Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 08-20-2019, 15:21   #15241 (permalink)
Member: 216446
Thanks Meter: 170
ZTE A512 UNLOCK SUCESS
Software engine version: 1.0.0.10850
Searching phone ...
MODEL : QCOM SERIES 53
COMPILED DATE : Sep 3 2018 11:40:00
RELEASE DATE : May 27 2016 05:00:00
FIRMWARE INFO : MPSS.JO.1.2.c2-00081-8937_GENNS_PACK-1
IMEI : 86107003026621-8
BLUETOOTH ADDR : 00 00 00 00 00 00
FIRMWARE: PT_VDF_P817E52V1.0.0B37
close_event_report: OK;
close_log_report: OK;
close_message_report: OK;
closing_com_port: OK;
Starting the backup process;
connect_server: OK;
backup in progress: OK;
Backup saved to: C:\Users\ETRONICS\Desktop\Unlock\furious\QCOM_SMAR T_TOOL_v1.0.0.10850 (2)\86107003026621_20_08_2019_15_17_37.bkp
switching_download_mode: OK;
Preparing to open COM10
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
Found an eMMC memory 22D5
Looking for the interface;
Port found [ZTE CDMA Handset Diagnostics Interface (COM62)]
connect_server: OK;
restore in progress: OK;
SIM_LOCK REMOVED !
Log file saved to: LOG_20_08_2019_15_20_31.txt
Time needed - 00:02:57
Old 08-22-2019, 14:41   #15242 (permalink)
Member: 1507732
Thanks Meter: 25
FIG-LA1 FRP Done VIA TP
Process identifier:4620471
Writing bootloader...
Writing Kirin659_T0_A8.0_V1_3.dtwork...
Writing Kirin659_T0_A8.0_V1_4.dtwork...
Waiting for fastboot device...
Device found: 35P4C1xxx7005754
Looking for a device in fastboot mode
Device found: 35P4C1xxxx05754
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
SN:3xxxxxxx
IMEI:8658xxxxxxxx
IMEI1:xxxxxxxxxx
MEID:00000000000000
Build number: :FIG-LA1 9.1.0.121(C185E5R1P4)
Model: FIG-LA1
Battery state: 0
OEM lock state info:
FB LockState: UNLOCKED
USER LockState: LOCKED
OEM get bootinfo:
unlocked
Unlocking FRP...
Writing FRP partition
FRP partition UPDATE :FAIL partition error
FRP partition UPDATE ...OK
Software written
8/22/2019 6:37:25 PM Writing device finished OK
The Following 2 Users Say Thank You to /\/\@ster For This Useful Post:
Old 08-27-2019, 15:30   #15243 (permalink)
Member: 7910
Thanks Meter: 49
Huawei y6 2019 mrd-lx1 unlock success
Using library Brom_DLL_v7.1813.3
Searching phone in normal mode;
[connect the phone powered off to the usb cable with testpoint connected]
Phone detected (MediaTek USB Port (COM39))
Preparing to start flash mode;
Preparing to open COM39
Connecting;
Downloading DA;
Initializing;
Rid: 1e5f4eeb1957831d2b8819d4381e3841
Requesting baudrate change;
Done;
USB SPEED: USB_HIGH_SPEED
DEVICE INFO:
BB CHIP: MT6761 [CA01, 200, 6761, 00]
HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x8B1F0142 0x7116C906 [SIZE=0x749400000]
IMEI1 [OTP 0000]: 000000-00-000000-0
IMEI2 [OTP 0000]: 000000-00-000000-0
PROVIDER: N/A
USRDATA INFO: 0x110000000 SIZE: 0x637A00000
Searching data;
Phone unlocked; Remove battery and cable;
Time needed - 00:00:00
Log file saved to: LOG_27_08_2019_15_22_02.txt
Old 08-28-2019, 08:04   #15244 (permalink)
asia_gsm's Avatar
Member: 435412
Sonork: 100.1608142
Thanks Meter: 275
FInallly 6c pro Is Supported
Flashing
Flashing
[connect the phone powered off to the usb cable]
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM6))
Preparing to open COM6
Connecting;
Downloading DA;
Initializing;
Rid: 778c9bb4551d368f3694e30fbf6ca09e
Done;
DEVICE INFO:
BB CHIP: MT6750 [CB00, 01, 6750, 00]
HW_STORAGE_EMMC: 0x484A0190 0x61344742 0xB24ED432 0x0B6497AE  [SIZE=0x748800000]
PROVIDER: N/A
USRDATA INFO: 0x15E800000 SIZE: 0x5E83FBE00
Loading the file ...
Cfg done ...
Downloading bootloader...
Done;
Downloading images...
Done;
Success;
Time needed - 00:05:34
6c Pro Jmm-L22 Imei Repair
Connecting;
Downloading DA;
Initializing;
Done;
DEVICE INFO:
PROVIDER: N/A
Searching data;
Checking data;
NEW IMEI1: 111111-11-111111-9
OLD IMEI1: 865612-54-564785-9
NEW IMEI2: 111111-11-111111-9
OLD IMEI2: 865612-54-564784-9
NEW IMEI2: 222222-22-222222-8
IMEI repaired; Remove battery and cable;
Time needed - 00:00:02
Screen Shots
Special Thanks To Sir Mr.:hack3r2k:.
The Following User Says Thank You to asia_gsm For This Useful Post:
Old 08-28-2019, 08:24   #15245 (permalink)
Member: 1714226
Thanks Meter: 57
Alcatel 5099y Unlock done by OTSmart
Phone detected (MediaTek USB Port (COM63))
Preparing to open COM63
Requesting authorization;
Connecting;
Downloading DA;
Initializing;
Rid: 2e59c6df02c56cd0a114e64d1c3cc8ae
Done;
USB SPEED: USB_FULL_SPEED
Switching to DA_HIGHSPEED_VCOM;
Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \;
If the detection fails, install manually the port from the device manager using usbvcom.inf;
DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM (Android))
TRYING TO OPEN COM41;
DEVICE INFO:
BB CHIP: MT6737T [CA00, 00, 321, 05]
HW_STORAGE_EMMC: 0x51000115 0x4D333645 0xAA1D0342 0x9B955AD2 [SIZE=0x3A4A00000]
IMEI1 [OTP 0001]: 353937-09-064199-0
IMEI2 [OTP 0001]: 000000-00-000000-0
PROVIDER: 5099Y-2BTWGB1
USRDATA INFO: 0xEE000000 SIZE: 0x2B2280000
Searching data;
Locked to [SIM1]: 234-10
code_cat_n: 8157595936498579 enabled: yes tries: 10
code_cat_ns: 0515192764992779 enabled: no tries: 0
code_cat_sp: 8157595936498579 enabled: yes tries: 10
code_cat_c: 8157595936498579 enabled: no tries: 0
code_cat_sim: 8157595936498579 enabled: no tries: 0
Time needed - 00:00:04
Log file saved to: LOG_28_08_2019_13_22_20.txt
The Following User Says Thank You to rubelgsm For This Useful Post:
Old 08-29-2019, 22:47   #15246 (permalink)
Member: 2382052
Thanks Meter: 1,422
alcatel 4044l unlock done
Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ;
Phone detected (@oem226.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008)
Preparing to open COM28
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
Found an eMMC memory 22CD size 3.6 GB
IMEI: 01496000150124-5
PTH: 04
PTS: K4M
PROV_ID: 4044L-2DOSUS1
SBTADDR: 5C:77:76:5D:F0:E8
SWIFIADDR: 5C:77:76:4F:23:B0
HS_PN: SAA61UHAE20C
SSN: MHKF14CFGIB027P
Bruteforcing data; This operation can take up to 30 minutes !!!
Done;
Work id: 3563E0CF
Done;
Stype: 00000001
SECURITY: XNK4U1M0CL00 Size: 000002D7
Backup saved to: 01496000150124-5
Unlocking;
SIM_LOCK REMOVED !
Log file saved to: LOG_29_08_2019_17_46_35.txt
Time needed - 00:13:05
Old 08-31-2019, 11:21   #15247 (permalink)
Member: 2179221
Thanks Meter: 22
Huawei w1-u00 unlock done
2019-08-31 10:58:56.202 FlyCaptain Huawei Module v2.0.0.0184
2019-08-31 10:58:56.204 Dongle S/N: 91261461
Before detection connect cable to usb and enable Manufacture mode !
Qualcomm and HiSilicon: *#*#2846579#*#*
MTK: *#*#14789632#*#*
Windows: ##2846579#
ProjectMenu
1.Background setting
2.USB ports setting
Select Manufacture mode (for MTK other/debug mode)
2019-08-31 10:59:19.522 Autodetect started!
2019-08-31 10:59:19.562 Compatible COM ports not found!
2019-08-31 10:59:19.568 ERROR!
Phone not found !
2019-08-31 11:00:06.954 Autodetect started!
2019-08-31 11:00:07.073 Found COM port: COM367
2019-08-31 11:00:07.077 Open port COM367 (Qualcomm WinMobile Diagnostics 319B (COM367))...
2019-08-31 11:00:07.184 Start read phone info!
2019-08-31 11:00:07.196 Connecting to server...
2019-08-31 11:00:11.019 Connected!
2019-08-31 11:00:11.022 Read data from server...
2019-08-31 11:00:15.036 Read data from server success!
2019-08-31 11:00:29.207 Read secure info...
2019-08-31 11:00:29.250 Read basic info...
2019-08-31 11:00:29.331 Autodetect started!
2019-08-31 11:00:29.427 Found COM port: COM367
2019-08-31 11:00:29.512 Connecting to server...
2019-08-31 11:00:32.645 Connected!
2019-08-31 11:00:32.649 Read data from server...
2019-08-31 11:00:35.039 Read data from server success!
2019-08-31 11:00:35.042 Open COM port COM367 (Qualcomm WinMobile Diagnostics 319B (COM367))...
2019-08-31 11:00:47.560 Read secure info...
2019-08-31 11:00:47.905 Read basic info...
2019-08-31 11:00:48.117 Unlocking start
2019-08-31 11:00:53.866 Read data from server...
2019-08-31 11:00:57.785 Read data from server success!
2019-08-31 11:00:57.790 Writing security data...
2019-08-31 11:01:00.435 Write security data success!
2019-08-31 11:01:01.410 Unlock done!
2019-08-31 11:01:01.416 Job finished!
2019-08-31 11:01:05.731 Detect phone done!
IMEI: 868624012672356
Firmware ver.: 1030.5613.07500.05700
Firmware model: W1_U00
Custom SN: 021YPM4C34000254
WiFi MAC: A4:99:47:4C:09:FE
BlueTooth MAC: A4:99:47:4B:F6:29
IMEI 1 Sim Lock status:
NET: locked, unlock retry counts: 0
NETSUB: unlocked
SP: unlocked
2019-08-31 11:03:40.015 Autodetect started!
2019-08-31 11:03:40.095 Found COM port: COM367
2019-08-31 11:03:40.100 Open port COM367 (Qualcomm WinMobile Diagnostics 319B (COM367))...
2019-08-31 11:03:40.203 Start read phone info!
2019-08-31 11:03:40.217 Read secure info...
2019-08-31 11:03:40.265 Read basic info...
2019-08-31 11:03:40.347 Detect phone done!
NET: unlocked
NETSUB: unlocked
SP: unlocked
2019-08-31 11:03:52.026 Autodetect started!
2019-08-31 11:03:52.105 Found COM port: COM367
2019-08-31 11:03:52.110 Open port COM367 (Qualcomm WinMobile Diagnostics 319B (COM367))...
2019-08-31 11:03:52.216 Start read phone info!
2019-08-31 11:03:52.231 Read secure info...
2019-08-31 11:03:52.278 Read basic info...
2019-08-31 11:03:52.359 Detect phone done!
NET: unlocked
NETSUB: unlocked
SP: unlocked
Old 09-02-2019, 09:06   #15248 (permalink)
Member: 2179221
Thanks Meter: 22
Talking Flash Zte Z820 Done with furiousGold Box
[connect the phone powered off with volume up pressed to the usb cable]
Phone detected (MediaTek USB Port (COM3))
Connecting;
Downloading DA;
Initializing;
Rid: 8c6d0e7c322ed2fc8b499406dd5b6fca
Done;
DEVICE INFO:
BB CHIP: MT6735M [CA00, 00, 335, 05]
HW_STORAGE_EMMC: 0x484A0190 0x65314738 0x28800705 0xB3528AA4 [SIZE=0x1D2C00000]
IMEI1 [OTP 00FF]: 867117-02-013439-5
IMEI2 [OTP 00FF]: 000000-00-000000-0
PROVIDER: N/A
USRDATA INFO: 0xD6000000 SIZE: 0x60000000
Cfg done ...
Formatting file system now...
Done;
Formatting SECCFG partition now...
Done;
Formatting FRP partition now...
Done;
Formatting NVDATA partition now...
Done;
Formatting METADATA partition now...
Done;
Done;
Done;
Success;
Time needed - 00:42:51
Log file saved to: LOG_2_09_2019_08_32_59.txt
FlashTool Fail
Miracle box : DA ERROR Fail
UMT : DA NO EXIST FAIL
AVENGERS : ... Bcom... fail
FuriousGold Box : Time needed - 00:42:51 and DOOOOOOONNNNNNEEE
Old 09-02-2019, 16:33   #15249 (permalink)
Member: 2382052
Thanks Meter: 1,422
huawei fig-lx3 frp done
Fly Captain Huawei Resurrector 0.0.0.38
user:57A96656
Device detected:
COM542: HUAWEI USB COM 1.0 (COM542)
BOOTLOADER File to update: Kirin659_T0_A8.0_V1
02/09/2019 11:22:22 a.m. Starting to write device...
Process identifier:4644966
Device found: LDG4C18613000228
Getting IMEI...
Getting model ...
SN:LDG4C18613000228
IMEI:8658410381
IMEI1:000000000000000
MEID:00000000000000
Build number: :FIG-LX3 8.0.0.122(C25)
Model: FIG-LX3
Battery state: 3205mv
OEM get bootinfo:
unlocked
Unlocking FRP...
Software written
02/09/2019 11:22:54 a.m. Writing device finished OK
Old 09-02-2019, 23:25   #15250 (permalink)
Member: 2382052
Thanks Meter: 1,422
HUAWEI ANE-LX3 DOWNGRADE DONE FROM 9 TO 8
WRITE OEM INFO ANE-L23
USE BOOTLOADER KIRIM 659
user:57A96656
Looking for a device in upgrade mode
COM548: Android Adapter PCUI (COM548)
COM549: DBAdapter Reserved Interface (COM549)
02/09/2019 11:59:50 p.m. Starting to write device in UPGRADE mode...
Device found: 6NUDU18828002047
02/09/2019 11:59:56 p.m. start to write update file
File to update: UPDATE.APP
File size: 4,339,279,260 bytes
Current version(CURVER): ANE-BD 1.0.0.999
Process identifier:4645952
Validating file...
Detecting port...
Preparing to write...
Writing file 1 of 34: SHA256RSA...OK
Writing file 2 of 34: CRC...OK
Writing file 3 of 34: CURVER...OK
Writing file 4 of 34: VERLIST...OK
Writing file 5 of 34: PACKAGE_TYPE...OK
Writing file 6 of 34: EFI...OK
Writing file 7 of 34: XLOADER...OK
Writing file 8 of 34: FW_LPM3...OK
Writing file 9 of 34: FASTBOOT...OK
Writing file 10 of 34: MODEMNVM_UPDATE...OK
Writing file 11 of 34: TEEOS...OK
Writing file 12 of 34: TRUSTFIRMWARE...OK
Writing file 13 of 34: SENSORHUB...OK
Writing file 14 of 34: FW_HIFI...OK
Writing file 15 of 34: KERNEL...OK
Writing file 16 of 34: RAMDISK...OK
Writing file 17 of 34: RECOVERY_RAMDISK...OK
Writing file 18 of 34: RECOVERY_VENDOR...OK
Writing file 19 of 34: ERECOVERY_KERNEL...OK
Writing file 20 of 34: ERECOVERY_RAMDISK...OK
Writing file 21 of 34: ERECOVERY_VENDOR...OK
Writing file 22 of 34: RECOVERY_VBMETA...OK
Writing file 23 of 34: ERECOVERY_VBMETA...OK
Writing file 24 of 34: DTS...OK
Writing file 25 of 34: MODEM_FW...OK
Writing file 26 of 34: VBMETA...OK
Writing file 27 of 34: ODM...OK
Writing file 28 of 34: CACHE...OK
Writing file 29 of 34: SYSTEM...OK
Writing file 30 of 34: CUST...OK
Writing file 31 of 34: VENDOR...OK
Writing file 32 of 34: VERSION...OK
Writing file 33 of 34: PRODUCT...OK
Writing file 34 of 34: USERDATA...OK
Software written
03/09/2019 06:19:51 p.m. Writing device finished OK
Old 09-03-2019, 15:22   #15251 (permalink)
Member: 328688
Thanks Meter: 1,439
Dra lx2 flashing done
HERE LOG
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post:
Old 09-04-2019, 15:51   #15252 (permalink)
Member: 731353
Thanks Meter: 139
Hisense u605 network lock done using world famous box
Searching phone;
For an successful connection do the following:
1. Connect the phone powered off with the battery inside to the usb cable
Phone detected (@oem186.inf,%usbcomm_dl%;SPRD U2S Diag)
Preparing to sync;
Port opened [COM268];
Entering diagnostic mode;
Done;
Chip type: 0000:0000
Platform Version: MOCORTM_17C_W18.23.4_P20_Debug
Project Version: pike2_pub
BASE Version: FM_BASE_17C_W18.23.4_P20
HW Version: sc7731e_modem
02-25-2019 18:03:32
Build number: sp7731e_fs280_project-user 8.1.0 OPM2.171019.012 26112 release-keys
PHONE INFO:
BT ADDR: FF:FF:FF:FF:FF:FF
SW IMEI[0]: 867790-04-XXX-X
SW IMEI[1]: 867400-02-XXXX-X
SW IMEI[2]: 867400-02-XXXX-X
SW IMEI[3]: 867400-02-X-6XXXX
SIMLOCK FLAG: ON
SIM_LOCK TYPE: 3
IMEI: 867790-04-195950-1 UNLOCK CODE: 44940458
Done;
Log file saved to: LOG_4_09_2019_16_47_04.txt
Time needed - 00:00:05
The Following 2 Users Say Thank You to bigjef1 For This Useful Post:
Old 09-05-2019, 13:07   #15253 (permalink)
Member: 328688
Thanks Meter: 1,439
world 1st Huawei BGO-DL09 flashing done
here log
The Following 3 Users Say Thank You to CHAUDHRAY ARSHAD For This Useful Post:
Old 09-05-2019, 16:25   #15254 (permalink)
faisal jee's Avatar
Member: 882981
Sonork: 161363
Thanks Meter: 259
Honor 8a jat-l29 9.0.1 frp done
Phone detected (MediaTek USB Port (COM169))
Preparing to open COM169
Connecting;
Downloading DA;
Initializing;
Rid: fcddd895c15f8ce58b618e045055166f
Done;
DEVICE INFO:
BB CHIP: MT6765 [CA00, 00, 6765, 00]
HW_STORAGE_EMMC: 0x51000115 0x4D333644 0xFA370142 0x9B55A4D6 [SIZE=0x749400000]
PROVIDER: N/A
USRDATA INFO: 0xEE000000 SIZE: 0x659A00000
Contents saved to :
E:\SETUP\FG\PACK6\OTSmart_v1.0.0.3605_Cowabanga_Ed ition\jat l29\HUAWEI JAT-L29_IMEI_951715D7_8855D92E_fcddd895c15f8ce58b618e0 45055166f_5_09_2019_01_01_34.osp
Done;
Searching phone;
(insert the USB cable in the powered off phone)
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM182))
Preparing to start fastboot mode;
Done; Fastboot mode entered;
Connecting;
switching_fastboot_mode: OK;
resistance is futile : OK !?;
data_written : OK;
data_written : OK;
data_written : OK;
data_written : OK;
data_written : OK;
data_written : OK;
data_written : OK;
data_written : OK;
Factory Reset Protection successfully removed !
Time needed - 00:01:57
Old 09-05-2019, 17:02   #15255 (permalink)
fokal2008's Avatar
Member: 953931
Sonork: 1652252
Thanks Meter: 762
Cool itel it6080 sc6531efm lock code remove done
ITEL IT6080 SPD SC6531EFM FORMAT DONE BY CHOSING ITEL IT6110
The Following User Says Thank You to fokal2008 For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.35910 seconds with 9 queries
