11-25-2009, 14:48 | #1741 (permalink) |
Temporary banned !! Join Date: Jun 2009
Member: 1048290 Status: Offline Thanks Meter: 49 | Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037220582 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_18.46.54_25.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:35 |
11-25-2009, 14:54 | #1742 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Al-Madina Communication Age: 45
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081036907304 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_18.53.37_25.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:31 |
11-25-2009, 15:18 | #1743 (permalink) |
The Following User Says Thank You to alis For This Useful Post: |
11-25-2009, 15:20 | #1744 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037237727 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_19.20.03_25.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:53 |
11-25-2009, 16:42 | #1745 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | Time to post logs from three modems Software engine version: 1.0.0.3260 Searching phone ... MODEL : MF MODEM SERIES COMPILED DATE : Mar 12 2009 17:42:00 RELEASE DATE : Mar 5 2009 20:30:00 FIRMWARE INFO : MF626V1.0.0B06 IMEI : 35536403939115-7 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00AD:0036 MEMORY NAME : HYNIX_HYCOSEHOMF3P MEMORY INFO : 0200:0020:081F ENTERING SECURE MODE; ENTERED; GETTING CODE HASH; GETTING SIGN; GETTING LOCK; CALCULATING; UNLOCKED ! NOW RECONNECT MODEM TO USB PORT ! Time needed - 00:00:01 Software engine version: 1.0.0.3260 Searching phone ... MODEL : MF MODEM SERIES COMPILED DATE : Mar 12 2009 17:42:00 RELEASE DATE : Mar 5 2009 20:30:00 FIRMWARE INFO : MF626V1.0.0B06 IMEI : 35703703527499-3 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00AD:0036 MEMORY NAME : HYNIX_HYCOSEHOMF3P MEMORY INFO : 0200:0020:081F ENTERING SECURE MODE; ENTERED; GETTING CODE HASH; GETTING SIGN; GETTING LOCK; CALCULATING; UNLOCKED ! NOW RECONNECT MODEM TO USB PORT ! Time needed - 00:00:01 Two ZTE MF626 Software engine version: 1.0.0.3260 Searching phone ... MODEL : QCOM SERIES 7 COMPILED DATE : Jun 10 2009 11:51:00 RELEASE DATE : Jun 10 2009 11:51:00 FIRMWARE INFO : 11.806.02.02.18 IMEI : 35220103008043-4 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 0000:0000 MEMORY NAME : MEMORY INFO : 0000:0000:0000 UNLOCK INFO IMEI: 352201030080434 NCK: 62585436 UNLOCK STATUS: [OK] OK LOCK STATUS: [OK] OK Time needed - 00:00:01 Huawei E1612 Regards Luskao |
11-25-2009, 16:58 | #1746 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 341539 Status: Offline Thanks Meter: 9 | Attach USB cable now ... Phone detected ! USB Port opened ! RamLoader download success; Config done ! Authorising; Authorisation passed; Getting memory info; Memory: EC000000B1 Getting unlock data; Checking unlock data; Calculating; IMEI: 35573703139199600 Codes: 5499483202378860 5499483202378860 1320183142184908 Enter codes using 2945#*71001# Restarting; Time needed - 00:00:24 |
11-25-2009, 17:05 | #1747 (permalink) |
Member: 341539 Status: Offline Thanks Meter: 9 | GW300 BOUYGUE TELECOM UNLOCK OK !!! Attach USB cable now ... Phone detected ! USB Port opened ! RamLoader download success; Config done ! Authorising; Authorisation passed; Getting memory info; Memory: EC000000B1 Getting unlock data; Checking unlock data; Calculating; IMEI: 35573703075573800 Codes: 1193678892107574 1193678892107574 0889930844274052 Enter codes using 2945#*71001# Restarting; Time needed - 00:00:25 |
11-26-2009, 07:12 | #1749 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | blackberry 9630 unlock done. hello friends, see this report. thanks furious team. Searching for usb device ... Reading info ... IMEI: 3594..021..172.. Calculating ... MEP: MEP-15326-002 MEP2 CODE: 34246595 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) BR, themobileshop 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:14 |
11-26-2009, 07:35 | #1750 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 877161 Status: Offline Thanks Meter: 48 | Successfully Unlocked KU990 Software engine version: 1.0.0.3260 Searching phone ... MODEL : KU990 COMPILED DATE : Dec 14 2007 16:42:00 RELEASE DATE : Dec 4 2007 17:00:00 FIRMWARE INFO : KU990-MSM6280-V10f-DEC-04-2007-XX IMEI : 3582030174776xxx BLUETOOTH ADDR : 37 F6 D2 75 1E 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:06 TNX TO Furious TeaM |
11-26-2009, 07:56 | #1751 (permalink) |
Freak Poster Join Date: Mar 2008 Location: I Don,t Know Age: 38
Member: 718939 Status: Offline Thanks Meter: 90 | AgaIN MY212x UnLOcK dOnE Press power on shortly ... Starting communication ... MCU ID: 14C0010B168F54C10000000000000220 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2B7E:3300 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my212X Hash: 00001867 Algo: 05 Firmware: LB5,PF: 240507 1451 Imei: 352492012332386 Phone code: 0000 Prod. code: 252955903 Id calculation done; CODES: NET LO CODE: 3363520170 NET HI CODE: 2293972586 Done ! Time needed - 00:02:09 |
11-26-2009, 08:57 | #1752 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037182972 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_12.54.50_26.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:15 |
11-26-2009, 09:46 | #1753 (permalink) |
Member: 718939 Status: Offline Thanks Meter: 90 | ZONG A316G+ unlock done 30 set . Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_13.41.57_26.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:57 |
11-26-2009, 10:48 | #1754 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Muzaffarabad
Member: 695543 Status: Offline Sonork: 100.1602536 Thanks Meter: 149 | ufone new unlock done thanx for this support ] Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039299477 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_20.33.49_25.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:17 |
11-26-2009, 10:50 | #1755 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 788782 Status: Offline Sonork: 100.1610033 Thanks Meter: 1,035 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038627892 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_14.49.19_26.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:14 |
