10-10-2011, 08:30 | #9646 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | z100 unlock ok Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865042334417 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 3A 84 97 69 01 85 0C Flash ID(0): 00C2:22A7 Saved: ZTE_352865042334417_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_12.02.41_10.10.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:45 |
10-10-2011, 08:34 | #9647 (permalink) |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | Zong g2100 unlock done Comm opened 53 ! Baud set ! Auth made ! Sw version: Huawei g2100v100r001pakc19b102sec test mode status: Off sim status: Off imei: 351633041446983 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:15 |
10-10-2011, 08:35 | #9648 (permalink) |
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | G1000 Unlock Comm opened 53 ! Baud set ! Auth made ! Sw version: Rel_c1.2pu01v01.05 test mode status: Off sim status: Off imei: 356820040793599 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:12 |
10-10-2011, 10:54 | #9649 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Alcatel OT355 flash don Make your handset power off, plug in the UART cable! Product: OT-355 Load DA file... Load AUTH file... Load flash image file... Start to connect the handset, keep pressing the power on key! Start to flash handset image... IMEI: 353923047104837 Provider ID: 355A-2ACECO3 Security information version: ËÉ”òÿÇL Downloading flash image now... Downloading flash image now... Formatting file system now... Proceeding post process now... Flash full handset image successfully! |
10-10-2011, 10:57 | #9650 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | alcatel OT355 unlock don Make your handset power off, plug in the UART cable! Product: OT-355 Load DA file... Load AUTH file... Start to connect the handset, keep pressing the power on key! Start to read security information from handset... IMEI: 353923047104837 Security file: C:\Program Files\FuriouS-Gold\Alcatel\Security\BackupSecurityFile\355A-2ACECO3 Read security information successfully! Start code calculate... Product: OT-355 IMEI: 353923047104837 Security file: C:\Program Files\FuriouS-Gold\Alcatel\Security\BackupSecurityFile\355A-2ACECO3 NCK:4122893064 NSCK: SPCK: PCK: Code calculate finished successfully! |
10-10-2011, 14:32 | #9651 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | t156 unlock don Software engine version: 1.0.0.6109 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031672172 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_358146031672172_P1.2PU01V01.02_18.28.54_10. 10.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:34 |
10-11-2011, 01:30 | #9652 (permalink) |
Freak Poster Join Date: May 2011 Location: europa
Member: 1580957 Status: Offline Thanks Meter: 8 | Vodafone 246 feito com a versao 1.0.0.6109 Cabo Fgold -067 Software engine version: 1.0.0.6109 Insert cable in box now [NO BATTERY INSIDE PHONE] ! Starting communication ... Platform: E-Gold Voice3-32 [00 00] ... Preloader sent .... Loader sent .... Flash ID(0): 00EF:4016 Checking firmware version ... Detected: EP-PT-P118A2(MR)V1.0.0B03 Saved: ZTE_NONE_EP-PT-P118A2(MR)V1.0.0B03_01.24.59_11.10.2011_PARTIAL.bi n Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 |
10-11-2011, 13:51 | #9653 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Bulgaria,Assenovgrad Age: 46
Member: 591325 Status: Offline Thanks Meter: 151 | s319 unlock done Software engine version: 1.0.0.5245 Connect phone powered on ! Start auth ! SW Ver: EB-MTEL-P108A34(S)V1.0.0B03 Imei: 358530030878700 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 A4 39 03 98 82 07 0E 10 Flash ID(0): 00C2:22A7 Saved: ZTE_358530030878700_EB-MTEL-P108A34(S)V1.0.0B03_15.49.35_11.10.2011_PARTIAL.bi n Unlocked ! Remove battery and put back ! Time needed - 00:01:22 |
10-11-2011, 14:43 | #9654 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | alcatel ot 355 flashing and unlock done!!!! with pack8 flashing done... Make your handset power off, plug in the UART cable! Product: OT-355 Load DA file... Load AUTH file... Load flash image file... Start to connect the handset, keep pressing the power on key! Start to flash handset image... IMEI: 353923046615346 Provider ID: 355X-2ARGTE5 Security information version: XI46AB81 Detect special firmware version! If the handset is reflashed with SIMFree version, it may not power on correctly! If so, you can try to repair the handset secure region with special golden file after flash process is done! Downloading flash image now... Downloading flash image now... Formatting file system now... Proceeding post process now... Flash full handset image successfully! read code done..... Make your handset power off, plug in the UART cable! Product: OT-355 Load DA file... Load AUTH file... Start to connect the handset, keep pressing the power on key! Start to read security information from handset... IMEI: 353923046615346 Security file: C:\Program Files\FuriouS-Gold\PACK8\Alcatel\Security\BackupSecurityFile\355 X-2ARGTE5 Read security information successfully! Start code calculate... Product: OT-355 IMEI: 353923046615346 Security file: C:\Program Files\FuriouS-Gold\PACK8\Alcatel\Security\BackupSecurityFile\355 X-2ARGTE5 NCK:2041150196 NSCK: SPCK:2042532088 PCK: Code calculate finished successfully! |
10-11-2011, 17:08 | #9655 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | zte a66 locked by zain unlock done!!!! Software engine version: 1.0.0.6047 Connect phone powered on ! Start auth ! SW Ver: EF-NG-ZAIN-P108A17(S)V1.0.0B03 Imei: 357941028545931 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: ZTE_357941028545931_EF-NG-ZAIN-P108A17(S)V1.0.0B03_16.57.23_11.10.2011_PARTIAL.bi n Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:11 |
10-12-2011, 07:19 | #9656 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.6047 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865043700418 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 5B 38 04 97 48 05 9A 06 Flash ID(0): 00C2:22A7 Saved: ZTE_352865043700418_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_14.48.36_11.10.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:55 |
10-12-2011, 07:36 | #9657 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Comm opened 42 ! Baud set ! Auth made ! Sw version: Huawei g2100v100r001pakc19b102sec test mode status: Off sim status: Off imei: 351633041187801 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:19 |
10-12-2011, 09:03 | #9658 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g1000 unlocked Comm opened 4 ! Baud set ! Auth made ! Sw version: Rel_c1.2pu01v01.05 test mode status: Off sim status: Off imei: 356820041680860 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:12 |
10-12-2011, 10:10 | #9659 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | LG GW300 unlock don Attach USB cable now ... Phone detected ! USB Port opened ! RamLoader download success; Config done ! Authorising; Authorisation passed; Getting memory info; Memory: EC000000B1 Getting unlock data; Checking unlock data; Calculating; IMEI: 35171404637808000 Codes: 6966983019454479 6966983019454479 9747680525831527 Enter codes using 2945#*71001# Restarting; Time needed - 00:00:21 |
10-12-2011, 10:11 | #9660 (permalink) |
