11-15-2009, 18:00 | #1621 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Al-Madina Communication Age: 45
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Start auth ! SW Ver: P1.2PU03V01.01 Imei: Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_21.49.25_15.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:22 |
The Following User Says Thank You to alis For This Useful Post: |
11-15-2009, 22:15 | #1622 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Where Dreams Comes True...S4U
Member: 755709 Status: Offline Sonork: 100.1592000 Momo... Thanks Meter: 6,635 | another succfull operation from first class with sagem phoneS: Press power on shortly ... Starting communication ... MCU ID: 21800215B1F458C1000000000000DE6D ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411X Hash: 00002056 Algo: 05 Firmware: LO5,RE: 120407 1623 Imei: 355150010800500 Phone code: 0000 Prod. code: 252904539 Id calculation done; CODES: NET LO CODE: 3762171235 NET HI CODE: 2692623779 DIRECT UNLOCK: OK Done ! Time needed - 00:02:14 |
11-16-2009, 09:34 | #1623 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_13.18.17_16.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:10 |
11-16-2009, 10:57 | #1624 (permalink) |
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | one more unlock Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_14.53.36_16.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:10 |
11-16-2009, 12:38 | #1625 (permalink) |
No Life Poster Join Date: Dec 2006 Location: RWP Pakistan
Member: 420821 Status: Offline Sonork: 100.1603493 Thanks Meter: 731 | unlock success 9530 Searching for usb device ... Reading info ... IMEI: 3521100399***** Calculating ... MEP: MEP-15326-001 MEP2 CODE: 8939309282872338 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code |
11-16-2009, 12:46 | #1626 (permalink) |
Freak Poster Join Date: Mar 2008 Location: I Don,t Know Age: 38
Member: 718939 Status: Offline Thanks Meter: 90 | AgAin 20 Set U-FONE UnLocK DonE Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039424471 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.16.38_14.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:35 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039197481 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_13.43.54_15.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:28 Connect phone powered on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081036531666 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_14.13.00_15.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:35 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037755223 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_13.18.17_16.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:09 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038180371 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_14.53.49_16.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:16 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038387539 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_15.21.01_16.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:19 |
11-16-2009, 13:41 | #1627 (permalink) |
Banned Join Date: Nov 2007 Age: 36
Member: 631286 Status: Offline Thanks Meter: 1,250 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039299873 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_17.41.09_16.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:09 |
11-16-2009, 14:38 | #1628 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 3 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_18.34.25_16.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:04 |
11-16-2009, 14:39 | #1629 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Online Sonork: 100.1584069 Thanks Meter: 473 | LG U890 unlock done thanks Furious team Software engine version: 1.0.0.3071 Searching phone ... MODEL : U890 COMPILED DATE : Apr 18 2006 14:28:00 RELEASE DATE : Apr 18 2006 17:00:00 FIRMWARE INFO : U890-MSM6250A-V10a_wm-APR-18-2006-H3G-IT IMEI : 3592-------------- BLUETOOTH ADDR : 67 0C 34 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 359---------- BLUETOOTH ADDR: [OK] 670C34561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:25 |
11-16-2009, 14:56 | #1630 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037156505 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_18.53.22_16.11.2009_PARTIAL.bin Unlocked ! Remove battery and put back ! Time needed - 00:01:02 |
11-16-2009, 14:58 | #1631 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081033335350 PhoneLock Reset success ! Error ... ! Time needed - 00:00:06 |
11-16-2009, 15:04 | #1632 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my100X Hash: 00001D38 Algo: 05 Firmware: LB5,JC: 251006 1146 Imei: 351989010096922 Phone code: 00000000 Prod. code: 252795498 Id calculation done; CODES: NET LO CODE: 2599932318 NET HI CODE: 3669479774 DIRECT UNLOCK: ERROR Done ! Time needed - 00:01:54 |
11-17-2009, 06:24 | #1633 (permalink) |
Member: 631286 Status: Offline Thanks Meter: 1,250 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037320473 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_10.23.38_17.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:11 |
11-17-2009, 06:40 | #1634 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | lg gw300 Successfully Unlocked Attach USB cable now ... Phone detected ! USB Port opened ! RamLoader download success; Config done ! Authorising; Authorisation passed; Getting memory info; Memory: EC000000B1 Getting unlock data; Checking unlock data; Calculating; IMEI: 35573703068821800 Codes: 6317136954366348 6317136954366948 2149823683170486 Enter codes using 2945#*71001# Restarting; Time needed - 00:00:23 |
The Following User Says Thank You to vodafoneserver For This Useful Post: |
11-17-2009, 07:26 | #1635 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037807883 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_11.16.58_17.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:14 |
