Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 11-20-2019, 07:28   #15316 (permalink)
Member: 328688
Thanks Meter: 2,282
world 1st aspir a5 network unlock done
here log
The Following 3 Users Say Thank You to CHAUDHRAY ARSHAD For This Useful Post:
Old 11-20-2019, 07:29   #15317 (permalink)
Registered User
Member: 731353
Thanks Meter: 254
ZTE L130 KICKA 4 VODACOM DONE..using 1 & only FG
Searching phone;
For an successful connection do the following:
1. Power on the phone and power it off and leave the battery inside
2. Keep pressed firmly volume DOWN key
3. Insert the usb cable inside the phone while keeping pressed volume DOWN
Phone detected (@oem186.inf,%usbcomm_dl%;SPRD U2S Diag)
Preparing to sync;
Port opened [COM45];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: Spreadtrum Boot Block version 1.1
Starting FDL2;
FDL2 sent;
Starting auth;
HW IMEI : 000000-00-000000-0
Analysing data; Please WAIT !
OK;
PHONE INFO: NONE
BT ADDR: FF:FF:FF:FF:FF:FF
SW IMEI[0]: 861486-04-080172-1
SW IMEI[1]: 867400-02-031662-0
SW IMEI[2]: 867400-02-031663-8
SW IMEI[3]: 867400-02-031664-6
SIMLOCK FLAG: ON
Reading NV;
NV saved to : NV_000000-00-000000-0_861486-04-080172-1_96330000_20_11_2019_08_25_58.spd
Gathering security data;
Security check result: 0
Connecting to server;
Authorisation process started;
Done;
Requesting data from server ! Wait please ...
Re-programming;
Security programmed;
Sync NV;
Done;
Phone unlocked; Remove battery and cable;
Log file saved to: LOG_20_11_2019_08_26_16.txt
Time needed - 00:05:47
Old 11-20-2019, 13:16   #15318 (permalink)
gunit1's Avatar
Member: 2041210
Thanks Meter: 541
levi's the original 3g unlock done
The Following User Says Thank You to gunit1 For This Useful Post:
Old 11-22-2019, 19:00   #15319 (permalink)
Member: 3508
Thanks Meter: 71
Originally Posted by samindapowerson View Post
many tools i was try but its show unlocked but no service......finaly FG done without any issue
Reading device...
Model: E5372
Application port: COM24
IMEI: 864578010977791
Firmware Version: 21.236.03.00.00
Build Date: Sep 23 2013, 19:16:28
Product name: B710D0
SIM status: Unlocked
Unlock process started at 2/12/2016 10:29:34 AM
Detecting port...
Port detected: COM24
Device VID_12D1&PID_1506 removed
Switching device to download mode...
Device VID_12D1&PID_1C05 inserted
Device found
Setting device to download...
Device Product: HUAWEI B710D0
Downloading data...
Downloading data...
Downloading data...
Downloading data...
Downloading data...
Downloading data...
Downloading data...
Downloading data...
Downloading data...
Downloading data...
Downloading data...
Downloading data...
Data successfully downloaded
Switching device to diagnostic mode...
Device VID_12D1&PID_1C05 removed
Searching ports in diagnostic mode by VID_12D1
Resetting device
Unlock process finished OK at 2/12/2016 10:31:38 AM
...just to mention...
it is needed to connect router with USB cable and install suite from router to install driver so you can detect router on PC.
The Following User Says Thank You to GSMBlade For This Useful Post:
Old 11-25-2019, 17:14   #15320 (permalink)
ThePhoneTechDoc's Avatar
Member: 2673816
Thanks Meter: 612
Smile Alcatel 5044C new security unlock done
Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ;
Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device)
Preparing to enter download mode;
Preparing to open COM29
Connecting;
Init;
Port opened;
Phone detected (@oem157.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008)
Preparing to start flash mode;
Preparing to open COM319
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
Found an eMMC memory size 14.7 GB, target id 8909
IMEI: 01507500-8
PTH: 06
PTS: T4F
PROV_ID: 5044C-2ARKUS3-R
SBTADDR: E4:E1:30:AD:B3:EC
SWIFIADDR: E4:E1:30:B4:43:CF
HS_PN: SAA2A30WA11C
SSN: MQLC41CH2EC03DU
Work id: 22021984
Done;
Stype: 00000001
SECURITY: XVT4UCF0CL10 Size: 000002B8
Backup saved to: 01507500-8
Unlocking;
SIM_LOCK REMOVED !
Log file saved to: LOG_25_11_2019_11_06_15.txt
Time needed - 00:00:35
The Following 2 Users Say Thank You to ThePhoneTechDoc For This Useful Post:
Old 11-26-2019, 15:01   #15321 (permalink)
Member: 2742707
Thanks Meter: 138
Alcatel 4034x flashing done
Using library Brom_DLL_v7.1813.3
Searching phone in normal mode;
[connect the phone powered off to the usb cable]
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM8))
Preparing to open COM8
Connecting;
Downloading DA;
Initializing;
Rid: 35e0ee51f09050be8d09609895e2e85f
Requesting baudrate change;
Done;
USB SPEED: USB_HIGH_SPEED
DEVICE INFO:
BB CHIP: MT6580 [CA00, 00, 6580, FF]
HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0x8446124D 0x95657EEA [SIZE=0xE9B00000]
IMEI1 [OTP 0001]: 358893-08-811499-2
IMEI2 [OTP 0001]: 000000-00-000000-0
PROVIDER: 4034X-2KVDZAA
USRDATA INFO: 0x58800000 SIZE: 0x60000000
Loading the file ...
Cfg done ...
Formatting file system now...
Done;
Formatting SECCFG partition now...
Done;
Formatting FRP partition now...
Done;
Formatting NVDATA partition now...
Done;
Formatting METADATA partition now...
Done;
Downloading bootloader...
Done;
Downloading images...
Done;
Success;
Time needed - 00:04:46
Log file saved to: LOG_26_11_2019_15_53_13.txt
Old 11-26-2019, 21:29   #15322 (permalink)
unlockmachine44's Avatar
Member: 1350724
Thanks Meter: 188
ALCATEL 1V FRP REMOVE DONE
Searching phone;
2. Keep pressed firmly volume UP key
3. Insert the usb cable inside the phone while keeping pressed volume UP
Phone detected (@oem200.inf,%usbcomm_dl%;SPRD U2S Diag)
Preparing to sync;
Port opened [COM107];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: (c)2019, FuriouSTeaM
Starting FDL2;
FDL2 sent;
Starting auth;
memory_type: IF_TYPE_MMC
dev_no: 0
part_type: PART_TYPE_UNKNOWN
vendor: Man 000088 Snr 8a089529
product: D9D16G
revision: 3.8
memory_size: 14,5 GB
PHONE INFO: NONE
BT ADDR: NONE
SW IMEI[0]: 356308-1XXXX-0
SW IMEI[1]: 356308-1XXXX-6
SW IMEI[2]: 867400-XXXX6X
SIMLOCK FLAG: OFF
Starting format;
Formatted;
Done;
Log file saved to: LOG_26_11_2019_21_23_25.txt
Old 11-27-2019, 14:53   #15323 (permalink)
Member: 328688
Thanks Meter: 2,282
p10 was lx1 lite downgrad reapir done
here log
Old 11-29-2019, 01:16   #15324 (permalink)
Member: 2581848
Thanks Meter: 249
unlock alcatel 4052R Done With Fg
Phone detected (@oem14.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008)
Connecting;
Loading;
Init;
Port opened;
Hello Received;
MSM_ID: 0x009600E1
OEM_ID: 0x0042
MODEL_ID: 0x004D
PK_HASH: B451BD3B38D9EDD197CCADF0838D5F8652B8F4642E5BF70411 C8153D1AC40ADBB451BD3B38D9EDD197CCADF0838D5F8652B8 F4642E5BF70411C8153D1AC40ADBB451BD3B38D9EDD197CCAD F0838D5F8652B8F4642E5BF70411C8153D1AC40ADB
BOOT Loaded;
Getting config;
Getting mem info;
Found an eMMC memory size 3.5 GB, target id 8909
IMEI: 01545500251528-
PTH: 04
PTS: X34
PROV_ID: 4052R-2AAQUS3-R
SBTADDR: 88:9E:33:A9:6B:23
SWIFIADDR: 88:9E:337:C6:4A
HS_PN: SAA66A0AA10C
SSN: D7LC03CKEMC00XZ
Work id: 22021984
Done;
Stype: 00000001
SECURITY: XZX3UA40CL00 Size: 0000030D
Backup saved to: 01545500251528-
Unlocking;
SIM_LOCK REMOVED !
Log file saved to: LOG_28_11_2019_18_11_42.txt
Time needed - 00:01:01
thanks fg
http://forum.gsmhosting.com/vbb/f272...*****-2720628/
The Following User Says Thank You to Dzomega For This Useful Post:
Old 12-02-2019, 14:51   #15325 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
ZTE Blade L130 Unlock Done
Searching phone;
Phone detected (@oem87.inf,%usbcomm_dl%;SPRD U2S Diag)
Preparing to sync;
Port opened [COM22];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Starting FDL2;
FDL2 sent;
Starting auth;
OK;
PHONE INFO: NONE
SW IMEI[0]: 861486-04-079594-9
SIMLOCK FLAG: ON
Reading NV;
NV saved to : NV_000000-00-000000-0_861486-04-079594-9_96330000_2_12_2019_15_29_13.spd
Done;
Re-programming;
Sync NV;
Done;
Log file saved to: LOG_2_12_2019_15_29_20.txt
Time needed - 00:02:35
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
Old 12-02-2019, 19:03   #15326 (permalink)
Member: 1728478
Thanks Meter: 22
IMO DASH read unlock code done
Searching phone;
1. Remove battery and usb cable
2. Insert the usb cable in the phone
3. Keep pressed the boot key and insert the battery
Phone detected (SCI USB2Serial)
Preparing to sync;
Port opened [COM48];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Starting FDL2;
FDL2 sent;
Chip type: 7702:0000
Starting auth;
Memory NAND [CS0]: 0098:00B1 - SIZE : 08000000
EFUSE HASH: 0000000000000000000000000000000000000000
EFUSE LOCK STATUS: 000E 000E 000E 000E 000E
Reading phone info;
PHONE INFO: NONE
BT ADDR: EE:1D:1B:C5:0A:30
SW IMEI[0]: 358889-08-316928-8
SW IMEI[1]: 352751-01-077044-0
SW IMEI[2]: 358570-01-010389-3
SW IMEI[3]: 910575-60-140046-8
SIMLOCK FLAG: ON
FIXED NV BASE: 40040000
Reading NV;
NV saved to : NV_000000-00-000000-0_358889-08-316928-8_77020000_2_12_2019_17_11_47.spd
IMEI: 358889-08-316928-8 UNLOCK CODE: 86784503
Code reading finished; Remove battery and cable;
Old 12-03-2019, 13:33   #15327 (permalink)
Member: 2925617
Thanks Meter: 49
Zte l130 network unlock done
Searching phone;
Phone detected (@oem9.inf,%usbcomm_dl%;SPRD U2S Diag)
Preparing to sync;
Port opened [COM34];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Starting FDL2;
FDL2 sent;
Starting auth;
OK;
PHONE INFO: NONE
SW IMEI[0]: 861486-04-116817-9
SIMLOCK FLAG: ON
Reading NV;
NV saved to : NV_000000-00-000000-0_861486-04-116817-9_96330000_3_12_2019_14_26_53.spd
Done;
Re-programming;
Sync NV;
Done;
Log file saved to: LOG_3_12_2019_14_27_00.txt
Time needed - 00:02:24
Old 12-03-2019, 15:27   #15328 (permalink)
mothertelecom's Avatar
Member: 1033714
Sonork: 1640811:mothertelecom
Thanks Meter: 91
vfd 630 unlock done 2019 new security
Searching phone;
(insert the USB cable in the powered off phone
or
insert the USB cable in the powered off phone while keeping volume down pressed)
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM28))
Preparing to start meta mode;
Searching for debug port; (be sure drivers from support were installed)
Meta mode entered;
Baseband Chip: MT6761
Sw version:
Hw Version: alps-mp-p0.mp1-V3.12
Sw version: MOLY.LR12A.R3.MP.V31.3.P34
Hw Version: TK_MD_BASIC_HW
Reading phone info;
IMEI 1: 359956-10-042726-9
IMEI 2: N/A
Loading config;
Done;
Working;
Unlocking;
Time needed - 00:00:28
Log file saved to: LOG_3_12_2019_20_24_07.txt
Old 12-03-2019, 15:33   #15329 (permalink)
Member: 2925617
Thanks Meter: 49
World first hisense f16 network unlock done in seconds
Searching phone;
or
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM4))
Meta mode entered;
Baseband Chip: MT6739,S01
Sw version:
Hw Version: alps-mp-o1.mp1_P18
Sw version: MOLY.LR12A.R2.MP.V48.12.P4
Reading phone info;
IMEI 1: 86XXXXXXXXXXX
IMEI 2: N/A
Loading config;
Done;
Working;
Unlocking;
Time needed - 00:00:37
Log file saved to: LOG_3_12_2019_16_30_23.txt
The Following User Says Thank You to 123frp For This Useful Post:
Old 12-03-2019, 16:23   #15330 (permalink)
Member: 2925617
Thanks Meter: 49
World first mascom s750 read and direct unlock done
Searching phone;
1. Connect the phone powered off with the battery inside to the usb cable
Phone detected (@oem22.inf,%usbcomm_dl%;SPRD U2S Diag)
Preparing to sync;
Port opened [COM7];
Entering diagnostic mode;
Done;
Chip type: 0000:0000
Platform Version: MOCORTM_17C_W18.23.4_P2_Debug
Project Version: pike2_pub
BASE Version: FM_BASE_17C_W18.23.4_P2
HW Version: sc7731e_modem
06-20-2018 11:11:40
Build number: sp7731e_1h20_native-user 8.1.0 OPM2.171019.012 20190130 release-keys
PHONE INFO:
SW IMEI[0]: 35XXXXXXXXXXXXXX4
SW IMEI[1]: 35X-2XXXXXXXXXXXX
SW IMEI[2]: 86XXXXXXXXXXXXXX8
SW IMEI[3]: 86XXXXXXXXXXXXXXX
SIMLOCK FLAG: ON
SIM_LOCK TYPE: 3
IMEI: 35XXXXXXXXXX6-4 UNLOCK CODE: 86110843
Done;
Log file saved to: LOG_3_12_2019_17_19_49.txt
Time needed - 00:00:04
The Following 2 Users Say Thank You to 123frp For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.58301 seconds with 11 queries
