08-03-2012, 14:54 | #10936 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Software engine version: 1.0.0.6502 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041428855 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 32 04 97 A0 06 20 0A Flash ID(0): 00C2:22A7 Saved: ZTE_352865041428855_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_18.18.16_31.07.2012_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:44 |
08-03-2012, 14:54 | #10937 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 1000 unlock done COMM OPENED 5 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042496019 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 |
08-03-2012, 14:55 | #10938 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 2100 unlock done COMM OPENED 5 ! BAUD SET ! AUTH MADE ! SW VERSION: HUAWEI G2100V100R001PAKC19B102SEC TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 351633040589486 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:23 |
08-03-2012, 15:00 | #10939 (permalink) |
Freak Poster Join Date: Jul 2007 Location: some where Age: 41
Member: 545608 Status: Offline Thanks Meter: 25 | Searching Huawei phone COM ports... not found ! Searching Android USB Interface... OK Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Starting bootloader... OK Sending data to server... OK Reading data from server... OK Sending boot data... OK Initializing NAND functions... OK Initializing NV functions... OK Server disconnected! Reading NV item #550...OK Reading NV item #114...OK Reading NV item #60001...OK Searching for OEMINFO data... OK Product name: U8150 Model name: Huawei U8150 IMEI: 352607043351838 S/N: AAA7NE10B0416362 Firmware: U8150V100R001C85B819_EFS SIM Lock status: locked (NCK lock) 2012-08-03 13:52:46.311 Start unlocking procedure (352607043351838) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Reading NV item #550...OK Checking bootloader status... OK Reading NV item #114...OK Searching for OEMINFO data... OK Creating backup of Sensitive Data... OK Backup saved to file "C:\Program Files\FuriouS-Gold\pack7\Backup\352607043351838_2012-08-03_135305.fhb" Sending data to server... OK Reading data from server... OK Writing NAND... OK Verification... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... OK Server disconnected! 2012-08-03 13:53:16.889 Done! |
08-03-2012, 15:05 | #10940 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 1000 unlock done COMM OPENED 5 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042095068 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 |
08-03-2012, 15:05 | #10941 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 2201 unlock done Software engine version: 1.0.0.6502 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620030648036 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 00EC:0106 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:04:15 |
08-03-2012, 15:06 | #10942 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Z 100 unlock done Software engine version: 1.0.0.6502 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865043788629 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 32 04 98 E5 09 0B 0F Flash ID(0): 00C2:22A7 Saved: ZTE_352865043788629_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_17.18.43_15.07.2012_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:46 |
08-04-2012, 05:35 | #10943 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.8280 Searching phone ... MODEL : QCOM SERIES 17 COMPILED DATE : Aug 20 2008 18:11:00 RELEASE DATE : Feb 20 2008 11:00:00 FIRMWARE INFO : M6280-ESPOO-409545 IMEI : 00000000000000-0 BLUETOOTH ADDR : 01 00 00 00 00 00 INIT NAND ROUTINES; NAND INIT MADE; READING; SAVED: BEB0731FF6C641EA7D8091339840447A.bin ZzZ ERASING; WRITING; UNLOCKED ! Time needed - 00:00:49 |
08-06-2012, 09:38 | #10946 (permalink) |
No Life Poster Join Date: May 2005 Location: Bulgaria Age: 49
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Successfully unlock HUAWEI U8150 ! Searching Huawei phone COM ports... not found ! Searching Android USB Interface... OK Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Starting bootloader... OK Sending data to server... OK Reading data from server... OK Sending boot data... OK Initializing NAND functions... OK Initializing NV functions... OK Disconnecting from server... OK Reading NV item #550...OK Reading NV item #114...OK Reading NV item #60001...OK Searching for OEMINFO data... OK Product name: U8150 Model name: Huawei U8150 IMEI: 35509304xxxxxxx S/N: W7K7NE10B0503198 Firmware: U8150V100R001C127B816_EFS SIM Lock status: locked (NCK lock) 2012-08-06 11:10:00.203 Start unlocking procedure (35509304xxxxxxx) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Reading NV item #550...OK Checking bootloader status... OK Reading NV item #114...OK Searching for OEMINFO data... OK Directory "C:\Documents and Settings\PACO\Desktop\7.HUAWEI_ANDROID_UNLOCKER_00 19\Backup" not found ! Creating backup directory "C:\Documents and Settings\PACO\Desktop\7.HUAWEI_ANDROID_UNLOCKER_00 19\Backup"... failed! Backup directory set to default! ("D:\C\Desktop\GSM\Furious Gold\New\7.HUAWEI_ANDROID_UNLOCKER\Backup") Creating backup directory "D:\C\Desktop\GSM\Furious Gold\New\7.HUAWEI_ANDROID_UNLOCKER\Backup"... Creating backup of Sensitive Data... OK Backup saved to file "D:\C\Desktop\GSM\Furious Gold\New\7.HUAWEI_ANDROID_UNLOCKER\Backup\35509304 xxxxxxx_2012-08-06_111008.fhb" Sending data to server... OK Reading data from server... OK Writing NAND... OK Verification... Writing NAND... OK Verification... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... OK Disconnecting from server... OK 2012-08-06 11:10:12.250 Done! |
08-07-2012, 11:01 | #10947 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Dhaka mirpur-1 Age: 38
Member: 577653 Status: Offline Thanks Meter: 235 | Motorola mb300 unlock done Software engine version: 1.0.0.8280 Searching phone ... MODEL : QCOM SERIES 18 COMPILED DATE : May 19 2010 18:56:00 RELEASE DATE : Jan 14 2010 19:00:00 FIRMWARE INFO : M76XX-SDCBALUM-63805027 IMEI : 356693030xxxxxxxx BLUETOOTH ADDR : A4 ED 4E 2D 12 77 LOADING DATA; DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; NETWORK: 14888777 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:46 |
08-08-2012, 11:03 | #10948 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania/Piatra Neamt
Member: 880649 Status: Offline Thanks Meter: 73 | Alcatel OT991 unlock ok by calculating Useing AlcatelMTKPhoneUnlockTool v1.0.3.4 Product: OT-991 Provider ID: 991X-2[X=A,B,C]YGES1 IMEI: 862601010499XXX (mask some digits) Start code calculate... NCK:33673965 NSCK:30149362 SPCK:24360474 PCK:33578487 Code calculate finished successfully! |
08-08-2012, 13:33 | #10949 (permalink) |
Member: 880649 Status: Offline Thanks Meter: 73 | Vodafone 545 unlock ok Software engine version: 1.0.0.6486 Press power on shortly or insert the cable in the powered off phone ... COM Port opened; Boot-loader Alive; Sending loaders; Done; Boot Mode: BB; Ebl_ver: XMM2130_RAM_Bootloader_B9.3_V 1..1; Sending loader config; Done; Memory Info: 0001:007E [0x02000000] Reading calibration; Reading static eeprom; Reading dynamic eeprom; Saved: 546_545_15.19.13_08.08.2012_EEP_CAL.bin Checking version; Detected: EFSPHAZR-RO-P160A6(SPA)V1.0.0B08 Reading; Writing; Direct unlock finished. Time needed - 00:03:07 THANKS TO FURIOUS TEAM!!! |
08-10-2012, 11:31 | #10950 (permalink) |
Major Poster Join Date: Jul 2010 Location: Philippines
Member: 1336822 Status: Offline Sonork: jabar Thanks Meter: 4 | B-Mobile U526 Unlock....DONE I want to share this unlocking B-Mobile U526 using Furious Gold.... UNIT PREVIEW PROCEDURE: 1. Connect USB cable from (FG package) if asking driver. download this file: V710, U526 USB Driver 2.Open HUAWEI (VODAFONE Q MODULE) 3. Phone must be in TEST MODE (press *,0,# simultaneously) White screen only: 4. SCAN PORTS 5. Finally Tick DO JOB Strong Evidence Then manually enter the unlock code or NCK code Pic after successfully unlock phone Manual restart phone... and THIS IS IT............. br: msjabar |
The Following 3 Users Say Thank You to msjabar For This Useful Post: |
