11-20-2019, 07:29 | #15317 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | ZTE L130 KICKA 4 VODACOM DONE..using 1 & only FG Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem186.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM45]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 861486-04-080172-1 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_861486-04-080172-1_96330000_20_11_2019_08_25_58.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_20_11_2019_08_26_16.txt Time needed - 00:05:47 |
11-22-2019, 19:00 | #15319 (permalink) | |
No Life Poster Join Date: Mar 2001 Location: Croatia Age: 45
Member: 3508 Status: Offline Thanks Meter: 71 | Quote:
it is needed to connect router with USB cable and install suite from router to install driver so you can detect router on PC. BR | |
The Following User Says Thank You to GSMBlade For This Useful Post: |
11-25-2019, 17:14 | #15320 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Jamaica
Member: 2673816 Status: Offline Thanks Meter: 612 | Alcatel 5044C new security unlock done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM29 Connecting; Init; Port opened; Phone detected (@oem157.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM319 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory size 14.7 GB, target id 8909 IMEI: 01507500-8 PTH: 06 PTS: T4F PROV_ID: 5044C-2ARKUS3-R SBTADDR: E4:E1:30:AD:B3:EC SWIFIADDR: E4:E1:30:B4:43:CF HS_PN: SAA2A30WA11C SSN: MQLC41CH2EC03DU Work id: 22021984 Done; Stype: 00000001 SECURITY: XVT4UCF0CL10 Size: 000002B8 Backup saved to: 01507500-8 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_25_11_2019_11_06_15.txt Time needed - 00:00:35 |
The Following 2 Users Say Thank You to ThePhoneTechDoc For This Useful Post: |
11-26-2019, 15:01 | #15321 (permalink) |
Freak Poster Join Date: Jul 2017 Location: Globe
Member: 2742707 Status: Offline Thanks Meter: 138 | Alcatel 4034x flashing done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM8)) Preparing to start flash mode; Preparing to open COM8 Connecting; Downloading DA; Initializing; Rid: 35e0ee51f09050be8d09609895e2e85f Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0x8446124D 0x95657EEA [SIZE=0xE9B00000] IMEI1 [OTP 0001]: 358893-08-811499-2 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4034X-2KVDZAA USRDATA INFO: 0x58800000 SIZE: 0x60000000 Loading the file ... Cfg done ... Formatting file system now... Done; Formatting SECCFG partition now... Done; Formatting FRP partition now... Done; Formatting NVDATA partition now... Done; Formatting METADATA partition now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:04:46 Log file saved to: LOG_26_11_2019_15_53_13.txt |
11-26-2019, 21:29 | #15322 (permalink) |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | ALCATEL 1V FRP REMOVE DONE Searching phone; For an successful connection do the following: 1. Power on the phone and power it off 2. Keep pressed firmly volume UP key 3. Insert the usb cable inside the phone while keeping pressed volume UP Phone detected (@oem200.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM107]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2019, FuriouSTeaM Starting FDL2; FDL2 sent; Starting auth; memory_type: IF_TYPE_MMC dev_no: 0 part_type: PART_TYPE_UNKNOWN vendor: Man 000088 Snr 8a089529 product: D9D16G revision: 3.8 memory_size: 14,5 GB HW IMEI : 000000-00-000000-0 PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: 356308-1XXXX-0 SW IMEI[1]: 356308-1XXXX-6 SW IMEI[2]: 867400-XXXX6X SIMLOCK FLAG: OFF Starting format; Formatted; Done; Remove battery and cable; Log file saved to: LOG_26_11_2019_21_23_25.txt |
11-29-2019, 01:16 | #15324 (permalink) |
No Life Poster Join Date: Jun 2016 Location: UK
Member: 2581848 Status: Offline Thanks Meter: 249 | unlock alcatel 4052R Done With Fg Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem14.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM3 Connecting; Loading; Init; Port opened; Hello Received; MSM_ID: 0x009600E1 OEM_ID: 0x0042 MODEL_ID: 0x004D PK_HASH: B451BD3B38D9EDD197CCADF0838D5F8652B8F4642E5BF70411 C8153D1AC40ADBB451BD3B38D9EDD197CCADF0838D5F8652B8 F4642E5BF70411C8153D1AC40ADBB451BD3B38D9EDD197CCAD F0838D5F8652B8F4642E5BF70411C8153D1AC40ADB BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory size 3.5 GB, target id 8909 IMEI: 01545500251528- PTH: 04 PTS: X34 PROV_ID: 4052R-2AAQUS3-R SBTADDR: 88:9E:33:A9:6B:23 SWIFIADDR: 88:9E:337:C6:4A HS_PN: SAA66A0AA10C SSN: D7LC03CKEMC00XZ Work id: 22021984 Done; Stype: 00000001 SECURITY: XZX3UA40CL00 Size: 0000030D Backup saved to: 01545500251528- Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_28_11_2019_18_11_42.txt Time needed - 00:01:01 thanks fg http://forum.gsmhosting.com/vbb/f272...*****-2720628/ |
The Following User Says Thank You to Dzomega For This Useful Post: |
12-02-2019, 14:51 | #15325 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | ZTE Blade L130 Unlock Done Code: Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem87.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM22]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 861486-04-079594-9 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_861486-04-079594-9_96330000_2_12_2019_15_29_13.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_2_12_2019_15_29_20.txt Time needed - 00:02:35
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
12-02-2019, 19:03 | #15326 (permalink) |
Freak Poster Join Date: Mar 2012 Location: Midicmobile
Member: 1728478 Status: Offline Thanks Meter: 22 | IMO DASH read unlock code done Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM48]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Chip type: 7702:0000 Starting auth; Memory NAND [CS0]: 0098:00B1 - SIZE : 08000000 EFUSE HASH: 0000000000000000000000000000000000000000 EFUSE LOCK STATUS: 000E 000E 000E 000E 000E HW IMEI : 000000-00-000000-0 Reading phone info; PHONE INFO: NONE BT ADDR: EE:1D:1B:C5:0A:30 SW IMEI[0]: 358889-08-316928-8 SW IMEI[1]: 352751-01-077044-0 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 40040000 Reading NV; NV saved to : NV_000000-00-000000-0_358889-08-316928-8_77020000_2_12_2019_17_11_47.spd IMEI: 358889-08-316928-8 UNLOCK CODE: 86784503 Code reading finished; Remove battery and cable; |
12-03-2019, 13:33 | #15327 (permalink) |
Freak Poster Join Date: Aug 2019 Location: ZW port of good hope
Member: 2925617 Status: Offline Thanks Meter: 49 | Zte l130 network unlock done Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem9.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM34]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 861486-04-116817-9 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_861486-04-116817-9_96330000_3_12_2019_14_26_53.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_3_12_2019_14_27_00.txt Time needed - 00:02:24 |
12-03-2019, 15:27 | #15328 (permalink) |
No Life Poster Join Date: May 2009 Location: Bangladesh/USA/UK Age: 39
Member: 1033714 Status: Offline Sonork: 1640811:mothertelecom Thanks Meter: 91 | vfd 630 unlock done 2019 new security Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek PreLoader USB VCOM (Android) (COM28)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6761 Sw version: Hw Version: alps-mp-p0.mp1-V3.12 Baseband Chip: MT6761 Sw version: MOLY.LR12A.R3.MP.V31.3.P34 Hw Version: TK_MD_BASIC_HW Reading phone info; IMEI 1: 359956-10-042726-9 IMEI 2: N/A Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:28 Log file saved to: LOG_3_12_2019_20_24_07.txt |
12-03-2019, 15:33 | #15329 (permalink) |
Member: 2925617 Status: Offline Thanks Meter: 49 | World first hisense f16 network unlock done in seconds Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek PreLoader USB VCOM (Android) (COM4)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1_P18 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V48.12.P4 Hw Version: TK_MD_BASIC_HW Reading phone info; IMEI 1: 86XXXXXXXXXXX IMEI 2: N/A Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:37 Log file saved to: LOG_3_12_2019_16_30_23.txt |
The Following User Says Thank You to 123frp For This Useful Post: |
12-03-2019, 16:23 | #15330 (permalink) |
Member: 2925617 Status: Offline Thanks Meter: 49 | World first mascom s750 read and direct unlock done Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem22.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM7]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_17C_W18.23.4_P2_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P2 HW Version: sc7731e_modem 06-20-2018 11:11:40 Build number: sp7731e_1h20_native-user 8.1.0 OPM2.171019.012 20190130 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 35XXXXXXXXXXXXXX4 SW IMEI[1]: 35X-2XXXXXXXXXXXX SW IMEI[2]: 86XXXXXXXXXXXXXX8 SW IMEI[3]: 86XXXXXXXXXXXXXXX SIMLOCK FLAG: ON SIM_LOCK TYPE: 3 IMEI: 35XXXXXXXXXX6-4 UNLOCK CODE: 86110843 Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_3_12_2019_17_19_49.txt Time needed - 00:00:04 |
The Following 2 Users Say Thank You to 123frp For This Useful Post: |
