11-23-2009, 08:01 | #1698 (permalink) |
Banned Join Date: Nov 2007 Age: 36
Member: 631286 Status: Offline Thanks Meter: 1,250 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039046274 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_12.00.53_23.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:24 |
11-23-2009, 08:57 | #1699 (permalink) |
Member: 631286 Status: Offline Thanks Meter: 1,250 | Searching USB device ... Device found and connected. Booting ... Starting communication ... BootRom v05.02 Sending bootloader ... Bootloader started ! Flash ID(0): 0089:8874:0000 Reading eeprom image ... Saved: LOCOSTO_EEP_12.56.50_23.11.2009_00010000.bin Writing eeprom image ... Direct unlock finished ! Done ! Time needed - 00:00:06 |
11-23-2009, 09:03 | #1700 (permalink) |
No Life Poster Join Date: Jul 2007 Location: PK
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | my411c successful unlock.... Code: Press power on shortly ... Starting communication ... MCU ID: 24B00107F7BC63C10000000000009A0D ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411C Hash: 00002C18 Algo: 05 Firmware: EAN,BL: 100108 1147 Imei: 357970011578971 Phone code: 0000 Prod. code: 253043447 Id calculation done; CODES: NET LO CODE: 1135882544 NET HI CODE: 0066335216 DIRECT UNLOCK: ERROR Done ! Time needed - 00:02:58 |
11-23-2009, 09:32 | #1701 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | designed by inq3 unlock ok FG Software engine version: 1.0.0.3179 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Apr 22 2009 14:35:00 RELEASE DATE : Nov 12 2008 22:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_8A IMEI : 35454102144220-2 BLUETOOTH ADDR : EA 45 4E 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:07 |
The Following User Says Thank You to shahid41 For This Useful Post: |
11-23-2009, 11:54 | #1702 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038702356 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_15.50.48_23.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:16 |
11-23-2009, 14:11 | #1703 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:25 |
The Following 3 Users Say Thank You to vodafoneserver For This Useful Post: |
11-23-2009, 15:54 | #1704 (permalink) |
No Life Poster Join Date: Sep 2005 Location: PAKISTAN Age: 39
Member: 181886 Status: Offline Sonork: 100.1579817 Thanks Meter: 1,007 | my511x unlock done Press power on shortly ... Starting communication ... MCU ID: 2A8001138ABC63C1000000000000AC27 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: Sagem my511X Hash: 00002786 Algo: 05 Firmware: EON,DF: 010408 1801 Imei: 3568670p hone code: 0000 Prod. code: 253045884 Id calculation done; CODES: NET LO CODE: 2876707378 NET HI CODE: 3946255090 Done ! Time needed - 00:02:22 |
11-24-2009, 04:43 | #1705 (permalink) |
Freak Poster Join Date: Mar 2008 Location: I Don,t Know Age: 38
Member: 718939 Status: Offline Thanks Meter: 90 | AgAiN U890 UnLoK DonE first flash with special firmware Software engine version: 1.0.0.3248 Searching phone ... MODEL : U890 COMPILED DATE : Jun 7 2006 15:56:00 RELEASE DATE : Jun 7 2006 17:00:00 FIRMWARE INFO : U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-UK IMEI : 35921300076437-9 BLUETOOTH ADDR : 6F 31 2F 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35921300076437900 BLUETOOTH ADDR: [OK] 6F312F561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:02:18 |
11-24-2009, 05:00 | #1706 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Software engine version: 1.0.0.3248 Searching phone ... MODEL : QCOM SERIES 1 COMPILED DATE : Oct 16 2006 10:23:00 RELEASE DATE : Aug 3 2006 00:00:00 FIRMWARE INFO : M6250D-VMSY-6.2.9343T IMEI : 35209101046566-7 BLUETOOTH ADDR : 7A 11 37 40 12 00 MEMORY ID : 00EC:0036 MEMORY NAME : samsung_k9f1208 MEMORY INFO : 0200:0020:08C0 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:07 |
11-24-2009, 05:08 | #1707 (permalink) |
Member: 718939 Status: Offline Thanks Meter: 90 | AgAiN U880 UnLoCk DonE first flash with special firmware Software engine version: 1.0.0.3248 Searching phone ... MODEL : U880 COMPILED DATE : Feb 20 2006 09:02:00 RELEASE DATE : Jul 3 2005 16:00:00 FIRMWARE INFO : U880-MSM6250-V10b_wm-FEB-08-2006-H3G-UK IMEI : 35705000673922-5 BLUETOOTH ADDR : 90 71 0A 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35705000673922500 BLUETOOTH ADDR: [OK] 90710A561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: OFF NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:02:22 |
11-24-2009, 05:53 | #1708 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1145301 Status: Offline Thanks Meter: 116 | Lg KP170 unlock successfully Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:01:08 |
11-24-2009, 09:35 | #1709 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0098:004A:0001 READING INFO ... WAIT ! (CAN TAKE ~60s) DATE: Oct 16 2006 OPERATOR: 234-30 VERSION: V10a REVISION: 44 FIRMWARE: KG800P64FL IMEI: 35263801885276500 LOCK: ON Phone unlocked. Phone reseted ! Time needed - 00:00:29 |
11-24-2009, 10:58 | #1710 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038702729 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_14.53.27_24.11.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:13 |
