03-15-2010, 22:15 | #3242 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | LG KG290 Flashing Successfully Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0089:8816:0101 READING INFO ... WAIT ! (CAN TAKE ~60s) IMEI: 35 LOCK: ON Writting... Done ! Time needed - 00:37:19 |
03-16-2010, 04:13 | #3243 (permalink) |
Freak Poster Join Date: Dec 2009 Location: home
Member: 1190533 Status: Offline Thanks Meter: 33 | Software engine version: 1.0.0.3543 Searching phone ... MODEL : CU920 COMPILED DATE : Sep 26 2008 09:12:00 RELEASE DATE : Jul 31 2008 11:00:00 FIRMWARE INFO : CU920-MSM4090201D-V10p-SEP-26-2008-ATT-US IMEI : 01133300691988-2 BLUETOOTH ADDR : 90 20 F2 FB 21 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:06 |
03-16-2010, 07:49 | #3244 (permalink) |
Banned Join Date: Feb 2008 Location: GSM Nowshera
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037507731 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_11.45.29_16.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:30 |
03-16-2010, 07:50 | #3245 (permalink) |
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037056333 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_11.50.29_16.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:32 |
03-16-2010, 07:52 | #3246 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | HUAWEI T156 UNLOCK DONE VODAFONE INFINEEON MODULE V1.0.4059 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 35308103XXXXXX Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_P1.2PU03V01.01_353081037XXXXXX_11.48.33_16. 03.2010_PARTI AL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:18 |
03-16-2010, 08:37 | #3247 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | kg800 done again and again here is log Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0098:004A:0002 READING INFO ... WAIT ! (CAN TAKE ~60s) DATE: Jul 27 2006 OPERATOR: 234-30 VERSION: V10c REVISION: 44 FIRMWARE: KG800P64FL IMEI: 35542501496693100 LOCK: ON Phone unlocked. Phone reseted ! Time needed - 00:00:23 |
03-16-2010, 11:35 | #3248 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | Bb 8700 unlock ok with fg Quote:
03-16-2010, 12:28 | #3249 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | HUAWEI g1157 unlock done with fg Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334037293795 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334037293795_16.21.22 _16.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:38 |
03-16-2010, 12:34 | #3250 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | BB 8220 Unlock Done....... Searching for usb device ... Reading info ... IMEI: 356028028646827 Calculating ... MEP: MEP-11414-002 MEP2 CODE: 0108596843558622 MEP3 CODE: 0336738942639708 MEP4 CODE: 9095911269138894 MEP5 CODE: 3534464766229815 MEP6 CODE: 6752487242930367 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:39 |
03-16-2010, 13:00 | #3251 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | zong (pakistani Cellular Co ) phone unlock successfull......... Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 Imei: 35435403xxxxxxxxxx Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09_35435403xxxxxxxxxx_12.47.0 0_16.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:09 |
03-16-2010, 13:53 | #3252 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | 136+ unlock done BY FG HERE IS LOG Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 Imei: 354354030019106 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09_354354030019106_00.01.59_1 6.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 |
03-16-2010, 14:32 | #3253 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | Few pieces of g1157 unlocked like charm Code: Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039128627 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039128627_00.17.36_14.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:59 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039127884 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039127884_00.23.37_14.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:41 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039126142 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039126142_00.27.15_14.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:54 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039313583 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039313583_00.14.31_15.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:49 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334037326785 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334037326785_00.44.48_15.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:53 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039881621 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039881621_23.38.56_15.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:44 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039881647 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039881647_23.45.35_15.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:45 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039880698 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039880698_23.50.44_15.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:47 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039882108 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039882108_23.53.25_15.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:46 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039880730 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039880730_23.59.30_15.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 |
03-16-2010, 15:50 | #3255 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | g1157 unlock ok Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334********* Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334*********_19.55.18 _16.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 |
