03-23-2010, 14:34 | #3391 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039330918 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039330918_06.34.35 _23.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 |
03-23-2010, 14:36 | #3392 (permalink) |
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | 7TH Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039332740 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039332740_06.36.09 _23.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:35 |
03-23-2010, 14:38 | #3393 (permalink) |
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | 8TH Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039279297 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039279297_06.37.59 _23.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 |
03-23-2010, 14:40 | #3394 (permalink) |
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | 9TH Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039278505 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039278505_06.37.59 _23.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 |
03-23-2010, 15:15 | #3395 (permalink) |
Freak Poster Join Date: May 2005 Age: 45
Member: 143878 Status: Offline Thanks Meter: 9 | 8900 Searching for usb device ... Reading info ... IMEI: 357238037889339 Calculating ... MEP: MEP-09292-004 MEP2 CODE: 1219590098041649 MEP3 CODE: 5131616576260602 MEP4 CODE: 3648063469041824 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:01:00 regards |
03-23-2010, 15:47 | #3396 (permalink) |
Member: 143878 Status: Offline Thanks Meter: 9 | bb 8800 unlocked Searching for usb device ... Reading info ... IMEI: 354672017728930 Calculating ... MEP: MEP-07321-002 MEP2 CODE: 39763486 MEP3 CODE: 08287242 MEP4 CODE: 97147746 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:29 |
03-23-2010, 15:56 | #3397 (permalink) |
Member: 143878 Status: Offline Thanks Meter: 9 | bb8120 unlocked Searching for usb device ... Reading info ... IMEI: 359181017473625 Calculating ... MEP: MEP-07723-003 MEP2 CODE: 3983036706867964 MEP3 CODE: 3553103114889968 MEP4 CODE: 3264030178829004 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:38 regards |
03-23-2010, 15:58 | #3398 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | ZTE A316g+ unlocked Code: Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 Imei: 354354030948072 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10_354354030948072_00.56.44_24.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:19 |
03-23-2010, 16:00 | #3399 (permalink) |
Member: 143878 Status: Offline Thanks Meter: 9 | bb 9500 unlocked Searching for usb device ... Reading info ... IMEI: 359484023055240 Calculating ... MEP: MEP-06814-004 MEP2 CODE: 7685164101117054 MEP3 CODE: 8957933920338869 MEP4 CODE: 0820657637514968 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:07:26 regards |
03-23-2010, 16:06 | #3400 (permalink) |
Member: 143878 Status: Offline Thanks Meter: 9 | Searching for usb device ... Reading info ... IMEI: 359181016721768 Calculating ... MEP: MEP-07723-001 MEP2 CODE: 56699257 MEP3 CODE: 35194449 MEP4 CODE: 58883153 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:26 |
03-24-2010, 07:48 | #3405 (permalink) |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | huawei t156 unlocked ufone :) Code: Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037068874 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_P1.2PU03V01.01_353081037068874_11.47.08_24. 03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:07:) |
