02-22-2010, 08:04 | #2926 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | LOG: Software engine version: 1.0.0.3543 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Nov 28 2007 09:22:00 RELEASE DATE : Aug 10 2007 08:00:00 FIRMWARE INFO : M6260A-KYRZ-2.1.3022 IMEI : 357767017XXXXX-X BLUETOOTH ADDR : 79 6A 08 40 12 00 MEMORY ID : 00EC:0036 MEMORY NAME : samsung_k9f1208 MEMORY INFO : 0200:0020:06BD INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:42 MIANLINKS |
02-22-2010, 08:49 | #2927 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | huawei t156new unlock ok (6pcs) Connect phone powered on ! Start auth ! SW Ver: P1.2CU03V01.02 Imei: 353081035236119 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_08.30.55_22.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:20 Connect phone powered on ! Start auth ! SW Ver: P1.2CU03V01.02 Imei: 353081035369571 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_08.35.12_22.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:14 Connect phone powered on ! Start auth ! SW Ver: P1.2CU03V01.02 Imei: 353081035255341 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_08.37.16_22.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:19 Connect phone powered on ! Start auth ! SW Ver: P1.2CU03V01.02 Imei: 353081035373706 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_08.39.10_22.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:05 Connect phone powered on ! Start auth ! SW Ver: P1.2CU03V01.02 Imei: 353081035411324 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_08.41.09_22.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:12 Connect phone powered on ! Start auth ! SW Ver: P1.2CU03V01.02 Imei: 353081035373235 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_08.43.47_22.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:10 |
02-22-2010, 09:21 | #2928 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | sagem my100x new unlock ok Press power on shortly ... Starting communication ... MCU ID: 3930010EDC7054C1000000000000B035 ROM HASH: E556221E9367E36C9F11BDCF23DF4D0F ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:297E:1500 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my100X Hash: 00001211 Algo: 05 Firmware: LA5,JC: 261006 1050 Imei: 351988010109107 Phone code: 00000000 Prod. code: 252806569 Id calculation done; CODES: NET LO CODE: 1787222279 NET HI CODE: 0717674823 Done ! Time needed - 00:01:41 |
02-22-2010, 11:04 | #2929 (permalink) |
Junior Member Join Date: Apr 2009 Location: France Age: 44
Member: 1014049 Status: Offline Sonork: 100.1582864 Thanks Meter: 3 | gw520 not unlocked [SOLVED] I can't unlock LG gw520 with the new update posted 21st february 2010. I tried with this pinout: http://media.photobucket.com/image/p...untitled-3.jpg it doesn't work |
02-22-2010, 11:38 | #2930 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Software engine version: 1.0.0.3543 Searching phone ... MODEL : CU720 COMPILED DATE : Mar 26 2008 12:40:00 RELEASE DATE : Oct 3 2007 23:00:00 FIRMWARE INFO : CU720-MSM4090201C-V10l-MAR-26-2008-ATT-US IMEI : 0116790xxxxxxxxx0 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:07 |
02-22-2010, 12:08 | #2932 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Swansea, UK Age: 41
Member: 523318 Status: Offline Thanks Meter: 268 | GD330 successfully unlocked Press power on ! ASIC ID: 00040105 JTAG ID: B619 Platform: OMAP V1030 ... Baud rate change request ... Flash ID(0): 00EC:00A1 Unlocking ... Reading ... Saved: OMAP_12.06.07_22.02.2010_EEP.bin IMEI: 35628902711XXX000 Writing ... Unlocked ! Resetting ... Done ! Time needed - 00:00:51 |
02-22-2010, 12:25 | #2933 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 3530xxxxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_23.03.02_16.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:35 |
02-22-2010, 12:29 | #2934 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 35814xxxxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_00.13.22_22.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:52 |
02-22-2010, 12:29 | #2935 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 35814@@@@@@@@@ Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_01.23.26_22.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:43 |
02-22-2010, 12:30 | #2936 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 3581xxxxxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_05.29.06_21.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 |
02-22-2010, 12:37 | #2937 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 692708 Status: Offline Thanks Meter: 20 | Htc touch pro 2 Successfully Unlocked Phones By Furious Starting cab upload; Preparing to install; Checking installed file; Library found; Reading data; Saved: C:\Documents and Settings\Compaq\Desktop\HTC_BEAST_v1.0.0.833\HTC_1 2.32.24_22.02.2010.bin UNLOCK CODE: 04387265 Time needed - 00:00:28 |
02-22-2010, 14:23 | #2939 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | My 1st set with furious gold unlock ok ufone t156 a yz Quote:
02-22-2010, 14:24 | #2940 (permalink) | |
Member: 171512 Status: Offline Thanks Meter: 1,034 | Lg u370 unlock ok with fg Quote:
