06-28-2011, 11:05 | #8926 (permalink) |
Product Supporter Join Date: Nov 2010 Location: Every where
Member: 1549240 Status: Offline Thanks Meter: 1,130 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039543882 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081039543882_P1.2PU01V01.01_15.04.41_28. 06.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:46 |
06-28-2011, 11:07 | #8927 (permalink) |
Freak Poster Join Date: Feb 2010 Location: BATUMI
Member: 1238491 Status: Offline Thanks Meter: 32 | Zte-blade unlocked only 1s Software engine version: 1.0.0.6607 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Apr 26 2011 22:09:00 RELEASE DATE : Aug 4 2010 16:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6030 IMEI : 355508040xxxxx-x BLUETOOTH ADDR : F6 AF A5 C7 64 C8 CALCULATING; UNLOCK CODE: 75043832 UNLOCKED ! Time needed - 00:00:01 |
06-28-2011, 12:30 | #8928 (permalink) |
No Life Poster Join Date: Sep 2008 Location: BD - UK Age: 44
Member: 861464 Status: Offline Sonork: 100.1597346 noor Thanks Meter: 172 | u7510 unlock done Searching phone ... Phone detected ... MODEL : Q62xx-FSBL STARTING; OK; LOADING; OK; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35739703079116-3 READING; SP_SAVED_TO: SP_35739703079116_DA6_17.06.27_28.06.2011_HUAWEI.b in CHECKING; LOCKED_TO: MCC-MNC [0]: 234-20 MCC-MNC [1]: FFF-FF MATCHED; ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:04:38 |
06-28-2011, 13:55 | #8929 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 582790 Status: Offline Thanks Meter: 378 | ZTE F930 unlock Code: Software engine version: 1.0.0.6607 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : May 11 2010 13:50:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : 3UK_GB_P608D1V1.0.0B04-S IMEI : 35994103018460-2 BLUETOOTH ADDR : 23 88 E4 1A 18 08 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:51 |
06-28-2011, 15:12 | #8930 (permalink) |
Freak Poster Join Date: Nov 2010 Location: south africa
Member: 1453345 Status: Offline Thanks Meter: 17 | zong z100 unlock done Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504202???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 89 65 38 DA F4 05 02 02 09 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042027???_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_17.29.45_28.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:43 |
06-28-2011, 15:13 | #8931 (permalink) |
Member: 1453345 Status: Offline Thanks Meter: 17 | zong z100 unlock done Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504202???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 49 65 38 DA F4 56 02 94 04 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042027????_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_17.32.04_28.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:43 |
06-28-2011, 15:14 | #8932 (permalink) |
Member: 1453345 Status: Offline Thanks Meter: 17 | zong z100 unlock done Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504202???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 39 65 28 DA F4 D1 08 9A 0E Flash ID(0): 00C2:22A7 Saved: ZTE_35286504202????_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_17.34.42_28.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:41 |
06-28-2011, 15:14 | #8933 (permalink) |
Member: 1453345 Status: Offline Thanks Meter: 17 | zong z100 ulock done Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504202???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 89 65 38 DA F4 56 02 15 0D Flash ID(0): 00C2:22A7 Saved: ZTE_35286504202????_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_17.37.07_28.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:42 |
06-28-2011, 15:16 | #8934 (permalink) |
Member: 1453345 Status: Offline Thanks Meter: 17 | zong z100 unlock done Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504199???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 C9 65 28 DA F4 05 02 87 05 Flash ID(0): 00C2:22A7 Saved: ZTE_35286504199????_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_17.40.34_28.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:38 |
06-28-2011, 15:16 | #8935 (permalink) |
Member: 1453345 Status: Offline Thanks Meter: 17 | zong z100 unlock done Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504201???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 49 65 38 DA F4 56 02 20 06 Flash ID(0): 00C2:22A7 Saved: ZTE_35286504201????_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_17.43.13_28.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:36 |
06-28-2011, 15:17 | #8936 (permalink) |
Member: 1453345 Status: Offline Thanks Meter: 17 | zong z100 unlock successfully Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504202????? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 29 65 38 DA F4 C2 08 95 10 Flash ID(0): 00C2:22A7 Saved: ZTE_35286504202?????_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_17.46.15_28.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:41 |
06-28-2011, 15:18 | #8937 (permalink) |
Member: 1453345 Status: Offline Thanks Meter: 17 | zong z100 unlock done Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504202????? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 69 65 38 DA F4 05 02 92 0F Flash ID(0): 00C2:22A7 Saved: ZTE_35286504202????_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_17.49.34_28.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:37 |
06-28-2011, 15:19 | #8938 (permalink) |
Member: 1453345 Status: Offline Thanks Meter: 17 | zong z100 unlock done Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504202???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 99 65 38 DA F4 05 02 94 0A Flash ID(0): 00C2:22A7 Saved: ZTE_35286504202????_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_17.52.05_28.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:43 |
06-28-2011, 15:20 | #8939 (permalink) |
Member: 1453345 Status: Offline Thanks Meter: 17 | zong z100 unlock ok Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504201???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 49 65 38 DA F4 56 02 15 05 Flash ID(0): 00C2:22A7 Saved: ZTE_35286504201????_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_17.55.06_28.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:43 |
06-28-2011, 15:21 | #8940 (permalink) |
Member: 1453345 Status: Offline Thanks Meter: 17 | zong z100 unlock successfully Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504207????? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 49 65 28 DA F4 56 02 0B 0B Flash ID(0): 00C2:22A7 Saved: ZTE_35286504207????_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_17.58.54_28.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:40 |
