01-12-2019, 19:14 | #15016 (permalink) |
Junior Member Join Date: Dec 2006
Member: 403806 Status: Offline Thanks Meter: 5 | Ot-5041c frp done Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM27)) Preparing to start flash mode; Preparing to open COM27 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 72db5011fe6f0d7601abdf176ec70dae Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0xFDCB0342 0x415577AC [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 015163-00-XXXXXX-8 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5041C-2AAQUS6-R USRDATA INFO: 0x139000000 SIZE: 0x2672FBE00 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_12_01_2019_11_11_57.txt |
The Following User Says Thank You to russianz64 For This Useful Post: |
01-14-2019, 21:25 | #15017 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Mongolia
Member: 2022955 Status: Offline Sonork: 100.1646687 Thanks Meter: 418 | Unlock ZTE V9815 ( ZTE N5 ) 1)Root 2)Enable diag 3)Select ZTE Handset Diag_mdm Interface 4)Done Unlock ( Unlock PUK + PIN ) Code: Software engine version: 1.0.0.10670 Searching phone ... MODEL : QCOM SERIES 45 COMPILED DATE : May 16 2013 05:09:00 RELEASE DATE : Feb 26 2013 10:00:00 FIRMWARE INFO : M9615A-CEFWMAZM-2.0.12144 IMEI : 86130302002984-5 BLUETOOTH ADDR : 20 48 3F 1D F3 30 DONE; WORKING; SAVED: 2B5660CF88C5CD9D4CD2AE29844FC7E5.bin UNLOCK CODE: N/A DONE; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_14_01_2019_23_16_16.txt Time needed - 00:00:48 |
The Following User Says Thank You to huaweinckunlock For This Useful Post: |
01-16-2019, 13:06 | #15018 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Portugal Age: 43
Member: 7557 Status: Offline Thanks Meter: 26 | Altice S11 done. With help of Hack3r2k Searching phone; Phone detected (@oem276.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM170); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6580, E01 Sw version: MOLY.WR8.W1449.MD.WG.MP.V181 Hw Version: SAGETEL_O1MP2_K80_BSP_HSPA_HW Reading phone info; IMEI: 357012-09-010744-6 Reading simlock info; Locked to: C1C-1C code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Unlocking SIM2 too. Time needed - 00:00:54 |
01-17-2019, 15:47 | #15019 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Narowal
Member: 207708 Status: Offline Sonork: 100.1602241 Thanks Meter: 1,005 | Old is Gold Huawei T156 Ufone unlock done with Furious Gold Old is Gold Huawei T156 Ufone unlock done with Furious Gold Here are logs Youtube Link https://www.youtube.com/watch?v=jYX_...ture=********* |
The Following 2 Users Say Thank You to umarnlw For This Useful Post: |
01-18-2019, 17:27 | #15020 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 5033a unlock done Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MTK USB Port (COM44)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.54_k39tv1.bsp_P32 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V18.P69 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 356268-09-159458-3 IMEI 2: 000000-00-000000-0 Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:30 Log file saved to: LOG_18_01_2019_12_24_11.txt |
01-19-2019, 07:41 | #15021 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Vfd 700 done Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM28)) Preparing to start flash mode; Preparing to open COM28 Connecting; Downloading DA; Initializing; Rid: 4f30e4abc9737709be0d2f95540a94f9 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6755 [CB00, 01, 6755, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333238 0xC0A90042 0x8B331BD6 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 357042-07-028682-9 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V700-2AVDGB1 USRDATA INFO: 0x11C800000 SIZE: 0x283AFBE00 Searching data; Locked to [SIM1]: 234-15 code_cat_n: 3637086158220620 enabled: yes tries: 8 code_cat_ns: 7415526304355637 enabled: no tries: 10 code_cat_sp: 1385283158813576 enabled: no tries: 10 code_cat_c: 5296034227607254 enabled: no tries: 10 code_cat_sim: 3906039172213885 enabled: no tries: 10 code_cat_ns_sp: 6683639807647252 enabled: no tries: 5 code_cat_sim_c: 7672825051212200 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:11 Log file saved to: LOG_19_01_2019_09_37_01.txt |
01-19-2019, 16:30 | #15022 (permalink) | ||
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | OT-5020T_{Network Lock}_Successfully removed<<OTSmart>> Full logs of the operation/ Quote:
The Following 2 Users Say Thank You to lyes_albert For This Useful Post: |
01-19-2019, 19:33 | #15023 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | HUAWEI DRA-LX3 UNLOCK DONE Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MTK USB Port (COM44)) Preparing to start flash mode; Preparing to open COM44 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: d8702fb9765c8c680a77e56a7a68bc86 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x46000115 0x4D323645 0xEA140342 0xFD35DCCE [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x9B000000 SIZE: 0x307DFBE00 Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 Log file saved to: LOG_19_01_2019_14_31_39.txt |
01-20-2019, 10:32 | #15024 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Paris Age: 36
Member: 670113 Status: Offline Sonork: 100:1615871 Thanks Meter: 44 | Archos Sense 55 DC (FRP) Remove Sucessfully Program Pack 6 OT Smart V1.0.0.3107 HERO EDITION I Choice Archos Sense 50 DC and FRP RESET Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume up pressed to the usb cable] Phone detected (MediaTek USB Port (COM152)) Preparing to start flash mode; Preparing to open COM152 Connecting; Downloading DA; Initializing; Rid: 77212f586c25fe68295b0d49fa0861c1 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem92.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM16; DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x514E0113 0x36334A32 0x62001043 0x89729001 [SIZE=0x3AC000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xE4000000 SIZE: 0x2C6380000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_20_01_2019_10_26_29.txt Phone Version IS 7.0 Android Security Patch Level MAY 5, 2017 Thank You Furious Team Br |
The Following User Says Thank You to lovelyboy For This Useful Post: |
01-21-2019, 12:24 | #15025 (permalink) | ||
Member: 2669781 Status: Offline Thanks Meter: 1,839 | OT-4007X_{Resurrection}_Exclusively done with ''Otsmart".. Full logs of the operation/ Files used: available at support area===>>>4007X-2[X=A,B,C,D]ALDZ1 Quote:
01-21-2019, 15:17 | #15026 (permalink) |
No Life Poster Join Date: Jun 2007
Member: 523482 Status: Offline Thanks Meter: 27 | Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM237)) Preparing to start flash mode; Preparing to open COM237 Connecting; Downloading DA; Initializing; Rid: a30bd062b5c35126fd8f9d95cf0b9947 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem76.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM9; DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, 05] HW_STORAGE_EMMC: 0x46000115 0x4D323645 0x03E00342 0xB975F7D3 [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x81000000 SIZE: 0x321D80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 |
The Following User Says Thank You to pipou911 For This Useful Post: |
01-22-2019, 10:17 | #15027 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Huawei Mate 9 [MHA-AL00] downgrade and Huawei ID remove This Huawei Mate 9 wasn't possible to remove Huawei ID via standard connection due to Android 8 update, so... Solution is simple: 1. Use FlyCaptainHuaweiResurrector_v30 [ or newnes ] . 2. Open phone and attach it with closed Testpoint to USB to see it like HUAWEI USB COM 1.0 in Device Manager. 3. On FlyCaptain go to Update OEMINFO tab, Mark "Use Bootloader" and "Update OEMINFO" and select needed data [ you can use filters to shrink selection depend of CPU and Model ] Press Update: Code: Device detected: COM76: HUAWEI USB COM 1.0 (COM76) BOOTLOADER File to update: Kirin960_T2_A7.0_V3 OEM File to update: MHA-AL00 22.1.2019 г/ 10:28:32 Starting to write device... Writing bootloader... Writing Kirin960_T2_A7.0_V3_3.dtwork... Writing Kirin960_T2_A7.0_V3_4.dtwork... Writing Kirin960_T2_A7.0_V3_5.dtwork... Waiting for fastboot device... Device found: 3HX5T17812004569 Looking for a device in fastboot mode Device found: 3HX5T178120xxx69 SN:3HX5T178120xxx69 IMEI:8667160323xxx33IMEI1:8667160324xxx28MEID:A000007AA00FA0 Build number: :MHA-AL00 8.0.0.370(C00) Model: MHA-AL00 Battery state: 6606mv Erasing OEMINFO partition Partition OEMINFO erased Writing OEMINFO partition OEMINFO partition UPDATE ...OK Software written 22.1.2019 г/ 10:29:22 Writing device finished OK 4. Just press "Reboot device" . The unit will go to reboot and start charging. 5. Attach [ if not attached ] flat cable and start phone from power button. Wait untill see factory reset and all circle of erase. The unit will become free and you can use it: Hope will alltime get good solutions and tools from FGTeam. WBR, DebeliaMark, BG |
The Following User Says Thank You to debeliamark For This Useful Post: |
01-22-2019, 19:54 | #15028 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | Optus X Start Unlock Sucessful. Code: Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone) Phone detected (MTK USB Port (COM54)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.54_k39tv1.bsp_P56 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V18.P95 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 356267-09-07xxxx-0 IMEI 2: 000000-00-000000-0 Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:25 Log file saved to: LOG_22_01_2019_23_48_56.txt |
01-23-2019, 12:47 | #15029 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | UTOK q5 GT FRP done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM65)) Preparing to start flash mode; Preparing to open COM65 Connecting; Downloading DA; Initializing; Rid: 52e2a2abcfb3ba1ab1cb25f4427346c5 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6735M [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0xA1210705 0x35923AA9 [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xA4800000 SIZE: 0x12C780000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 |
01-23-2019, 16:45 | #15030 (permalink) |
Freak Poster Join Date: Dec 2015
Member: 2502617 Status: Offline Thanks Meter: 42 | Vodafone 720 | VFD720 network unlock done Yes it is supported, only must have good drivers, make sure to download from support these drivers: Driver_Auto_Installer_EXE_v5.1632.00_META_ALCATEL. zip Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MTK USB Port (COM10)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.54_k39tv1.bsp_TMP1 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V18.T3 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 352861-09-107243-8 IMEI 2: 000000-00-000000-0 Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:01:21 Log file saved to: LOG_22_01_2019_16_19_41.txt |
