Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 02-10-2011, 12:15   #7741 (permalink)
Cheater -Don't Deal with him-
Member: 283204
Sonork: 100.1577140
Thanks Meter: 1,097
<<<<Succsessfully unlock zte t108 with furious-gold>>>>
Here is log:
Software engine version: 1.0.0.5949
Searching phone ...
MODEL : QCOM SERIES 10
COMPILED DATE : Feb 1 2010 19:08:00
RELEASE DATE : Nov 10 2009 00:00:00
FIRMWARE INFO : TEL_AU_P607C4V1.0.0B08-S
IMEI : 35883403018617-5
BLUETOOTH ADDR : 85 36 71 1A 18 08
INIT NAND ROUTINES;
NAND INIT MADE;
PHONE CODE: 0000
LOOKING SENSITIVE DATA;
DATA FOUND;
READING FW SIGN;
READING NET DATA;
READING NCK DATA;
READING PUBLIC KEY;
CHECKING SIGN;
SIGN OK;
LOCKED NET 1 (MCC: 1 MNC: 1)
READING;
CALCULATING;
ERASING;
WRITING;
UNLOCKED;
RESET !
Time needed - 00:00:10
Br:
Harkishan
Old 02-10-2011, 13:52   #7742 (permalink)
shabir97's Avatar
Member: 1277468
Sonork: 100.1603661
Thanks Meter: 700
G2158 sucessful unlock ..................
Software engine version: 1.0.0.5472
Connect phone powered on !
Start auth !
SW Ver: REL_P1.1PU01V01.06
Imei: 35889203409????
Done;
Press power on !
Starting communication ...
Platform: E-Gold Voice ...
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Flash ID(0): 00C2:22A7
Reading ...
Saved: HUAWEI_35889203409????_REL_P1.1PU01V01.06_12.53.27 _10.02.2011_PARTIAL.bin
Erasing ...
Press reset button !
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Writing ...
Unlocked ! Remove battery and put back !
Time needed - 00:01:59
br:.
shabir97
Old 02-10-2011, 21:33   #7743 (permalink)
Member: 642071
Thanks Meter: 54
GS390go Unlock done
Press power on !
Platform: S-Gold3 ...
Preloader sent ....
Loader sent ....
UNLOCK CODES:
NETWORK: 1991041963298954
NETWORK SUBSET: 8876776373677218
SERVICE PROV.: 5595903880516649
CORPORATE: 6429591960601681
SIM/USIM: 4900794658661298
Power on phone with original sim.
Type 2945#*390# and enter code.
Done !
Time needed - 00:00:19
Old 02-10-2011, 23:31   #7744 (permalink)
Member: 1008455
Sonork: 0000
Thanks Meter: 99
Searching for usb device ...
Reading info ...
IMEI: 355767013995977
Calculating ...
MEP LOCK: MEP-04598-005
MEP1 [SIM]: 0897639179539133
MEP2 [NETWORK]: 4394880172994096
MEP3 [NETWORK SUBSET]: 2420252964212772
MEP4 [SERVICE PROVIDER]: 6944363146022141
MEP5 [CORPORATE]: 1120518828188460
How to enter codes in BlackBerry:
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (where needed)
7. Type MEPPD or MEPD (you will not be able to see the typed info)
8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK)
9. Now it will ask to enter then mep code
Done !
Time needed - 00:00:51
> IMEI: 012295000462046
> NCK: 028532286044
> SPCK: 668796286536
FOR SOME MODELS TYPE *983*8284# OR ###825*09# (WITHOUT SIM) TO ENTER THE N.P. CODE.
Reading info ...
IMEI: 357154022517480
Calculating ...
MEP LOCK: MEP-04104-007
MEP1 [SIM]: 5207586980574217
MEP2 [NETWORK]: 6745546607090480
MEP3 [NETWORK SUBSET]: 6018217609790087
MEP4 [SERVICE PROVIDER]: 2738312569714813
MEP5 [CORPORATE]: 8744830803217402
3. Go to Options
5. Select SIM Card
Done !
Time needed - 00:00:49
Starting cab upload;
Preparing to install;
Preparing to do application unlock;
Application security unlock performed;
Checking installed file;
Library and exe found;
Reading data;
DOC ID:
0000000082260203110E03420209067B00
Doing sp area internally backup;
Please wait;
Simlock area read failed !
ERROR: kioctl(FLASH, init1) - The network request is not supported.
error initializing flash
Trying alternative scanning method;
Scanning 0
Saved: C:\Program Files\FuriouS-Gold\HTC_0000000082260203110E03420209067B00_14.41. 51_10.01.2011.bin
IMEI: 35169501143776
NCK CODE: 44868963
Time needed - 00:00:42
Insert Battery In Phone !
Speed changed ...
Sending boot ...
Boot sent ...
Application started ...
Flash ID : 0001:227E
IMEI : 01034500055143-9
Version : C20.15 > fPLMN CR Blocked [%d] C1=%d_
Lock : OFF
Phone is allready unlocked.
Operation finished.
Enter 2945#*# without a sim inside
and select 'Fact. Reset'.
Time needed - 00:00:04
Press power on !
Platform: E-Gold Lite ...
Preloader sent ....
Loader sent ....
Flash ID(0): 007F:22F6
Bypassing security ...
LOCK: INACTIVE
IMEI: 358503027228270
UNLOCK CODE: 00000000
Saved: INFINEON_13.13.06_12.01.2011_EEP.bin
REMOVE BATTERY AND PUT BACK !
Time needed - 00:00:21
Reading info ...
IMEI: 355283046780964
Calculating ...
MEP LOCK: MEP-07723-007
MEP1 [SIM]: 5089098752751714
MEP2 [NETWORK]: 4037770552795018
MEP3 [NETWORK SUBSET]: 9185324970515172
MEP4 [SERVICE PROVIDER]: 0087434423819676
MEP5 [CORPORATE]: 2833697899445385
3. Go to Options
5. Select SIM Card
Done !
Time needed - 00:00:45
> Model: V770
> IMEI: 353039016828262
> NCK: 1539567647
> NSCK: 1775796353
> SPCK: 3035734616
> SIM: 2415849583
> C: 0905680467
> Other: 3225436973
Reading data;
DOC ID:
EC00E67542603439323731350202030800
Please wait;
Saved: C:\Program Files\FuriouS-Gold\HTC_EC00E67542603439323731350202030800_23.23. 52_19.01.2011.bin
IMEI: 35563402021934
NCK CODE: 88118624
Time needed - 00:00:39
Press power on !
ASIC ID: 00040105 JTAG ID: B619
Platform: OMAP V1030 ...
Baud rate change request ...
Flash ID(0): 00AD:0036
Unlocking ...
Reading ...
Saved: OMAP_10.49.06_25.01.2011_EEP.bin
IMEI: 01129800045239804
Writing ...
Unlocked !
Resetting ...
Done !
Time needed - 00:01:02
Software engine version: 1.0.0.5368
Start auth !
SW Ver: P1.2JD01V01.04:ULC2GL
Imei: 353081032814421
PhoneLock Reset success !
Unlocked !
Done !
Time needed - 00:00:05
Reading data;
DOC ID:
000000003F1901011D3A17BB060806D300
Please wait;
Scanning 0
Saved: C:\Program Files\FuriouS-Gold\HTC_000000003F1901011D3A17BB060806D300_15.05. 35_26.01.2011.bin
IMEI: 35169501109683
NCK CODE: 82196539
Time needed - 00:00:33
Searching phone ...
COMPILED DATE : Jul 15 2009 11:34:00
RELEASE DATE : Jun 24 2009 19:00:00
FIRMWARE INFO : H3G_GB_P607C3V1.0.0B07-sec
IMEI : 35674003003445-9
BLUETOOTH ADDR : B1 79 F8 A1 19 00
INIT NAND ROUTINES;
NAND INIT MADE;
PHONE CODE: 0000
DATA FOUND;
READING FW SIGN;
READING NET DATA;
READING NCK DATA;
READING PUBLIC KEY;
CHECKING SIGN;
SIGN OK;
LOCKED NET 0 (MCC: 234 MNC: 20)
LOCKED NET 1 (MCC: 235 MNC: 94)
READING;
CALCULATING;
ERASING;
WRITING;
UNLOCKED;
RESET !
Searching phone ...
COMPILED DATE : Dec 2 2009 11:18:00
RELEASE DATE : Aug 26 2009 02:00:00
FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S
IMEI : 35674003244953-1
BLUETOOTH ADDR : 0E 20 3F 4A 15 D0
INIT NAND ROUTINES;
NAND INIT MADE;
PHONE CODE: 0000
DATA FOUND;
READING FW SIGN;
READING NET DATA;
READING NCK DATA;
READING PUBLIC KEY;
CHECKING SIGN;
SIGN OK;
READING;
CALCULATING;
ERASING;
WRITING;
UNLOCKED;
RESET !
Time needed - 00:00:48
Reading info ...
IMEI: 980070002083761
Calculating ...
MEP LOCK: MEP-15326-002
MEP1 [SIM]: 93881638
MEP2 [NETWORK]: 00610789
MEP3 [NETWORK SUBSET]: 77679401
MEP4 [SERVICE PROVIDER]: 88596114
MEP5 [CORPORATE]: 15617690
3. Go to Options
5. Select SIM Card
Done !
Reading info ...
IMEI: 980046000427085
Calculating ...
MEP1 [SIM]: 94056528
MEP2 [NETWORK]: 18994109
MEP3 [NETWORK SUBSET]: 67486319
MEP4 [SERVICE PROVIDER]: 16513330
MEP5 [CORPORATE]: 39901764
3. Go to Options
5. Select SIM Card
Done !
Press power on !
Platform: S-Gold2 ...
Loader version: FuriouSTeaM GSM DEVELOPEMENT
Baud rate changed ok !
Flash ID(0): 0089:88B0 0489
Flash ID(1): 0089:88B0 0489
CODE: 06321752
Type 2945#*9701# and enter code.
Done !
Time needed - 00:04:53
Reading data;
DOC ID:
EC0043157E4E3038333631371C1C020800
Please wait;
Saved: C:\Program Files\FuriouS-Gold\HTC_EC0043157E4E3038333631371C1C020800_20.48. 22_07.02.2011.bin
IMEI: 35727602030193
NCK CODE: 28561466
Time needed - 00:00:53
Reading data;
DOC ID:
FFFFFFFFD9FFFFFF9A6B0D5F07009BD600
Please wait;
Scanning 0
Scanning 1
Saved: C:\Program Files\FuriouS-Gold\HTC_FFFFFFFFD9FFFFFF9A6B0D5F07009BD600_23.17. 33_10.02.2011.bin
IMEI: 35286201207804
NCK CODE: 36089754
Time needed - 00:00:38
Old 02-11-2011, 04:36   #7745 (permalink)
Member: 1331614
Thanks Meter: 15
unlock success ku250 & cu920
thanks to furious team
Old 02-11-2011, 09:59   #7746 (permalink)
gsmcrazy1's Avatar
Member: 897524
Sonork: 100,1609543
Thanks Meter: 164
successfully unlock Z100
Software engine version: 1.0.0.4874
Start auth !
SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03
Imei: 352865042912477
Done;
Press power on !
Preloader sent ....
Starting ...
Authorising ...
Loader started ..
MCU ID: 45 E5 24 36 05 92 D1 04 90 11
Saved: ZTE_352865042912477_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_12.43.43_11.02.2011_PARTIAL. bin
Time needed - 00:01:48
Old 02-11-2011, 10:00   #7747 (permalink)
gsmcrazy1's Avatar
Member: 897524
Sonork: 100,1609543
Thanks Meter: 164
Successfully unlock T156
Start auth !
SW Ver: P1.2PU02V01.01
Imei: 353081034534605
Getting config data;
Done;
Press power on !
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Flash ID(0): 0001:22C4
Reading ...
Saved: HUAWEI_353081034534605_P1.2PU02V01.01_14.41.19_11. 02.2011_PARTIAL.bin
Erasing ...
Writing ...
Time needed - 00:00:40
Old 02-11-2011, 10:39   #7748 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 499
Wink Successfully Unlock T156
The Following 3 Users Say Thank You to RAVI_SINGH For This Useful Post:
Old 02-11-2011, 12:47   #7749 (permalink)
danrachita's Avatar
Member: 428861
Sonork: 100.1619141
Thanks Meter: 1,619
Vodafone 246
Vodafone 246 succesfully unlocked.
Thank you Furious Team.
BR.
Software engine version: 1.0.0.5463
Insert cable in box now [NO BATTERY INSIDE PHONE] !
Platform: E-Gold Voice3-32 [00 00] ...
Preloader sent ....
Loader sent ....
Flash ID(0): 00EF:4016
Checking firmware version ...
Detected: ED-DE-P118A2V1.0.0B10
Saved: ZTE_NONE_ED-DE-P118A2V1.0.0B10_14.45.47_11.02.2011_PARTIAL.bin
Erasing ...
Writing ...
Erasing ...
Writing ...
Time needed - 00:00:44
Old 02-11-2011, 13:22   #7750 (permalink)
ch mobiles's Avatar
Member: 748029
Sonork: 100.1603742
Thanks Meter: 1,822
T156 Done.
Software engine version: 1.0.0.5419
Start auth !
SW Ver: P1.2nV01.05:ULC2GL
Imei: 359428010214062
Unlocked !
Done !
Time needed - 00:00:13
B,R.
Old 02-11-2011, 19:08   #7751 (permalink)
Member: 1513691
friends which is the program to calculate the MEP2 of Blackberry? which software is used? please help
Old 02-12-2011, 08:43   #7752 (permalink)
mianjabbar's Avatar
Member: 481915
Sonork: 100.1604233
Thanks Meter: 460
F102 unlocked
log:
Searching phone ...
IMEI : 3567400327xxxx-x
BLUETOOTH ADDR : 3C 69 49 4A 15 D0
INIT NAND ROUTINES;
NAND INIT MADE;
PHONE CODE: 0000
DATA FOUND;
READING FW SIGN;
READING NET DATA;
READING NCK DATA;
READING PUBLIC KEY;
CHECKING SIGN;
SIGN OK;
READING;
CALCULATING;
ERASING;
WRITING;
UNLOCKED;
RESET !
MIANLINKS
Old 02-12-2011, 10:11   #7753 (permalink)
kushol's Avatar
Member: 293662
Sonork: 100.1622609
Thanks Meter: 315
U890 Unlock Done
Software engine version: 1.0.0.5901
Searching phone ...
MODEL : U890
COMPILED DATE : Jun 7 2006 15:56:00
RELEASE DATE : Jun 7 2006 17:00:00
FIRMWARE INFO : U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-UK
IMEI : 35921300342333-8
BLUETOOTH ADDR : 87 4A 46 56 12 00
MEMORY ID : 0098:0079
MEMORY NAME : toshiba_ty9000ac10aobg
MEMORY INFO : 0200:0020:1980
LOADING INIT DATA;
RESETTING PHONE !
WAITING FOR PHONE TO POWER ON 30 SEC;
PHONE ONLINE;
SW VERSION: [OK] MODULE ERROR
IMEI: [OK] 35921300342333800
BLUETOOTH ADDR: [OK] 874A46561200
PLAYING MUSIC ... WAIT;
DOING CONFIG;
INJECTING VODKA;
INJECTING JUICE;
DRINKING;
DANCING;
STAT: ON
NAND UNLOCK DONE;
PROCESS STARTED;
READING;
ERASING;
WRITING;
READING;
ERASING;
WRITING;
UNLOCKED !
Time needed - 00:01:10
Old 02-12-2011, 11:28   #7754 (permalink)
shabir97's Avatar
Member: 1277468
Sonork: 100.1603661
Thanks Meter: 700
huawei t156 unlock done..................
huawei t156 ufone..
Start auth !
SW Ver: P1.2PU03V01.01
Imei: 35308103995????
Done;
Press power on !
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Flash ID(0): 00BF:234B
Reading ...
Saved: HUAWEI_35308103995?????_P1.2PU03V01.01_16.21.15_12 .02.2011_PARTIAL.bin
Erasing ...
Writing ...
Time needed - 00:01:24
br:.
shabir97
Old 02-12-2011, 13:25   #7755 (permalink)
ch mobiles's Avatar
Member: 748029
Sonork: 100.1603742
Thanks Meter: 1,822
T156 Done.
Start auth !
Imei: 353081037711978
Done;
Press power on !
Preloader sent ....
Starting ...
Authorising ...
Loader sent ....
Reading ...
Saved: HUAWEI_353081037711978_P1.2PU03V01.01_18.13.02_12. 02.2011_PARTIAL.bin
Erasing ...
Writing ...
B,R.
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.55238 seconds with 9 queries
