08-08-2009, 11:48 | #1007 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Blackberry 9530 Verizon Searching for usb device ... Reading info ... IMEI: 352110030200795 Calculating ... MEP: MEP-15326-001 MEP2 CODE: 5016291475028631 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:22 |
08-08-2009, 12:01 | #1008 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | Blackberry 8320 T Mobile USA Searching for usb device ... Reading info ... IMEI: 357154020696203 Calculating ... MEP: MEP-04104-007 MEP2 CODE: 4155423054207884 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:13 |
08-08-2009, 17:33 | #1009 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | 2 Pcs LG_KS360 UNLOCKED_SUCCESSFULLY LOGS SET # 1 Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 71077108 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:14 SET # 2 Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 90909826 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:15 BR |
08-09-2009, 10:55 | #1010 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Islamic Republic Age: 36
Member: 466635 Status: Offline Sonork: 100.1614186 Thanks Meter: 482 | u310 unlocked whit new 2537 Software engine version: 1.0.0.2537 Searching phone ... MODEL : U310 COMPILED DATE : Jan 23 2007 17:32:00 RELEASE DATE : May 9 2006 17:00:00 FIRMWARE INFO : U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI : 35281801343588-7 BLUETOOTH ADDR : 9C FA 71 A1 19 00 MEMORY ID : 0098:0076 MEMORY NAME : toshiba_ty90009800cogg MEMORY INFO : 0200:0020:0900 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35281801343588700 BLUETOOTH ADDR: [OK] 9CFA71A11900 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:12 B.R SHERRY MOBILES |
08-09-2009, 14:34 | #1011 (permalink) |
Banned Join Date: Nov 2007 Age: 36
Member: 631286 Status: Offline Thanks Meter: 1,250 | Software engine version: 1.0.0.2537 Searching phone ... MODEL : U310 COMPILED DATE : Oct 12 2006 14:55:00 RELEASE DATE : May 9 2006 17:00:00 FIRMWARE INFO : U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI : 35281801360596-8 BLUETOOTH ADDR : DF F9 73 A1 19 00 MEMORY ID : 0098:0076 MEMORY NAME : toshiba_ty90009800cogg MEMORY INFO : 0200:0020:0900 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35281801360596800 BLUETOOTH ADDR: [OK] DFF973A11900 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:15 |
08-09-2009, 14:47 | #1012 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Turkey
Member: 337837 Status: Offline Thanks Meter: 538 | F866 s e x fully unlock with furious Software engine version: 1.0.0.2003 Searching phone ... MODEL : QCOM SERIES 6 COMPILED DATE : Nov 3 2006 17:18:00 RELEASE DATE : Sep 26 2001 01:30:00 FIRMWARE INFO : P600B2V4.0.0B11-SEC IMEI : 357************ BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0076 MEMORY NAME : samsung_kag00j007m MEMORY INFO : 0200:0020:0800 INIT NAND ROUTINES; NAND INIT MADE; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! RESET ! Time needed - 00:00:10 |
08-09-2009, 15:23 | #1013 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 49
Member: 58685 Status: Offline Thanks Meter: 7 | help me please Searching for usb device ... Reading info ... IMEI: 3594840xxxxxx52 Calculating ... MEP: MEP-05277-004 MEP2 CODE: 2873132394391858 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:16 phone 9500 but i don't see MEPPD or MEPD. Where is the MEPPD or MEPD? how can i do it |
08-10-2009, 09:01 | #1014 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Software engine version: 1.0.0.2537 Searching phone ... MODEL : CU920 COMPILED DATE : May 6 2008 10:38:00 RELEASE DATE : Jan 4 2008 15:00:00 FIRMWARE INFO : TU915-MSM4090201D-V10e-MAY-06-2008-RW-CA IMEI : 35497002022641-7 BLUETOOTH ADDR : 0F 7A 8A E3 1F 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:22 |
08-10-2009, 09:02 | #1015 (permalink) |
Member: 631286 Status: Offline Thanks Meter: 1,250 | Software engine version: 1.0.0.2537 Searching phone ... MODEL : U250 COMPILED DATE : May 19 2007 02:54:00 RELEASE DATE : May 19 2007 14:00:00 FIRMWARE INFO : U250-MSM6245-V10a-MAY-19-2007-XX IMEI : 35638501150159-5 BLUETOOTH ADDR : 32 4E 23 62 1C 00 MEMORY ID : 00AD:0076 MEMORY NAME : hynix_hyc0ueh0mf3p MEMORY INFO : 0200:0020:0996 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:06 |
08-10-2009, 09:03 | #1016 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Software engine version: 1.0.0.2537 Searching phone ... MODEL : U990 COMPILED DATE : Jul 8 2008 15:32:00 RELEASE DATE : Oct 1 2007 17:00:00 FIRMWARE INFO : U990-MSM6280-V10a-OCT-01-2007-XX IMEI : 35493502374803-0 BLUETOOTH ADDR : 1F CD 93 E3 1F 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:22 |
08-10-2009, 16:30 | #1017 (permalink) |
Member: 337837 Status: Offline Thanks Meter: 538 | 9500 blackberry unlocked Searching for usb device ... Reading info ... IMEI: 35*************** Calculating ... MEP2 CODE: 4734255634597188 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:15 |
08-10-2009, 18:02 | #1018 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Bristol, UK
Member: 607045 Status: Offline Thanks Meter: 127 | LG KF 310 Unlock Successfully. Software engine version: 1.0.0.2537 Searching phone ... MODEL : KF310 COMPILED DATE : Dec 11 2008 11:43:00 RELEASE DATE : Nov 28 2008 08:00:00 FIRMWARE INFO : KF310-MSM6245-V10b-NOV-28-2008-XX IMEI : 35423902788828-4 BLUETOOTH ADDR : 00 EB F2 A9 22 00 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY INFO : 0800:0040:02FD INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:23 |
08-11-2009, 14:18 | #1020 (permalink) |
Freak Poster Join Date: Nov 2007 Location: tunisia tunis
Member: 640494 Status: Offline Sonork: 1583054 Thanks Meter: 67 | mtv 3.3 unlocked succefully Mtv 3.3 unlocked successfully with furious gold module: vodafone Q module v 1.0.0.3424 cable: v810 usb driver: mtv 3.4 (in support) |
