Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| FuriouS TeaM Products FuriouS GOLD Support Area |
| | #10906 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Jan 2010 Location: Paris Age: 37
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks: 495
| Product: SFR3440 Provider ID: F344X-2[X=A]SFFR1 IMEI: 867242000204040 Start code calculate... NCK:1510100129 NSCK: SPCK: PCK: Code calculate finished successfully! Product: SFR3440 Provider ID: F344X-2[X=A]SFFR1 IMEI: 867242000413898 Start code calculate... NCK:0393077204 NSCK: SPCK: PCK: Code calculate finished successfully! |
| | #10907 (permalink) |
| Code calculate finished successfully! Product: SFR3440 Provider ID: F344X-2[X=A]SFFR1 IMEI: 867242001301159 Start code calculate... NCK:2360711535 NSCK: SPCK: PCK: Code calculate finished successfully! Product: SFR3440 Provider ID: F344X-2[X=A]SFFR1 IMEI: 867242001112192 Start code calculate... NCK:1342742112 NSCK: SPCK: PCK: Code calculate finished successfully! |
| | #10908 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Thanks: 756
| HAPPY DAY!!! My 511x unlock done!! Code: Press power on shortly ... Starting communication ... MCU ID: 1F40020BFF0A5FC10000000000001218 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my511X Hash: 00002834 Algo: 05 Firmware: EVN,DA: 030807 1430 Imei: 356867010134395 Phone code: 0000 Prod. code: 252996371 Id calculation done; CODES: NET LO CODE: 0574865077 NET HI CODE: 1644412533 DIRECT UNLOCK: OK Done ! Time needed - 00:02:18 |
| | #10909 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 642071 Status: Offline Thanks: 33
| Zte z990 unlock done - Set phone to FTM mode (Press power button and Volume down together) - Connect phone to PC and install driver - Scan Ports - Choose "UNLOCK" - Press Do the "JOB" - Follow Onscreen instruction Software engine version: 1.0.0.7893 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Oct 24 2011 10:10:00 RELEASE DATE : May 11 2011 02:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-60503001 IMEI : 3568000******** BLUETOOTH ADDR : FE 05 46 5B 7B C8 TAG_ID:P736TB15 DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:48 |
| | #10910 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2009 Location: near the mosque
Member: 1187394 Status: Offline Thanks: 57
| vodafone 255 unlocked. Software engine version: 1.0.0.6486 Insert cable in box now [NO BATTERY INSIDE PHONE] ! Starting communication ... Platform: E-Gold Voice3-32 [00 00] ... Preloader sent .... Loader sent .... Flash ID(0): 00EF:4016 Checking firmware version ... Detected: ED-DE-P118A16V1.0.0B09 Saved: ZTE_NONE_ED-DE-P118A16V1.0.0B09_22.56.54_14.06.2012_PARTIAL.bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:58 |
| | #10911 (permalink) |
| Code calculate from blackberry 8707v Searching for usb device ... Reading info ... IMEI: 35988400227.... Calculating ... MEP LOCK: MEP-05277-004 MEP1 [SIM]: 2218314022438740 MEP2 [NETWORK]: 6234240909130114 MEP3 [NETWORK SUBSET]: 4545879780214617 MEP4 [SERVICE PROVIDER]: 4272023974521171 MEP5 [CORPORATE]: 0105520789521246 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:48 |
| | #10912 (permalink) |
| Code calculate finished successfully! Product: SFR3440 Provider ID: F344X-2[X=A]SFFR1 IMEI: 867242001112499 Start code calculate... NCK:0675694862 NSCK: SPCK: PCK: Code calculate finished successfully! Product: SFR3440 Provider ID: F344X-2[X=A]SFFR1 IMEI: 867242001112291 Start code calculate... NCK:3147081575 NSCK: SPCK: PCK: Code calculate finished successfully! |
| | #10913 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2009 Location: Inside Gsmserver Cafe
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks: 251
| U2800A at&t done Searching phone ... Phone detected ... MODEL : Q62xx-OSBL- STARTING; OK; LOADING; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35663104510755-6 READING; SP_SAVED_TO: SP_35663104510755_E77_08.31.07_14.06.2012_HUAWEI.b in ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:01:43 |
| | #10914 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2010 Location: Uzbekistan Age: 34
Member: 1293050 Status: Online Sonork: 100.1625975 Thanks: 165
| Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 1B 35 C4 99 87 0A 9A 01 Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:56 |
| | #10915 (permalink) |
| Software engine version: 1.0.0.6486 Connect phone powered on ! Start auth ! SW Ver: 08.06.00:18.26.22:06.00.00:ULC2GL Imei: 357356031021558 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-32 [00 31] ... Preloader sent .... Loader sent .... Flash ID(0): 0020:8828 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:08:35 |
| | #10916 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: www.theunlocker.org
Member: 740263 Status: Online Sonork: 100.1608512 Thanks: 73
| Searching Huawei phone COM ports... not found ! Searching Android USB Interface... OK Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Starting bootloader... OK Sending data to server... OK Reading data from server... OK Sending boot data... OK Initializing NAND functions... OK Initializing NV functions... OK Server disconnected! Reading NV item #550...OK Reading NV item #114...OK Reading NV item #60001...OK Searching for OEMINFO data... OK Product name: U8220 Model name: Huawei U8230 IMEI: 357262030502251 S/N: MV7NAC1012601074 Firmware: U8230V100R001C01B208_EFS SIM Lock status: locked (NCK lock) 2012-06-17 17:07:42.601 Start unlocking procedure (357262030502251) Connecting to server... failed! Server disconnected! failed! Error connecting to server ! 2012-06-17 17:08:03.770 Start unlocking procedure (357262030502251) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Reading NV item #550...OK Checking bootloader status... OK Reading NV item #114...OK Searching for OEMINFO data... OK Creating backup of Sensitive Data... OK Backup saved to file "D:\FURIOUS\7\HUAWEI_ANDROID_UNLOCKER_0020\Backup\ 357262030502251_2012-06-17_170818.fhb" Sending data to server... OK Reading data from server... OK Writing NAND... OK Verification... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... Error! Server disconnected! 2012-06-17 17:08:33.254 Done! Searching Huawei phone COM ports... not found ! Searching Android USB Interface... OK Checking bootloader status... OK Reading NV item #550...OK Reading NV item #114...OK Reading NV item #60001...OK Searching for OEMINFO data... OK Product name: U8220 Model name: Huawei U8230 IMEI: 357262030502251 S/N: MV7NAC1012601074 Firmware: U8230V100R001C01B208_EFS SIM Lock status: not locked |
| | #10917 (permalink) |
| Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 35 06 96 05 02 0A 05 Flash ID(0): 001C:22C4 PARTIAL: MiniFone_TDS12-1_UomeX V15_MEGAFON_RUSSIA RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:04:18 |
| | #10918 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Aug 2007 Location: Pakistan " Karachi " Age: 31
Member: 572216 Status: Online Sonork: 100.1612300 Thanks: 961
| Searching for usb device ... Reading info ... IMEI: 351846038483252 Calculating ... MEP LOCK: MEP-16472-001 MEP1 [SIM]: 3134483456114458 MEP2 [NETWORK]: 9505118517407717 MEP3 [NETWORK SUBSET]: 5897479934792711 MEP4 [SERVICE PROVIDER]: 5982763900251904 MEP5 [CORPORATE]: 1380288792884748 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:01:54 |
| | #10919 (permalink) |
| Software engine version: 1.0.0.6486 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620031668868 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 0001:0110 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:03:58 |
| | #10920 (permalink) |
| Software engine version: 1.0.0.7886 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Nov 4 2011 17:25:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 86160300035935-5 BLUETOOTH ADDR : 4F 76 B7 B2 1A 68 TAG_ID:QCNDef DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:43 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
