01-13-2010, 10:53 | #2341 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | Code: Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 Imei: 354354031090700 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_14.51.17_13.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 |
01-13-2010, 11:45 | #2342 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Software engine version: 1.0.0.3338 Searching phone ... MODEL : KU990 COMPILED DATE : Jan 16 2008 16:47:00 RELEASE DATE : Sep 27 2007 17:00:00 FIRMWARE INFO : KU990-MSM6280-V10a-SEP-27-2007-XX IMEI : 35363802205614-7 BLUETOOTH ADDR : 21 8B 1D 6B 1F 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:05 |
01-13-2010, 12:46 | #2343 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Al-Madina Communication Age: 45
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 Imei: 354354030935038 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_10.59.31_13.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:03 |
01-13-2010, 12:46 | #2344 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 Imei: 354354030960630 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_11.15.12_13.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:40 |
01-13-2010, 13:08 | #2345 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | huawei t156 unlock done huawei t156 unlock done Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039265189 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_17.05.38_13.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:15 |
01-13-2010, 13:09 | #2346 (permalink) |
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039263291 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_17.09.17_13.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:10 |
01-13-2010, 17:16 | #2347 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | ufone t156 unlock done....... Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081xxxxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_21.02.22_13.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:16 |
01-13-2010, 18:40 | #2348 (permalink) |
Crazy Poster Join Date: Mar 2008 Location: UAE Age: 40
Member: 724178 Status: Offline Thanks Meter: 15 | Searching for usb device ... Reading info ... IMEI: 356544033059541 Calculating ... MEP: MEP-04103-001 MEP2 CODE: 2782153822424661 MEP3 CODE: 4076911199128421 MEP4 CODE: 5054553876743909 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:28 |
01-13-2010, 18:58 | #2349 (permalink) |
Freak Poster Join Date: May 2005 Age: 45
Member: 143878 Status: Offline Thanks Meter: 9 | unlocked t6 Software engine version: 1.0.0.3338 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Nov 3 2008 13:15:00 RELEASE DATE : Sep 24 2008 23:00:00 FIRMWARE INFO : TEL_AU_P622C3V1.0.3B01-S IMEI : 35535202159267-6 BLUETOOTH ADDR : 57 01 8A 93 22 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_hyg0sgh0mf3 MEMORY INFO : 0200:0020:133D INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; UNLOCK CODE: 4341939926439315 ENTER USING: *983*865625# RESET ! Time needed - 00:00:10 |
01-14-2010, 06:33 | #2350 (permalink) |
Freak Poster Join Date: Mar 2008 Location: I Don,t Know Age: 38
Member: 718939 Status: Offline Thanks Meter: 90 | AgAiN BB 9000 DONe Searching for usb device ... Reading info ... IMEI: 980041009985761 Calculating ... MEP: MEP-06424-002 MEP2 CODE: 4991217813830419 MEP3 CODE: 1092267618767703 MEP4 CODE: 8885244501645276 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:36 |
01-14-2010, 08:34 | #2351 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | KE800 Unlock Successfully Press power on ! Starting communication ... Platform: S-Gold2 ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0089:887E 0404 Flash ID(1): 0089:887E 0404 Bypassing security ... LOCK: ACTIVE PHONE UNLOCKED ! REMOVE BATTERY AND PUT BACK ! Time needed - 00:04:45 Blackberry 7100 Unlock Successfully BBPIN: 204218D1 Detected: RIM 7100 Series Colour GPRS Handheld Platform version: 1.8.0.138 NET Unlock Code (10) : 3512100385153304 (Active) Operator: 234150 Time needed - 00:00:02 Thanxs |
01-14-2010, 09:12 | #2352 (permalink) |
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | huawei t156 unlock successfully huawei t156 unlock successfully Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037789487 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_13.11.49_14.01.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:21 |
01-14-2010, 09:14 | #2353 (permalink) |
Freak Poster Join Date: Apr 2009 Location: manila
Member: 1003463 Status: Offline Thanks Meter: 67 | BB 8250 curve read code ok Searching for usb device ... Reading info ... IMEI: 35593103846**** Calculating ... MEP: MEP-11414-002 MEP2 CODE: 8470395432542796 MEP3 CODE: 0183892245291333 MEP4 CODE: 1224884060132930 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:31 |
01-14-2010, 10:21 | #2354 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Software engine version: 1.0.0.3338 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Apr 22 2009 14:35:00 RELEASE DATE : Nov 12 2008 22:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_8A IMEI : 35454102097652-3 BLUETOOTH ADDR : 02 90 4D 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:07 |
