08-20-2011, 04:51 | #9286 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865042353235 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E4 31 44 97 24 06 07 0F Flash ID(0): 00C2:22A7 Saved: ZTE_352865042353235_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_10.57.15_17.07.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:42 |
08-20-2011, 04:59 | #9287 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Software engine version: 1.0.0.5880 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040981243 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 19 65 28 DA F4 A0 00 8C 08 Flash ID(0): 00C2:22A7 Saved: ZTE_352865040981243_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_11.37.50_21.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:40 |
08-20-2011, 05:00 | #9288 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | KU990 ok Software engine version: 1.0.0.6727 Searching phone ... MODEL : KU990 COMPILED DATE : Aug 15 2008 15:54:00 RELEASE DATE : Aug 15 2008 17:00:00 FIRMWARE INFO : KU990-MSM6280-V10i-AUG-15-2008-XX IMEI : 35493502242064-9 BLUETOOTH ADDR : 1E 69 D7 E3 1F 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:07 |
08-20-2011, 16:46 | #9290 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | Zte t870 done Code: Software engine version: 1.0.0.6794 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jul 8 2010 20:14:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : TEL_AU_P624B1V1.0.0B20-S IMEI : 35977303063417-3 BLUETOOTH ADDR : 78 00 0B 37 F5 98 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 1 (MCC: 1 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:07 |
08-21-2011, 12:54 | #9291 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,738 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865043642073 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 5B 35 04 97 5C 00 0E 0C Flash ID(0): 00C2:22A7 Saved: ZTE_352865043642073_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_16.45.02_21.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:03:51 |
08-21-2011, 12:54 | #9292 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,738 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040949174 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 79 65 28 DA F4 60 00 96 0D Flash ID(0): 00C2:22A7 Saved: ZTE_352865040949174_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_16.05.58_21.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:41 |
08-21-2011, 14:08 | #9293 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | zte f951e 0lso orange unlock done [COLOR="rgb(255, 192, 203)"]Software engine version: 1.0.0.6794 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jul 21 2010 18:26:00 RELEASE DATE : Nov 18 2009 00:00:00 FIRMWARE INFO : ORG_ES_P608A1V1.0.0B21-S IMEI : 35871803054776-9 BLUETOOTH ADDR : D3 C2 E0 1A 18 08 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 214 MNC: 3) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:11 [/COLOR] |
08-22-2011, 05:06 | #9294 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Huawei G2200.. unlock done!! Software engine version: 1.0.0.5779 Connect phone powered on ! Start auth ! SW Ver: 08.06.00:18.26.22:06.00.00:ULC2GL Imei: 35============ Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-32 [00 31] ... Preloader sent .... Loader sent .... Flash ID(0): 0020:8828 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:02:46 Uploaded with ImageShack.us |
08-22-2011, 06:33 | #9295 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 354975 Status: Offline Sonork: Love For All Thanks Meter: 462 | A 316G unlock done with fg Software engine version: 1.0.0.5931 Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 Imei: 354354030368297 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_354354030368297_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09_10.25.29_22.08.2011_PARTIA L.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:38 |
08-22-2011, 06:47 | #9296 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g2158 unlock done Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 358892032741348 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_358892032741348_REL_P1.1PU01V01.06_10.44.32 _22.08.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:16 |
08-22-2011, 16:18 | #9297 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | RIO II SUCCESSFULL UNLOCK Software engine version: 1.0.0.6761 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Apr 8 2011 09:18:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : ORG_UK_P671A80V1.0.0B23-S IMEI : 35635204XXXXXX BLUETOOTH ADDR : FC 94 C7 C7 64 C6 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; SP NEW DETECTED; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 33) LOCKED NET 1 (MCC: 234 MNC: 86) LOCKED NET 2 (MCC: 1 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:51 |
08-22-2011, 16:20 | #9298 (permalink) |
Member: 488632 Status: Offline Thanks Meter: 391 | SAN FRANCISCO SUCCESSFULL UNLOCK Software engine version: 1.0.0.6761 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Jan 25 2011 00:36:00 RELEASE DATE : May 12 2010 18:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-53303002 IMEI : 35545804XXXXXX-9 BLUETOOTH ADDR : 61 43 A4 C7 64 C8 CALCULATING; UNLOCK CODE: 57582572 COUNTER CLEAR DONE; UNLOCKED ! Time needed - 00:00:19 |
08-22-2011, 22:21 | #9299 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | 8520 unlock done Searching for usb device ... Reading info ... IMEI: 35xxxxxxxxxxxxxx Calculating ... MEP LOCK: MEP-14896-005 MEP1 [SIM]: 0783913594121606 MEP2 [NETWORK]: 3656164950295307 MEP3 [NETWORK SUBSET]: 0895204591522737 MEP4 [SERVICE PROVIDER]: 3603678662811128 MEP5 [CORPORATE]: 4794561092279716 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:01:09 THANKS FURIUS TEAM |
08-23-2011, 06:54 | #9300 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Software engine version: 1.0.0.6794 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jul 17 2010 20:08:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : 3ITA_GB_P608D1V1.0.0B11-S IMEI : 35994103067844-7 BLUETOOTH ADDR : 3C 10 B3 4A 15 D0 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; SP NEW DETECTED; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 222 MNC: 99) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:08 ZTE MD MINI TOUCH |
