05-31-2012, 21:10 | #10727 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Software engine version: 1.0.0.7893 Searching phone ... MODEL : QCOM SERIES 18 COMPILED DATE : Aug 20 2010 13:43:00 RELEASE DATE : May 5 2010 02:00:00 FIRMWARE INFO : M76XX-SDCBALUM-63805036 IMEI : 35364104026412-3 BLUETOOTH ADDR : F8 7B 7A 34 38 79 LOADING DATA; DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; NETWORK: 50601003 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:42 |
06-01-2012, 09:29 | #10728 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.7886 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 22 2010 15:33:00 RELEASE DATE : Jun 24 2010 21:00:00 FIRMWARE INFO : BL_RU_P607C3V1.0.0B06-S IMEI : 35541604074084-6 BLUETOOTH ADDR : 00 00 00 00 00 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 250 MNC: 99) LOCKED NET 6 (MCC: 255 MNC: 2) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:10 |
06-01-2012, 09:29 | #10729 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 1B 30 C4 99 16 02 82 0A Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:04:08 |
06-02-2012, 12:19 | #10730 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | MOTO MB501 sucessfully unlocked. Software engine version: 1.0.0.7888 Searching phone ... MODEL : QCOM SERIES 18 COMPILED DATE : Aug 20 2010 13:43:00 RELEASE DATE : May 5 2010 02:00:00 FIRMWARE INFO : M76XX-SDCBALUM-63805036 IMEI : 3583380304***** BLUETOOTH ADDR : A4 ED 4E 32 B8 CE LOADING DATA; DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; NETWORK: 42256613 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. |
06-02-2012, 16:29 | #10731 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Online Age: 18
Member: 368697 Status: Offline Thanks Meter: 223 | palm pre sucessfully unlocked. Software engine version: 1.0.0.7893 Searching phone ... MODEL : QCOM SERIES 15 COMPILED DATE : May 12 2010 16:30:00 RELEASE DATE : May 12 2010 16:13:00 FIRMWARE INFO : CU0.5.42(257) IMEI : 35813902071833-8 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0036 MEMORY NAME : samsung_k9f1208 MEMORY INFO : 0200:0020:033C WORKING; UNLOCKED; POWER OFF PHONE TO COMPLETE UNLOCK AND AFTER DISABLE THE DIAG; Time needed - 00:00:01 |
06-04-2012, 09:40 | #10732 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.7886 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Oct 28 2010 14:29:00 RELEASE DATE : Jun 24 2010 21:00:00 FIRMWARE INFO : BL_RU_P607C3V1.0.0B05-S IMEI : 35541604010535-4 BLUETOOTH ADDR : F9 AF 76 37 F5 98 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 250 MNC: 99) LOCKED NET 6 (MCC: 255 MNC: 2) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:09 |
06-04-2012, 10:11 | #10733 (permalink) |
Freak Poster Join Date: Apr 2008 Location: *.onion
Member: 740263 Status: Offline Sonork: 100.1608512 Thanks Meter: 37 | Searching Huawei phone COM ports... not found ! Searching Android USB Interface... OK Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Starting bootloader... OK Sending data to server... OK Reading data from server... OK Sending boot data... OK Initializing NAND functions... OK Initializing NV functions... OK Server disconnected! Reading NV item #550...OK Reading NV item #114...OK Reading NV item #60001...OK Searching for OEMINFO data... OK Product name: U8150 Model name: Huawei U8350 IMEI: 356899040271012 S/N: Q3P7NB1170107609 Firmware: U8350V100R001C00B606_EFS SIM Lock status: locked (NCK lock) 2012-06-04 11:08:46.033 Start unlocking procedure (356899040271012) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Reading NV item #550...OK Checking bootloader status... OK Reading NV item #114...OK Searching for OEMINFO data... OK Creating backup of Sensitive Data... OK Backup saved to file "D:\FURIOUS\7\HUAWEI_ANDROID_UNLOCKER_0016\Backup\ 356899040271012_2012-06-04_110903.fhb" Sending data to server... OK Reading data from server... OK Writing NAND... OK Verification... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... OK Server disconnected! 2012-06-04 11:09:05.710 Done! FINALLY 1 PIECE |
06-04-2012, 12:12 | #10734 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Unlock ZTE SFR 112 noir Software engine version: 1.0.0.6416 Connect phone powered on ! Start auth ! SW Ver: EFSPI-FR-SFR-P108E10FM(S)V1.0.0B08 Imei: 353894031176596 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0103 Reading ... Saved: ZTE_353894031176596_EFSPI-FR-SFR-P108E10FM(S)V1.0.0B08_13.07.39_04.06.2012_PARTIAL. bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:48 |
06-04-2012, 15:26 | #10735 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 A4 35 45 96 28 09 93 0C Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:57 |
06-04-2012, 15:35 | #10736 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | F160 Atlanta unlocked !! Software engine version: 1.0.0.7893 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : May 5 2011 17:44:00 RELEASE DATE : Apr 1 2011 04:00:00 FIRMWARE INFO : ORG_PL_P622F2V1.0.0B05-S IMEI : 3573410404xxxxx BLUETOOTH ADDR : 55 92 D8 62 B3 B4 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: EFE42F017CCA1B2CDF1512817524200B.bin ERASING; WRITING; READING; AFTER BACKUP: 119CAC077F4D6218744568737E8A4AB9.bin UNLOCKED; RESET ! Time needed - 00:00:12 |
06-04-2012, 15:56 | #10737 (permalink) |
Member: 368697 Status: Offline Thanks Meter: 223 | vodafone 835 unlock done Searching phone ... MODEL : Q62xx-FSBL STARTING; OK; LOADING; OK; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35230403011406-0 READING; SP_SAVED_TO: SP_35230403011406_EA1_07.52.19_04.06.2012_HUAWEI.b in CHECKING; LOCKED_TO: MCC-MNC [0]: 640-04 MATCHED; ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:01:49 pack 2 select vodafone 840 |
06-05-2012, 07:38 | #10738 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | G1157 unlock done Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 358145036149459 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_358145036149459_REL_P1.2PU04V01.04_11.36.53 _05.06.2012_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 BR |
06-05-2012, 11:00 | #10739 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 1B 39 C4 99 55 0A 07 08 Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:59 |
06-05-2012, 11:00 | #10740 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Comm opened 11 ! Baud set ! Auth made ! Sw version: Huawei g2100v100r001uzbc44b103sec test mode status: Off sim status: Off imei: 351633048893542 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:21 |
