09-22-2014, 09:09 | #12031 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | Using library Brom_DLL_v5.1316.1 COM opened ok; Press power and keep it pressed now ! Requesting authorization; Done; Connecting; Meta mode entered; Baseband Chip: MT6250 Sw version: MAUI.11B.W12.24.MP.V10.F10 Hw Version: JRDHZ50_11B_HW Reading phone info; IMEI: 862279-02-118754-4 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:10 |
09-22-2014, 09:10 | #12032 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | 2005x unlock sing library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port) Preparing to start meta mode; Requesting authorization; Done; Meta mode entered; Baseband Chip: MT6250 Sw version: MAUI.11B.W12.24.MP.V2.F41 Hw Version: JRDHZ50_12864_11B_24MP_HW Reading phone info; IMEI: 869795-01-461875-0 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; |
09-22-2014, 09:10 | #12033 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | ot 1046 unlock Using library Brom_DLL_v5.1316.1 COM opened ok; Press power and keep it pressed now ! Requesting authorization; Done; Connecting; Meta mode entered; Baseband Chip: MT6260 Sw version: MAUI.11B.W13.08.MP.V4.F21 Hw Version: JRDHZ60A_11B_HW Reading phone info; IMEI: 863803-02-047679-5 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; |
09-22-2014, 16:50 | #12034 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Oued zenati Algeria Age: 44
Member: 266158 Status: Offline Sonork: 131654654654 Thanks Meter: 198 | Starchine 2 unlock done pack 6 Searching phone; Phone detected (MediaTek PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM267); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V1.F2.P4 Hw Version: SAGETEL72_WET_JB3_HSPA_HW Reading phone info; IMEI: 358602-05-002719-3 Reading simlock info; Locked to: 208-10 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:35 |
09-22-2014, 22:26 | #12035 (permalink) |
No Life Poster Join Date: Nov 2011 Location: Ksar El Boukhari
Member: 1688512 Status: Offline Thanks Meter: 1,098 | OLD SAGEM 212 Read Code ! SAGEM 212 Read Code Successful Code: Press power on shortly ... Starting communication ... MCU ID: 0B700119EC605DC1000000000000501C ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2B7E:3300 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my212X Hash: 00001D2A Algo: 05 Firmware: LB5,PF: 290607 1353 Imei: 3524XXXXXXXXX45 Phone code: 0000 Prod. code: 252985914 Id calculation done; CODES: NET LO CODE: 1549195016 NET HI CODE: 0479647560 Done ! Time needed - 00:01:29 |
The Following User Says Thank You to Sid@li For This Useful Post: |
09-23-2014, 18:18 | #12036 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 605126 Status: Offline Sonork: 100.1617907 Thanks Meter: 297 | zte grand x(m) successfully unlock zte grand x(m) successfully unlock by F.G mtk code reader THX TO F.G TEAM LOGS.... Searching phone; Phone detected (@oem410.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM181); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6577 Sw version: MAUI.11AMD.W12.22.SP.V1.P5 Hw Version: ZTENJ77_CU_ICS2_HW Reading phone info; IMEI: 868841-01-000285-3 Reading simlock info; Locked to: 214-04 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:01:13 |
The Following User Says Thank You to louisgsm For This Useful Post: |
09-23-2014, 21:10 | #12037 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Morocco
Member: 382783 Status: Offline Thanks Meter: 124 | Alcatel OT510/OT510A unlock Done. Hello, it's easy to unlock Alcatel OT510/OT510A Because we have Furious Gold Box. 1-Choose com port 2-check Remove Sim_Lock 3connect cable 4-press Connect |
The Following 2 Users Say Thank You to rafanachi For This Useful Post: |
09-24-2014, 13:25 | #12038 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | ZTE S518M SUCCESSFULL UNLOCKED HERE IS LOG: Quote:
MianLinks | |
The Following User Says Thank You to mianjabbar For This Useful Post: |
09-26-2014, 19:10 | #12039 (permalink) |
Major Poster Join Date: Dec 2004 Location: Jamaica Age: 40
Member: 97192 Status: Offline Thanks Meter: 7 | Successfully UNLOCKED Blu Studio 5.0 II with Furious gold mtkreader v1.0.0.470 Successfully UNLOCKED Blu Studio 5.0 II (D522u) with Furious gold mtkreader v1.0.0.470 Log: earching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM28); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V1.P6 Hw Version: TINNO72_WET_JB3_HSPA_HW Reading phone info; IMEI: 351xxx-xx-xxxxxx-3 Reading simlock info; Locked to: 460-00 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:01:01 Also unlocked a Blu Tank as well with same version mtkreader!!! Both phones were from Digicel Jamaica. |
The Following User Says Thank You to danoph83 For This Useful Post: |
09-29-2014, 11:56 | #12040 (permalink) |
Member: 382783 Status: Offline Thanks Meter: 124 | Alcatel OT-918 Unlock Done Alcatel OT-918 Unlock Done with MTK Coda Reader PAck 6 |
The Following User Says Thank You to rafanachi For This Useful Post: |
09-29-2014, 12:44 | #12041 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,701 | zte kis pro unlocked hi here u are a successfull log about zte orange zali unlocking Code: Software engine version: 1.0.0.8952 Searching phone ... MODEL : QCOM SERIES 25 COMPILED DATE : Jun 9 2013 13:53:00 RELEASE DATE : May 7 2013 02:00:00 FIRMWARE INFO : 76XXU-USNSKOLYM-2540 IMEI : 358046********* BLUETOOTH ADDR : 8F 8C 10 B6 E8 78 FIRMWARE: ORANGE_MD_P752D20V1.0.0B01 DONE; LOADING DATA; INIT NAND ROUTINES; NAND INIT MADE; UNLOCKING; PERFORMING EXTENDED UNLOCK; SIM_LOCK REMOVED ! RESET ! |
09-29-2014, 14:05 | #12042 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | OYSTERS T72 3G UNLOCK DONE FURIOUS THE BEST Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Gadget Serial (COM12); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6582, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V18 Hw Version: ELINK82_TB_JB5_HSPA_HW Reading phone info; IMEI: 351591-06-3755-1 Reading simlock info; Locked to: 250-01 code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Unlocking SIM2 too. Time needed - 00:01:16 |
09-30-2014, 10:41 | #12043 (permalink) |
No Life Poster Join Date: Jan 2010 Location: iraq
Member: 1215266 Status: Offline Thanks Meter: 129 | ALCATEL 1060 unlock and arabick done Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM123]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0000 Starting auth; HW IMEI : 869789-01-083345-5 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: 1060X-2ATNHU1 BT ADDR: 3A:EF:A3:2E:5F:90 SW IMEI[0]: 352273-01-738634-0 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303B8000 Reading NV; NV saved to : NV_869789-01-083345-5_352273-01-738634-0_65310000_30_09_2014_01_28_27.spd IMEI: 869789-01-xxxxxxxxxxx UNLOCK CODE: 79821134 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_30_09_2014_01_28_46.txt For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM123]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0000 Starting auth; HW IMEI : 869789-xxxxxxxxx Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: 1060X-2ATNHU1 BT ADDR: 3A:EF:A3:2E:5F:90 SW IMEI[0]: 352273-01-738634-0 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 303B8000 Uncompressing; Done; Re-programming; FLS programmed; Done; Remove battery and cable; Log file saved to: LOG_30_09_2014_01_41_42.txt |
The Following User Says Thank You to tornado779 For This Useful Post: |
10-01-2014, 14:03 | #12044 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | alcatel ot 4010x unlock done ALCATEL OT 4010X UNLOCK DONE Code: Searching phone; Phone detected (@oem19.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM222); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6575 Sw version: MAUI.11AMD.W11.50.SP.V31.F2.P9 Hw Version: JRDHZ75_GB2_HW Reading phone info; IMEI: 869294-01-193746-2 Reading simlock info; NOTE: Most of the times one of the first variants will work ! MODEL: OT-4010 UNLOCK CODE: 1 8 5 7 9 6 5 3 MODEL: OT-4010 UNLOCK CODE: 1 9 7 2 5 9 1 4 MODEL: OT-4010 UNLOCK CODE: 1 2 1 9 1 2 0 1 MODEL: OT-4010 UNLOCK CODE: 3 7 2 1 0 7 5 0 Time needed - 00:10:47 |
10-02-2014, 11:52 | #12045 (permalink) |
Registered User Join Date: May 2009 Location: BONOUA - Ivory Coast
Member: 1040340 Status: Offline Thanks Meter: 58 | Sfr startrail 5 unlock succesfully Select Alcatel ANDROID MTK Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM31); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V1.F3.P1 Hw Version: SAGETEL72_WET_JB3_HSPA_HW Reading phone info; IMEI: 353273-06-014482-7 Reading simlock info; Locked to: 208-10 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:40 |
