02-13-2012, 22:06 | #10396 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Reading info ... IMEI: 357493000436531 Calculating ... MEP LOCK: MEP-04626-001 MEP1 [SIM]: 9441953333559213 MEP2 [NETWORK]: 61352755 MEP3 [NETWORK SUBSET]: 1993189415461940 MEP4 [SERVICE PROVIDER]: 0233757949197647 MEP5 [CORPORATE]: 8605640608912976 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:47 |
02-13-2012, 23:38 | #10397 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Corral de Bustos, Argentina
Member: 578880 Status: Offline Thanks Meter: 144 | ZTE N720 (Unlock) First in the World [ Furious Gold ] Instant Unlock ZTE N720 Claro Argentina QCOM SMART TOOL Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Jun 7 2011 16:05:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : ZTE-U N720_H3_Z5_SP_TSDCD213B IMEI : 3535770XXXXXX0-1 BLUETOOTH ADDR : 0F 94 FB C7 64 C8 TAG_ID:r UNSUPPORTED FIRMWARE VERSION FOR UNLOCK.IF THE CODE(S) DONT WORK SELECT DUMP ME FROM JOBS AND SEND THE RESULTED FILE TO SUPPORT. FOR ACER AND BOSTON MODELS FLASH DEVICE WITH FIRMWARE FROM SUPPORT CALCULATING; COUNTER CLEAR DONE; UNLOCKED ! Time needed - 00:00:01 Thanks thanks .:hack3r2k:. and Furious Gold TEAM BR: Sergio |
02-14-2012, 06:02 | #10398 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Ufone G1000 unlock 15 set done COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042562638 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042563214 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042563230 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042563164 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042563222 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042562562 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042562596 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042562570 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042562695 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042562588 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042562745 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042562729 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042562620 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042562646 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 |
02-14-2012, 06:03 | #10399 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 2100 zong unlock done COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: HUAWEI G2100V100R001PAKC19B102SEC TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 351633041521702 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:22 |
02-14-2012, 11:26 | #10400 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | ZTE F116 Unlock Done 12 seconds ! Software engine version: 1.0.0.7704 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Nov 2 2011 22:26:00 RELEASE DATE : Apr 19 2011 08:00:00 FIRMWARE INFO : MTC_MD_P640A30V1.0.0B04-S IMEI : 35735304056957-8 BLUETOOTH ADDR : 9C EF C1 B2 1A 68 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 31742A91327189323BC3F17F3AA80C27.bin ERASING; WRITING; READING; AFTER BACKUP: 25CA7CACDBA19CC4573B615CE5565A9C.bin UNLOCKED; RESET ! Time needed - 00:00:12 |
02-14-2012, 11:28 | #10401 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Product: OT-306 Provider ID: 306X-2[X=E]BGKZ1 IMEI: 356080042713067 Start code calculate... NCK:3582955005 NSCK: SPCK: PCK: Code calculate finished successfully! Product: OT-306 Provider ID: 306X-2[X=E]BGKZ1 IMEI: 356080044380006 Start code calculate... NCK:2585237076 NSCK: SPCK: PCK: Code calculate finished successfully! |
02-14-2012, 11:29 | #10402 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6331 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 1B 31 84 99 9D 06 06 08 Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:46 |
02-15-2012, 12:49 | #10403 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 2100 unlock done COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: HUAWEI G2100V100R001PAKC19B102SEC TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 351633041560221 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:20 |
02-15-2012, 16:05 | #10404 (permalink) |
Freak Poster Join Date: Jun 2003 Location: zimbab Age: 46
Member: 32705 Status: Offline Thanks Meter: 66 | IMEI: 357360031886762 Calculating ... MEP LOCK: MEP-04598-005 MEP1 [SIM]: 5609377898926282 MEP2 [NETWORK]: 8949313053910348 MEP3 [NETWORK SUBSET]: 8514447278838565 MEP4 [SERVICE PROVIDER]: 5605858716933584 MEP5 [CORPORATE]: 0894930198757380 |
02-15-2012, 16:05 | #10405 (permalink) |
Member: 32705 Status: Offline Thanks Meter: 66 | Searching for usb device ... Reading info ... IMEI: 980039005575693 Calculating ... MEP LOCK: MEP-15326-002 MEP1 [SIM]: 0923723430965763 MEP2 [NETWORK]: 10976006 MEP3 [NETWORK SUBSET]: 6536540461777277 MEP4 [SERVICE PROVIDER]: 0459385798342512 MEP5 [CORPORATE]: 1605705044772399 |
02-15-2012, 16:06 | #10406 (permalink) |
Member: 32705 Status: Offline Thanks Meter: 66 | Searching for usb device ... Reading info ... IMEI: 352481044426548 Calculating ... MEP LOCK: MEP-09292-004 MEP1 [SIM]: 3155822063485081 MEP2 [NETWORK]: 1114898547740058 MEP3 [NETWORK SUBSET]: 8991975614771677 MEP4 [SERVICE PROVIDER]: 4662097618854335 MEP5 [CORPORATE]: 7272548097454493 |
02-16-2012, 10:01 | #10407 (permalink) |
Junior Member Join Date: Jan 2012
Member: 1716954 Status: Offline Thanks Meter: 0 | sfr startrail unlock done one of the best unlocking zte android phone fg box hihiihhi Software engine version: 1.0.0.7687 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Mar 25 2011 02:49:00 RELEASE DATE : Aug 4 2010 16:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6030 IMEI : 86744900014943-6 BLUETOOTH ADDR : 62 56 A4 C7 64 C8 TAG_ID:733SFR07 DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:45 |
02-16-2012, 19:22 | #10408 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | SFR STARADDICT (noir) Software engine version: 1.0.0.7710 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Oct 15 2011 03:47:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 86853400068257-4 BLUETOOTH ADDR : 8E 02 FD 50 4B 34 TAG_ID:P743FB05 DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:46 |
02-17-2012, 06:25 | #10409 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Ufone G 2201 unlock done Software engine version: 1.0.0.6364 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620031630397 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 00EC:0106 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:04:24 |
02-17-2012, 15:12 | #10410 (permalink) |
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Zte T50 Unlocked Software engine version: 1.0.0.7710 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Aug 25 2011 20:48:00 RELEASE DATE : Jun 3 2010 07:00:00 FIRMWARE INFO : TEL_AU_P671A70V1.0.1B03-S IMEI : 86824600029475-1 BLUETOOTH ADDR : A0 87 B7 50 4B 34 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; SP NEW DETECTED; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 1 (MCC: 1 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:10 |
