12-24-2014, 14:23 | #12226 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Portugal Age: 43
Member: 7557 Status: Offline Thanks Meter: 26 | Check your phone and "Always allow from this computer" and select "OK". BRAND: HUAWEI MODEL: HUAWEI Y530-U00 ANDROID: v4.3 CPU: QCOM IMEI: 869563012409436 KERNEL: Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Aug 11 18:52:35 IST 2014 Cleaning; Loading files; Done; Reconnecting; Setting access; Done; Exploiting; Android v4.3 TRUE Backing up sec area; Done; Getting sec size; 00204174 bytes Decompressing; Backup saved to: 869563012409436 Finished; IMEI: 869563012409436 BT ADDR: F4:9F:F3:18:82:F2 MAC ADDR: F4:9F:F3:18:7D:15 BOOTLOADER PASS: 1414119525214118 MCC-MNC: 268-06 [tmn/pt] LOCK [0] HASH: 09BE042242AD434CEF20AFFFC58E620A LOCK [1] HASH: 667F5D66EAA3964A891E62453F9BC3D7 LOCK [2] HASH: FE32A719D45A281609416482894BD4DD LOCK [3] HASH: BDC2D3436B7D3BD26A3625990B9E2ACB LOCK [4] HASH: BDC2D3436B7D3BD26A3625990B9E2ACB LOCK [5] HASH: DCEA2F2DACB4F94F503B852442CC2266 LOCK [6] HASH: A67768E324C245A40C84D9DE2EBD11ED LOCK [7] HASH: BDC2D3436B7D3BD26A3625990B9E2ACB LOCK [8] HASH: BDC2D3436B7D3BD26A3625990B9E2ACB LOCK [9] HASH: BDC2D3436B7D3BD26A3625990B9E2ACB Starting; Done; Unlocking in progress; Calc 0000 ; SIM_LOCK REMOVED ! Rebooting; Log file saved to: LOG_24_12_2014_13_19_26.txt Time needed - 00:00:58 |
12-24-2014, 14:40 | #12227 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (@oem145.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start flash mode; Connecting; Downloading DA; Initializing; Rid: dcf28840ba6b0e5557669171c2285151 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem145.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM76; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x4E000115 0x4D5A5735 0x62640142 0xE931F0CA [SIZE=0xE9480000] IMEI1 [OTP 0001]: 862643-02-997907-1 IMEI2 [OTP 0001]: 862643-02-997908-9 PROVIDER: 5036D-2CBGGE1 USRDATA INFO: 0x5C6C0000 SIZE: 0x8CDC0000 Searching data; Locked to: 250-99 code_cat_n: 3641243429 enabled: yes tries: 8 code_cat_ns: 8225728647 enabled: no tries: 10 code_cat_sp: 5380553517 enabled: no tries: 10 code_cat_c: 0219726417 enabled: no tries: 10 code_cat_sim: 9541796946 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:30 |
12-25-2014, 11:11 | #12228 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | Zte t28 unlocking done........... Software engine version: 1.0.0.9023 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Sep 13 2012 12:54:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 8685XXXXXXXXXX-X BLUETOOTH ADDR : CF 9C 25 27 1D 90 TAG_ID:P727B109 DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_25_12_2014_15_36_23.txt Time needed - 00:00:48 |
12-25-2014, 11:40 | #12229 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | unlock zong zte s518m Code: Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem193.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM53]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6530 FdlStat: 0000 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 866767-01-092295-0 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303C0000 Reading NV; NV saved to : NV_000000-00-000000-0_866767-01-092295-0_65300000_25_12_2014_10_48_23.spd IMEI: 866767-01-092295-0 UNLOCK CODE: NONE Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_25_12_2014_10_48_39.txt Time needed - 00:00:27 |
12-29-2014, 00:19 | #12234 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | HUAWEI Y530-U051 unlock Code: Connecting; Check your phone and "Always allow from this computer" and select "OK". BRAND: HUAWEI MODEL: HUAWEI Y530-U051 ANDROID: v4.3 CPU: QCOM IMEI: 352421035176272 KERNEL: Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Fri Jul 18 14:28:31 IST 2014 Cleaning; Loading files; Done; Reconnecting; Setting access; Done; Exploiting; Android v4.3 TRUE Backing up sec area; Done; Getting sec size; 00165794 bytes Decompressing; Backup saved to: 352421035176272 Finished; IMEI: 352421035176272 BT ADDR: F4:9F:F3:32:AC:92 MAC ADDR: F4:9F:F3:32:A4:A7 BOOTLOADER PASS: 1771884173113119 MCC-MNC: 505-01 [telstra/au] LOCK [0] HASH: 3ABDEEEAB4077BD4F2C8CA83CA439013 LOCK [1] HASH: 3F8811F6E0166905205116FE76D1EB17 LOCK [2] HASH: 0E54EC04B18D4B819CF4F32FFDEC0265 LOCK [3] HASH: 01753EA46F19B4507B06807C6EF6BA0A LOCK [4] HASH: 01753EA46F19B4507B06807C6EF6BA0A LOCK [5] HASH: AA5B684684F7C43876DFB7D518D58309 LOCK [6] HASH: C0EBFD73555D5D1151CCB43C422600EA LOCK [7] HASH: 01753EA46F19B4507B06807C6EF6BA0A LOCK [8] HASH: 01753EA46F19B4507B06807C6EF6BA0A LOCK [9] HASH: 01753EA46F19B4507B06807C6EF6BA0A Starting; Done; Unlocking in progress; Calc 0000 ; Calc 0001 ; SIM_LOCK REMOVED ! Rebooting; Log file saved to: LOG_29_12_2014_12_16_24.txt Time needed - 00:00:52 Connecting; Check your phone and "Always allow from this computer" and select "OK". BRAND: HUAWEI MODEL: HUAWEI Y530-U051 ANDROID: v4.3 CPU: QCOM IMEI: 352421035882309 KERNEL: Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Fri Jul 18 14:28:31 IST 2014 Cleaning; Loading files; Done; Reconnecting; Setting access; Done; Exploiting; Android v4.3 TRUE Backing up sec area; Done; Getting sec size; 00166584 bytes Decompressing; Backup saved to: 352421035882309 Finished; IMEI: 352421035882309 BT ADDR: 80:71:7A:56:41:14 MAC ADDR: 80:71:7A:56:2D:EF BOOTLOADER PASS: 1492331831631231 MCC-MNC: 505-01 [telstra/au] LOCK [0] HASH: A900652EE457EA7F2177E5F2D2D1C190 LOCK [1] HASH: 708529BE3895BD9422C30EF09A25A2B1 LOCK [2] HASH: 9FD7F51E8FD1308EBC3277E3FC606366 LOCK [3] HASH: 7092F0E3F1E8F236C6EE1B814DECC20B LOCK [4] HASH: 7092F0E3F1E8F236C6EE1B814DECC20B LOCK [5] HASH: 79503C3937D9A5E06F8485A705860EB0 LOCK [6] HASH: 73488EE723E5C1EB8D1844A02790653D LOCK [7] HASH: 7092F0E3F1E8F236C6EE1B814DECC20B LOCK [8] HASH: 7092F0E3F1E8F236C6EE1B814DECC20B LOCK [9] HASH: 7092F0E3F1E8F236C6EE1B814DECC20B Starting; Done; Unlocking in progress; Calc 0000 ; SIM_LOCK REMOVED ! Rebooting; Log file saved to: LOG_29_12_2014_12_18_55.txt Time needed - 00:01:06 |
The Following User Says Thank You to chris2007 For This Useful Post: |
12-29-2014, 08:56 | #12235 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Orange Nivo done Code: Software engine version: 1.0.0.8957 Searching phone ... MODEL : QCOM SERIES 35 COMPILED DATE : Jun 9 2013 21:34:00 RELEASE DATE : Dec 5 2012 19:00:00 FIRMWARE INFO : 8X25-SSRSKOLYM-2050 IMEI : 8691090103xxxx-x BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 3A603B8B7CC9B4E009113367DE1C0153.bin UNLOCK CODE: N/A DONE; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_29_12_2014_09_40_54.txt Time needed - 00:00:59 |
12-30-2014, 09:08 | #12236 (permalink) |
No Life Poster Join Date: Feb 2006 Location: EDSELLULAR
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | lenovo A536 unlocked Code: Searching phone; Phone detected (PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM57); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6582, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V34.P3 Hw Version: BYD82_WET_KK_HSPA_HW Reading phone info; IMEI: 865660-02-rea1One Reading simlock info; Locked to: 515-02 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:03:08 |
12-30-2014, 10:09 | #12237 (permalink) |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | ZTE RIO2 UNLOCK DONE Software engine version: 1.0.0.8746 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Apr 8 2011 09:18:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : ORG_UK_P671A80V1.0.0B23-S IMEI : 35635204038878-2 BLUETOOTH ADDR : C0 C6 B3 50 4B 34 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; SP NEW DETECTED; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 33) LOCKED NET 1 (MCC: 234 MNC: 86) LOCKED NET 2 (MCC: 1 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:06 |
12-30-2014, 15:36 | #12238 (permalink) |
No Life Poster Join Date: May 2007 Location: barsoume
Member: 515559 Status: Offline Sonork: no Thanks Meter: 121 | ALCATEL ONE TOUCH C3 UNLOCK OK Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (@oem167.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM26 Connecting; Downloading DA; Initializing; Rid: 3f3d46f2d2d68a6ffea6122ede7bf05a Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem167.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM32; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x4E000115 0x4D5A5835 0x62890142 0x4D810242 [SIZE=0xE9880000] IMEI1 [OTP 0001]: 862149-02-650591-9 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4033X-2AM3DZ1 USRDATA INFO: 0x5D680000 SIZE: 0x8C200000 Searching data; Locked to [SIM1]: 603-01 code_cat_n: 42493380 enabled: yes tries: 2 code_cat_ns: 21848761 enabled: no tries: 10 code_cat_sp: 22276604 enabled: no tries: 10 code_cat_c: 22712083 enabled: no tries: 10 code_cat_sim: 41581789 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:14 |
12-30-2014, 15:36 | #12239 (permalink) |
12-30-2014, 16:58 | #12240 (permalink) |
Freak Poster Join Date: Jun 2007 Location: UNITED STATES
Member: 520764 Status: Offline Thanks Meter: 27 | HUAWEI Y600 unlock with mtk reader pack 6 Searching phone; Phone detected (@oem179.inf,%mtk_preloader%;MediaTek PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM39); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V11.P6 Hw Version: HUAQIN72_WE_B2B_JB3_HSPA_HW Reading phone info; IMEI: 353235-04-100772-0 Reading simlock info; Locked to: 730-01 code_cat_n: 39910838 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:32 |
The Following User Says Thank You to hcom For This Useful Post: |
