12-15-2019, 12:51 | #15346 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | S.A Vodafone locked ITEL i2160s unlock done by selecting ZTE 522[new] Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port (COM248)) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6261 Sw version: it2160S-DL194-EnFrPo-MZ-Vodacom-20180625 Hw Version: SAGETEL61D_11C_HW Reading phone info; IMEI: 359399-09-xxxxxxx Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:16 Log file saved to: LOG_15_12_2019_13_44_07.txt |
The Following 2 Users Say Thank You to bigjef1 For This Useful Post: |
12-16-2019, 13:18 | #15347 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | Blackview A60 FRP Done! open OTsmart , select OT-5080 phone powered off and connect to usb . Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM22)) Preparing to start flash mode; Preparing to open COM22 Connecting; Downloading DA; Initializing; Rid: fa06ff0f7f947374bdee46f4cd32bbb6 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x484A0190 0x61344741 0x3532A432 0xE9B3460A [SIZE=0x3AC000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x96800000 SIZE: 0x60000000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_16_12_2019_13_46_15.txt |
12-18-2019, 12:32 | #15348 (permalink) |
Freak Poster Join Date: Nov 2017
Member: 2775355 Status: Offline Thanks Meter: 177 | T-Smart FP789L-T Unlock Done Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem173.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM149]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_17B_Release_W19.44.3_Debug Project Version: sharkle_Feature_Phone BASE Version: FM_BASE_17B_Release_W19.44.3 HW Version: sc9820e_modem 10-30-2019 05:27:36 Build number: sp9820e_2h10_oversea-user 4.4.4 KTU84P eng.a1401.20191128.133614 test-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 864934-04-006973-9 SW IMEI[1]: 864934-04-006974-7 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_864934-04-006973-9_00000000_18_12_2019_14_12_21.spd SIM_LOCK TYPE: 3 IMEI: 864934-04-006973-9 UNLOCK CODE: 43740508 Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_18_12_2019_14_12_26.txt Time needed - 00:00:07 |
The Following 3 Users Say Thank You to KSJphoneFastFix For This Useful Post: |
12-19-2019, 09:15 | #15349 (permalink) |
No Life Poster Join Date: Apr 2005 Location: mars
Member: 132881 Status: Offline Thanks Meter: 105 | zte L130 done Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem340.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM23]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 861486-04-******-0 SW IMEI[1]: 867400-02-******-0 SW IMEI[2]: 867400-02-******-8 SW IMEI[3]: 867400-02-******-6 SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_861486-04-138767-0_96330000_18_12_2019_14_26_35.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; Phone unlocked; Remove battery and cable; |
12-19-2019, 09:19 | #15350 (permalink) |
Member: 132881 Status: Offline Thanks Meter: 105 | aspire 5 done again Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem340.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM23]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 860250-04-******-0 SW IMEI[1]: 867400-02-******-0 SW IMEI[2]: 867400-02-******-8 SW IMEI[3]: 867400-02-******-6 SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_860250-04-******-0_98550000_18_12_2019_14_44_32.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; Phone unlocked; Remove battery and cable; |
12-20-2019, 10:18 | #15351 (permalink) |
No Life Poster Join Date: Apr 2008 Location: South Africa
Member: 746586 Status: Offline Thanks Meter: 205 | Vodafone VFD 510 frp reset Software engine version: 1.0.0.10922 Searching phone ... MODEL : QCOM SERIES 51 COMPILED DATE : Mar 14 2019 17:20:00 RELEASE DATE : May 10 2017 19:00:00 FIRMWARE INFO : MPSS.JO.3.0-00291-8909_GEN_PACK-1.97872.1.98558.1 IMEI : 35224909353877-2 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: ZA_MR4_VDF_P809V51V1.0.0B04 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\antho\Downloads\QCOM_SMART_TOOL_v1.0.0.10 922\35224909353877_20_12_2019_10_59_11.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM48 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_20_12_2019_11_02_10.txt Time needed - 00:03:04 |
12-21-2019, 19:42 | #15352 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | Alcatel one touch p310a language portuguese added success Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM Port (COM41)) Preparing to start flash mode; Preparing to open COM41 Connecting; Downloading DA; Initializing; Rid: 6f6023b4c78eba3307550e520c222038 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem63.inf,%mtk_sp_da%;MediaTek DA USB VCOM Port) TRYING TO OPEN COM42; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, FF] HW_STORAGE_EMMC: 0x38000115 0x33424D57 0x9F5B0152 0x4341B361 [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 014135-00-006125-7 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: P310A-2ATBUSK USRDATA INFO: 0x5F880000 SIZE: 0x173000000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:02:12 Log file saved to: LOG_21_12_2019_23_50_27.txt |
12-21-2019, 20:49 | #15353 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Jamaica
Member: 2673816 Status: Offline Thanks Meter: 612 | Alcatel OT-6062W new security unlock done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM45)) Preparing to start flash mode; Preparing to open COM45 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 8ba1f42b50b641a84a752c08d8a25e9f Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6763 [CA01, 01, 6763, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x901D0742 0x9585EDF2 [SIZE=0x748800000] IMEI1 [OTP 0001]: 015126-00- IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 6062W-2BTBUS7 USRDATA INFO: 0x13B800000 SIZE: 0x6088FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:00:00 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:00:05 |
The Following 2 Users Say Thank You to ThePhoneTechDoc For This Useful Post: |
12-24-2019, 09:42 | #15354 (permalink) |
Freak Poster Join Date: May 2014 Location: Africa
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | HUAWEI Y530-U00 unlock With Furious-gold Only Adb mode no need manifacture 1.10 sec Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: HUAWEI MODEL: HUAWEI Y530-U00 ANDROID: v4.3 CPU: QCOM IMEI: 864921024582712 KERNEL: Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Aug 4 14:57:37 IST 2014 Cleaning; Loading files; Done; Reconnecting; Setting access; Done; Exploiting; Android v4.3 TRUE Backing up sec area; Done; Getting sec size; 00118353 bytes Decompressing; Backup saved to: 864921xxxxxxxxxxx Finished; IMEI: 864921024582712 BT ADDR: E0:19:1D:8C:AF:2D MAC ADDR: E0:19:1D:8C:99:AF BOOTLOADER PASS: 4423516311035202 MCC-MNC: [unitel/ao] LOCK [0] HASH: 3D835CD2966CC118CB06EA89A6DF914B LOCK [1] HASH: 51675D5A8A4B3508FDA4747B6AB152D3 LOCK [2] HASH: 24C72D6256FD8A807B653DECD62D783F LOCK [3] HASH: BE5B202DFA8D306AB531D59DA4B2EBC3 LOCK [4] HASH: BE5B202DFA8D306AB531D59DA4B2EBC3 LOCK [5] HASH: CD6BA6FBC39D278AD68FC673E7CAE7C7 LOCK [6] HASH: 3F2DE1CAEC5E5749FCC1920DF8E189F7 LOCK [7] HASH: BE5B202DFA8D306AB531D59DA4B2EBC3 LOCK [8] HASH: BE5B202DFA8D306AB531D59DA4B2EBC3 LOCK [9] HASH: BE5B202DFA8D306AB531D59DA4B2EBC3 Starting; Done; Unlocking in progress; Calc 0000 ; Calc 0001 ; SIM_LOCK REMOVED ! Rebooting; |
12-27-2019, 09:15 | #15355 (permalink) |
Member: 731353 Status: Offline Thanks Meter: 254 | mobicel beam forever locked done Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem20.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM9]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_17C_W18.23.4_P22_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P22 HW Version: sc7731e_modem 09-17-2019 20:33:29 Build number: k130-user 8.1.0 OPM2.171019.012 1569730015 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 357809-10-010622-1 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_357809-10-010622-1_00000000_27_12_2019_00_12_11.spd SIM_LOCK TYPE: 2 IMEI: 357809-10-010622-1 UNLOCK CODE: 11483414 Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_27_12_2019_00_12_15.txt Time needed - 00:00:07 |
12-27-2019, 13:33 | #15356 (permalink) |
Member: 132881 Status: Offline Thanks Meter: 105 | Vodacom 3g vibe unlocked Searching phone; Phone detected (@oem227.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM1823); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V62.P16 Hw Version: SR72_W_KK_HSPA_HW Reading phone info; IMEI: 358030-10-******-8 Reading simlock info; Locked to: 655-01 code_cat_n: 12345678 enabled: yes tries: 224 code_cat_ns: 56781234 enabled: no tries: 255 code_cat_sp: 11112222 enabled: no tries: 255 code_cat_c: 33334444 enabled: no tries: 255 code_cat_sim: 55556666 enabled: no tries: 255 code_cat_ns_sp: 77778888 enabled: no tries: 255 code_cat_sim_c: 99990000 enabled: no tries: 255 Time needed - 00:00:56 |
12-28-2019, 12:57 | #15357 (permalink) |
No Life Poster Join Date: May 2009 Location: Bangladesh/USA/UK Age: 39
Member: 1033714 Status: Offline Sonork: 1640811:mothertelecom Thanks Meter: 91 | unlock done mobiwire nokosi mtk code reader select AQUILA https://www.4shared.com/get/luDFPJiZ...iver_v108.html Searching phone; Phone detected (@oem26.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM30); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V62.P14 Hw Version: SR72_W_KK_HSPA_HW Reading phone info; IMEI: 359473-09-006758-4 Reading simlock info; Locked to: 234-30 code_cat_n: 12345678 enabled: yes tries: 4 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:04:01 Log file saved to: LOG_28_12_2019_17_43_06.txt |
The Following User Says Thank You to mothertelecom For This Useful Post: |
12-28-2019, 16:51 | #15358 (permalink) |
Member: 2673816 Status: Offline Thanks Meter: 612 | Alcatel 5041C 2019 security unlock done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM45)) Preparing to start flash mode; Preparing to open COM45 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: cb57556f54897bfc5999b4f3407862db Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0x230D0342 0x5BA57B07 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 015174-00- IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5041C-2ARKUS1 USRDATA INFO: 0x139000000 SIZE: 0x2672FBE00 Searching data; File not found; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 |
12-29-2019, 09:49 | #15359 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | Alcatel 4034g unlock success Code: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM_V1632 (Android) (COM20)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM20 Connecting; Downloading DA; Initializing; Rid: 6662c18848bf06b0ba3faa34b57088ab Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x45000170 0x44453848 0x2C300134 0x1965E18C [SIZE=0x1C8C00000] IMEI1 [OTP 0001]: 015347-00-021xxx-x IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4034G-2AB7AUA USRDATA INFO: 0x82800000 SIZE: 0x60000000 Searching data; Locked to [SIM1]: 505-01 code_cat_n: 1965238892333263 enabled: no tries: 10 code_cat_ns: 4027745186053000 enabled: no tries: 98 code_cat_sp: 5930368598966105 enabled: no tries: 10 code_cat_c: 8161262885729405 enabled: no tries: 10 code_cat_sim: 9092273207604644 enabled: no tries: 10 code_cat_ns_sp: 9161267785375210 enabled: no tries: 5 code_cat_sim_c: 9429491358447390 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:10 Log file saved to: LOG_29_12_2019_16_40_40.txt |
The Following User Says Thank You to buffer2k11 For This Useful Post: |
