01-26-2011, 12:25 | #7576 (permalink) | |
Crazy Poster Join Date: Oct 2010
Member: 1431334 Status: Offline Thanks Meter: 14 | siemens S75 Unlock done Quote:
01-26-2011, 13:25 | #7577 (permalink) |
No Life Poster Join Date: May 2005 Age: 44
Member: 146630 Status: Offline Thanks Meter: 21 | Blackberry 9800 unlock done Thanks Furious Team Searching for usb device ... Reading info ... IMEI: 353489048916991 Calculating ... MEP LOCK: MEP-07723-007 MEP1 [SIM]: 3093379044640290 MEP2 [NETWORK]: 3315196595880509 MEP3 [NETWORK SUBSET]: 7150338385496282 MEP4 [SERVICE PROVIDER]: 3384937002050289 MEP5 [CORPORATE]: 3663774286301750 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:41 |
01-26-2011, 13:42 | #7578 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | z100 hang done Software engine version: 1.0.0.5335 Press power on ! Starting communication ...Software engine version: 1.0.0.5335 Press power on ! Starting communication ... Platform: E-Gold Voice ...Software engine version: 1.0.0.5335 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 34 44 97 1D 06 04 05 Flash ID(0): 00C2:22A7 PARTIAL: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 RANGE(S): 00000000:003E0000 00000000:003E0000 Restored ! Remove battery and put back ! Time needed - 00:06:55 Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 34 44 97 1D 06 04 05 Flash ID(0): 00C2:22A7 PARTIAL: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 RANGE(S): 00000000:003E0000 00000000:003E0000 Restored ! Remove battery and put back ! Time needed - 00:06:55 Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 34 44 97 1D 06 04 05 Flash ID(0): 00C2:22A7 PARTIAL: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 RANGE(S): 00000000:003E0000 00000000:003E0000 Restored ! Remove battery and put back ! Time needed - 00:06:55 |
01-26-2011, 14:07 | #7579 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock G2158 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.03 Imei: 358892032436584 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Reading ... Saved: HUAWEI_358892032436584_REL_P1.1PU01V01.03_16.42.44 _26.01.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:33 |
01-27-2011, 07:39 | #7580 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | Zong Z100 Unlock done Software engine version: 1.0.0.5455 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040105397 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 30 84 91 59 02 0E 05 Flash ID(0): 00C2:22A7 Saved: ZTE_352865040105397_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_19.01.48_26.01.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:56 |
01-27-2011, 07:39 | #7581 (permalink) |
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | G1157 unlock done. Software engine version: 1.0.0.5455 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 358145032458920 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_358145032458920_REL_P1.2PU04V01.04_11.19.07 _27.01.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:33 |
01-27-2011, 07:40 | #7582 (permalink) |
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | Another G1157 Unlock done Software engine version: 1.0.0.5455 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039162295 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_356334039162295_REL_P1.2PU04V01.04_11.35.50 _27.01.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:32 |
01-27-2011, 09:37 | #7583 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | ufone t156 AYZ SUCCESSFULL UNLOCKED.......... ufone t156 AYZ SUCCESSFULL UNLOCKED.......... Software engine version: 1.0.0.5444 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 35814603205???? Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_35814603205????_P1.2PU01V01.02_13.17.24_27. 01.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:46 BR:. SHABIR97 |
01-27-2011, 10:49 | #7584 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 877161 Status: Offline Thanks Meter: 48 | FuriousGold Successfully Unlocked SFR 112 Connect phone powered on ! Start auth ! SW Ver: EFSPI-FR-SFR-P108E10FM(S)V1.0.0B04 Imei: 35389xxxxxxxxxx Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0103 Reading ... Saved: ZTE_353894030481765_EFSPI-FR-SFR-P108E10FM(S)V1.0.0B04_15.15.34_27.01.2011_PARTIAL. bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:55 |
01-27-2011, 15:41 | #7585 (permalink) |
No Life Poster Join Date: Aug 2010
Member: 1357721 Status: Offline Thanks Meter: 4,294,967,292 | Huawei Z100 SUCCESSFULL UNLOCKED Done.......... Software engine version: 1.0.0.5352 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041297490 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 39 04 98 E1 04 89 09 Flash ID(0): 00C2:22A7 Saved: ZTE_352865041297490_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_16.16.09_27.01.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:46 |
01-27-2011, 16:14 | #7586 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pakistan Age: 36
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Software engine version: 1.0.0.5419 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146032015900 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_358146032015900_P1.2PU01V01.02_13.32.25_16. 01.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:55 B,R. |
01-27-2011, 16:15 | #7587 (permalink) |
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Software engine version: 1.0.0.5419 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865043433242 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 30 84 97 C5 05 0E 09 Flash ID(0): 00C2:22A7 Saved: ZTE_352865043433242_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_12.55.19_21.01.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:53 B,R. |
The Following User Says Thank You to ch mobiles For This Useful Post: |
01-27-2011, 16:16 | #7588 (permalink) |
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | i tried 6 times with huawei g2158.set dead restore dead resotre..... Finally set unlocked successfully Software engine version: 1.0.0.5419 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 358892033458926 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_358892033458926_REL_P1.1PU01V01.06_19.46.22 _27.01.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:16 B,R. |
01-27-2011, 16:20 | #7589 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Huawei Vodafone 716: Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Memory Info: 00EC:0036 Requesting random data ... Sending data ... Authorisation started ... Authorisation passed ... Unlock Code: 7777777777777777 Done ! Time needed - 00:00:11 |
01-28-2011, 07:39 | #7590 (permalink) |
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock G2158 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 358892033558790 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_358892033558790_REL_P1.1PU01V01.06_11.05.44 _28.01.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:48 |
