02-20-2010, 10:21 | #2911 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 Imei: 354354030055936 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_14.19.44_20.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:12 |
02-20-2010, 11:06 | #2912 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081xxxxxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_15.03.27_20.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 |
02-20-2010, 12:30 | #2914 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 3530xxxxxxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_16.27.52_20.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 |
02-20-2010, 15:12 | #2915 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | BB 9000 unlock Searching for usb device ... Reading info ... IMEI: 35184xxxxxxxxxx Calculating ... MEP: MEP-04598-005 MEP2 CODE: 0045822653582333 MEP3 CODE: 0217235489366069 MEP4 CODE: 6547810172627333 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:23 |
02-21-2010, 03:20 | #2916 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Where Dreams Comes True...S4U
Member: 755709 Status: Offline Sonork: 100.1592000 Momo... Thanks Meter: 6,635 | Software engine version: 1.0.0.3543 Searching phone ... MODEL : KU990i COMPILED DATE : Mar 21 2009 17:59:00 RELEASE DATE : Mar 13 2009 17:00:00 FIRMWARE INFO : KU990i-MSM6280-V10b-MAR-13-2009-XX IMEI : 35469303720189-8 BLUETOOTH ADDR : 31 D2 DF 83 24 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] Invalid Module Software Version IMEI: [OK] 354693037201898 BLUETOOTH ADDR: [OK] 002483DFD231 PLAYING MUSIC ... WAIT; DOING CONFIG; NAND INIT MADE; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:01:11 REGARDS FURIOUS TEAM. |
02-21-2010, 08:42 | #2917 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Searching for usb device ... Reading info ... IMEI: 354005024734585 Calculating ... MEP: MEP-11414-002 MEP2 CODE: 2773263943775539 MEP3 CODE: 7949035750974288 MEP4 CODE: 1846543868158530 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:33 |
02-21-2010, 11:21 | #2918 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | BLACKBERRY 8520 UNLOCKED LOG: Searching for usb device ... Reading info ... IMEI: 35390603XXXXXXX Calculating ... MEP: MEP-04104-007 MEP2 CODE: 0677936221515628 MEP3 CODE: 9815458481433216 MEP4 CODE: 0264585139983790 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:37 MIANLINKS |
02-21-2010, 13:50 | #2919 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | Lg kp100 successfully unlock done LG KP100 SUCCESSFULLY UNLOCK DONE 1 - Use Original SIM to switch ON the Phone. 2 - Compose 2945#*265# 3 - Then go to MENU > SETTINGS > SECURITY 4 - Then go to SIM LOCKS > NETWORK > DESACTIVATE 5 - ENTER NCK (your Unlock Code) Press power on ! Starting communication ... Platform: E-Gold Lite ... Preloader sent .... Loader sent .... Flash ID(0): 0001:011A Bypassing security ... LOCK: ACTIVE IMEI: 359961014553630 UNLOCK CODE: 43897887 Saved: INFINEON_17.24.02_21.02.2010_EEP.bin REMOVE BATTERY AND PUT BACK ! Time needed - 00:00:14 |
02-21-2010, 15:14 | #2921 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:011A Reading ... Saved: SAGEM_06.12.55_21.02.2010_PARTIAL.bin Done ! Time needed - 00:00:35 |
02-21-2010, 16:01 | #2922 (permalink) |
Member: 755709 Status: Offline Sonork: 100.1592000 Momo... Thanks Meter: 6,635 | first sagem230v unlocked now hack deals good: Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:011A Reading ... Saved: SAGEM_14.57.29_21.02.2010_PARTIAL.bin Done ! Time needed - 00:00:55 BR---s@nsari--- |
02-22-2010, 05:46 | #2925 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Unknown
Member: 603971 Status: Offline Thanks Meter: 730 | t156 {Ufone} UNLOCK DONE Code: Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 35************* Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_09.19.15_22.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:58 {ahmadge} |
