Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 11-09-2009, 07:44   #1546 (permalink)
adreesas's Avatar
Member: 752606
Sonork: 100.1587361
Thanks Meter: 110
sagem my300c unlock done with FG
SAGEM MY300C UNLOCK DONE WITH FURIOUS GOLD....
Press power on shortly ...
Starting communication ...
MCU ID: 14C00210086746C10000000000001219
ROM HASH: 62FB6505AC902905678D99DD748702EE
ROM VER: 05.02
Authorising ...
Sending preloader ...
Exploiting ...
Preloader started ...
Sending applet ...
Loader version: FuriouSTeaM GSM DEVELOPEMENT
Changing baudrate ...
Flash ID(0): 0001:327E:4300
Reading unbinded data;
Unbinded flash data done;
Unbinded eeprom data done;
Plain datadone;
Model: my300C
Hash: 000033AC
Algo: 05
Firmware: LH5,PG: 220607 1050
Imei: 355437013150722
Phone code: 0000
Prod. code: 252964275
Id calculation done;
CODES:
NET LO CODE: 3459428534
NET HI CODE: 2389880950
DIRECT UNLOCK: OK
Done !
Time needed - 00:03:05
USMAN COMUNICATIONS CHAKSWARI
Old 11-09-2009, 09:58   #1547 (permalink)
Unlocker AL's Avatar
Member: 3617
Thanks Meter: 477
Vodafone 710 unlock ok
Searching phone ...
MODEL : D618 V1.0
Download mode entered ...
Loading bootloader ...
Requesting random data ...
Completed ...
Init nand made;
Reading;
Imei : 35197901085746-4
Unlock code: 8414652213818678
Done !
Time needed - 00:01:51
Old 11-09-2009, 10:57   #1548 (permalink)
Member: 239004
Sonork: 100.1589817
Thanks Meter: 388
MY411Cv unlock
MCU ID: 0DA0010DF96163C10000000000001C17
ROM VER: 05.02
Authorising ...
Exploiting ...
Sending applet ...
Flash ID(0): 0001:2D7E:2F00
Plain datadone;
Model: my411Cv
Hash: 00002034
Algo: 05
Firmware: EVN,SE: 230707 1108
Imei: 356540011958746
Phone code: 0000
Prod. code: 252975872
CODES:
NET LO CODE: 4124123074
NET HI CODE: 3046186754
Old 11-09-2009, 11:54   #1549 (permalink)
Member: 337837
Thanks Meter: 536
The Following User Says Thank You to sairat For This Useful Post:
Old 11-09-2009, 12:06   #1550 (permalink)
Member: 1008455
Sonork: 0000
Thanks Meter: 98
Press power on !
Start auth !
SW Ver: P1.2JD01V01.04:ULC2GL
Imei: 353081032710462
PhoneLock Reset success !
Unlocked !
Done !
Time needed - 00:00:07
Press power on !
Start auth !
Imei: 353081032435466
Unlocked !
Done !
Time needed - 00:00:11
Press power on !
Start auth !
SW Ver: P1.2JD02V01.01
Imei: 358832025107636
Unlocked !
Done !
Time needed - 00:00:08
Press power on !
Start auth !
SW Ver: P1.2JD01V01.03:ULC2GL
Imei: 358545028620955
Unlocked !
Done !
Time needed - 00:00:06
Old 11-09-2009, 16:44   #1551 (permalink)
adelgsm's Avatar
Member: 476287
Sonork: 100.1587961
Thanks Meter: 833
sagem my 421z code read done
MCU ID: 2C700118846700C2000000000000BC6A
ROM HASH: 731C27AB2AE00189FBD4FD3013B53252
ROM VER: 05.02
Authorising ...
Exploiting ...
Sending applet ...
Flash ID(0): 0001:317E:4100
Plain datadone;
Model: my421Z
Hash: 00002108
Algo: 07
Firmware: EON,TF: 061008 1200
Imei: 3************
Phone code: 0000
Prod. code: 254063571
CODES:
NET LO CODE: 1779861723
NET HI CODE: 1873468628
Done !
Time needed - 00:02:23
Old 11-10-2009, 03:32   #1552 (permalink)
Member: 180833
Sonork: 100.1578281
Thanks Meter: 215
Sagem 411x Unlock Successfully
MCU ID: 24D00013A2AD63C1000000000000B433
ROM VER: 05.02
Authorising ...
Exploiting ...
Sending applet ...
Plain datadone;
Model: my411X
Hash: 00002054
Algo: 05
Firmware: LO5,RF: 280607 1806
Imei: 351628021761682
Phone code: 0000
Prod. code: 252925020
CODES:
NET LO CODE: 1833381700
NET HI CODE: 0763833476
DIRECT UNLOCK: ERROR
Done !
Time needed - 00:03:33
Old 11-10-2009, 07:20   #1553 (permalink)
mali_comm's Avatar
Member: 1145301
Thanks Meter: 116
Vodafone 527 Successfully Unlock
MCU ID: 134002119C8B46C1000000000000F636
ROM VER: 05.02
Authorising ...
Exploiting ...
Sending applet ...
Plain datadone;
Model: VF527
Hash: 00002947
Algo: 07
Firmware: EVN,PL: 050808 1804
Imei: 35926-------------
Phone code: 0000
Prod. code: 254060202
CODES:
NET LO CODE: 1567505076
NET HI CODE: 0356825117
DIRECT UNLOCK: OK
Done !
Time needed - 00:02:17
Old 11-10-2009, 08:38   #1554 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 999
MY 411C unlock ok
MCU ID: 2F50020544A246C10000000000008801
ROM VER: 05.02
Authorising ...
Exploiting ...
Sending applet ...
Plain datadone;
Model: my411C
Hash: 00002C18
Algo: 05
Firmware: EMN,BL: 160108 1742
Imei: 35797001321xxxx
Phone code: 0000
Prod. code: 253043447
CODES:
NET LO CODE: 2792181167
NET HI CODE: 3861728623
DIRECT UNLOCK: OK
Done !
Time needed - 00:02:41
Old 11-10-2009, 11:46   #1555 (permalink)
mali_comm's Avatar
Member: 1145301
Thanks Meter: 116
Vodafone 527 Unlock Successfully
ROM VER: 05.02
Authorising ...
Exploiting ...
Sending applet ...
Plain datadone;
Model: VF527
Hash: 00002947
Algo: 07
Phone code: 0000
CODES:
DIRECT UNLOCK: OK
Done !
THANKS Furious Team
The Following User Says Thank You to mali_comm For This Useful Post:
Old 11-10-2009, 11:51   #1556 (permalink)
pawansingh's Avatar
Member: 306087
Thanks Meter: 24
LG CU 500unlocked successfully 3G at&t locked
here is the log
Searching phone ...
MODEL : CU500
COMPILED DATE : Aug 3 2006 11:29:00
RELEASE DATE : Aug 3 2006 13:00:00
FIRMWARE INFO : CU500-MSM32701001-V10c-Aug-03-2006-CW-US
IMEI : 01085100834718-3
BLUETOOTH ADDR : 00 19 A1 0B CF 4D
MEMORY ID : 0098:0076
MEMORY NAME : toshiba_ty90009c00sogg
MEMORY SIZE : 35MB
PERFORMING OPERATION ...
READING NV ...
READY...
SW VERSION: [OK] CU500FL-V10c-2006-Aug-03-310-410-00-00-00
IMEI: [OK] 01085100834718304
BLUETOOTH ADDR: [OK] 4DCF0BA11900
FORMAT: [OK] IDDE OK
Old 11-10-2009, 13:29   #1557 (permalink)
Member: 245026
Thanks Meter: 379
motorola ve538 unlock ok
Software engine version: 1.0.0.3071
Searching phone ...
MODEL : QCOM SERIES 2
COMPILED DATE : Mar 16 2009 11:10:00
RELEASE DATE : Mar 16 2009 10:05:00
FIRMWARE INFO : O'zapft is000Athens2.08ATHB1A_2.08P0
IMEI : 3588888888888
BLUETOOTH ADDR : 6E 48 5B CA 17 00
MEMORY ID : 00AD:0036
MEMORY NAME : hynix_HYC0SEH0AF3P
MEMORY INFO : 0200:0020:06ED
INIT NAND ROUTINES;
NAND INIT MADE;
PROCESS STARTED;
DATA FOUND;
PHONE CODE: 1234
RL STARTED;
RL DONE;
UNLOCK CODE(S): 59646186
MASTER CODE: 73083793
ENTER CODE(S) NOW ! DO NOT RESTART THE PHONE !
IF PHONE DOESN'T ASK ANY CODE OR YOU RESTART IT THEN REPEAT THE OPERATION !
Time needed - 00:00:09
Old 11-10-2009, 13:59   #1558 (permalink)
rajesh_ch's Avatar
Member: 618404
Sonork: 100.1624568
Thanks Meter: 287
>>>>>another u970 successfully unlocked<<<<<<<<<<
u970 unlocked successfully.
thanks.furious team.
wbr.
rajesh ch.
Old 11-11-2009, 08:01   #1559 (permalink)
rajesh_ch's Avatar
Member: 618404
Sonork: 100.1624568
Thanks Meter: 287
u450 lg unlock successfully.
u450 lg unlock successfully without any problem..
thanks furious.
wbr.
rajesh ch.
Old 11-11-2009, 09:06   #1560 (permalink)
HAMMZA_MOBILES's Avatar
Member: 718939
Thanks Meter: 90
AgAiN BlACk beRRY 9000 UNlOcK DoNE
Searching for usb device ...
Reading info ...
IMEI: 355256026758168
Calculating ...
MEP: MEP-06813-002
MEP2 CODE: 0041534657940586
How to enter codes in BlackBerry
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (where needed)
7. Type MEPPD or MEPD (you will not be able to see the typed info)
8. Enter MEP2 or MEPP2
9. Now it will say enter network mep code
Done !
Time needed - 00:07:15
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.53496 seconds with 9 queries
