11-14-2009, 08:49 | #1591 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Searching phone ... MODEL : U300 COMPILED DATE : Sep 28 2006 19:04:00 RELEASE DATE : Sep 28 2006 17:00:00 FIRMWARE INFO : U300-MSM6250A-V10h-SEP-28-2006-H3G-UK IMEI : 35928800056610-7 BLUETOOTH ADDR : 63 BE 4C 56 12 00 MEMORY ID : 0098:0076 MEMORY NAME : toshiba_ty90009800cogg MEMORY INFO : 0200:0020:0900 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35928800056610700 BLUETOOTH ADDR: [OK] 63BE4C561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:09 |
The Following User Says Thank You to vodafoneserver For This Useful Post: |
11-14-2009, 09:30 | #1592 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037897975 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_13.26.29_14.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:21 |
11-14-2009, 09:47 | #1593 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081xxxxxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_19.39.09_14.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:15 |
11-14-2009, 10:03 | #1594 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Proud To Be A Muslim Age: 39
Member: 434968 Status: Offline Sonork: 100.1590883 Thanks Meter: 580 | T156 new unlock with f.g Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037431346 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_14.00.41_14.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:06 |
The Following 8 Users Say Thank You to diljan_07 For This Useful Post: |
11-14-2009, 11:10 | #1595 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | aConnect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081036989351 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037201236 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_15.03.36_14.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:19 Reading ... Saved: HUAWEI_15.01.13_14.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:20 |
11-14-2009, 11:48 | #1596 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | kp 170 unlock ok FG Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:18 |
11-14-2009, 12:17 | #1598 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Press power on shortly ... Starting communication ... MCU ID: 24A002133D0068C10000000000007809 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411C Hash: 00002C18 Algo: 05 Firmware: EMN,BL: 160108 1742 Imei: 357970012235332 Phone code: 0000 Prod. code: 253043447 Id calculation done; CODES: NET LO CODE: 2538978778 NET HI CODE: 3608526106 Done ! Time needed - 00:01:50 |
11-14-2009, 13:09 | #1599 (permalink) |
No Life Poster Join Date: Sep 2005 Location: PAKISTAN Age: 39
Member: 181886 Status: Offline Sonork: 100.1579817 Thanks Meter: 1,007 | t156 unlock done Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 35308 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_15.43.53_14.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:11 |
11-14-2009, 15:32 | #1600 (permalink) |
Freak Poster Join Date: Mar 2008 Location: I Don,t Know Age: 38
Member: 718939 Status: Offline Thanks Meter: 90 | AgAiN Black Berry 8310 unlock done Searching for usb device ... Reading info ... IMEI: 359158024141015 Calculating ... MEP: MEP-04598-005 MEP2 CODE: 0742094508727577 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:10 |
11-14-2009, 15:33 | #1601 (permalink) |
Member: 718939 Status: Offline Thanks Meter: 90 | AgAiN LG CU720 UnLoCK doNE Software engine version: 1.0.0.3071 Searching phone ... MODEL : CU720 COMPILED DATE : Mar 26 2008 12:40:00 RELEASE DATE : Oct 3 2007 23:00:00 FIRMWARE INFO : CU720-MSM4090201C-V10l-MAR-26-2008-ATT-US IMEI : 01167900463023-0 BLUETOOTH ADDR : 38 C9 8D E3 1F 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:26 |
11-14-2009, 15:35 | #1602 (permalink) |
Member: 718939 Status: Offline Thanks Meter: 90 | AgAiN 20 set T156 unlock done NEW SECURITY (CY,B) Connect phone powered on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081036530478 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_19.23.08_14.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:22 |
11-15-2009, 06:08 | #1603 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | T156 Ufone Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 35 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_12.22.02_14.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:59 |
11-15-2009, 06:08 | #1604 (permalink) |
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | T156 Ufone Unlock Again. Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 35 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_12.22.02_14.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:59 |
11-15-2009, 06:09 | #1605 (permalink) |
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | T156 Ufone Again Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 35 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_12.22.02_14.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:59 |
