03-02-2010, 13:01 | #3046 (permalink) |
Freak Poster Join Date: Mar 2008 Location: I Don,t Know Age: 38
Member: 718939 Status: Offline Thanks Meter: 90 | Software engine version: 1.0.0.3590 Searching phone ... MODEL : QCOM SERIES 1 COMPILED DATE : Oct 16 2006 10:23:00 RELEASE DATE : Aug 3 2006 00:00:00 FIRMWARE INFO : M6250D-VMSY-6.2.9343T IMEI : 35209101047011-3 BLUETOOTH ADDR : 3C 13 37 40 12 00 MEMORY ID : 00AD:0036 MEMORY NAME : HYC0SEH0MF3(P) MEMORY INFO : 0200:0020:08C0 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:38 |
03-02-2010, 13:08 | #3047 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | u300 successfully unlocked here is log Software engine version: 1.0.0.3590 Searching phone ... MODEL : U300 COMPILED DATE : Jul 14 2006 10:00:00 RELEASE DATE : Jul 14 2006 17:00:00 FIRMWARE INFO : U300-MSM6250A-V10e-JUL-14-2006-H3G-UK IMEI : 35xxxxxxxxxxxxxxxx-1 BLUETOOTH ADDR : 8E 2E 47 56 12 00 MEMORY ID : 0098:0076 MEMORY NAME : toshiba_ty90009800cogg MEMORY INFO : 0200:0020:0900 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35928800011196100 BLUETOOTH ADDR: [OK] 8E2E47561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:21 |
03-02-2010, 13:20 | #3048 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Sagem My411x Successfully Unlocked Press power on shortly ... Starting communication ... MCU ID: 3CE00013A77F63C1000000000000282B ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411X Hash: 00002054 Algo: 05 Firmware: LO5,RF: 280607 1805 Imei: 35 Phone code: 0000 Prod. code: 252925020 Id calculation done; CODES: NET LO CODE: 3653323082 NET HI CODE: 2566998666 DIRECT UNLOCK: OK Done ! Time needed - 00:04:18 |
03-02-2010, 13:21 | #3049 (permalink) |
03-02-2010, 13:55 | #3050 (permalink) |
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | U8120 Successfully Unlocked Press Power On shortly ! LatencyTimer: 10ms Phone Detected ! Chip ID: 71000301 FLASH CID: 17 PHONE COLOR: BROWN Loading ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J OTP CID: 17 IMEI: 35 Settings made ... Bypassing restriction ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Settings Done ! Certificate sent ... Boot info: HACK3R2K.COM GSM DEVELOPEMENT Flash 1: 0089:880D Flash 2: 0089:8810 Firmware version: U8120_v105+ Working. Please wait ... Operation finished ! Time needed - 00:00:23 |
03-02-2010, 15:03 | #3051 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Online Age: 18
Member: 368697 Status: Offline Thanks Meter: 223 | VF527 DONE Press power on shortly ... Starting communication ... MCU ID: 1AA00112576700C2000000000000EA30 ROM HASH: 731C27AB2AE00189FBD4FD3013B53252 ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 00002910 Algo: 05 Firmware: EVN,PJ: 160908 1059 Imei: 359262022487998 Phone code: 0000 Prod. code: 254053893 Id calculation done; CODES: NET LO CODE: 0609139183 NET HI CODE: 1687070255 DIRECT UNLOCK: OK Done ! Time needed - 00:02:59 |
03-02-2010, 15:24 | #3052 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | T156 AGAIN AND AGAIN HERE IS LOG Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 3530XXXXXXXXXXXXXXX Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_P1.2PU01V01.01_353081039352391_19.21.35_02. 03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:06 |
03-02-2010, 18:14 | #3053 (permalink) |
No Life Poster Join Date: Dec 2008 Location: morocco
Member: 931360 Status: Offline Sonork: 100.1592533 Thanks Meter: 539 | ku250 Successfully Unlocked Software engine version: 1.0.0.3590 Searching phone ... MODEL : KU250 COMPILED DATE : Jun 8 2007 14:54:00 RELEASE DATE : Apr 29 2007 17:00:00 FIRMWARE INFO : KU250-MSM6245-V10a-MAY-30-2007-XX IMEI : 35638501220647-5 BLUETOOTH ADDR : 82 28 45 62 1C 00 MEMORY ID : 00AD:0076 MEMORY NAME : hynix_hyc0ueh0mf3p MEMORY INFO : 0200:0020:0996 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:22 br gsm.magic |
03-03-2010, 06:30 | #3054 (permalink) |
Freak Poster Join Date: Mar 2007 Location: i love pakistan Age: 47
Member: 458868 Status: Offline Sonork: 100.1597325 Thanks Meter: 27 | 8700 unlock ok Reading info ... IMEI: 35764600xxxxxx40 Calculating ... MEP: MEP-06814-001 MEP2 CODE: 3363546932349156 MEP3 CODE: 5820568501570215 MEP4 CODE: 2393637961547219 MEP5 CODE: 6397894431714592 MEP6 CODE: 5112614421022390 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:41 |
03-03-2010, 10:32 | #3056 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | 9000 bb done HERE IS ANOTHER LOG Searching for usb device ... Reading info ... IMEI: 355XXXXXXXXXXXXX Calculating ... MEP: MEP-04626-002 MEP2 CODE: 59360470 MEP3 CODE: 71270059 MEP4 CODE: 63125725 MEP5 CODE: 81642069 MEP6 CODE: 03132561 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options |
03-03-2010, 10:52 | #3058 (permalink) |
No Life Poster Join Date: May 2008 Location: Sri Lanka , Kandy Age: 34
Member: 763865 Status: Offline Sonork: Cvlvertcharges Thanks Meter: 123 | Sucsessfull unlockin Sagem my411V Press power on shortly ... Starting communication ... MCU ID: 3600020428DC4FC1000000000000202B ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411V Hash: 00002640 Algo: 05 Firmware: LV5,RP: 150507 1134 Imei: 355150012829887 Phone code: 0000 Prod. code: 252902155 Id calculation done; CODES: NET LO CODE: 2928332360 NET HI CODE: 4006268552 DIRECT UNLOCK: OK Done ! Time needed - 00:02:47 thanks furious gold |
03-03-2010, 11:10 | #3059 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | pentect c300 done with my FG HERE IS LOG Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID: 001C:007C 1C7C READING INFO ... WAIT ! (CAN TAKE ~60s) FW VERSION: HCUX0105042006 MODEL: PG-C300 IMEI: 01XXXXXXXXXXXXXX Phone unlocked. Phone reseted ! Time needed - 00:00:17 |
03-03-2010, 11:18 | #3060 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 596071 Status: Offline Thanks Meter: 160 | Successfully unlock Sagem my511x Thanks fg team and hacker here is log Press power on shortly ... Starting communication ... MCU ID: 1B10010E88BC63C10000000000003C4A ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: Sagem my511X Hash: 00002786 Algo: 05 Firmware: EON,DF: 010408 1801 Imei: 35xxxxxxxxxxx Phone code: 0000 Prod. code: 253045884 Id calculation done; CODES: NET LO CODE: 1691657911 NET HI CODE: 0613721719 DIRECT UNLOCK: OK Done ! Time needed - 00:02:32 |
