05-14-2019, 07:39 | #15166 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | P20 pro stuck on recovery flashing done Code: Looking for a device in upgrade mode COM66: Android Adapter PCUI (COM66) COM138: DBAdapter Reserved Interface (COM138) 14-May-19 7:36:02 AM Starting to write device in UPGRADE mode... File to update: UPDATE.APP Current version: CLT_Global-CUST 9.0.0(C999) Validating file... Detecting port... Preparing to write... Writing file 1 of 45: SHA256RSA...OK Writing file 2 of 45: CRC...OK Writing file 3 of 45: CURVER...OK Writing file 4 of 45: VERLIST...OK Writing file 5 of 45: PACKAGE_TYPE...OK Writing file 6 of 45: HISIUFS_GPT...OK Writing file 7 of 45: XLOADER...OK Writing file 8 of 45: FASTBOOT...OK Writing file 9 of 45: DTS...OK Writing file 10 of 45: DTO...OK Writing file 11 of 45: VECTOR...OK Writing file 12 of 45: FW_LPM3...OK Writing file 13 of 45: HHEE...OK Writing file 14 of 45: TEEOS...OK Writing file 15 of 45: TRUSTFIRMWARE...OK Writing file 16 of 45: SENSORHUB...OK Writing file 17 of 45: FW_HIFI...OK Writing file 18 of 45: KERNEL...OK Writing file 19 of 45: VBMETA...OK Writing file 20 of 45: MODEMNVM_UPDATE...OK Writing file 21 of 45: MODEMNVM_CUST...OK Writing file 22 of 45: RECOVERY_RAMDISK...OK Writing file 23 of 45: RECOVERY_VENDOR...OK Writing file 24 of 45: RECOVERY_VBMETA...OK Writing file 25 of 45: ENG_VENDOR...OK Writing file 26 of 45: ENG_SYSTEM...OK Writing file 27 of 45: HDCP...OK Writing file 28 of 45: CACHE...OK Writing file 29 of 45: SYSTEM...OK Writing file 30 of 45: CUST...OK Writing file 31 of 45: ISP_FIRMWARE...OK Writing file 32 of 45: MODEM_FW...OK Writing file 33 of 45: HISEE_IMG...OK Writing file 34 of 45: HISEE_FS...OK Writing file 35 of 45: VENDOR...OK Writing file 36 of 45: VERSION...OK Writing file 37 of 45: ODM...OK Writing file 38 of 45: PRODUCT...OK Writing file 39 of 45: PRELOAD...OK Writing file 40 of 45: ERECOVERY_KERNEL...OK Writing file 41 of 45: ERECOVERY_VENDOR...OK Writing file 42 of 45: ERECOVERY_RAMDISK...OK Writing file 43 of 45: ERECOVERY_VBMETA...OK Writing file 44 of 45: USERDATA...OK Writing file 45 of 45: UFSFW...OK Software written 14-May-19 8:38:42 AM Writing device finished OK |
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
05-14-2019, 19:10 | #15167 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Edmonton AB
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | SELECTED MODEL ALCATEL PIXI 4 (4) Code: Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM150)) Preparing to start flash mode; Preparing to open COM150 Connecting; Downloading DA; Initializing; Rid: 760316b214b2e9a65cc8c16f8a9c3bb9 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem191.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM151; DEVICE INFO: BB CHIP: MT6735_S00 [CA00, 00, 321, FF] HW_STORAGE_EMMC: 0x46000115 0x4D323237 0xD4A60042 0x3F83C8D2 [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 0;1804-72-180000-0 IMEI2 [OTP 0000]: 2>8768-65-000000-0 PROVIDER: N/A USRDATA INFO: 0x58800000 SIZE: 0x60000000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_14_05_2019_11_57_01.txt |
05-16-2019, 02:10 | #15168 (permalink) |
No Life Poster Join Date: Jun 2016 Location: UK
Member: 2581848 Status: Offline Thanks Meter: 249 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM10 Connecting; Init; Port opened; Phone detected (@oem72.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM8 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 7.3 GB IMEI: 01480200152753-3 PTH: 08 PTS: M5R PROV_ID: 4060A-2AAQUS3-R1 SBTADDR: 24:0D:C2:A3:E5:6A SWIFIADDR: 24:0D:C2:AC:C0:BD HS_PN: SAA1GY0WA10C SSN: 48KB10CGONZ022W Work id: 080D8E4A Done; Stype: 00000001 SECURITY: X1M0UA04CL10 Size: 000002E2 Backup saved to: 01480200152753-3 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_15_05_2019_21_07_23.txt Time needed - 00:01:12 |
05-17-2019, 06:53 | #15169 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | MOBIWIRE NAKAI succesfuly unlocked by selecting Mobiwire Ayasha Using library Brom_DLL_v5.1428.0 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM78)) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6261 Sw version: MOBIWIRE_NAKAI_SS_L_V01.2_181214_MP Hw Version: SAGETEL61M_11C_HW Reading phone info; IMEI: 353292-10-006914-1 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:15 Log file saved to: LOG_17_05_2019_08_51_50.txt |
05-18-2019, 19:41 | #15170 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 5044c unlock and frp done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem87.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM595 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 14.7 GB IMEI: 01507500052942-5 PTH: 04 PTS: T3T PROV_ID: 5044C-2ARKUS3 SBTADDR: 9C:4F:CF:BD:77:7E SWIFIADDR: 9C:4F:CF:52:9A:9E HS_PN: SAA2A30WA11C SSN: MQLC08BBBEB00IH Work id: 22021984 Done; Stype: 00000001 SECURITY: X8C0LS01BR20 Size: 000002A5 Backup saved to: 01507500052942-5 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; Erase Done; FRPEx Done; Log file saved to: LOG_18_05_2019_14_38_43.txt Time needed - 00:01:13 |
05-20-2019, 14:56 | #15172 (permalink) | |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | vfd 620 frp done Quote:
05-21-2019, 20:32 | #15173 (permalink) |
No Life Poster Join Date: Oct 2008 Location: PAKISTAN
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Vivo 1820 imei repair successfully one click VIVO 1820 IMEI REPAIR SUCCESSFULLY DONE ONE CLICK Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM37)) Preparing to start flash mode; Preparing to open COM37 Connecting; Downloading DA; Initializing; Rid: 24d67b5c7d22ad0cba5ded5f8cb2f741 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0xE2800142 0x1B16A8F2 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x132800000 SIZE: 0x6118FBE00 Searching data; Checking data; IMEI repaired; Remove battery and cable; Time needed - 00:00:14 Log file saved to: LOG_22_05_2019_00_14_25.txt FAISAL JEE |
The Following User Says Thank You to faisal jee For This Useful Post: |
05-23-2019, 15:52 | #15174 (permalink) |
No Life Poster Join Date: Feb 2004
Member: 56121 Status: Offline Thanks Meter: 107 | HUAWEI P-SMART FIG-LX1 L31 Downgrade+FRP+IMEI DONE! Ok Buddies, i had this Phone with damn Android new security. Phone infos: SW version: FIG-LX1 8.0.0.176(C432) Performed by 1.7.1.0 Software version. Platform: HUAWEI Selected model: FIG-LX1 Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: FIG-LX1 Phone SN: XEDDU18xxxxxxxx Phone IMEI: 8621600xxxxxxx Phone IMEI2: 8621600xxxxxx SW version: FIG-LX1 8.0.0.176(C432) Connecting to server..OK Authorizing...OK Resetting FRP lock.. Operation was failed! FIRST, put phone in UPGRADE MODE ( Vol+ and Vol- and insert cable) USE HUAWEI RESURRECTOR latest version and this firmware from support: Figo-L31_8.0.0.128(C432)_Firmware_Android_8.0.0_EMUI_8. 0.0_05014XFJ PHONE DOWNGRADED OK THEN ERASE FRP: Model: FIG-LX1 MEID: 00000000000000 pESN: 00000000 IMEI: 862160041454132 Firmware ver.: System 8.0.0.046(04AP SN: XEDDU187xxxxxxxx IMEI1:8621600xxxxxxx FB LockState: LOCKED USER LockState: LOCKED locked Battery state: 4664mv 2019-05-23 16:37:13.581 Erase FRP start 2019-05-23 16:37:17.863 Reading phone info... 2019-05-23 16:37:18.452 Read phone info success! Model: FIG-LX1 MEID: 00000000000000 pESN: 00000000 IMEI: 8621600xxxxxxxx Firmware ver.: System 8.0.0.046(04AP SN: XEDDU18725002059 2019-05-23 16:37:18.489 Reading Certify data... 2019-05-23 16:37:18.753 Reading Certify data success! 2019-05-23 16:37:18.759 Signing Certify data... 2019-05-23 16:37:25.003 Erase FRP done! NOW REPAIR IMEI: 2019-05-23 16:46:18.647 Autodetect started! 2019-05-23 16:46:20.269 Found COM port: COM25 2019-05-23 16:46:20.281 Open port COM25 (Android Adapter PCUI (COM25))... 2019-05-23 16:46:20.397 Start read phone info! 2019-05-23 16:46:21.419 Connecting to server... 2019-05-23 16:46:22.340 Connected! 2019-05-23 16:46:22.346 Read data from server... 2019-05-23 16:46:23.952 Read data from server success! 2019-05-23 16:46:37.454 CP State: ready 2019-05-23 16:46:37.464 Read phone basic info... 2019-05-23 16:46:37.833 Read phone secure info... 2019-05-23 16:46:47.510 Detect phone done! Model: FIG-L31 MEID: 00000000000000 pESN: 00000000 IMEI: 8621600xxxxxxxxxx IMEISV: 46 Firmware ver.: System 8.0.0.046(04AP) SN: XEDDU187xxxxxxxxxx Custom SN: DU4MBHxxxxxxxx WiFi MAC: 7C:76:68:7E:9C:5D BlueTooth MAC: 7C:76:68:7E:A8E Vendor: hw Country: eu FASTBOOT:Chipset-dallas8.0.0.001(01FC)_FASTBOOT BOOT:System 8.0.0.046(04AP)_BOOT RECOVERYunknow) SYSTEM:System 8.0.0.046(04AP) MAINVER:System 8.0.0.046(04AP) DATAVERunknow) APTIME:Tue Jan 30 02:59:48 CST 2018 RAM: 3G eMMC: 32G IMEI 1 Sim Lock status: NET: unlocked NETSUB: unlocked SP: unlocked 2019-05-23 16:48:06.237 Autodetect started! 2019-05-23 16:48:07.820 Found COM port: COM25 2019-05-23 16:48:09.055 Repairing start New IMEI 1 : 869541091009848 2019-05-23 16:48:09.067 Connecting to server... 2019-05-23 16:48:10.188 Connected! 2019-05-23 16:48:10.193 Read data from server... 2019-05-23 16:48:11.982 Read data from server success! 2019-05-23 16:48:11.993 Open COM port COM25 (Android Adapter PCUI (COM25))... 2019-05-23 16:48:20.488 CP State: ready 2019-05-23 16:48:20.494 Read phone basic info... 2019-05-23 16:48:20.958 Read phone secure info... 2019-05-23 16:48:30.478 Read from server... 2019-05-23 16:48:30.932 Read from server success! 2019-05-23 16:48:31.340 Repair IMEI 1 start! 2019-05-23 16:48:31.345 Phone secure identify start 2019-05-23 16:48:36.355 Phone secure identify success! 2019-05-23 16:48:36.365 Reading from server... 2019-05-23 16:48:38.361 Read from server success! 2019-05-23 16:48:39.429 Repair IMEI 1 Success! 2019-05-23 16:48:39.441 Synchronize NV... 2019-05-23 16:48:39.914 Synchronize NV success! 2019-05-23 16:48:39.924 Factory reset... 2019-05-23 16:48:43.468 Factory reset success! 2019-05-23 16:48:43.767 Finished! DONE ;-) Just a question: can i upgrade software by OTA or not? |
The Following User Says Thank You to Millo_6 For This Useful Post: |
05-27-2019, 09:25 | #15175 (permalink) |
Freak Poster Join Date: May 2014 Location: Africa
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | Remove frp Alcatel 4034D ok 2 sec Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM8)) Preparing to start flash mode; Preparing to open COM8 Connecting; Downloading DA; Initializing; Rid: 0d2eb4dd4d0e37994a3de7c1b3f9b1ec Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x30000111 0x45473430 0x56450030 0x85539A0C [SIZE=0xEC480000] IMEI1 [OTP 0001]: 354442-08-099345-0 IMEI2 [OTP 0001]: 354442-08-099346-8 PROVIDER: 4034D-2AALWE1 USRDATA INFO: 0x58800000 SIZE: 0x60000000 Factory Reset Protection successfully removed ! Time needed - 00:00:02 Log file saved to: LOG_27_05_2019_09_15_58 . txt |
The Following User Says Thank You to elykia For This Useful Post: |
05-28-2019, 11:03 | #15176 (permalink) |
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | S8-701U 28/05/2019 10:24:46 FlyCaptain Huawei Module v2.0.0.0184 Furious Gold Pack 7 Dongle S/N: 91261461 Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2019-05-28 10:25:49.639 Autodetect started! 2019-05-28 10:26:00.647 Found COM port: COM199 2019-05-28 10:26:00.651 Open port COM199 (DBAdapter Reserved Interface (COM199))... 2019-05-28 10:26:00.765 Start read phone info! 2019-05-28 10:26:00.770 Connecting to server... 2019-05-28 10:26:05.073 Read secure info... 2019-05-28 10:26:05.090 Read basic info... 2019-05-28 10:26:05.109 Detect phone done! IMEI: 86450502********* IMEI 1 Sim Lock status: NET: unknown NETSUB: unknown SP: unknown 2019-05-28 10:26:18.507 Autodetect started! 2019-05-28 10:26:19.338 Found COM port: COM199 2019-05-28 10:26:19.435 Connecting to server... 2019-05-28 10:26:21.337 Connected! 2019-05-28 10:26:21.340 Read data from server... 2019-05-28 10:26:23.272 Read data from server success! 2019-05-28 10:26:23.275 Open COM port COM199 (DBAdapter Reserved Interface (COM199))... 2019-05-28 10:26:29.351 Read secure info... 2019-05-28 10:26:29.410 Read basic info... 2019-05-28 10:26:29.579 Unlocking start 2019-05-28 10:26:32.079 Read data from server... 2019-05-28 10:26:38.283 Read data from server success! 2019-05-28 10:26:38.288 Writing security data... 2019-05-28 10:26:38.469 Write security data success! 2019-05-28 10:26:40.087 Unlock done! 2019-05-28 10:26:40.101 Job finished! |
05-29-2019, 08:50 | #15177 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Inside
Member: 455852 Status: Offline Sonork: 100.1596308 Thanks Meter: 1,993 | Alcatel A392A Unlock OK Using library Brom_DLL_v5.1316.1 COM opened ok; Press power and keep it pressed now ! COM opened ok; Press power and keep it pressed now ! Requesting authorization; Done; Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: MAUI.11A.W11.12.SP1.V14.F18 Hw Version: JRD76_11A_GEMINI_HW Reading phone info; IMEI: 014077-00-046823-3 Reading; Reading security; Done; Checking; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:48 Log file saved to: LOG_29_05_2019_12_44_27.txt |
05-29-2019, 10:42 | #15178 (permalink) |
Freak Poster Join Date: Jun 2003
Member: 30455 Status: Offline Thanks Meter: 14 | mobiwire oneida world first furious do it! :) hi i try it world first Mobiwire Oneida phone from vodafone Hungary only furious unlock it with my methode unlock done by furious :-) furious mobiwire.jpg |
The Following 3 Users Say Thank You to tonyaki2 For This Useful Post: |
05-29-2019, 14:14 | #15180 (permalink) |
No Life Poster Join Date: Sep 2011 Location: NOKIA
Member: 1663119 Status: Offline Sonork: iffi3 Thanks Meter: 213 | World 1st zte r570 unlock done. SPECIAL THX TO HACK AND CHAUDARY ARSHAD FOR HELPING ME |
The Following User Says Thank You to iffipower For This Useful Post: |
