03-17-2010, 14:22 | #3271 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 35633403872 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_35633403872_14.53.40_17. 03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:49 |
03-17-2010, 15:44 | #3272 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Swansea, UK Age: 41
Member: 523318 Status: Offline Thanks Meter: 268 | BlackBerry 9700 unlocked successfully. Searching for usb device ... Reading info ... IMEI: 358428032192859 Calculating ... MEP: MEP-07723-005 MEP2 CODE: 1637214040191253 MEP3 CODE: 6877871888225924 MEP4 CODE: 7545185298812389 MEP5 CODE: 7471592319595992 MEP6 CODE: 0183381547497492 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code B.R. ProcyOne |
03-17-2010, 16:24 | #3273 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | g 1157 unlock ok Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334************ Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334*********_20.21.53 _17.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:53 |
03-17-2010, 17:12 | #3274 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Software engine version: 1.0.0.3590 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Mar 17 2009 13:13:00 RELEASE DATE : Oct 29 2008 02:00:00 FIRMWARE INFO : YOG_ES_P622C1V1.0.1B02-S IMEI : 35786401324333-0 BLUETOOTH ADDR : AA AD EB 93 22 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_hyg0sgh0mf3 MEMORY INFO : 0200:0020:133D INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; UNLOCK CODE: 4423109943999935 ENTER USING: *983*865625# RESET ! Time needed - 00:00:43 |
03-17-2010, 18:13 | #3275 (permalink) |
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | t156 ayz unlock ok Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031704538 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_P1.2PU01V01.02_358146031704538_22.14.44_17. 03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:24 |
03-18-2010, 04:21 | #3279 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Barcelona Spain
Member: 862582 Status: Offline Sonork: 100.1604840 Thanks Meter: 71 | Quote:
Great Job Man--------- | |
03-18-2010, 05:47 | #3280 (permalink) |
Freak Poster Join Date: Mar 2007 Location: i love pakistan Age: 47
Member: 458868 Status: Offline Sonork: 100.1597325 Thanks Meter: 27 | bb 8900 unlock ok Searching for usb device ... Reading info ... IMEI: 3594850xxxxxxxx Calculating ... MEP: MEP-07723-003 MEP2 CODE: 0331929802276303 MEP3 CODE: 2269130764245075 MEP4 CODE: 6029861132717444 MEP5 CODE: 3243815157576142 MEP6 CODE: 9674044676543360 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code |
03-18-2010, 09:08 | #3281 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | Ufone T-156 Unlock Done............ Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 35308103xxxxxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_P1.2PU03V01.01_35308103xxxxxxxxxx_10.47.19_ 18.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:40 |
03-18-2010, 09:26 | #3282 (permalink) |
Freak Poster Join Date: May 2008 Location: ghana
Member: 782390 Status: Offline Sonork: oshiu Thanks Meter: 57 | Connect phone powered on ! Start auth ! SW Ver: EF-GH-P108E5(S)V1.0.0B05 Imei: 352786034747715 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: ZTE_EF-GH-P108E5(S)V1.0.0B05_352786034747715_08.09.54_18.03. 2010_PARTIAL.bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:03 |
03-18-2010, 12:19 | #3284 (permalink) |
Freak Poster Join Date: Mar 2008 Location: I Don,t Know Age: 38
Member: 718939 Status: Offline Thanks Meter: 90 | LG GW520 unlock done Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 3461217300195185 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:17 |
03-18-2010, 12:21 | #3285 (permalink) |
Member: 718939 Status: Offline Thanks Meter: 90 | BB unlock Done Searching for usb device ... Reading info ... IMEI: 356088023326486 Calculating ... MEP: MEP-04598-005 MEP2 CODE: 4135872055144589 MEP3 CODE: 6932117482937277 MEP4 CODE: 5451059047858919 MEP5 CODE: 2991347716603754 MEP6 CODE: 5693882647454249 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:39 Searching for usb device ... Reading info ... IMEI: 358264013957832 Calculating ... MEP: MEP-04104-007 MEP2 CODE: 0340000860095618 MEP3 CODE: 8963687325473090 MEP4 CODE: 6142365689847923 MEP5 CODE: 3156546305142793 MEP6 CODE: 5674575481243559 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:39 Searching for usb device ... Reading info ... IMEI: 980002003422052 Calculating ... MEP: MEP-15326-001 MEP2 CODE: 0994614594041743 MEP3 CODE: 7402446504016681 MEP4 CODE: 6620914457293026 MEP5 CODE: 9594925848834511 MEP6 CODE: 2736767180840474 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:38 |
