08-02-2011, 18:10 | #9196 (permalink) |
No Life Poster Join Date: Oct 2004 Location: AL-SATWA DUBAI U.A.E Age: 45
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | Searching for usb device ... Reading info ... IMEI: 353486044601817 Calculating ... MEP LOCK: MEP-16472-001 MEP1 [SIM]: 4409441420516801 MEP2 [NETWORK]: 2023763959112721 MEP3 [NETWORK SUBSET]: 8288559541757874 MEP4 [SERVICE PROVIDER]: 0497891554374563 MEP5 [CORPORATE]: 5604669640420594 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:41 |
The Following User Says Thank You to Ramzan For This Useful Post: |
08-02-2011, 18:13 | #9197 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | BlackBerry 8110 successfull unlock Searching for usb device ... Reading info ... IMEI: 359181017060455 Calculating ... MEP LOCK: MEP-16472-001 MEP1 [SIM]: 1779918962896828 MEP2 [NETWORK]: 6816683070966203 MEP3 [NETWORK SUBSET]: 6440525461467605 MEP4 [SERVICE PROVIDER]: 6970780486793463 MEP5 [CORPORATE]: 6891576505147708 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:39 |
08-02-2011, 18:15 | #9198 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | ZTE ZONG Z100 successfull unlock Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041785031 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 A4 36 04 97 5D 02 90 0D Flash ID(0): 00C2:22A7 Saved: ZTE_352865041785031_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_15.34.45_21.07.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:34 |
08-02-2011, 18:16 | #9199 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | LG GD510 successfull unlock Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 5597940181457864 Power on phone with original sim. Type 2945#*510# and enter code. Done ! Time needed - 00:00:17 |
08-02-2011, 18:17 | #9200 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | LG GD510 successfull unlock Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 6368923986264089 Power on phone with original sim. Type 2945#*510# and enter code. Done ! Time needed - 00:00:18 |
08-02-2011, 18:18 | #9201 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | Foma L704i Successfully Unlocked Software engine version: 1.0.0.6739 Searching phone ... MODEL : L704 COMPILED DATE : Oct 7 2007 03:48:00 RELEASE DATE : Aug 7 2007 00:00:00 FIRMWARE INFO : L704i-MSM2340555C-V10a-OCT-02-2007-DCM-JP IMEI : 35500701040391-9 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0686 INIT NAND ROUTINES; NAND INIT MADE; UNLOCKED ! Time needed - 00:00:03 |
08-02-2011, 18:19 | #9202 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | ZTE ZONG Z100 successfull unlock Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865043607266 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 79 65 28 DA F4 82 07 18 03 Flash ID(0): 00C2:22A7 Saved: ZTE_352865043607266_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_22.15.19_06.07.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:45 |
08-02-2011, 18:20 | #9203 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | Huawei U-Fone G2158 successfull unlock Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 358892034448215 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_358892034448215_REL_P1.1PU01V01.06_17.35.34 _06.07.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:56 |
08-02-2011, 18:20 | #9204 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | Huawei U-Fone G2201c successfull unlock Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620030435160 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 00EC:0106 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:04:08 |
08-02-2011, 18:21 | #9205 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | ZTE ZONG Z100 successfull unlock Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 004999010640000 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 E9 65 28 5A F4 67 08 0A 0C Flash ID(0): 00C2:22A7 Saved: ZTE_004999010640000_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_05.20.22_05.07.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:40 |
08-02-2011, 18:22 | #9206 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | ZTE ZONG Z100 successfull unlock Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042649889 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 A4 39 84 96 92 07 94 01 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042649889_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_02.31.53_27.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:36 |
08-02-2011, 18:26 | #9207 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | ZTE ZONG Z100 successfull unlock Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040619934 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 29 65 38 DA F4 A1 05 1C 09 Flash ID(0): 00C2:22A7 Saved: ZTE_352865040619934_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_04.18.32_19.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:42 |
08-02-2011, 18:26 | #9208 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | ZTE ZONG Z100 successfull unlock Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042627042 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 A4 35 84 97 60 04 11 05 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042627042_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_07.46.53_27.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:36 |
08-02-2011, 18:27 | #9209 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | ZTE ZONG Z100 successfull unlock Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040606998 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 E9 65 28 DA F4 60 00 0D 10 Flash ID(0): 00C2:22A7 Saved: ZTE_352865040606998_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_06.16.51_03.05.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:44 |
08-02-2011, 18:27 | #9210 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | ZTE ZONG Z100 successfull unlock Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040505000 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 15 27 09 21 05 90 06 01 04 0D Flash ID(0): 00C2:22A7 Saved: ZTE_352865040505000_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_06.22.04_02.05.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:34 |
