10-14-2014, 17:44 | #12076 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Almoradi (ALICANTE) . SPAIN
Member: 1677266 Status: Offline Thanks Meter: 90 | Searching phone; Phone detected (@oem149.inf,%mtk_preloader%;MediaTek PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM141); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6575 Sw version: MAUI.11AMD.W11.50.SP.V27.F1 Hw Version: BIRD75_D_CU_ICS_HW Reading phone info; IMEI: 35xxxxxxxx3-2 Reading simlock info; Locked to: 647-10 code_cat_n: 12345678 enabled: yes tries: 0 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:24 |
10-15-2014, 01:05 | #12077 (permalink) |
No Life Poster Join Date: Apr 2013 Location: PT
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | Coolpad Otimus Nivo Coolpad Otimus Nivo Portuguese Otimus Network Software engine version: 1.0.0.8957 Searching phone ... MODEL : QCOM SERIES 35 COMPILED DATE : Nov 27 2013 15:50:00 RELEASE DATE : Dec 5 2012 19:00:00 FIRMWARE INFO : 8X25-SSRSKOLYM-2050 IMEI : 86910901025987-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 6B644DC7ED0D8439BE8253EDB0279256.bin UNLOCK CODE: N/A DONE; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_14_10_2014_22_53_00.txt Time needed - 00:00:35 |
10-15-2014, 05:52 | #12078 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Pirmahal, Punjab,Pakistan
Member: 1377131 Status: Offline Sonork: yasar612 Thanks Meter: 8 | sagem my411x unlock Press power on shortly ... Starting communication ... MCU ID: 2D7001157FCE60C1000000000000184E ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411X Hash: 00002054 Algo: 05 Firmware: LO5,RE: 120407 1624 Imei: 35515------- Phone code: 0000 Prod. code: 252----- Id calculation done; CODES: NET LO CODE: 2519477641 NET HI CODE: 3605802697 DIRECT UNLOCK: OK Done ! Time needed - 00:02:37 |
10-15-2014, 13:31 | #12079 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | HUAWEI U1280 UNLOCK DONE ! Searching phone ... Phone detected ... MODEL : Q62xx-FSBL STARTING; OK; LOADING; OK; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35529103150824-1 READING; SP_SAVED_TO: SP_35529103150824_EA1_14.50.26_15.10.2014_HUAWEI.b in CHECKING; LOCKED_TO: MCC-MNC [0]: FFF-FF MCC-MNC [1]: FFF-FF MCC-MNC [2]: FFF-FF MCC-MNC [3]: FFF-FF MCC-MNC [4]: FFF-FF MCC-MNC [5]: FFF-FF MCC-MNC [6]: FFF-FF MCC-MNC [7]: FFF-FF MCC-MNC [8]: FFF-FF MCC-MNC [9]: FFF-FF MCC-MNC [10]: FFF-FF MCC-MNC [11]: FFF-FF MCC-MNC [12]: FFF-FF MCC-MNC [13]: FFF-FF MCC-MNC [14]: FFF-FF MCC-MNC [15]: FFF-FF MCC-MNC [16]: FFF-FF MCC-MNC [17]: FFF-FF MCC-MNC [18]: FFF-FF MCC-MNC [19]: FFF-FF MATCHED; ERASING; WRITING; SIM_LOCK REMOVED ! DONE ! RESET ! Time needed - 00:02:04 |
10-15-2014, 23:46 | #12080 (permalink) |
Freak Poster Join Date: May 2012 Location: under the philippine deep
Member: 1766158 Status: Offline Sonork: 1618330 Thanks Meter: 24 | HUAWEI ANDROID UNLOCKER v1.00.0061 Searching Huawei phone COM ports... OK Application port: COM13 Diagnostics port: COM9 Driver version: 2.0.6.601 OEMSBL running: Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OKOK Starting bootloader... OK Disconnecting from server... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Reading bootloader lock status... OK Model name: Huawei MSM8X25 series IMEI: Bootloader status: locked SIM Lock status: locked (NCK lock) 2014-10-16 06:42:57.986 Start unlocking procedure Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Creating backup of Sensitive Data... OK Backup saved to file Sending data to server... OK Reading data from server... OK Writing flash... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... OK Disconnecting from server... OK 2014-10-16 06:43:06.776 Done! |
10-16-2014, 08:31 | #12081 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | ALcatel Ot-4007 D counter blocked flash succesfull. Code: Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (@oem22.inf,%mtk_preloader%;MediaTek PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM9 Connecting; Downloading DA; Initializing; Rid: a134190acf9ef162bc286a0f5ea0f556 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem22.inf,%mtk_sp_da%;MediaTek DA USB VCOM Port) TRYING TO OPEN COM10; DEVICE INFO: BB CHIP: MT6575_S01 [CB00, E201, 6575, FF] HW_STORAGE_NAND: [SAMSUNG] KA100O015E_BJTT/KF94G16Q4V [EC:BC:00] [SIZE=0x20000000] IMEI1 [OTP 0000]: 863580-02-138xx7-8 IMEI2 [OTP 0000]: 863580-02-138xx8-6 PROVIDER: 4007D-2ARGJO3 USRDATA INFO: 0x15580000 SIZE: 0x09600000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:02:31 |
10-16-2014, 17:57 | #12082 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | alcatel ot 4007d flashing 100% OK alcatel ot4007 d flashing done!!!!!! Code: Searching phone; Phone detected (@oem19.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM198 Connecting; Downloading DA; Initializing; Rid: 89e19442ca91330d722e6b08f925c21b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem19.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM199; DEVICE INFO: BB CHIP: MT6575_S01 [CB00, E201, 6575, FF] HW_STORAGE_NAND: [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [2C:BC:90] [SIZE=0x20000000] IMEI1 [OTP 0000]: 861340-02-898550-3 IMEI2 [OTP 0000]: 861340-02-898551-1 PROVIDER: 4007D-2CRGTE3 USRDATA INFO: 0x15580000 SIZE: 0x09600000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:02:44 |
10-21-2014, 00:16 | #12083 (permalink) |
Insane Poster Join Date: Mar 2008 Location: Ecuator QUito
Member: 731820 Status: Offline Sonork: lerouxito Thanks Meter: 236 | SGH-I257M Factory Unlock successfull FG Samsung Module v1.0.3.0 ~ SAMSUNG GALAXY S4 MINI ~ ~ FACTORY UNLOCK ~ Start at 18:03:19 Checking server 1; not ok Checking server 2; not ok Checking server 3; ok Connecting to server; ok Asking server for access; ok Disconnecting from server; ok PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! Searching for phone; ok Reading BUILD INFO; ok MODEL: SGH-I257M IMEI: 3586000509xxxx FIRMWARE: I257MVLUBNG1 MSL ADDRESS: R21DA6C5W4 UNIQUE NO: CMA007EE4B0AA80 Reading data; ok Checking server 1; not ok Checking server 2; not ok Checking server 3; ok Connecting to server; ok Asking server for access; ok Sending data to server; ok Calculating [by server] please wait; ok PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! Searching for phone; ok Unlocking phone; ok BACKUPS\SAMSUNG\Galaxy S4 Mini\_3586000509xxxx_SIMLOCK_2014_10_20_18_04_53.f gb Saving backup; ok Unlocking phone; ok If phone ask CODE please use: 00000000 Restarting phone; ok Disconnecting from server; ok End at 18:05:06 |
10-21-2014, 08:02 | #12084 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PhP Age: 42
Member: 757799 Status: Offline Thanks Meter: 782 | Polaroid android phone unlock done Searching phone; Phone detected (@oem143.inf,%tinno_preloader%;Mobistel PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Mobistel Cynus T1-CDC Serial (COM32); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V4.P11 Hw Version: HEXING72_WET_JB3_HSPA_HW Reading phone info; IMEI: 865617-81-003192-7 Reading simlock info; Locked to: 515-02 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 02:42:50 |
10-22-2014, 11:02 | #12085 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | alcatel 1010D unlock ok alcatel 1010D UNLOCK NETWORK DONE Code: ary Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (@oem120.inf,%mtk6218%;MTK USB Port) Preparing to start meta mode; Requesting authorization; Done; Meta mode entered; Baseband Chip: MT6250 Sw version: MAUI.11B.W11.32.SP.V12.F4 Hw Version: JRDHZ50M_11B_HW Reading phone info; IMEI: 863651-02-352449-5 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:30 |
10-22-2014, 16:59 | #12086 (permalink) |
No Life Poster Join Date: Nov 2011 Location: Ksar El Boukhari
Member: 1688512 Status: Offline Thanks Meter: 1,098 | My511 unlock Done SAGEM My511X Unlock successful Code: Press power on shortly ... Starting communication ... MCU ID: 1610010E218C60C1000000000000B660 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my511X Hash: 0000213B Algo: 05 Firmware: EAN,DH: 071207 1133 Imei: 3568XXXXXXXXX00 Phone code: 0000 Prod. code: 254030056 Id calculation done; CODES: NET LO CODE: 3805908339 NET HI CODE: 2727972147 Done ! Time needed - 00:01:58 |
10-22-2014, 19:54 | #12087 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | alcatel ot 4010x unlock done ALCATEL 4010X NETWORK UNLOCK DONE Code: Phone detected (@oem19.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM222); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6575 Sw version: MAUI.11AMDW1150SP.V31.F2.P9.T1 Hw Version: JRDHZ75_GB2_HW Reading phone info; IMEI: 869294-01-420832-5 Reading simlock info; NOTE: Most of the times one of the first variants will work ! MODEL: OT-4010 UNLOCK CODE: 3 7 2 4 0 2 0 3 MODEL: OT-4010 UNLOCK CODE: 3 3 3 5 8 5 5 3 :rolleyes: MODEL: OT-4010 UNLOCK CODE: 4 2 2 6 5 5 0 7 MODEL: OT-4010 UNLOCK CODE: 1 8 5 4 7 5 8 5 Time needed - 00:00:28 |
10-23-2014, 10:13 | #12088 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Novo
Member: 177503 Status: Offline Sonork: 100.1657346 Thanks Meter: 390 | 3 phones done successfully ZTE S501 unlock Code: AUTH DONE; TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 864626000***** SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:29 |
10-23-2014, 10:15 | #12089 (permalink) |
Member: 177503 Status: Offline Sonork: 100.1657346 Thanks Meter: 390 | V860 Vodafone Code: Attach the phone to the USB now ... Phone found on COM81 and initialized; Reading imei; IMEI: 862924-01-XXXXXX-0 Reading data; Log saved: F65D10D98EB728AEE02BF713D4B0A186.bin Enter an restricted sim and use as unlock code : 00000000 (8 times 0) NOTE: For ZTE models enter *983*258# in order to be able to input code SIM_LOCK REMOVED ! Resetting the target ... Time needed - 00:00:13 |
10-23-2014, 10:17 | #12090 (permalink) |
Member: 177503 Status: Offline Sonork: 100.1657346 Thanks Meter: 390 | SFR 1180 Code: Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (@oem142.inf,%mtk6218%;MTK USB Port) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6260 Sw version: V05_M131030_UL18_SFR1180_MP Hw Version: SAGETEL60A_12864_11B_HW Reading phone info; IMEI: 359562-05-XXXXXX-2 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:50 thx to furious gold |
