07-17-2012, 06:00 | #10876 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Software engine version: 1.0.0.6502 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865043788629 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 32 04 98 E5 09 0B 0F Flash ID(0): 00C2:22A7 Saved: ZTE_352865043788629_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_17.18.43_15.07.2012_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:46 |
07-17-2012, 06:01 | #10877 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Connect phone powered on ! Start auth ! SW Ver: 08.06.00:18.26.22:06.00.00:ULC2GL Imei: 359391026131359 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-32 [00 31] ... Preloader sent .... Loader sent .... Flash ID(0): 0020:8828 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:08:15 |
07-17-2012, 11:58 | #10878 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E4 36 46 95 55 06 07 0F Flash ID(0): 001C:22C4 PARTIAL: MiniFone_TDS12-1_UomeX V15_MEGAFON_RUSSIA RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:28 |
07-17-2012, 12:28 | #10879 (permalink) |
No Life Poster Join Date: Feb 2010 Location: 90-region Age: 39
Member: 1246378 Status: Offline Thanks Meter: 123 | Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 38 C5 99 9B 04 8B 06 Flash ID(0): 00C2:22A7 PARTIAL: REL_P1.1KK01V01.05 RANGE(S): 00000000:003F0000 00000000:003F0000 Restored ! Remove battery and put back ! Time needed - 00:07:06 |
07-17-2012, 13:47 | #10880 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1271541 Status: Offline Thanks Meter: 35 | Successfully Unlocked acer e310 Software engine version: 1.0.0.8143 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Oct 24 2011 18:02:00 RELEASE DATE : May 25 2011 06:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6170 , CCI:ACER Unknown 5.043.00 IMEI : 00000000000000-0 BLUETOOTH ADDR : 01 00 00 00 00 00 LOADING DATA; DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; NETWORK: 21988614 SERVICE: 12345678 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. RESET ! Time needed - 00:00:46 |
07-17-2012, 15:01 | #10881 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.8143 Searching phone ... MODEL : QCOM SERIES 17 COMPILED DATE : Aug 20 2008 18:11:00 RELEASE DATE : Feb 20 2008 11:00:00 FIRMWARE INFO : M6280-ESPOO-409545 IMEI : 00000000000000-0 BLUETOOTH ADDR : 01 00 00 00 00 00 INIT NAND ROUTINES; NAND INIT MADE; READING; SAVED: BEB0731FF6C641EA7D8091339840447A.bin ZzZ ERASING; WRITING; UNLOCKED ! Time needed - 00:00:09 |
07-18-2012, 00:43 | #10882 (permalink) |
No Life Poster Join Date: May 2007 Location: MOROCCO
Member: 510826 Status: Offline Thanks Meter: 183 | UNLOCK TG01 DONE : Software engine version: 1.0.0.8145 Searching phone ... MODEL : TOSHIBA TG01 ENTERING DOWNLOAD MODE; ENTERED; BOOTLOADER VER: 8650B--SDCA ALLOCATING BUFFERS; PREPARING TO DUMP SENSITIVE DATA; DECODING DATA; SAVED TG01S.bin; IMEI : 35923902011214-1 BLUETOOTH ADDR : 19 14 25 18 23 00 NETWORK: 19303982 NETWORK SUBSET: 96820148 SERVICE PROV.: 72172182 CORPORATE: 97217377 SIM/USIM: 07131512 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. USUALLY NETWORK OR SIM/USIM ARE THE ENABLED LOCKS ! IN WORST CASE TRY ALL ;-) ONE WILL SURELY WORK ! RESETTING; Time needed - 00:00:52 |
07-18-2012, 11:31 | #10883 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Connect phone powered on ! Start auth ! SW Ver: 08.06.00:18.26.22:06.00.00:ULC2GL Imei: 359391027382498 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-32 [00 31] ... Preloader sent .... Loader sent .... Flash ID(0): 0020:8828 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:08:06 |
07-18-2012, 11:52 | #10884 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 1B 39 84 9A 1E 02 0A 06 Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:04:06 |
07-18-2012, 22:47 | #10885 (permalink) |
Member: 1271541 Status: Offline Thanks Meter: 35 | MCU ID: 2600020A086746C1000000000000B61C ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 0000220E Algo: 05 Firmware: EVN,PI: 200808 0938 Imei: 359262020908169 Phone code: 0000 Prod. code: 254025878 Id calculation done; CODES: NET LO CODE: 2942304842 NET HI CODE: 4011852426 DIRECT UNLOCK: OK Done ! Time needed - 00:02:28 |
07-19-2012, 09:24 | #10886 (permalink) |
Freak Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 43
Member: 120908 Status: Offline Thanks Meter: 38 | Software engine version: 1.0.0.8145 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jul 8 2010 20:08:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : TEL_AU_P608D1V1.0.0B20-S IMEI : 35181504008784-9 BLUETOOTH ADDR : B9 32 71 1A 18 08 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 1 (MCC: 1 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:10 |
07-19-2012, 13:24 | #10887 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Dhaka mirpur-1 Age: 38
Member: 577653 Status: Offline Thanks Meter: 235 | Searching phone ... Phone detected ... MODEL : Q62xx-OSBL- STARTING; OK; LOADING; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 3538200400xxxxx READING; SP_SAVED_TO: SP_353820040xxxxx_E77_18.17.31_19.07.2012_HUAWEI.b in ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:01:49 |
07-20-2012, 14:10 | #10888 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | ZTE 112 Noir Software engine version: 1.0.0.6502 Connect phone powered on ! Start auth ! SW Ver: EFSPI-FR-SFR-P108E10FM(S)V1.0.0B06 Imei: 353894030939721 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0103 Reading ... Saved: ZTE_353894030939721_EFSPI-FR-SFR-P108E10FM(S)V1.0.0B06_15.08.40_20.07.2012_PARTIAL. bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:32 |
07-21-2012, 09:49 | #10889 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | zte f102 unlock done Software engine version: 1.0.0.7890 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003337074-4 BLUETOOTH ADDR : 27 06 6C 37 F5 98 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:10 |
07-21-2012, 09:50 | #10890 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | vodafone527 unlock ok Press power on shortly ... Starting communication ... MCU ID: 3AA00118304900C20000000000002C64 ROM HASH: 731C27AB2AE00189FBD4FD3013B53252 ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 00002D30 Algo: 05 Firmware: EVN,PH: 240408 0931 Imei: 351959020169977 Phone code: 0000 Prod. code: 254023494 Id calculation done; CODES: NET LO CODE: 3933516745 NET HI CODE: 2863969161 DIRECT UNLOCK: OK Done ! Time needed - 00:02:03 |
