01-05-2010, 09:54 | #2191 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Vodafone 527 unlocked successfully Thanks Furious Team. Press power on shortly ... Starting communication ... MCU ID: 2250030144A246C10000000000006205 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 00002910 Algo: 05 Firmware: EVN,PJ: 160908 1057 Imei: 35 Phone code: 0000 Prod. code: 254053893 Id calculation done; CODES: NET LO CODE: 1110893286 NET HI CODE: 0049741094 DIRECT UNLOCK: OK Done ! Time needed - 00:03:20 Qaisar telecom |
The Following 2 Users Say Thank You to Qaisar Mahmood For This Useful Post: |
01-05-2010, 12:09 | #2192 (permalink) |
No Life Poster Join Date: Mar 2006 Location: morroco
Member: 245026 Status: Offline Thanks Meter: 382 | zte md-2 Software engine version: 1.0.0.3338 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Sep 5 2007 22:23:00 RELEASE DATE : Apr 13 2007 15:00:00 FIRMWARE INFO : P621C1V1.1.0B01 IMEI : 35***********-2 BLUETOOTH ADDR : 89 46 1B EB 15 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_hyg0sgh0mf3 MEMORY INFO : 0200:0020:133B INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; UNLOCK CODE: 9499999918422132 ENTER USING: *983*865625# RESET ! Time needed - 00:00:11 |
01-05-2010, 12:14 | #2193 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038541937 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_16.12.46_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:49 |
01-05-2010, 14:03 | #2195 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | u900 unlocking done once again.. Software engine version: 1.0.0.3338 Searching phone ... MODEL : U900 COMPILED DATE : Jan 23 2007 10:39:00 RELEASE DATE : Jan 23 2007 12:00:00 FIRMWARE INFO : U900-MSM6250A-V11g-JAN-23-2007-H3G-IT IMEI : 3593xxxxxxxxxx-x BLUETOOTH ADDR : DB 74 43 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 3593xxxxxxxxx-x BLUETOOTH ADDR: [OK] DB7443561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:02:13 |
01-05-2010, 14:51 | #2196 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 3530 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_18.07.42_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:12 |
01-05-2010, 17:08 | #2197 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Supporters also work... KP502 Vodafone UNLOCKED Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 43821816 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:23 Regards Furious Support |
The Following User Says Thank You to FTEAM_MODERATOR For This Useful Post: |
01-06-2010, 06:11 | #2198 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | t156 ayz unlock done with out open phone. 1000% ok see here 05 set done report Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031778847 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_14.42.14_04.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:14 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031752834 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_15.13.58_04.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:10 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031770331 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_15.17.48_04.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:09 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031770356 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_15.20.27_04.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:06 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031771842 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_15.23.36_04.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:07 BR, themobileshop |
01-06-2010, 06:15 | #2199 (permalink) |
Member: 977491 Status: Offline Thanks Meter: 82 | Zong set unlock done. Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 Imei: 354354030163953 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_14.48.03_04.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:14 |
01-06-2010, 06:18 | #2200 (permalink) |
Member: 977491 Status: Offline Thanks Meter: 82 | see here 5 t156 old version cy or b unlock done reports Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037893693 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_23.56.43_01.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:05 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039402790 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_04.58.33_02.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:07 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038755511 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_12.49.56_04.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:06 Connect phone powered on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034725799 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_12.51.55_04.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:08 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081033813000 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_12.47.53_04.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:09 BR, themobileshop |
01-06-2010, 10:47 | #2201 (permalink) |
Freak Poster Join Date: Sep 2006 Location: pakistan
Member: 355565 Status: Offline Sonork: 1597522 Thanks Meter: 95 | Huawei t156 ayz 100 pcs unlock today TODAY I UNLOCK HUAWEI T156 NEW SECURITY AYZ 100 PCS WITHOUT OPEN SUCCESSFULLY.THANX FURIOUSE TEAM KEEP GIVING UPDATES LIKE THAT special thanx to navad he modified cable for me Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031761371 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_13.50.58_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:14 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031770034 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_14.39.11_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:08 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031865503 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_16.44.46_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:11 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031851990 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_20.37.35_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:08 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031862005 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_20.41.54_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:04 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031861742 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_20.44.48_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:03 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031860462 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_20.48.00_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:03 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031862583 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_20.59.44_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:58 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031836553 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.02.29_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031858474 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.08.05_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031856155 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.10.47_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:40 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031861197 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.13.08_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031850331 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.22.07_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:45 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031809477 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.25.09_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031811531 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.26.44_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:43 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031819641 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.28.10_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031834954 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.30.05_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:34 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031850083 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.31.45_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031825952 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.33.29_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:35 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031812703 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.34.57_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031817488 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.37.13_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:40 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031807018 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.38.37_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031804296 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.45.35_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031836116 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.47.20_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:41 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031819757 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.50.14_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031835191 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.52.25_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031850190 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.53.54_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:35 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031821100 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.55.25_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031745374 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.00.19_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031763773 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.02.58_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031770570 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.04.26_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031749517 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.05.59_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031751463 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.07.29_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031777286 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.08.50_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031776635 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.10.12_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031764904 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.11.32_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031771628 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.12.57_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:42 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031769598 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.14.38_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031776643 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.16.00_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031776874 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.17.44_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031775736 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.19.20_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031772105 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.20.51_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:46 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031771602 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.23.57_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031776221 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.25.21_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031775769 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.26.46_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031844805 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.31.25_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:44 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031815284 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.33.14_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031846149 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.35.27_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:07 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031846453 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.37.32_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031807612 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.38.56_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:40 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031844888 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.40.33_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:42 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031843484 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.42.07_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031780488 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.43.37_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031846891 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.44.59_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031821894 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.46.22_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031827586 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.47.50_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031845943 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.49.12_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:35 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031846685 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.50.27_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031846297 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.51.58_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031845497 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.53.32_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:35 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031822223 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.54.49_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031816753 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.56.21_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:42 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031808925 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.57.45_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031818668 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_22.59.06_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031846479 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_23.00.24_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:35 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031848947 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_23.02.32_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031785966 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_23.04.06_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031864134 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_23.05.36_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031864928 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_23.06.55_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031864795 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_23.08.19_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031867186 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_23.09.37_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031864787 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_23.10.58_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:35 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031848863 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_23.12.21_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:41 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031847436 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_23.15.51_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031849341 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_23.17.32_05.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031829541 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_11.14.10_06.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:03 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031866089 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_11.16.14_06.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:08 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031830077 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_11.18.14_06.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:02 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031846610 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_11.20.13_06.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:02 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031865859 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_11.22.02_06.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:04 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031856718 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_11.24.25_06.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:06 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031866113 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_11.26.43_06.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:02 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031791121 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_11.29.06_06.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:04 Last edited by super decent; 01-06-2010 at 10:54. |
01-06-2010, 11:01 | #2202 (permalink) |
Freak Poster Join Date: Mar 2007 Location: i love pakistan Age: 47
Member: 458868 Status: Offline Sonork: 100.1597325 Thanks Meter: 27 | Zong set unlock done Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 Imei: 354354030>>>>>>> Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_11.23.26_06.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:02:53 |
01-06-2010, 11:20 | #2203 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | zong a316g+ unlock done thanx by furiuose team Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 Imei: 354354030184504 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_03.05.58_06.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:13 |
01-06-2010, 11:25 | #2204 (permalink) |
Freak Poster Join Date: Apr 2008 Age: 40
Member: 752606 Status: Offline Sonork: 100.1587361 Thanks Meter: 110 | zte a136G+ unlock done Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 Imei: 354354030277423 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_15.23.34_06.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:24 |
01-06-2010, 14:08 | #2205 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Swansea, UK Age: 41
Member: 523318 Status: Offline Thanks Meter: 268 | CU515 Software engine version: 1.0.0.3338 Searching phone ... MODEL : CU515 COMPILED DATE : Nov 27 2007 17:51:00 RELEASE DATE : Sep 5 2007 04:00:00 FIRMWARE INFO : CU515-MSM21302430-V10g-NOV-27-2007-ATT-US IMEI : 01166600162xxx-x BLUETOOTH ADDR : D8 67 9D E3 1F 00 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY INFO : 0800:0040:02D3 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:19 |
