Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 02-04-2020, 23:39   #15406 (permalink)
Crazy Poster
Member: 2644395
Thanks Meter: 11
World first Aspera A40 unlock using furious gold spd using diag mode pixi 4024
Searching phone;
For an successful connection do the following:
1. Connect the phone powered off with the battery inside to the usb cable
Phone detected (@oem145.inf,%dvcdsc%;SCI USB2Serial)
Preparing to sync;
Port opened [COM19];
Entering diagnostic mode;
Done;
Chip type: 8860:B100
Platform Version: MOCORTM_W16.28.2_P2_Debug
Project Version: sc7731C_CP0_modem
BASE Version: TM_BASE_W16.28.2_P2
HW Version: sc7731C_CP0_modem
10-12-2016 11:16:57
Build number: Aspera_A40_V07_20161107
PHONE INFO:
BT ADDR: 3F:65:E8:0B:72:60
SW IMEI[0]: 355701-06-642520-2
SW IMEI[1]: 352751-01-719180-0
SW IMEI[2]: 358570-01-010389-3
SW IMEI[3]: 910575-60-140046-8
SIMLOCK FLAG: ON
BKP saved to : BKP_000000-00-000000-0_355701-06-642520-2_8860B100_5_02_2020_11_35_04.spd
SIM_LOCK TYPE: 3
IMEI: 355701-06-642520-2 UNLOCK CODE: 82160723
Done;
Phone unlocked; Remove battery and cable;
Log file saved to: LOG_5_02_2020_11_35_10.txt
Fijian style......
Old 02-06-2020, 15:15   #15407 (permalink)
Member: 1813192
Thanks Meter: 58
Using library Brom_DLL_v7.1813.3
Searching phone;
(insert the USB cable in the powered off phone
or
insert the USB cable in the powered off phone while keeping volume down pressed)
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM5))
Preparing to start meta mode;
Searching for debug port; (be sure drivers from support were installed)
Meta mode entered;
Baseband Chip: MT6739
Sw version:
Hw Version: alps-mp-p0.mp1-V5.20_tinno.sz.p0mp1.k39tv1.64.bsp_P22
Sw version: MOLY.LR12A.R3.MP.V37.3.P8
Hw Version: TK_MD_BASIC_HW
Reading phone info;
IMEI 1: 355572-10-258533-7
IMEI 2: 355572-10-263575-1
Loading config;
Done;
Working;
Unlocking;
Unlocking SIM2;
Time needed - 00:00:46
Log file saved to: LOG_6_02_2020_14_51_35.txt
unlock ok wiko y60
Old 02-07-2020, 18:30   #15408 (permalink)
Member: 2179221
Thanks Meter: 31
Thumbs up Tutorial How to unlock Vodafone 890n with FuriousGold
Software engine version: 1.0.0.10879
Searching phone ...
MODEL :		QCOM SERIES 43
COMPILED DATE :	Sep 24 2014 10:53:00
RELEASE DATE :	Sep 16 2014 04:00:00
FIRMWARE INFO :	GWL_T3_01_10350101_02
IMEI :		356602065xxxxx-x
BLUETOOTH ADDR :	 00 00 00 00 00 00
DONE;
WORKING;
SAVED: D36203C562C1041DF9401DB54226EBA7.bin
UNLOCK CODE:		N/A
DONE;
SIM_LOCK REMOVED !
RESET !
How to do it ???
Unlock Vodafone 890n
1.Root use kingo root
2. Enable Diag adb use QCOM Smart Tool pack5
3.Download driver : coolpad
4. install it without connect phone
- connect phone in normal mode and install driver
5. check ENUM All ports
6. Scan Port
7. in port Usb select Diagnoctic port (2xx)
8.select Unlock
9.click Do job
10.Done
By Elykiasoft and SmileGsm
CLICK THANKS FOR APPRECIATION
Old 02-11-2020, 14:13   #15409 (permalink)
Member: 1431846
alcatel 1066 sim restricted message
hello
customer bring phone showing sim restricted somone flash it. so with the help of furious team fixed the issue. first flast it with file from support, then simlock on and then do the sim lock remove. and all sorted
Old 02-11-2020, 23:43   #15410 (permalink)
Crazy Poster
Member: 1779905
Thanks Meter: 2
unlocked vfd630 network / frp with otsmart
best support
Old 02-14-2020, 06:48   #15411 (permalink)
mtb116's Avatar
Member: 177568
Thanks Meter: 92
Alcatel 1V (OT-5001T)
Searching phone;
1. Power on the phone and power it off
2. Keep pressed firmly volume UP key
3. Insert the usb cable inside the phone while keeping pressed volume UP
Phone detected (@oem76.inf,%dvcdsc%;SCI USB2Serial) (Driver version: 1.5.6.1)
Preparing to sync;
Port opened [COM82];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: (c)2019, FuriouSTeaM
Starting FDL2;
FDL2 sent;
Starting auth;
memory_type: IF_TYPE_MMC
dev_no: 0
part_type: PART_TYPE_UNKNOWN
vendor: Man 000070 Snr 1044b3d4
product: TB2816
revision: 2.0
memory_size: 14.6 GB
HW IMEI : 000000-00-000000-0
PHONE INFO: NONE
PHONE ID: MTAyMjA5MWQwMDkwMzQ2NQ==
BT ADDR: NONE
SW IMEI[0]: 356311-10-004861-1
SW IMEI[1]: 867400-02-031662-0
SW IMEI[2]: 867400-02-031663-8
SW IMEI[3]: 867400-02-031664-6
SIMLOCK FLAG: ON
Reading NV;
NV saved to : NV_000000-00-000000-0_356311-10-004861-1_98550000_14_02_2020_16_30_04.spd
Gathering security data;
Security check result: 0
Connecting to server;
Authorisation process started;
Done;
Requesting data from server ! Wait please ...
Re-programming;
Security programmed;
Sync NV;
Done;
Log file saved to: LOG_14_02_2020_16_30_26.txt
Time needed - 00:02:00
Old 02-17-2020, 19:24   #15412 (permalink)
Member: 2875052
Thanks Meter: 6
Spd tool
Searching phone;
Phone detected (@oem249.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.114)
Preparing to sync;
Port opened [COM264];
Done;
Chip type: 0000:0000
Platform Version: MOCORTM_18A_W19.08.2_P14_Debug
Project Version: sharkle_Smart_Phone
BASE Version: FM_BASE_18A_W19.08.2_P14
HW Version: sc9832e_modem
07-16-2019 19:38:26
Build number: sp9832e_1h10_gofu-user 9 PPR1.180610.011 41415 release-keys
PHONE INFO:
BT ADDR: FF:FF:FF:FF:FF:FF
SW IMEI[0]: 352023-10-530584-7
SW IMEI[1]: 362523-43-247624-3
SIMLOCK FLAG: ON
BKP saved to : BKP_000000-00-000000-0_352023-10-530584-7_00000000_17_02_2020_13_19_47.spd
SIM_LOCK TYPE: 3
IMEI: 352023-10-530584-7 UNLOCK CODE: 82518523
Done;
Old 02-21-2020, 16:39   #15413 (permalink)
Member: 2875052
Thanks Meter: 6
Alcatel ot 5033m frp removal done
Searching phone in normal mode;
[connect the phone powered off to the usb cable]
Phone detected (MediaTek USB Port (COM4)) (Driver version: 3.0.1504.0)
Preparing to start flash mode;
Preparing to open COM4
Requesting authorization;
Connecting;
Downloading DA;
Initializing;
Rid: bd77130255376116082c932f1ef2dc66
Requesting baudrate change;
Done;
USB SPEED: USB_HIGH_SPEED
DEVICE INFO:
BB CHIP: MT6739 [CB00, 02, 6739, 00]
HW_STORAGE_EMMC: 0x46000115 0x4D323645 0x9F680342 0x9B765807 [SIZE=0x3A4A00000]
IMEI1 [OTP 0000]: 358054-10-1321xx-x
IMEI2 [OTP 0000]: 000000-00-000000-0
PROVIDER: 5033M-2HC9JMA
USRDATA INFO: 0x85000000 SIZE: 0x31B2FBE00
Factory Reset Protection successfully removed !
Time needed - 00:00:00
Log file saved to: LOG_21_02_2020_10_38_27.txt
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
Page generated in 0.29460 seconds with 9 queries
