06-22-2011, 16:08 | #8866 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | SW Ver: P1.2PU01V01.01 Imei: 353081038950526 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081038950526_P1.2PU01V01.01_18.45.18_22. 06.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:40 |
06-22-2011, 16:08 | #8867 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081038950526 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081038950526_P1.2PU01V01.01_18.45.18_22. 06.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:40 |
06-22-2011, 20:41 | #8868 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5779 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 15 67 09 31 05 90 06 01 14 02 Flash ID(0): 00C2:22A7 PARTIAL: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 RANGE(S): 00000000:003E0000 00000000:003E0000 Restored ! Remove battery and put back ! Time needed - 00:06:54 |
06-22-2011, 20:42 | #8869 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5779 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040493660 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 15 67 09 31 05 90 06 01 14 02 Flash ID(0): 00C2:22A7 Saved: ZTE_352865040493660_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_12.28.47_22.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:45 |
06-22-2011, 20:43 | #8870 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5779 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.03 Imei: 358892031723149 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Reading ... Saved: HUAWEI_358892031723149_REL_P1.1PU01V01.03_12.41.00 _22.06.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:12 |
06-22-2011, 20:44 | #8871 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5779 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 19 65 28 DA F4 56 02 85 05 Flash ID(0): 00C2:22A7 PARTIAL: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 RANGE(S): 00000000:003E0000 00000000:003E0000 Restored ! Remove battery and put back ! Time needed - 00:07:01 |
06-22-2011, 20:46 | #8872 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5779 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865043124965 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 F9 65 28 5A F4 67 08 85 03 Flash ID(0): 00C2:22A7 Saved: ZTE_352865043124965_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_18.20.52_22.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:46 |
06-23-2011, 07:55 | #8873 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 297936 Status: Offline Thanks Meter: 201 | Software engine version: 1.0.0.6727 Searching phone ... MODEL : TOSHIBA TG01 ENTERING DOWNLOAD MODE; ENTERED; BOOTLOADER VER: 8650B--SDCA ALLOCATING BUFFERS; PREPARING TO DUMP SENSITIVE DATA; DECODING DATA; SAVED TG01S.bin; IMEI : 35923902103772-7 BLUETOOTH ADDR : 19 9D 08 18 23 00 NETWORK: 20424741 NETWORK SUBSET: 64726793 SERVICE PROV.: 18849403 CORPORATE: 42969491 SIM/USIM: 00031290 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. USUALLY NETWORK OR SIM/USIM ARE THE ENABLED LOCKS ! IN WORST CASE TRY ALL ;-) ONE WILL SURELY WORK ! RESETTING; Time needed - 00:00:44 |
06-23-2011, 11:08 | #8874 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania/Piatra Neamt
Member: 880649 Status: Offline Thanks Meter: 73 | First I write special flash for 64k sim, and becouse phone was from IR (eland), must correcting country. MODEL : U890 COMPILED DATE : Jun 7 2006 15:56:00 RELEASE DATE : Jun 7 2006 17:00:00 FIRMWARE INFO : U890-MSM6250A-V10awm-JUN-07-2006-H3G- IMEI : 35921300352mask last 4 digits BLUETOOTH ADDR : 00 12 56 4A A1 0C MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY SIZE : 105MB WORKING ... COUNTRY CODE CHANGED ! RESETTING PHONE ! Time needed - 00:00:03 Software engine version: 1.0.0.6688 Searching phone ... MODEL : U890 COMPILED DATE : Apr 29 2006 10:03:00 RELEASE DATE : Apr 29 2006 17:00:00 FIRMWARE INFO : U890-MSM6250A-V10b-MAY-23-2006-H3G-IR IMEI : 35921300352mask last 4 digits BLUETOOTH ADDR : 0C A1 4A 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35921300352mask last 4 digits BLUETOOTH ADDR: [OK] 0CA14A561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:18 Still have trouble like restart only with some Orange romanian sims. |
06-23-2011, 11:15 | #8875 (permalink) |
Member: 880649 Status: Offline Thanks Meter: 73 | VODAFONE 332FM unlock OK with VHGP 1.0.0.931 Press power on button ... Starting communication ... BootRom v05.02 Authorising ... Sending preloader ... Preloader started ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:2C7E:3500 Looking simlock data ... Imei: 357686020213mask last 4 digits Reading simlock data ... Writing simlock data ... Done ! Time needed - 00:01:00 |
06-23-2011, 14:47 | #8876 (permalink) |
Insane Poster Join Date: Dec 2010
Member: 1467796 Status: Offline Thanks Meter: 0 | UN LOCK Z100 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041764804 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E4 39 04 97 5B 0A 13 08 Flash ID(0): 00C2:22A7 Saved: ZTE_352865041764804_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_03.38.07_12.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:44 |
06-23-2011, 14:47 | #8877 (permalink) |
Member: 1467796 Status: Offline Thanks Meter: 0 | SUCCES FULLY UNLOCK Z100 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040130676 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 15 97 09 31 04 90 C9 01 21 0A Flash ID(0): 00C2:22A7 Saved: ZTE_352865040130676_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_07.37.26_14.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:04:40 |
06-23-2011, 14:48 | #8878 (permalink) |
Member: 1467796 Status: Offline Thanks Meter: 0 | UN LOCK Z100 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041775198 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 38 04 97 56 08 9D 0E Flash ID(0): 00C2:22A7 Saved: ZTE_352865041775198_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_08.08.33_15.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:41 |
06-23-2011, 14:49 | #8879 (permalink) |
Member: 1467796 Status: Offline Thanks Meter: 0 | UN LOCK Z100 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040060253 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 15 27 09 21 46 90 00 02 97 0D Flash ID(0): 00C2:22A7 Saved: ZTE_352865040060253_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_23.07.34_15.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:49 |
06-23-2011, 14:49 | #8880 (permalink) |
Member: 1467796 Status: Offline Thanks Meter: 0 | UN LOCK Z100 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040600215 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 F9 65 28 DA F4 60 00 0F 10 Flash ID(0): 00C2:22A7 Saved: ZTE_352865040600215_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_07.15.47_19.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:52 |
