12-10-2009, 10:19 | #1921 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Al-Madina Communication Age: 45
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Start auth ! SW Ver: P1.2nV01.05:ULC2GL Imei: 359428010127413 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:12 |
The Following User Says Thank You to alis For This Useful Post: |
12-10-2009, 10:22 | #1922 (permalink) |
No Life Poster Join Date: Feb 2005
Member: 113097 Status: Offline Thanks Meter: 365 | sagem my511x successfully unlocked By Furious Press power on shortly ... Starting communication ... MCU ID: 22300002F08F63C10000000000001852 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my511X Hash: 00002440 Algo: 05 Firmware: EVN,DC: 261007 1227 Imei: 3568************ Phone code: 0000 Prod. code: 252996467 Id calculation done; CODES: NET LO CODE: 3481099309 NET HI CODE: 2411551981 DIRECT UNLOCK: OK Done ! Time needed - 00:02:24 |
12-10-2009, 11:48 | #1923 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Ufone T156 new version successfully unlocked: Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 35....................... Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_15.40.04_10.12.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:13 |
12-10-2009, 12:28 | #1924 (permalink) |
No Life Poster Join Date: Apr 2009 Location: lebanon Age: 37
Member: 1008455 Status: Offline Sonork: 0000 Thanks Meter: 99 | take this boooomb Press power on shortly ... Starting communication ... MCU ID: 2820030143A246C1000000000000E412 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411C Hash: 00002C18 Algo: 05 Firmware: EMN,BL: 160108 1742 Imei: 357970013641058 Phone code: 0000 Prod. code: 253043447 Id calculation done; CODES: NET LO CODE: 1786061227 NET HI CODE: 0708125035 DIRECT UNLOCK: OK Done ! Time needed - 00:02:21 -------------------------------------- Insert Battery In Phone ! Starting communication ... Speed changed ... Sending boot ... Boot sent ... Application started ... Flash ID : 0001:227E IMEI : 01074200442860-8 Version : C2000P64FL_ Lock : ON Phone successfully unlocked. Enter 2945#*# without a sim inside and select 'Fact. Reset'. Time needed - 00:00:04 ------------------------------------ Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 15549926 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:16 ------------------------------------ Connect phone powered on ! Start auth ! SW Ver: P1.2JD01V01.04:ULC2GL Imei: 353081032819123 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:05 ------------------------------------ Searching for usb device ... Reading info ... IMEI: 359675015091362 Calculating ... MEP: MEP-04104-007 MEP2 CODE: 2310250118000298 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:13 ---------------------------------------------- Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0001:227E:2100 READING INFO ... WAIT ! (CAN TAKE ~60s) DATE: VUK JUL 24 2007ERATOR: 234-30 VERSION: V10a REVISION: 44 FIRMWARE: KG130P40FL IMEI: 35531101288715600 LOCK: ON Writting flash data ... Operation completed. Phone reseted ! Time needed - 00:14:44 =================================== Searching for usb device ... Reading info ... IMEI: 355771014500273 Calculating ... MEP: MEP-15326-002 MEP2 CODE: 62552789 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:11 ------------------------------------- BBPIN: 2030BD94 Detected: RIM 7100 Series Colour GPRS Handheld Platform version: 1.8.0.154 NET Unlock Code (10) : 1465544804874936 (Active) Operator: 3101500 Time needed - 00:01:00 ---------------------------------------- Press power on ! Starting communication ... Platform: E-Gold Lite ... Preloader sent .... Loader sent .... Flash ID(0): 0001:011A Bypassing security ... LOCK: ACTIVE IMEI: 353999032430585 UNLOCK CODE: 46006855 Saved: INFINEON_11.18.05_10.12.2009_EEP.bin REMOVE BATTERY AND PUT BACK ! Time needed - 00:00:16 ------------------------------------------- |
The Following User Says Thank You to ehab tabshy For This Useful Post: |
12-10-2009, 13:18 | #1925 (permalink) |
Freak Poster Join Date: Jan 2008 Location: shariatpur bangladesh Age: 44
Member: 682052 Status: Offline Thanks Meter: 8 | lg c1100 Press Power On ! Starting communication ... Sending application ... Application started ... Flash ID : 0098:0084 IMEI : 35619200469515-6 Version : _ Lock : ON Phone successfully unlocked. Enter 2945#*# without a sim inside and select 'Fact. Reset'. Time needed - 00:00:07 must be use RJ45 |
12-10-2009, 13:20 | #1926 (permalink) |
Member: 682052 Status: Offline Thanks Meter: 8 | u370 Software engine version: 1.0.0.3311 Searching phone ... MODEL : U370 COMPILED DATE : Dec 20 2007 15:20:00 RELEASE DATE : May 17 2007 14:00:00 FIRMWARE INFO : U370W-MSM6245-V10c-DEC-20-2007-XX IMEI : 35839101180981-2 BLUETOOTH ADDR : EE 01 CF 75 1E 00 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY INFO : 0800:0040:0308 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:07 |
12-10-2009, 13:41 | #1927 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 200548 Status: Offline Thanks Meter: 104 | cu720 unlock done Software engine version: 1.0.0.3260 Searching phone ... MODEL : CU720 COMPILED DATE : Mar 26 2008 12:40:00 RELEASE DATE : Oct 3 2007 23:00:00 FIRMWARE INFO : CU720-MSM4090201C-V10l-MAR-26-2008-ATT-US IMEI : 01148700460436-5 BLUETOOTH ADDR : 5D DA 86 6B 1F 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:22 |
12-10-2009, 13:44 | #1928 (permalink) |
12-10-2009, 17:19 | #1929 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038230390 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_20.45.15_10.12.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:32 |
12-10-2009, 18:33 | #1930 (permalink) |
No Life Poster Join Date: Dec 2003 Location: MX-KEY is the BEST NOKIA TOOL
Member: 46042 Status: Offline Sonork: 100.1575650 Thanks Meter: 93 | Connect phone powered on ! Start auth ! SW Ver: P1.2ZM03V01.02 Imei: 3563340******** Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_13.01.48_10.12.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:17 |
12-11-2009, 12:57 | #1931 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Android developers
Member: 904753 Status: Offline Sonork: 100.1583681 Thanks Meter: 2,677 | Model : LG KU990i 3G Software engine version: 1.0.0.3311 Searching phone ... MODEL : KU990i COMPILED DATE : Mar 22 2009 14:51:00 RELEASE DATE : Mar 12 2009 17:00:00 FIRMWARE INFO : KU990i-MSM6280-V10c-MAR-12-2009-XX IMEI : 35469303529880-5 BLUETOOTH ADDR : 0E 21 54 83 24 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] Invalid Module Software Version IMEI: [OK] 354693035298805 BLUETOOTH ADDR: [OK] 00248354210E PLAYING MUSIC ... WAIT; DOING CONFIG; NAND INIT MADE; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:02:22 Br. Waqar |
12-11-2009, 14:19 | #1932 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037152439 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_18.06.11_11.12.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:31 |
12-11-2009, 14:20 | #1933 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081039958080 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_18.20.08_11.12.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 |
12-12-2009, 07:43 | #1934 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | ku990i unlock done Software engine version: 1.0.0.3071 Searching phone ... MODEL : KU990i COMPILED DATE : Mar 22 2009 17:28:00 RELEASE DATE : Mar 20 2009 17:00:00 FIRMWARE INFO : KU990i-MSM6280-V10d-MAR-20-2009-XX IMEI : 35994402826703-3 BLUETOOTH ADDR : 8A 51 CF A9 22 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] Invalid Module Software Version IMEI: [OK] 359944028267033 BLUETOOTH ADDR: [OK] 0022A9CF518A PLAYING MUSIC ... WAIT; DOING CONFIG; NAND INIT MADE; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:01:18 |
The Following 2 Users Say Thank You to naveedbutt For This Useful Post: |
12-12-2009, 07:48 | #1935 (permalink) |
Freak Poster Join Date: Mar 2007 Location: i love pakistan Age: 47
Member: 458868 Status: Offline Sonork: 100.1597325 Thanks Meter: 27 | u300 unlocked Software engine version: 1.0.0.3311 Searching phone ... MODEL : U300 COMPILED DATE : Sep 28 2006 19:04:00 RELEASE DATE : Sep 28 2006 17:00:00 FIRMWARE INFO : U300-MSM6250A-V10h-SEP-28-2006-H3G-UK IMEI : 3592880000xxxxxx BLUETOOTH ADDR : 41 B7 45 56 12 00 MEMORY ID : 0098:0076 MEMORY NAME : toshiba_ty90009800cogg MEMORY INFO : 0200:0020:0900 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 359288000xxxxxx BLUETOOTH ADDR: [OK] 41B745561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:15 |
