01-01-2011, 08:06 | #7336 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | zong a316g unlock done Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 Imei: 354354030236569 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_354354030236569_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09_09.27.00_01.01.2011_PARTIA L.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:10 |
01-01-2011, 10:59 | #7337 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | VODAFONE V710 UNLOCK DONE Searching phone ... MODEL : D618 V1.0 Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Init nand made; Reading; Imei : 35197901619076-1 Unlock code: 1671837192401841 Done ! Time needed - 00:00:48 |
01-01-2011, 11:01 | #7338 (permalink) |
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | ZTE F107...... Software engine version: 1.0.0.5901 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Aug 15 2009 23:23:00 RELEASE DATE : Jun 24 2009 19:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B03-S IMEI : 35674003084462-6 BLUETOOTH ADDR : 8C 8E FE 12 25 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:47 |
01-01-2011, 11:34 | #7339 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<Succsessfully unlock lg gw300 with furious-gold>>>> Here is log: Attach USB cable now ... Phone detected ! USB Port opened ! RamLoader download success; Config done ! Authorising; Authorisation passed; Getting memory info; Memory: EC000000B1 Getting unlock data; Checking unlock data; Calculating; IMEI: 35296xxxxxxxxxxxxx Codes: 4393402117050757 4393402117050757 3429381569524402 Enter codes using 2945#*71001# Restarting; Time needed - 00:00:29 Br: Harkishan |
The Following User Says Thank You to Harkishan singh For This Useful Post: |
01-01-2011, 12:05 | #7340 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | ufone g1157 unlock ok Software engine version: 1.0.0.5412 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 3581450324240?? Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_3581450324240??_REL_P1.2PU04V01.04_15.50.28 _01.01.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:29 br shabir97 |
01-02-2011, 09:36 | #7341 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | ZTE F102 Unlocked in 6 secs Software engine version: 1.0.0.5949 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003266101-0 BLUETOOTH ADDR : 45 44 44 4A 15 D0 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 00000000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:06 |
01-02-2011, 16:43 | #7342 (permalink) |
No Life Poster Join Date: Sep 2007 Location: ATF Earth Age: 36
Member: 598395 Status: Offline Thanks Meter: 664 | (ZONG) Z100 Restart Problem Solve with Furious-Gold Software engine version: 1.0.0.5407 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 36 04 97 D6 09 17 0E Flash ID(0): 00C2:22A7 PARTIAL: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 RANGE(S): 00000000:003E0000 00000000:003E0000 Restored ! Remove battery and put back ! Time needed - 00:07:30 |
01-02-2011, 17:29 | #7343 (permalink) |
Member: 598395 Status: Offline Thanks Meter: 664 | (ZONG) Z100 UNLOCKED with Furious-Gold Software engine version: 1.0.0.5345 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041725086 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 36 04 97 D6 09 17 0E Flash ID(0): 00C2:22A7 Saved: ZTE_352865041725086_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_21.26.59_02.01.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:02:00 |
01-03-2011, 07:37 | #7344 (permalink) |
No Life Poster Join Date: May 2006 Location: Gojra
Member: 279362 Status: Offline Sonork: 100.1594141 Thanks Meter: 500 | zong a316 unlock done Software engine version: 1.0.0.5368 Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 Imei: 354354031140018 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_354354031140018_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10_11.33.25_03.01.2011_PARTIA L.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 |
01-03-2011, 08:44 | #7346 (permalink) |
Registered User Join Date: Jun 2010 Location: GSM POWERTEAM
Member: 1330543 Status: Offline Thanks Meter: 177 | f107 successful unlock in 13second Software engine version: 1.0.0.5949 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Mar 12 2010 17:58:00 RELEASE DATE : Dec 8 2009 23:00:00 FIRMWARE INFO : H3G_GB_P607C5V1.0.0B010-S IMEI : 35804803041808-8 BLUETOOTH ADDR : 1B 75 73 1A 18 08 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:13 great work by Fg team |
01-03-2011, 12:06 | #7348 (permalink) |
Freak Poster Join Date: Feb 2008 Location: royal mobiles kotla
Member: 714116 Status: Offline Thanks Meter: 48 | z100 unlock done Software engine version: 1.0.0.5368 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041641812 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 9B 31 04 97 A4 07 A1 08 Flash ID(0): 00C2:22A7 Saved: ZTE_352865041641812_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_02.57.43_03.01.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:53 |
01-03-2011, 12:07 | #7349 (permalink) |
Member: 714116 Status: Offline Thanks Meter: 48 | z100 unlock done Software engine version: 1.0.0.5368 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042654962 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 5B 3A 44 97 E5 04 0A 0A Flash ID(0): 00C2:22A7 Saved: ZTE_352865042654962_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_03.06.10_03.01.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:02:17 |
01-03-2011, 12:09 | #7350 (permalink) |
Member: 714116 Status: Offline Thanks Meter: 48 | z100 unlock done Software engine version: 1.0.0.5368 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042656835 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 DB 31 C4 96 E9 00 10 0C Flash ID(0): 00C2:22A7 Saved: ZTE_352865042656835_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_03.08.45_03.01.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:50 |
