calculating phone secure data... 2019-07-05 13:38:36.626 Calculate phone secure success! 2019-07-05 13:38:36.636 Writing phone secure data... 2019-07-05 13:38:36.792 Writing phone secure data success! 2019-07-05 13:38:37.798 Repair phone security data success! 2019-07-05 13:38:37.806 Factory reset... 2019-07-05 13:38:37.927 Factory reset success! 2019-07-05 13:38:37.937 Finished! |
The Following User Says Thank You to walkmanw800 For This Useful Post: |
07-07-2019, 04:03 | #15205 (permalink) |
Freak Poster Join Date: Mar 2012 Location: Midicmobile
Member: 1728478 Status: Offline Thanks Meter: 22 | SPD TOOL PACK 2 test for ARCHOS NEON 40 repair imei(0) success! generic method 2 ok log: Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem328.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM11]; Entering diagnostic mode; Done; Chip type: 8730:B001 Platform Version: MOCORTM_14B_TShark_OC_W16.06_Debug Project Version: sc7731g_CP0_modem BASE Version: TM_BASE_15A_W16.06 HW Version: sc7731g_CP0_modem 02-01-2016 20:26:46 Build number: revo_3204-user 5.1 LMY47D 20160513.191030 release-keys PHONE INFO: BT ADDR: F9:55:26:1E:FE:60 SW IMEI[0]: 35? SW IMEI[1]: 35? SW IMEI[2]: 35? SW IMEI[3]: 91? SIMLOCK FLAG: OFF Done; IMEI[0] repaired; Remove battery and cable; |
The Following User Says Thank You to daly2012 For This Useful Post: |
07-08-2019, 22:58 | #15206 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | verykool i330 unlock done using s135 Searching phone; Phone detected (@oem85.inf,%vcom_bootrom%;MediaTek USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: i330_Claro_PR_SW_2.1 Hw Version: 11B GINWAVE76_11B Reading phone info; IMEI: 354297-06-006034-4 Reading simlock info; Unlock codes: Locked to: 330-11 code_cat_n: 30078603 enabled: yes tries: 0 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:26 Log file saved to: LOG_8_07_2019_17_41_20.txt |
The Following User Says Thank You to maxpatri9 For This Useful Post: |
07-09-2019, 04:00 | #15207 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Australia
Member: 177568 Status: Offline Thanks Meter: 146 | Nokia 1 plus unlock done Nokia 1 plus unlock done Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM17)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739 Sw version: Hw Version: alps-mp-p0.mp2-V3.5 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V61.12.P9 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 352887-xx-xxxxxx-x IMEI 2: N/A Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:27 Log file saved to: LOG_9_07_2019_12_54_17.txt |
07-10-2019, 10:07 | #15208 (permalink) |
No Life Poster Join Date: Sep 2007 Location: around
Member: 595864 Status: Offline Thanks Meter: 163 | [REPORT] T-Mobile REVVL2 Alcatel 5052W new SEC unlock OK Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM102)) Preparing to start flash mode; Preparing to open COM102 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: f86ae3a495cf39b247049569f0985b0c Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x7ADE0742 0x6D65F6E4 [SIZE=0x748800000] IMEI1 [OTP 0001]: 015246-XX-XXXXXX-X IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5052W-2ATBUSE USRDATA INFO: 0x133800000 SIZE: 0x6108FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:00:00 Checking data integrity; Data integrity: OK; SIM_LOCK: PARTIAL_UNLOCK Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:00:02 Log file saved to: LOG_10_07_2019_10_40_43.txt |
The Following User Says Thank You to nbkappa For This Useful Post: |
07-10-2019, 16:28 | #15209 (permalink) |
Freak Poster Join Date: Jul 2009 Location: Dominican Republic Age: 35
Member: 1078865 Status: Offline Sonork: 100.1626549 Thanks Meter: 83 | unlock 9027w done Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM822)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.141.2_tb8765ap1.bsp_P12 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R3.MP.V16.P10 Hw Version: TK_MD_BASIC_HW Reading phone info; IMEI 1: 015263-00-158099-9 IMEI 2: 000000-00-000000-0 Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:29 Log file saved to: LOG_10_07_2019_11_26_42.txt |
07-11-2019, 16:52 | #15210 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Furious mrd-lx3 unlock,frp,and flash done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM9)) Preparing to start flash mode; Preparing to open COM9 Connecting; Downloading DA; Initializing; Rid: f6ac5b99b237e44248efbb2ea5883f15 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x5F8C0142 0x81162096 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x176800000 SIZE: 0x5D1200000 Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:00 Log file saved to: LOG_11_07_2019_10_11_48.txt Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM9)) Preparing to start flash mode; Preparing to open COM9 Connecting; Downloading DA; Initializing; Rid: f6ac5b99b237e44248efbb2ea5883f15 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x5F8C0142 0x81162096 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x176800000 SIZE: 0x5D1200000 Contents saved to : D:\HUAWEI MRD-LX3_IMEI_030A47E9_8DCF459C_f6ac5b99b237e44248efbb2 ea5883f15_11_07_2019_10_13_03.osp Downloading images... Done; Searching phone; (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM (Android) (COM5)) Preparing to start fastboot mode; Done; Fastboot mode entered; Connecting; switching_fastboot_mode: OK; resistance is futile : OK !?; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; Factory Reset Protection successfully removed ! Time needed - 00:01:16 Log file saved to: LOG_11_07_2019_10_14_20.txt Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM9)) Preparing to start flash mode; Preparing to open COM9 Connecting; Downloading DA; Initializing; Rid: f6ac5b99b237e44248efbb2ea5883f15 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x5F8C0142 0x81162096 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x14E800000 SIZE: 0x5F9200000 Loading the file ... Cfg done ... Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:06:21 Log file saved to: LOG_11_07_2019_11_46_16.txt |
