Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 11-25-2009, 14:48   #1741 (permalink)
Temporary banned !!
Member: 1048290
Thanks Meter: 49
Connect phone powered on !
Start auth !
SW Ver: P1.2PU03V01.01
Imei: 353081037220582
Getting config data;
Done;
Press power on !
Starting communication ...
Platform: E-Gold Voice ...
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Flash ID(0): 00BF:234B
Reading ...
Saved: HUAWEI_18.46.54_25.11.2009_PARTIAL.bin
Erasing ...
Writing ...
Unlocked ! Remove battery and put back !
Time needed - 00:00:35
Old 11-25-2009, 14:54   #1742 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 874
Start auth !
Imei: 353081036907304
Done;
Press power on !
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Reading ...
Saved: HUAWEI_18.53.37_25.11.2009_PARTIAL.bin
Erasing ...
Writing ...
Time needed - 00:00:31
Old 11-25-2009, 15:18   #1743 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 874
Start auth !
Done;
Press power on !
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Reading ...
Erasing ...
Writing ...
The Following User Says Thank You to alis For This Useful Post:
Old 11-25-2009, 15:20   #1744 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 874
Start auth !
Imei: 353081037237727
Done;
Press power on !
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Reading ...
Saved: HUAWEI_19.20.03_25.11.2009_PARTIAL.bin
Erasing ...
Writing ...
Time needed - 00:00:53
Old 11-25-2009, 16:42   #1745 (permalink)
Member: 81703
Thanks Meter: 1,332
Time to post logs from three modems
Software engine version: 1.0.0.3260
Searching phone ...
MODEL : MF MODEM SERIES
COMPILED DATE : Mar 12 2009 17:42:00
RELEASE DATE : Mar 5 2009 20:30:00
FIRMWARE INFO : MF626V1.0.0B06
IMEI : 35536403939115-7
BLUETOOTH ADDR : 00 00 00 00 00 00
MEMORY ID : 00AD:0036
MEMORY NAME : HYNIX_HYCOSEHOMF3P
MEMORY INFO : 0200:0020:081F
ENTERING SECURE MODE;
ENTERED;
GETTING CODE HASH;
GETTING SIGN;
GETTING LOCK;
CALCULATING;
UNLOCKED !
NOW RECONNECT MODEM TO USB PORT !
Time needed - 00:00:01
Searching phone ...
IMEI : 35703703527499-3
ENTERED;
GETTING CODE HASH;
GETTING SIGN;
GETTING LOCK;
CALCULATING;
UNLOCKED !
Two ZTE MF626
Searching phone ...
MODEL : QCOM SERIES 7
COMPILED DATE : Jun 10 2009 11:51:00
RELEASE DATE : Jun 10 2009 11:51:00
FIRMWARE INFO : 11.806.02.02.18
IMEI : 35220103008043-4
MEMORY ID : 0000:0000
MEMORY NAME :
MEMORY INFO : 0000:0000:0000
UNLOCK INFO
IMEI: 352201030080434
NCK: 62585436
UNLOCK STATUS: [OK] OK
Huawei E1612
Regards
Luskao
Old 11-25-2009, 16:58   #1746 (permalink)
Member: 341539
Thanks Meter: 9
Attach USB cable now ...
Phone detected !
USB Port opened !
RamLoader download success;
Config done !
Authorising;
Authorisation passed;
Getting memory info;
Memory: EC000000B1
Getting unlock data;
Checking unlock data;
Calculating;
IMEI: 35573703139199600
Codes:
5499483202378860
5499483202378860
1320183142184908
Enter codes using 2945#*71001#
Restarting;
Time needed - 00:00:24
Old 11-25-2009, 17:05   #1747 (permalink)
Member: 341539
Thanks Meter: 9
GW300 BOUYGUE TELECOM UNLOCK OK !!!
Phone detected !
USB Port opened !
Config done !
Authorising;
Memory: EC000000B1
Calculating;
IMEI: 35573703075573800
Codes:
1193678892107574
1193678892107574
0889930844274052
Restarting;
Time needed - 00:00:25
Old 11-25-2009, 22:44   #1748 (permalink)
Member: 877502
Sonork: 100.1593373
Thanks Meter: 3
S211 unlocked done
S211 UNLOCKED DONE..........
Old 11-26-2009, 07:12   #1749 (permalink)
Member: 977491
Thanks Meter: 82
blackberry 9630 unlock done.
hello friends, see this report.
thanks furious team.
Searching for usb device ...
Reading info ...
IMEI: 3594..021..172..
Calculating ...
MEP: MEP-15326-002
MEP2 CODE: 34246595
How to enter codes in BlackBerry
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (where needed)
7. Type MEPPD or MEPD (you will not be able to see the typed info)
BR, themobileshop
8. Enter MEP2 or MEPP2
9. Now it will say enter network mep code
Done !
Time needed - 00:00:14
Old 11-26-2009, 07:35   #1750 (permalink)
faruk_gsm's Avatar
Member: 877161
Thanks Meter: 48
Successfully Unlocked KU990
Searching phone ...
MODEL : KU990
COMPILED DATE : Dec 14 2007 16:42:00
RELEASE DATE : Dec 4 2007 17:00:00
FIRMWARE INFO : KU990-MSM6280-V10f-DEC-04-2007-XX
IMEI : 3582030174776xxx
BLUETOOTH ADDR : 37 F6 D2 75 1E 00
MEMORY ID : 0098:00CA
MEMORY NAME : toshiba_tya000bc00bogg
MEMORY INFO : 0800:0040:06C3
INIT NAND ROUTINES;
NAND INIT MADE;
READING SECURITY AREA;
READING SEC DATA;
SECURITY TESTS PASSED !
UNLOCKING PASSED !
LOCK HASH WRITTEN;
UNLOCKED !
Time needed - 00:00:06
TNX TO Furious TeaM
Old 11-26-2009, 07:56   #1751 (permalink)
HAMMZA_MOBILES's Avatar
Member: 718939
Thanks Meter: 90
AgaIN MY212x UnLOcK dOnE
Press power on shortly ...
MCU ID: 14C0010B168F54C10000000000000220
ROM HASH: 62FB6505AC902905678D99DD748702EE
ROM VER: 05.02
Authorising ...
Sending preloader ...
Exploiting ...
Preloader started ...
Sending applet ...
Loader version: FuriouSTeaM GSM DEVELOPEMENT
Changing baudrate ...
Flash ID(0): 0001:2B7E:3300
Reading unbinded data;
Unbinded flash data done;
Unbinded eeprom data done;
Plain datadone;
Model: my212X
Hash: 00001867
Algo: 05
Firmware: LB5,PF: 240507 1451
Imei: 352492012332386
Phone code: 0000
Prod. code: 252955903
Id calculation done;
CODES:
NET LO CODE: 3363520170
NET HI CODE: 2293972586
Done !
Time needed - 00:02:09
Old 11-26-2009, 08:57   #1752 (permalink)
shahid41's Avatar
Member: 623703
Sonork: 100.1614330
Thanks Meter: 439
Start auth !
Imei: 353081037182972
Done;
Press power on !
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Reading ...
Saved: HUAWEI_12.54.50_26.11.2009_PARTIAL.bin
Erasing ...
Writing ...
Time needed - 00:01:15
Old 11-26-2009, 09:46   #1753 (permalink)
Member: 718939
Thanks Meter: 90
ZONG A316G+ unlock done 30 set .
Press power on !
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Flash ID(0): 00EC:0106
Reading ...
Saved: ZTE_13.41.57_26.11.2009_PARTIAL.bin
Erasing ...
Writing ...
Time needed - 00:00:57
Old 11-26-2009, 10:48   #1754 (permalink)
Member: 695543
Sonork: 100.1602536
Thanks Meter: 149
ufone new unlock done
thanx for this support ]
Start auth !
SW Ver: P1.2PU01V01.01
Imei: 353081039299477
Done;
Press power on !
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Flash ID(0): 0001:22C4
Reading ...
Saved: HUAWEI_20.33.49_25.11.2009_PARTIAL.bin
Erasing ...
Writing ...
Time needed - 00:01:17
Old 11-26-2009, 10:50   #1755 (permalink)
MTK-BOX's Avatar
Member: 788782
Sonork: 100.1610033
Thanks Meter: 1,035
Start auth !
Imei: 353081038627892
Done;
Press power on !
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Reading ...
Saved: HUAWEI_14.49.19_26.11.2009_PARTIAL.bin
Erasing ...
Writing ...
Time needed - 00:01:14
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.34645 seconds with 10 queries
