07-30-2011, 11:01 | #9151 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Software engine version: 1.0.0.6761 Searching phone ... MODEL : CU920 COMPILED DATE : Dec 12 2008 14:36:00 RELEASE DATE : Nov 10 2008 23:00:00 FIRMWARE INFO : CU920-MSM4090201D-V10s-DEC-12-2008-ATT-US IMEI : 01148900063781-1 BLUETOOTH ADDR : 1C 29 37 A9 22 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:09 |
07-30-2011, 12:34 | #9152 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | Time needed - 00:00:43Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865043187756 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 32 84 97 41 04 87 02 Flash ID(0): 00C2:22A7 Saved: ZTE_352865043187756_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_12.22.46_25.07.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:51 |
07-30-2011, 12:46 | #9153 (permalink) |
07-30-2011, 12:47 | #9154 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003200263-7 BLUETOOTH ADDR : B9 6F 6B 1A 18 08 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:12??///Searching for usb device ... Reading info ... IMEI: 355167022504805 Calculating ... MEP LOCK: MEP-04104-007 MEP1 [SIM]: 9512594597009685 MEP2 [NETWORK]: 6041347521543798 MEP3 [NETWORK SUBSET]: 0304041018702914 MEP4 [SERVICE PROVIDER]: 8294941952967143 MEP5 [CORPORATE]: 4777955414585549 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code |
07-30-2011, 17:01 | #9155 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Muzaffarabad
Member: 695543 Status: Offline Sonork: 100.1602536 Thanks Meter: 149 | ZTE F107 unlock done Software engine version: 1.0.0.5565 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jun 17 2010 15:58:00 RELEASE DATE : Dec 8 2009 23:00:00 FIRMWARE INFO : H3G_GB_P607C5V1.0.0B11-S IMEI : 35804803214278-5 BLUETOOTH ADDR : 5C 2D 6C 37 F5 98 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:09 |
07-31-2011, 16:34 | #9156 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865043187756 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 32 84 97 41 04 87 02 Flash ID(0): 00C2:22A7 Saved: ZTE_352865043187756_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_12.22.46_25.07.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:51 |
07-31-2011, 16:35 | #9157 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | 2Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031705733 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_358146031705733_P1.2PU01V01.02_14.34.50_26. 07.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:0Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865043187756 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 32 84 97 41 04 87 02 Flash ID(0): 00C2:22A7 Saved: ZTE_352865043187756_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_15.56.25_26.07.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:54Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031677585 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_358146031677585_P1.2PU01V01.02_13.34.11_31. 07.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:46 |
07-31-2011, 16:36 | #9158 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Press power on shortly ... Starting communication ... MCU ID: 13300113A7A346C10000000000008A60 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411Cv Hash: 00002291 Algo: 05 Firmware: EVN,SE: 230707 1109 Imei: 356540013465740 Phone code: 0000 Prod. code: 252961761 Id calculation done; CODES: NET LO CODE: 0698832977 NET HI CODE: 1768381329 DIRECT UNLOCK: OK Done ! Time needed - 00:02:59Press Power On shortly ! LatencyTimer: 10ms Phone Detected ! Chip ID: 71000301 FLASH CID: 17 PHONE COLOR: BROWN Loading ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J OTP CID: 17 IMEI: 35511600581976-3 Settings made ... Bypassing restriction ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Settings Done ! Certificate sent ... Boot info: HACK3R2K.COM GSM DEVELOPEMENT Flash 1: 0089:880D Flash 2: 0089:8810 Firmware version: U8120_v105 Working. Please wait ... Operation finished ! Time needed - 00:00:32Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031705733 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 |
08-01-2011, 12:40 | #9160 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | earching for usb device ... Reading info ... IMEI: 354580014213477 Calculating ... MEP LOCK: MEP-04104-006 MEP1 [SIM]: 6870555622888191 MEP2 [NETWORK]: 9031908775211034 MEP3 [NETWORK SUBSET]: 5128996627209280 MEP4 [SERVICE PROVIDER]: 3794425287703006 MEP5 [CORPORATE]: 8255899078291181 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:56 |
08-01-2011, 13:43 | #9161 (permalink) |
No Life Poster Join Date: Mar 2006 Location: morroco
Member: 245026 Status: Offline Thanks Meter: 382 | Zte F950 Software engine version: 1.0.0.6739 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Mar 10 2010 15:55:00 RELEASE DATE : Jan 17 2010 21:00:00 FIRMWARE INFO : YOG_ES_P608A3V1.0.0B17-S IMEI : 35************-* BLUETOOTH ADDR : A9 17 E3 ED 26 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 214 MNC: 4) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:14 |
08-01-2011, 13:57 | #9162 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | LG KS360 Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 44787299 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:15 |
08-01-2011, 14:39 | #9163 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 42
Member: 101262 Status: Offline Thanks Meter: 8 | Gt405 GT405 Pack 9 and CA101 cable(gt505 usb driver) Searching phone; [*] Phone must be powered on;[*] Phone display must be lighted;[*] If USB is beeing used then MODEM port must be selected; Phone Found; MODEL: GT405AT-01-V10f-214-03-JUL-23-2010+0 IMEI: 3598290321xxxx Preparing to connect server; Checking server authorisation; Authentificated OK ! |
08-01-2011, 14:41 | #9164 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NICE MOBILES Age: 35
Member: 1293519 Status: Offline Sonork: 100.1596500 Thanks Meter: 169 | G1157 unlock don by FG Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: xxxxxxxxxxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_xxxxxxxxxxxxxxx_14.42.27 _14.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:25 |
The Following User Says Thank You to dilshad_noori For This Useful Post: |
08-01-2011, 15:03 | #9165 (permalink) |
Registered User Join Date: Sep 2008 Location: HardWare+Software & Unlocking
Member: 865598 Status: Offline Sonork: 100.1609492 Thanks Meter: 465 | unloke done Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: xxxxxxxxxxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_xxxxxxxxxxxxxxx_14.42.27 _14.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:25 |
