Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| FuriouS TeaM Products FuriouS GOLD Support Area |
| | #10771 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2010 Location: Uzbekistan Age: 34
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks: 165
| Software engine version: 1.0.0.6468 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 38 85 98 C5 01 8C 03 Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:04:16 |
| | #10772 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2009 Location: TUNISIA
Member: 1114818 Status: Offline Thanks: 18
| by sfr starshine unlock done (pack 7) hello all : here how put it in fast boot Turn off the phone. Then press Power shortly. Then press and hold "Vol -", "Menu" and "Power" buttons till sandclock appears on your phone screen (and the phone completely hangs). This will enter to fastboot mode. Then connect your phone to computer and follow the rest of instructions. here unlock log Searching Huawei phone COM ports... not found ! Searching Android USB Interface... OK Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Starting bootloader... OK Sending data to server... OK Reading data from server... OK Sending boot data... OK Initializing NAND functions... OK Initializing NV functions... OK Server disconnected! Reading NV item #550...OK Reading NV item #114...OK Reading NV item #60001...OK Searching for OEMINFO data... OK Product name: U8150 Model name: Huawei U8180/SFR STARSHINE IMEI: 357232044739371 S/N: D5J4CD11B0905832 Firmware: U8180-1V100R001C33B621_EFS SIM Lock status: locked (NCK lock) 2012-05-07 11:14:32.968 Start unlocking procedure (357232044739371) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Reading NV item #550...OK Checking bootloader status... OK Reading NV item #114...OK Searching for OEMINFO data... OK Log file successfully saved to file "C:\Documents and Settings\mohsen\Bureau\2012-05-07_111501_log.txt" Creating backup of Sensitive Data... OK Backup saved to file "C:\Program Files\FURIOUS-GOLD\PACK7\Backup\357232044739371_2012-05-07_111506.fhb" Sending data to server... OK Reading data from server... OK Writing NAND... OK Verification... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... OK Server disconnected! 2012-05-07 11:15:14.828 Done! |
| | #10773 (permalink) |
| Software engine version: 1.0.0.7886 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 22 2010 15:33:00 RELEASE DATE : Jun 24 2010 21:00:00 FIRMWARE INFO : BL_RU_P607C3V1.0.0B06-S IMEI : 35541604061152-6 BLUETOOTH ADDR : 00 00 00 00 00 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 250 MNC: 99) LOCKED NET 6 (MCC: 255 MNC: 2) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:11 |
| | #10775 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Jan 2006
Member: 226742 Status: Offline Thanks: 0
| p925 unlock Attach phone to usb cable, type 3845#*925#, select [Port Setting] and after [CP Image download] and press [OK] Phone detected; USB Port opened; Boot-loader Alive; Sending loaders; Done; Boot Mode: BB; Ebl_ver: XMM6260_20.04_M1S1 20..4; Sending loader config; Done; Memory Info: 00AD:00B1 [0x00000000] Reading Security; Done; Saved DE8B30DB9B372FCA0776A611DEAEF013.bin Working; MCC-MNC: 310-41 IMEI: 012621-00-283288-8 BTAD: 44:0B:50:13:1C:F0 PID: BS08S111107001183 LOCK STATUS: ON Writing Security; Done; Restart phone to complete the operation; Time needed - 00:01:54 |
| The Following User Says Thank You to greno For This Useful Post: |
| | #10776 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: campioni del mondo
Member: 235881 Status: Offline Thanks: 43
| UNLOCK PALM PRE Software engine version: 1.0.0.7890 Searching phone ... MODEL : QCOM SERIES 15 COMPILED DATE : Sep 2 2009 17:30:00 RELEASE DATE : Sep 2 2009 17:06:00 FIRMWARE INFO : CU0.5.13(127) IMEI : 35813 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0036 MEMORY NAME : samsung_k9f1208 MEMORY INFO : 0200:0020:033C WORKING; UNLOCKED; POWER OFF PHONE TO COMPLETE UNLOCK AND AFTER DISABLE THE DIAG; Time needed - 00:00:02 |
| | #10777 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2004 Location: VietNam Age: 33
Member: 56938 Status: Offline Thanks: 73
| Unlocked My401c Big thanks to .:hack3r2k:. Quote:
| | #10778 (permalink) |
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks: 195
| SFR staraddict noir done Code: Software engine version: 1.0.0.7891 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Oct 15 2011 03:47:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 86853400083286-4 BLUETOOTH ADDR : C8 AF D1 B2 1A 68 TAG_ID:P743FB05h DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:01:14 |
| | #10780 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 31
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks: 124
| SAGEM my411x Unlock Dne Press power on shortly ... Starting communication ... MCU ID: 25200313A9395AC1000000000000CE2A ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411X Hash: 00002054 Algo: 05 Firmware: LO5,RE: 120407 1624 Imei: 355150014875771 Phone code: 0000 Prod. code: 252925020 Id calculation done; CODES: NET LO CODE: 3825580767 NET HI CODE: 2764421535 DIRECT UNLOCK: ERROR Done ! Time needed - 00:04:01 |
| | #10781 (permalink) |
| Software engine version: 1.0.0.6468 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 32 85 94 09 00 95 04 Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:46 |
| | #10782 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009
Member: 953931 Status: Offline Thanks: 19
| zte f160 locked by orange cameroun unlock done!!!! ZTE F160 UNLOCK OK 100% Software engine version: 1.0.0.7883 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jun 14 2011 18:08:00 RELEASE DATE : Apr 1 2011 04:00:00 FIRMWARE INFO : ORG_CM_P622F2V1.0.0B02-S IMEI : 86500800228695-0 BLUETOOTH ADDR : 87 1F DE C7 64 C8 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 32A0ED81AF49C61CC956910B57504FC0.bin ERASING; WRITING; READING; AFTER BACKUP: 9E71704FC2636AAE54F9B1EAD156925C.bin UNLOCKED; RESET ! Time needed - 00:00:33 |
| | #10784 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: nigeria
Member: 581848 Status: Offline Thanks: 291
| Searching Huawei phone COM ports... not found ! Searching Android USB Interface... OK Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Starting bootloader... OK Sending data to server... OK Reading data from server... OK Sending boot data... OK Initializing NAND functions... OK Initializing NV functions... OK Server disconnected! Reading NV item #550...OK Reading NV item #114...OK Reading NV item #60001...OK Searching for OEMINFO data... OK Product name: U8150 Model name: Huawei U8350 IMEI: 356899040040722 S/N: Q3P7NB1161312753 Firmware: U8350V100R001C224B607_EFS SIM Lock status: locked (NCK lock) 2012-05-10 22:24:51.175 Start unlocking procedure (356899040040722) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Reading NV item #550...OK Checking bootloader status... OK Reading NV item #114...OK Searching for OEMINFO data... OK Creating backup of Sensitive Data... OK Backup saved to file "D:\furiou5\Backup\356899040040722_2012-05-10_222513.fhb" Sending data to server... OK Reading data from server... OK Writing NAND... OK Verification... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... OK Server disconnected! 2012-05-10 22:25:21.634 Done! ,huawei barcelona unlocked by furious gold......very easy just off the phone press volum- and end key red buton same time with power key then insert your usb thats all and furious will do the rest ..........just like magic thanks furious team for this pack7 please we need more update......thanks |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
