08-14-2009, 14:13 | #1036 (permalink) |
No Life Poster Join Date: Oct 2008 Location: BIH,Bratunac
Member: 888715 Status: Offline Thanks Meter: 109 | Searching phone ... MODEL : U450 COMPILED DATE : May 4 2007 12:01:00 RELEASE DATE : May 9 2006 17:00:00 FIRMWARE INFO : U450-MSM6250-V10a-MAY-04-2007-H3G-IT IMEI : 35658001095739-8 BLUETOOTH ADDR : 9C 2B 1C 62 1C 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:18D2 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35658001095739800 BLUETOOTH ADDR: [OK] 9C2B1C621C00 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:09:26 |
08-14-2009, 14:47 | #1037 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | Press power on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353xxxxxxxxxxxx PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:05 |
08-14-2009, 19:15 | #1039 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Blackberry 8320 T Mobile USA Searching for usb device ... Reading info ... IMEI: 357154021990803 Calculating ... MEP: MEP-04104-007 MEP2 CODE: 5189886101009180 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:11 |
08-15-2009, 04:40 | #1040 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | vodaphone 716 unlock ok FG Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Memory Info: 00EC:0036 Requesting random data ... Sending data ... Authorisation started ... Authorisation passed ... Unlock Code: 7777777777777777 Done ! Time needed - 00:00:11 |
08-15-2009, 05:39 | #1042 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | huawei t156 ufone unlock Press power on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081034x PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:16 |
08-15-2009, 05:40 | #1043 (permalink) |
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | t156 unlock successfully ufone network Press power on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 3530810 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:16 |
08-15-2009, 05:59 | #1044 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Pakistan Age: 36
Member: 158181 Status: Offline Thanks Meter: 113 | Software engine version: 1.0.0.2537 Searching phone ... MODEL : CU720 COMPILED DATE : Mar 26 2008 12:40:00 RELEASE DATE : Oct 3 2007 23:00:00 FIRMWARE INFO : CU720-MSM4090201C-V10l-MAR-26-2008-ATT-US IMEI : 01167900303213-1 BLUETOOTH ADDR : 0F 64 6C E3 1F 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:07 |
08-15-2009, 08:38 | #1046 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Press power on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034317670 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:05 |
08-15-2009, 08:49 | #1047 (permalink) |
No Life Poster Join Date: Jun 2005 Location: rajabrothers communications Age: 43
Member: 155773 Status: Offline Sonork: 1606514 Thanks Meter: 87 | a.o.a and hi to all hare is one more ufone........... Press power on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034286792 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:17 br raja |
08-15-2009, 08:50 | #1048 (permalink) |
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | T156 with new security for unlock no need to open T156 with new security for unlock just use LG C2500 cable and follow the unlocking steps and enjoy here is the report Press power on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034317670 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:05 |
The Following 2 Users Say Thank You to hasnain For This Useful Post: |
08-15-2009, 08:50 | #1049 (permalink) |
No Life Poster Join Date: Feb 2006 Location: pakistan Age: 49
Member: 232607 Status: Offline Sonork: 100.1585040 Thanks Meter: 260 | thanx FURIOUS TEAM <<<<T156 SUCCESSFULLY UNLOCKED>>>> Press power on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034375082 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:04 Press power on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034373897 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:05 THANX HACK3R2K |
08-15-2009, 08:52 | #1050 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Android developers
Member: 904753 Status: Offline Sonork: 100.1583681 Thanks Meter: 2,677 | Ufone t156 unlock done without open new method T156 NEW CPU ALL VERSION SUPPORTED BY NEW UPDATE HERE T156 NEW CPU UNLOCK INSTRUCTIONS: 1. PHONE MUST BE CONNECTED POWERED ON AND WITHOUT SIM 2. SELECT T156 FROM VODAFONE MODULE 3. PRESS FEW TIME RED BUTTON TILL LCD LIGHTS 1.First Download New VODAFONE BETVERSION: VODAFONE_BETA_v1.0.0.2903 2.OPEN VODAFONE BETA. 3.I M USE INTERFACE INFINITY COM AND USE CABEL C2500. 4.SIMPLY PRESS DO JOB. Press power on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034766744 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:23 BR. Waqar |
